深圳市东测科技有限公司
  • UltraFLEX Test System Teradyne FLEX 测试机
  • 发布时间:2017/3/16 10:58:17   修改时间:2017/3/16 10:58:17 浏览次数:2225
    The UltraFLEX test system delivers the power and precision you need for complex SoC devices built for mobile applications, networking, storage or high-end processing. Choose UltraFLEX when your device mix and throughput goals demand the highest speed, precision, coverage and site count.
    UltraPin1600 high density, high speed digital provides 128 or 256 channels per instrument with test coverage up to 2.2Gbps. The UltraPin1600 implements Teradyne’s groundbreaking multicore, hardware-based Protocol Aware capability that allows individual pin groups to be slaved to device data rate and timing and eliminates the need for digital patterns for programming standard data busses.  Proprietary hardware for same-cycle source synchronous capability and “walking strobe” timing measurements provides production test capability for high speed DDR and other critical applications when needed. The UltraPin1600 is also test program compatible with the earlier UltraPin800 and HSD1000 digital options.
    The UltraWave12G/UltraWave24 high port count RF options provide up to 96 universal, vector RF ports with carrier frequencies and modulation bandwidths to cover the most advanced cellular and connectivity standards. The UltraWave options offer accuracy and phase noise performance equal to or better than the highest performance bench equipment available and integrate waveform sourcing and capturing onboard to eliminate the need for extra tester instruments. The UltraFLEX ESA software toolkit and UltraDSP1 option provide industry-standard modulation and demodulation tools running on up to 32 dedicated processing cores with automatic data download via a dedicated high speed data bus for simple correlation to industry standards and the highest possible throughput.
    The UltraPAC80 high density AC source and capture instrument offers up to 8 source and capture channels, each with dedicated audio and video analog paths. Teradyne’s proprietary sample clock architecture provides the user with complete sample frequency flexibility without performance compromise and guaranteed phase alignment to every other instrument on every run of the test program to eliminate the need for job-specific calibration to achieve the phase balance required for the highest performance RF transceivers.
    The UltraVI80 high pin count, high accuracy voltage and current option provides 80 independent pins of “3-in-1” capability.  Each UVI80 pin is a true voltage or current (VI) source and measure instrument complete with ultra high-accuracy differential voltmeters and time measurement units available to each pin for complete, massively paralleled testing of mobile power management devices. In addition, UVI80 channels can operate in a special, low-droop voltage source mode that offers unmatched power supply noise performance for sensitive analog and RF applications. Finally, each UVI80 channel has an embedded high performance AC waveform source and measure capability for highly paralleled test of D/A and A/D converters embedded in complex SOC or microcontroller devices.
    The UltraVS256 high density Device Power Supply (DPS) provides 256 independent channels per instrument to provide the massively paralleled capability required by low power mobile communications devices. The UVS256 also offers a clamp-based current source capability for device parametric testing.  The UVS256 provides test engineers with the capability of programmable output bandwidth and full pattern setup and measure control that results in reduced DIB complexity and faster test times.
    The HEXVS and VSM Ultra High Accuracy and Stability Processor Core Supplies improve performance and yield of complex processors by offering unmatched voltage accuracy and stability under load. This allows devices to be configured for maximum performance at lower voltages, increasing the value and yield of devices tested on UltraFLEX.
    The DC30 and DC75 voltage/current supplies extend DC capability to 30 volts and 75 volts to address high voltage test requirements of of mobile power management and other devices. Like the UltraVI80, both options contain a precision differential voltmeter and time measurement capability.
    The UltraSerial10G high speed, high port count serial digital option provides up to 20 ports (80 pins) of SERDES capability to 10.7Gbps, which can be extended to over 40Gbps using configurable data rate extension options. It also uses the same multicore, hardware-based Protocol Aware capability and the standard digital pins to completely and automatically emulated high speed interfaces such as PCI Express, Serial-ATA with no low-level programming required by the user.
    The UltraPin4000 high speed, high precision digital option offers extremely high data rate capability with proprietary timing calibration options that allows unmatched timing accuracy to test the most challenging DDR interfaces on roadmap processors.
    The AWG6G and GigaDig ultra high-speed AWG and digitizer options provide multi-Gigahertz analog source and measure capability for the most critical storage controller and high modulation bandwidth RF applications.
深圳市东测科技有限公司公司现货销售、租赁惠普(安捷伦)、泰克、安立、爱得万、横河、安腾、力科、马可尼(IFR)、R&S、Exfo等品牌之眼图仪、光谱分析仪、光时域反射仪(OTDR)、可调激光源、光功率计、光衰减器、光纤熔接机等光纤通信仪…  更多>>
深圳市东测科技有限公司
联系人:黄文俊
地址:深圳市龙华新区人民南路莱蒙水榭春天7栋凤凰苑24C/24D
邮编:518131
电话:13928415151
传真:0755-83176509
公司网址:http://www.itestworld.com
  • 陈苗 在2024/9/22 13:42:00留言
  • 详细留言:您好 请添加我 的微信 twenty626
  • 韩女士 在2022/11/24 10:01:00留言
  • 详细留言:KLA Thermawave OP2600,KLA Tencor 5200XP,KLA 6420,KLA 2315。想了解报价和产品规格说明书。
  • 张鸿益 在2022/4/29 14:07:00留言
  • 详细留言:請與我聯繫。謝謝
  • 汪丽 在2021/12/13 10:48:00留言
  • 详细留言:需求CI-T120 管脚检查机
