41-2550高精密减压阀,41-2550
41-2550高精密减压阀简单介绍
Multi-stage, low-droop precision regulators maintain constant output over wide changes in flow and supply pressure Epoxy powder coat paint delivers improved corrosion resistance Wide selection of regulated pressures [1" to 450 psi] affords application versatility Patented Nullmatic pressure regulation system provides reliable maintenance-free operation
41-2550高精密减压阀Precision Pressure Regulators 41-2550的详细介绍
Features & Benefits:
Multi-stage, low-droop precision regulators maintain constant output over wide changes in flow and supply pressure Epoxy powder coat paint delivers improved corrosion resistance Wide selection of regulated pressures [1" to 450 psi] affords application versatility Patented Nullmatic pressure regulation system providesreliable maintenance-free operation Description The Models 40, 41, and 42 Precision Pressure Regulators control air pressures in applications where precise and dependable regulation is required, such as pneumatic instrument circuits, test stands, production checking fixtures,and industrial air gages. As such, they are suitable for dead-end service, and flows up to a maximum of 110 scfm.
