Agilent 81594B 模块
![](http://www.cechina.cn/UpLoad/CompanyFile/2014/1/13/6b28c59a-e351-42b6-ad2f-03461c95a47c.jpg)
Agilent/HP安捷伦81594B插件模块
详细资料:
主要性能指标: 插入损耗<1.5分贝 PDL<0.05分贝单一模式选项
最高重复性超过10.000随机开关周期规定:0.02分贝
描述
该插件模块安捷伦光波解决方案平台的8163B,8164B,8166B是在应用,
如收发器/接收器与复杂的级联与小尺打印或多个被动元件测试的测试灵活的系统配置的理想选择。
安捷伦的光学开关的模块化设计,具有低插入损耗和高重复性的交换机,
路由<10毫秒切换时间的SMF和MMF的2x2矩阵。
在不同wavelenght范围内的各种光,如激光源路由和路由等各种光接收机功率传感器,示波器,BERT。
特点:
优点: 使用在所有传输带的DUT测试的测试设置。
测试的不确定性最小化,
最大化的功率预算,使较高的生产产生一个竞争激烈的产品规格 尽量减少测试时间 –
最大限度地提高生产吞吐量。 传输信号的影响最小。
Key Features & Specifications
Key performance specifications:
· Insertion Loss < 1.5dB
· Guaranteed lifetime > 10 Mio. cycles
· PDL < 0.05dB for single-mode option
· Highest repeatablity specified over 10.000 random switch cycles: 0.02dB
Description
The plug-in module for Agilent's Lightwave Solution Platform 8163B, 8164B, 8166B is ideal for flexible system configuration in applications such as transceiver/receiver test with small foot-print or multiple passive component test with complex cascade. The Agilent modular design of the optical switch features a 2x2 matrix in both SMF and MMF with low insertion loss and highly repeatable switch routing in <10 ms switching time.
Routing of various optical sources such as laser in various wavelenght range and routing of various optical receiver such as power sensor, oscilloscope, BERT.
Features:
Benefits:
· Using one test setup for testing DUTs in all transmission bands.
· Minimize test uncertainties, maximize power budget enables higher production yield an highly competitive product specifications
· Minimize test times - maximize production throughput.
· Minimal influence on transmitted signal.
库存相关测试仪
可调激光源:AGILENT 81940A AGILENT 81949A AGILENT 81950A AGILENT 91980A AGILENT 81989A HP 8167B HP 8168F HP 8168E
AGILENT 81689A AGILENT 81480A/B AGILENT 81682A/B AGILENT81680A/B AGILENT 81640A/B 81642A AGILENT 81600B AQ4321A/D AQ4320D TSL-510
光谱仪:7004A/70950B 86142A/B 86140A/B 86141B 86143B 86145B 86142B MS9710A/B/C MS9740A MS9780A AQ6315E AQ6317B/C AQ6370B/C AQ6330 AQ6331 AQ6375 AQ6373 AQ6319 Q8381 Q8383 Q8384 Q8347 Q8344A
光示波器/眼图仪:86100A/B/C/D 86105A/B/C 86103A 83481A 83482A 83483A 83485A/B 83487A 86116C 54754A 86112A 86117A/B 86118A 86108A 83446A
光功率主机:8153A 8163A/B 8164A/B 1830-C 1830-R 1835-C 1936-C 1918-C 2936-C
光源模块:81551SM 81552SM 81553SM 81554SM 81650A 81651A 81652A 81653A 81654A 81655A 81656A 81657A 81663A
光功率模块:81531A 81532A 81533A 81533B 81618A 81619A 81536A 81632A/B 81633A 81634A/B 81635A 81636B
光功率探头:81521B 81525A 81524A 81623A/B 81624A/B 81625A/B 81626B 81628A/B
回损仪RM3750B RM3070B RX30701 RM3050 PS3650B ORL-55 IQ-3200 FOT-300 HP81534A 81610A 81611A 81612A 81613A 81614A
波长计:86120B/C 81622A AQ6140 TQ8325 Q8326 WA-1100 WA-1500 WA-1600 WA-1650 WA-7100 WA-7600 FTB5320
衰减器:8157A 8156A 8158B HA9 FVA-60B MN9610B
宽谱光源HP83437A 83438A
误码分析仪86130A 37717A/B/C 37718A/B/C N4903A N4906A
![](http://www.itestworld.com/uploads/braner/wxh.png)
