龙人旗下深圳市龙芯世纪科技有限公司
  • AT45DB041D 4Mbit,SPI接口DateFlash存储器
  • 发布时间:2009/8/13 10:22:55   修改时间:2009/8/13 10:22:55 浏览次数:1321
    Density 4M
    I/O Pins 8
    Interface Type SPI, RapidS
    Page Size (Bytes) 264
    Vcc (V) 2.7
    Pb-Free Packages SOIC (150mil)8
    SOIC (208mil)8
    MLF (VDFN) 8
    4M bit 2.5-Volt or 2.7-Volt DataFlash?
    The AT45DB041D is a 2.5V or 2.7V, serial-interface Flash memory ideally suited for a wide variety of digital voice-, image-, program code- and data-storage applications. The AT45DB041D supports RapidS serial interface for applications requiring very high speed operations. RapidS serial interface is SPI compatible for frequencies up to 66 MHz. Its 4,325,376 bits of memory are organized as 2,048 pages of 256 bytes or 264 bytes each. In addition to the main memory, the AT45DB041D also contains two SRAM buffers of 256/264 bytes each. The buffers allow the receiving of data while a page in the main Memory is being reprogrammed, as well as writing a continuous data stream. EEPROM emulation (bit or byte alterability) is easily handled with a self-contained three step read-modify-write operation. Unlike conventional Flash memories that are accessed randomly with multiple address lines and a parallel interface, the DataFlash uses a RapidS serial interface to sequentially access its data. The simple sequential access dramatically reduces active pin count, facilitates hardware layout,increases system reliability, minimizes switching noise, and reduces package size. The device is optimized for use in many commercial and industrial applications where high-density, low-pin count, low-voltage and low-power are essential. To allow for simple in-system reprogrammability, the AT45DB041D does not require high input voltages for programming. The device operates from a single power supply, 2.5V to 3.6V or 2.7V to 3.6V, for both the program and read operations. The AT45DB041D is enabled through the chip select pin (CS) and accessed via a three-wire interface consisting of the Serial Input (SI),Serial Output (SO), and the Serial Clock (SCK). All programming and erase cycles are self-timed.
    AT45DB041D 特性
    • Single 2.5V or 2.7V to 3.6V Supply
    • RapidS? Serial Interface: 66 MHz Maximum Clock Frequency
      – SPI Compatible Modes 0 and 3
    • User Configurable Page Size
      – 256 Bytes per Page
      – 264 Bytes per Page
      – Page Size Can Be Factory Pre-configured for 256 Bytes
    • Page Program Operation
      – Intelligent Programming Operation
      – 2,048 Pages (256/264 Bytes/Page) Main Memory
    • Flexible Erase Options
      – Page Erase (256 Bytes)
      – Block Erase (2 Kbytes)
      – Sector Erase (64 Kbytes)
      – Chip Erase (4 Mbits)
    • Two SRAM Data Buffers (256/264 Bytes)
      – Allows Receiving of Data while Reprogramming the Flash Array
    • Continuous Read Capability through Entire Array
      – Ideal for Code Shadowing Applications
    • Low-power Dissipation
      – 7 mA Active Read Current Typical
      – 25 μA Standby Current Typical
      – 5 μA Deep Power-down Typical
    • Hardware and Software Data Protection Features
      – Individual Sector
    • Sector Lockdown for Secure Code and Data Storage
      – Individual Sector
    • Security: 128-byte Security Register
      – 64-byte User Programmable Space
      – Unique 64-byte Device Identifier
    • JEDEC Standard Manufacturer and Device ID Read
    • 100,000 Program/Erase Cycles Per Page Minimum
    • Data Retention – 20 Years
    • Industrial Temperature Range
    • Green (Pb/Halide-free/RoHS Compliant) Packaging Options
    AT45DB041D 订购型号
    Ordering Code Package Lead Finish Operating Voltage Max. Freq.
    (MHz)
    Operation Range
    AT45DB041D-MU
    AT45DB041D-MU-SL954
    AT45DB041D-MU-SL955
    8M1-A - 25V to 3.6V 66 Industrial (-40°C to +85°C)
    AT45DB041D-SSU
    AT45DB041D-SSU-SL954
    AT45DB041D-SSU-SL955
    8S1 - 25V to 3.6V 66 Industrial (-40°C to +85°C)
    AT45DB041D-SU
    AT45DB041D-SU-SL954
    AT45DB041D-SU-SL955
    8S2 - 25V to 3.6V 66 Industrial (-40°C to +85°C)
    AT45DB041D-MU-2.5
    AT45DB041D-SSU-2.5
    AT45DB041D-SU-2.5
    8M1-A
    8S1
    8S2
    - 25V to 3.6V 50 Industrial (-40°C to +85°C)
    AT45DB041D 技术支持
    1. ATMEL 爱特梅尔Flash 存储器AT45DB041D 数据手册DataSheet 下载. PDF(PDF 文件格式完整版)
    2. 串行Flash 产品选型指南Excel 文档格式选型 Excel 文档格式)
    3. ATMEL 爱特梅尔公司全线产品目录. pdf
    4. Programmer Support for Serial Flash Devices. pdf (Other, 8 pages, revision C, updated 4/08)
    5. MicroLeadFrame Packages Pad Landing Recommendations (15 pages, revision B, updated 09/06). pdf
      This application note provides PCB designers with a set of guidelines for successful board mounting of Atmel's DataFlash memories housed in the MicroLeadFrame (MLF) package.
    6. AN-4: Using Atmel's DataFlash (30 pages, updated 11/02) . pdf
      Atmel's DataFlash is a new Flash family designed specifically for data storage applications. This Application Note describes this family.
    7. DataFlash Binary Page Size (2 pages, revision A, updated 5/08) . pdf
      Factory Configured DataFlash Binary Page Size options
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
