MAX196ACNI
6通道,多量程,5V,12位数据采集系统,带有12位总线接口和故障保护
概述
The MAX196ACNI multirange, 12-bit data-acquisition systems (DAS) require only a single +5V supply for operation, yet convert analog signals at their inputs up to ±10V (MAX196) and ±4V (MAX198). These systems provide six analog input channels that are independently software programmable for a variety of ranges: ±10V, ±5V, 0V to +10V, and 0V to +5V for the MAX196ACNI ; ±VREF, ±VREF/2, 0V to +VREF, and 0V to +VREF/2 for the MAX198. This range switching increases the effective dynamic range to 14 bits and provides the flexibility to interface ±12V, ±15V, and 4mA to 20mA powered sensors to a single +5V system. In addition, these converters are fault protected to ±16.5V; a fault condition on any channel will not affect the conversion result of the selected channel. Other features include a 5MHz bandwidth track/hold, 100ksps throughput rate, software-selectable internal/external clock, internal/external acquisition control, 12-bit parallel interface, and internal 4.096V or external reference.
Two programmable power-down modes (STBYPD, FULLPD) provide low-current shutdown between conversions. In STBYPD mode, the reference buffer remains active, eliminating start-up delays.
The MAX196ACNI employ a standard microprocessor (µP) interface. A three-state data I/O port is configured to operate with 16-bit data buses, and data-access and bus-release timing specifications are compatible with most popular µPs. All logic inputs and outputs are TTL/CMOS compatible.
These devices are available in 28-pin DIP, wide SO, SSOP (55% smaller in area than wide SO), and ceramic SB packages. For 8+4 bus interface, see the MAX197 and the MAX199 data sheets. An evaluation kit is available (MAX196EVkit-DIP).
关键特性
- MAX196ACNI 12-Bit Resolution, 1/2LSB Linearity
- MAX196ACNI Single +5V Supply Operation
- MAX196ACNI Software-Selectable Input Ranges:,
- ±10V, ±5V, 0V to +10V, 0V to +5V (MAX196)
- ±VREF, ±VREF/2, 0V to +VREF, 0V to +VREF/2 (MAX198)
- MAX196ACNI Internal 4.096V or External Reference
- MAX196ACNI Fault-Protected Input Multiplexer
- MAX196ACNI 6 Analog Input Channels
- MAX196ACNI 6µs Conversion Time, 100ksps Sampling Rate
- MAX196ACNI Internal or External Acquisition Control
- MAX196ACNI Two Power-Down Modes
- MAX196ACNI Internal or External Clock
应用:
- 自动测试设备(ATE)
- 数据采集
- 工业控制系统
- 医疗仪器
- 机器人技术
- 电信
相关订购型号:
MAX196BMDI, MAX196BC/D, MAX196ACNI+, MAX196BCNI, MAX196ACNI, MAX196BCNI+, MAX196AENI, MAX196BENI+, MAX196BENI, MAX196AENI+, MAX196ACWI+, MAX196ACWI+T, MAX196ACWI, MAX196BCWI-T, MAX196BCWI, MAX196ACWI-T, MAX196BCWI+T, MAX196BCWI+, MAX196BEWI+, MAX196BEWI+T, MAX196AEWI+, MAX196BEWI-T, MAX196BEWI, MAX196AEWI+T, MAX196AEWI, MAX196AEWI-T, MAX196ACAI, MAX196BCAI+T, MAX196BCAI+, MAX196ACAI-T, MAX196BCAI, MAX196BCAI-T, MAX196ACAI+, MAX196ACAI+T, MAX196BEAI, MAX196AEAI+, MAX196AEAI+T, MAX196BEAI+, MAX196BEAI+T, MAX196AEAI-T, MAX196BEAI-T, MAX196AEAI
技术支持:
MAX196ACNI DataSheet. PDF
数据采集器在工业自动控制中的应用数据采集器在工业自动控制中的应用 .PDF
