深圳市东测科技有限公司
  • 9000A福禄克 Fluke?9000A?仿真器
  • 发布时间:2014/5/22 22:09:10   修改时间:2014/5/22 22:09:10 浏览次数:1061
    Fluke 9000AThe Fluke 90000A-xxxxx Interface Pods function as trouble-shooting test interfaces between the microprocessor circuitry of suspect circuit boards and the 9000-series or 9100-series mainframes.There are more than 50 microprocessor-specific Interface Pods. Although the architecture of the troubleshooter main frame is not specific to any microprocessor and is designed to accomodate processors with up to 32 address lines and 32 data lines, the interface pod adapts this general purpose architecture to a specific microprocessor, or microprocessor family. Each Interface Pod has a self-contained system with its own microprocessor, RAM, ROM, and I/O memory space. The pod can run board-resident programs such as initialization and diagnostics. The Interface Pod uses the board clock circuit ensuring that all tests are performed at the designed speed of the board. The interface pod adapts the mainframe series to microprocessor-specific functions such as pin layout, status/control functions,
    interrupt handling, timing, size of memory space, and size of I/O space - all with merely a few key strokes. Automatic bus line monitoring eliminates the need for probing and enables detection of both static and dynamic faults. The pods have input protection circuitry against overvoltage and incorrect pod insertion. A self-test socket is provided for quick confidence checks. You can write test programs in a language independent of the actual microprocessor under test.The following is a partial list of Fluke 9000A interface pods:
    9000A-18029000A-65029000A-68009000A-68029000A-68099000A-80489000A-80519000A-80809000A-80859000A-80869000A-80889000A-99009000A-680009000A-801869000A-802869000A-Z809000A-Z8000
深圳市东测科技有限公司公司现货销售、租赁惠普(安捷伦)、泰克、安立、爱得万、横河、安腾、力科、马可尼(IFR)、R&S、Exfo等品牌之眼图仪、光谱分析仪、光时域反射仪(OTDR)、可调激光源、光功率计、光衰减器、光纤熔接机等光纤通信仪…  更多>>
深圳市东测科技有限公司
联系人:黄文俊
地址:深圳市龙华新区人民南路莱蒙水榭春天7栋凤凰苑24C/24D
邮编:518131
电话:13928415151
传真:0755-83176509
公司网址:http://www.itestworld.com
  • 陈苗 在2024/9/22 13:42:00留言
  • 详细留言:您好 请添加我 的微信 twenty626
  • 韩女士 在2022/11/24 10:01:00留言
  • 详细留言:KLA Thermawave OP2600,KLA Tencor 5200XP,KLA 6420,KLA 2315。想了解报价和产品规格说明书。
  • 张鸿益 在2022/4/29 14:07:00留言
  • 详细留言:請與我聯繫。謝謝
  • 汪丽 在2021/12/13 10:48:00留言
  • 详细留言:需求CI-T120 管脚检查机
