Delikon Electrical Flexible Conduit & Fittings Co., Ltd.
  • InterLocked Liquid Tight metal Conduit and liquid tight conduit fittings for machine wiring
  • 发布时间:2013/2/18 21:15:03   修改时间:2013/2/18 21:15:03 浏览次数:2836
    PVC Covered InterLocked Metallic Flexible Liquidtight Conduit
    *Galvanized steel strip core with interloked construction *Smooth Heavy Duty PVC sheath *Fully flexible with exceptional mechanical strength *Trade size: 1/4"~6"
    *Liquid-tight  *High mechanical tensile strength *Cover does not wrinkle when bent
    * Interlocked liquidtight conduit is most suitable for frequent bending and movements
    Smooth wipe clean PVC covering surface. The PVC is keyed into the corrugations of the inner steel flexible core, preventing the PVC from wrinkling when the conduit is frequently bent or moved.
    Interlocked Liquid tight flexible metallic conduit provides protection for wiring circuits located in extremely wet or damp areas. Used in industrial and commercial applications for conveyors, blowers, cranes, air conditioners, machine tooling and lubrication equipment
    http://www.delikon.com/yf806.htm
    <p align="center"><a href="http://www.delikon.com/yf806.htm"><img border="0" src="http://www.delikon.com/images/806l1.jpg" alt="InterLocked Liquid Tight Flexible Metal Conduit">
我司专业制造电线保护软管及接头: 1)金属软管 2)防水金属软管,接头,包塑金属软管 3)防爆电线保护软管:防水,防爆,耐磨损,抗干扰 主要用于: 机械设备电线保护; 仪器仪表电线保护; 汽车轮船电线保护. 工厂商业电线保护. ======================= http://www.del…  更多>>
联系人:delikon
地址:http://www.delikon.com
邮编:216000
电话:21_000000000
传真:_
公司网址:http://www.delikon.com
  • Craig PAN 在2023/7/3 16:12:00留言
  • 详细留言:关于贵司 YF-90604 Delikon 1/2" Reel 样品信息
