艾讯科技 (Axiomtek)
  • 车载平板电脑 10.4寸 EN501555认证
  • 发布时间:2013/1/28 23:01:23   修改时间:2023/5/22 16:08:03 浏览次数:1930
  • EN 50155 S3 10.4“ SVGA TFT 液晶显示器铁路无风扇触摸屏平板电脑,采用英特尔?凌动?处理器 E3845 1.91 GHz(-40°C 至 +70°C)
    LCD Panel
    • 10.4" TFT LCD
    • 1000 nits
    • 800 x 600 pixels
    CPU
    • Intel? Atom? processor E3845 1.91 GHz (Bay Trail)
    Chipset
    • SoC integrated
    System Memory
    • DDR3L 4GB onboard
    BIOS
    • AMI
    COM
    • 2 x Isolated M12 A-coded RS-232/422/485 (isolation level 1.5kV)
    USB
    • 1 x M12 A-coded USB 2.0 (2 port signal)
    Ethernet
    • 2 x isolated M12 X-coded GbE (isolation level 1.5kV)
    Display
    • N/A
    Audio
    • 1 x DB15 audio (line-in/mic-in/speaker-out/line-out)
    CANbus
    • 1 x Isolated DB9 CANbus (isolation level 1.5kV)
    Storage
    • 16GB flash onboard
    • 1 x mSATA
    DIO
    • 1 x Isolated terminal block DIO (6-in/2-out, isolation level 1.5kV)
    Expansion
    • 2 x PCI Express Mini Card slot
    Others
    • N/A
    Touchscreen
    • 5-wire resistive touchscreen with or without keyboard
    Front Bezel
    • IP65-rated aluminum front bezel and IP40-rated rear protection
    Power Supply
    • 1 x M12 A-coded DC-in
    • Typical 24 to 110 VDC
    • EN 50155 Class S3 20ms power interruption protection
    Power Comsumption
    • 24-110V@1.4-0.29A
    Watchdog Timer
    • 255 levels, 1 to 255 seconds
    Operating Temperature
    • -40°C to +70°C (-40°F to +158°F)
    Relative Humidity
    • 10% to 95% @ +40°C, non-condensing
    Vibration
    • N/A
    Dimensions (W x D x H)
    • 310 x 61.5 x 214 mm (12.20" x 2.42" x 8.43")
    Weight (net/gross)
    • 2.6kg (5.73lb)/4.4kg (9.7lb)
    Certifications
    • CE, EN 50155, EN 50121-3-2, EN 61373, EN 45545-2, UIC-612 (keypads) complied
    EOS
    • Windows? 10, Windows? 10 IoT, Windows? 8/8.1, Windows? 7, WES 7
    Mounting
    • Wall mount
    • Suspension mount
    • VESA mount
    标准
    IEEE802.3 10BASE-T
    IEEE802.3u标准100BASETX/100BASE-FX,带IEEE802.3x
    转发和过滤速率
    14,880 pps
    的为10Mbps
    148,810 pps
    的为100Mbps
    包缓冲存储器
    1.625M
    存储转发
    半双工背压和IEEE802.3x全双工流量控制处理类型
    地址表大小
    4096
    MAC地址
    延迟
    不到10微秒
    功率
    输入 输入电压:12?48VDC(接线端子),
    12VDC
    DC电源插座)
    最大功耗 7.4W0.6A @ 12VDC0.3A @ 24VDC0.15A @ 48VDC
    过载电流保护
    反极性保护
    机械
    外壳
    金属外壳,
    IP30
    尺寸
    69
    毫米(Wx 110毫米(深)x135毫米(H
    2.72“(宽)x 4.33”Dx 5.31“H))
    重量
    0.87
    公斤(1.92磅。)
    安装
    DIN
    导轨(顶帽式35毫米),面板,机架安装。
    接口
    以太网端口
    10/100BASE-TX
    161514个端口
    100BASE-FX
    012个端口
    每单位LED指示灯:电源状态(电源1,电源2,电源3
    每端口:10/100TX100FX:连接/活动
    报警触点
    继电器输出,电流1A @ 24VDC
    环境
    工作温度
    -10°C
    60°C14°F140°F
    测试@ -20°C70°C-4°F158°F
    存储温度:
    -40°C
    85°C-40°F185°F
    环境相对湿度
    5
    %至95%(无冷凝)
    安规认证
    ISO
    制造的ISO9001设施
    安全
    UL508
    EMI
    FCC
    15部分,A类,VCCI
    EN61000-6-4
    - EN55022
    - EN61000-3-2
    标准
    - EN61000-3-3
    EMS
    EN61000-6-2
    - EN61000-4-2 (ESD Standards)
    Contact: + / - 6KV; Criteria B
    Air: + / - 8KV; Criteria B
    - EN61000-4-3 (Radiated RFI Standards)
    10V/m, 80 to 1000MHz; 80% AM Criteria A
    3V/m, 1400 to 2000MHz; 80% AM Criteria A
    1V/m, 2000 to 2700MHz; 80% AM Criteria A
    - EN61000-4-4 (Burst Standards)
    Signal Ports: + / - 4KV; Criteria B
    D.C. Power Ports: + / - 4KV; Criteria B
    - EN61000-4-5 (Surge Standards)
    Signal Ports: + / - 1KV; Line-to-Line; Criteria B
    D.C. Power Ports: + / - 0.5KV; Line-to-earth; Criteria B
    - EN61000-4-6 (Induced RFI Standards)
    Signal Ports: 10Vrms @ 0.15 - 80MHz; 80% AM Criteria A
    D.C. Power Ports: 10Vrms @ 0.15 - 80MHz; 80% AM Criteria A
    - EN61000-4-8 (Magnetic Field Standards)
    30A/m @ 50, 60Hz; Criteria A
    Environmental Test Compliance
    IEC60068-2-6 Fc (Vibration Resistance)
    5g @ 10 - 150Hz, Amplitude 0.35mm(Operation/Storage/Transport)
    IEC60068-2-27 Ea (Shock)
    25g @ 11ms (Half-Sine Shock Pulse; Operation)
    50g @ 11ms (Half-Sine Shock Pulse; Storage/Transport)
    IEC60068-2-32 Ed (Free Fall)
    1M (3.281ft.)
艾讯科技 (Axiomtek) 于 1990 年成立于台湾,20余年来,作为工控业内的老牌厂商,已成为世界工业计算机领域公认的领先设计者和制造商。自公司初创立起,艾讯科技即以创新的设计、高质量的质量保证和高客户满意度的服务态度而领先业界。 艾讯已在大陆…  更多>>
艾讯科技 (Axiomtek)
联系人:王先生
地址:北京海淀区马连洼北路亿城国际
邮编:100085
电话:13911408386
公司网址:http://www.axiomtek.com
