龙人旗下深圳市龙芯世纪科技有限公司
  • AT89C5130A-M 带有USB接口8位FLash单片机
  • 发布时间:2009/8/12 10:48:51   修改时间:2009/8/12 10:48:51 浏览次数:1635
    Flash (Kbytes) 16
    USB Device Yes
    ISP Yes
    Self Program Memory Yes
    EEPROM (Kbytes) 1
    RAM (Bytes) 1280
    F.max (MHz) 48
    Vcc (V) 2.7-5.5
    I/O Pins 18/34
    UART Yes
    16-bit Timers Yes
    Watchdog Yes
    SPI Yes
    TWI Yes
    Pb-Free Packages LQFP 64
    VQFN (Punched) 32
    PLCC 52
    USB C51-based Microcontroller with 16K Bytes Flash, 1K Byte Data EEPROM, 1280 bytes RAM, Extended Range Power Supply: 2.7V to 5.5V, 7 USB Endpoints, TWI, SPI, UART, PCA
    AT89C5130A/31A-M is a high-performance Flash version of the 80C51 single-chip 8-bit microcontrollers with full speed USB functions.
    AT89C5130A/31A-M retains thefeaturesoftheAtmel0C52withextended Flashcapacity(16/32-Kbytes), 256 bytes of internal RAM, a 4-level interrupt system, two 16-bit timer/counters(T0/T1), a full duplex enhanced UART (EUART) and an on-chip oscillator.
    AT89C5130A/31A-M has two software-selectable modes of reduced activity for further reduction in power consumption. In the idle mode the CPU is frozen while the timers, the serial ports and the interrupt system are still operating. In the power-down mode the RAM is saved, the peripheral clock is frozen, but the device has full wake-up capability through USB events or external interrupts.
    AT89C5130A-M 特性
    • 80C52X2 Core (6 Clocks per Instruction)
      – Maximum Core Frequency 48 MHz in X1 Mode, 24 MHz in X2 Mode
      – Dual Data Pointer
      – Full-duplex Enhanced UART (EUART)
      – Three 16-bit Timer/Counters: T0, T1 and T2
      – 256 Bytes of Scratchpad RAM
    • 16/32-Kbyte On-chip Flash EEPROM In-System Programming through USB
      – Byte and Page (128 bytes) Erase and Write
      – 100k Write Cycles
    • 3-KbyteFlash EEPROM for Bootloader
      – 100k Write Cycles
    • 1-Kbyte EEPROM Data (
      – 100k Write Cycles
    • On-chip Expanded RAM (ERAM): 1024 Bytes
    • Integrated Power Monitor (POR/PFD) to Supervise Internal Power Supply
    • USB 1.1 and 2.0 Full Speed Compliant Module with Interrupt on Transfer Completion
      – Endpoint 0 for Control Transfers: 32-byte FIFO
      – 6 Programmable Endpoints with In or Out Directions and with Bulk, Interrupt or Isochronous Transfers
    • Endpoint 1, 2, 3: 32-byte FIFO
    • Endpoint 4, 5: 2 x 64-byte FIFO with Double Buffering (Ping-pong Mode)
    • Endpoint 6: 2 x 512-byte FIFO with Double Buffering (Ping-pong Mode)
      – Suspend/Resume Interrupts
      – 48 MHz PLL for Full-speed Bus Operation
      – Bus Disconnection on Microcontroller Request
    • 5 Channels Programmable Counter Array (PCA) with 16-bit Counter, High-speed Output, Compare/Capture, PWM and Watchdog Timer Capabilities
    • Programmable Hardware Watchdog Timer (One-time Enabled with Reset-out): 100 ms to 3s at 8 MHz
    • Keyboard Interrupt Interface on Port P1 (8 Bits)
    • TWI (Two Wire Interface) 400Kbit/s
    • SPI Interface (Master/Slave Mode)
    • 34 I/O Pins
    • 4 Direct-drive LED Outputs with Programmable Current Sources: 2-6-10 mA Typical
    • 4-level Priority Interrupt System (11 sources)
    • Idle and Power-down Modes
    • 0 to 24 MHz On-chip Oscillator with Analog PLL for 48 MHz Synthesis
    • Industrial Temperature Range
    • Extended Range Power Supply: 2.7V to 5.5V (3.3V to 5.5V required for USB)
    • Packages: PLCC52, VQFP64, QFN32
    AT89C5130A-M 订购型号
    Part Number Memory Size (Kbytes) Supply Voltage Temperature Range Package Packing
    AT89C5130A-RDTUM 16 2.7 to 5.5V Industrial Green VQFP64 Tray Dry Pack
    AT89C5130A-PUTUM 16 2.7 to 5.5V Industrial Green QFN32 Tray Dry Pack
    AT89C5130A-S3SUM 16 2.7 to 5.5V Industrial Green PLCC52 Stick
    AT89C5131A-RDTUM 16 2.7 to 5.5V Industrial Green VQFP64 Tray Dry Pack
    AT89C5131A-PUTUM 16 2.7 to 5.5V Industrial Green QFN32 Tray Dry Pack
    AT89C5131A-S3SUM 16 2.7 to 5.5V Industrial Green PLCC52 Stick
    AT89C5130A-M 技术支持
    1. AT89C5130A-M 数据手册DataSheet 下载. PDF
    2. 80C51微控制器的复位输入. PDF (编号: Tech 8051 00049)
    3. 80C51在系统Flash编程. PDF (编号:8051 00050)
    4. Device Programmers for 8051 Devices (Other, updated 09/07)
      This Excel spreadsheet provide summary information on device programmers supporting Atmel 8051 microcontrollers
    5. Emulators for 80C51 Devices (Other, updated 11/03)
      This Excel spreadsheet provide summary information on emulation support for Atmel 80C51 microcontrollers
    6. Package Adapters of 80C51 Devices (Other, updated 10/04)
      This Excel spreadsheet list available package adapters for Atmel 80C51 microcontrollers
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
