意大利AEP AEP张力计 AEP传感器 AEP压力计 AEP称重传感器
上海秋腾贸易有限公司长期优惠提供原装进口意大利AEP传感器。AEP液位开关, AEP传感器
FT2-C2-2T等,TC4-10T。TP12/BH53 500BAR 仪表MAN2/S 500 BAR 4-20mA,变送器TA4 0-10V,MP2E
。详细型号如下列:
1.压式称重传感器
CBS-250kg,CBS-500kg
CBS-1t,CBS-2.5t,CBS-5t,CBS-7.5t,CBS-10t,CBS-15t,CBS-20t,CBS-30t,CBS-50t,CBS-75t,CBS-100t
C2S-100kg,C2S-250kg,C2S-500kg(C1/C2/C3)
C2S-1t,C2S-2.5t,C2S-5t,C2S-7.5t,C2S-10t,C2S-20t,C2S-30t,C2S-50t,C2S-75t,C2S-100t
(C1/C2/C3)
2.拉压式称重传感器
TCA-1kg,TCA-2kg,TCA-5kg,TCA-10kg,TCA-25kg,TCA-50kg
TCE-350kg,TCE-500kg
TCE-1t,TCE-2.5t,TCE-5t,TCE-7.5t,TCE-10t,TCE-20t
3.拉式称重传感器
TS:25kg,50kg,100kg,200kg,300kg,500kg,1t,2t,2.5t,5t,7.5t(C2/C3)
TSA:100kg,200kg,300kg,500kg,1t,2t,2.5t(C2/C3/C4)
T20:5t,7.5t,10t,15t,20t(C2/C3)
D100:20t,30t,50t,75t,100t
4.波纹管称重传感器
F1:2.5kg,5kg,10kg,20kg,25kg,50kg,100kg,200kg(C2/C3)
F3:10kg,25kg,50kg,100kg,200kg,500kg,1t,105t,2t(C2/C3)
5.悬臂粱称重传感器
FT1:350kg,500kg,1t,2t,3t,5t,7.5t(C2/C3)
FT1A:500kg,1t,2t(C2/C3)
FT2:500kg,1t,2t,3t,5t(C2/C3)
FT5:10kg,20kg,50kg,100kg(C2)
6.称重模块
UPFT1:350kg,500kg,1t,2t,3t,5t(C2/C3)
UPFT2:500kg,1t,2t(C2/C3)
CFR:15kg,25kg,50kg,100kg
7.扭距传感器
TRX扭距传感器 STATIC force 100, 200, 500 Nm,1000, 2000 nN,EN 10/14:Classe:0,05 e 0,1,
0.03%,Material:Stainless Steel,
LASER welded,EN 60529: IP67,For dynamic applications,High long term stability,Flange
connection。
RT2扭距传感器 5, 10 Nm,25, 50 Nm,100, 250 Nm,500 Nm, 0.20% ROTATING torque transducers
Output: 2mV/V or 10Vdc Nominal Speed: 4000 rpm Contact transmission LOW COST
TRS扭距传感器 STATIC force 0.5, 2.5, 5 Nm 10, 25, 50 Nm 100, 250 Nm 500, 1000 Nm 0.20%
BTR 显示仪表 STATIC force 0.5, 2.5, 5 Nm 10, 25, 50 Nm 100, 250 Nm 500, 1000 Nm 2000 Nm
0.20%
ATC扭距传感器 0 - 1000 Nm ,0 - 2000 Nm
DTR 0.02 %
8.测力传感器
TSTM 0.5, 1, 2.5, 3 kN 0.02% Material:Stainless Steel,Output: 2mV/V
TCETM 5, 10, 25, 50 kN,75, 100 kN 0.03% Material:Stainless Steel,Output: 2mV/V,LASER
welded EN 60529: IP67
C10 10, 25, 50, 100 kN,250, 400 kN ,0.05% Material:Stainless Steel,Output:2mV/V,4-
20mA,0-5V,LASER welded,EN 60529: IP67
TC4 5, 10, 25, 50, 100 kN,200, 300, 500 kN,750, 1000 k,0.05% ,Material:Stainless
Steel,Output: 2mV/V,LASER welded,EN 60529: IP67
DCVTC4 0.5, 1, 2.5, 5, 10 t,20, 30, 50, 75, 100 t 0.05%,Material:Stainless Steel,
Output: 2mV/V,LASER welded,EN 60529: IP40
DCTC4 0.5, 1, 2.5, 5, 10 t,20, 30, 50, 75, 100 t ,0.05%,Material:Stainless Steel,
EN 60529: IP40
TC8 5, 10, 25, 50, 100 kN,200, 300, 500 kN,750, 1000 kN,0.03,Material:Stainless
EN 60529: IP67,mKAL 50, 100, 200, 500 N,1, 2, 3, 5 kN,0.02%,Output: 2mV/V,EN 60529:
IP50
KAL 10, 25, 50, 100 kN,200, 300, 500 kN,750, 1000 kN ,0.02%,Material:Stainless Steel
EN 60529: IP67
CM 100, 250, 500 kg,1000, 2500 kg ,0.20%,Material:Stainless Steel,Output: 2mV/V,
C8S 5, 10, 25, 50, 100 kN,200, 300, 500 kN,750, 1000 kN ,0.03%,Material:Stainless
EN 60529: IP67
