2010年MONITRAN工厂上海航欧中国区销售
MONITRAN加速计、MONITRAN加速度传感器、MONITRAN传感器、MONITRAN编码器、MONITRAN震动探头
上海航欧销售英国MONITRAN传感器,成立于1986年,是英国的振动传感器制造商。Monitran对速度计、机械保护和维修涡流探头的开发、生产和应用。Monitran的振动传感器,固定和移动监测系统及其辅助设备,如传感器,探头,转接器加速器探头驱动器和电缆组件等产品,Monitran产品通过ISO9001:2008认证,Monitran的加速计用于监测,如水泵、电机、传感器、加速器、探头风机、发动机、探头驱动器、
常用型号:
MTN/1185CM8-20
1185CMPG7-100
MTN/1185IC-50
MTN/1185-CM8-25F
MTN/1185CQ-20
MTN/1185CM-25
MTN/EP080
MTN/1187-10
MTN/1187CM8-1/219
MTN/IEAIW-75
MTN/1185IC-20
IEIRG050
MONITRAN加速度传感器
MTN/1187-10
MTN/1188Q-1
MTN/1120IHCF1/4
MTN/1185ICM-25
MTN/MH008
MTN/1185
MTN/1187
VM120
MTN/1100SC,,,5shanghaihangousalesesarmouredETFE
Extratwincore,screened,overbraidedETFEcable,
MTN/1100WSubmersible,,waterproofgland,5shanghaihangousaleses
PUwaterproofshanghaihangousalest
MTN/1100SWSubmersible,,waterproofgland,5shanghaihangousaleses
PUwaterproofshanghaihangousalestr
Extrathree-core,polyurethane,waterproofcable,
MTN/1100IATEX/IECEx,,,2pinMS
MTN/1100ICATEX/IECEx,,,5shanghaihangousaleses
armouredETFEcableshanghaihangousales
MTN/1100ISATEX/IECEx,,,2pinMS
MTN/1100ISCATEX/IECEx,,,5shanghaihangousaleses
MTN/7100Low,strain,smallfourmet
MTN/7110Low,strain,largefourshanghaihangousales
MTN/7120Low,strain,shanghaihangoushanghaihangousales
Aboveallsuppliedwith5shanghaihangousalesesoverbraidedcable.Specifyrangeing
MTN/7200Low,4-20mA,smallfourshanghaihangousales
MTN/7210Low,4-20mA,largefourshanghaihangousales
MTN/7220Low , 4-20mA , shanghai hangou shanghai hangou sales
Above all supplied with 5 shanghai hangou saleses overbraided cable. Specify range in g
MTN/P1100, charge , 1100pC/g, TNC connectorshanghai hangou sales
MTN/P100T, charge , 20pC/g,
MTN/P100, charge , 20pC/g,
MTN/P50, charge , 50pC/g, , 5 shanghai hangou saleseshanghai hangou sales
MTN/P05, charge , 5pC/g, , 5 shanghai hangou saleseshanghai hangou sales
MTN/CA003In-line charge amplifier in stainless steel enclosure with connectors, 2mV/pC
MTN/MS001Quick-fit to glue studshanghai hangou sales3.20metshanghai hangou sales2.70
MTN/MS002Quick-fit to M8 male studshanghai hangou sales3.50shanghai hangou sales3.20met
MTN/MS003Quick-fit to M10 male studshanghai hangou sales3.50shanghai hangou sales3.20met
MTN/MS004Quick-fit to 1/4"UNF male studshanghai hangou sales3.50shanghai hangou sales3.20met
MTN/MS005Quick-fit to 1/4"UNF femaleshanghai hangou sales3.50shanghai hangou sales3.20met
MTN/MS006Quick-fit to M6 male studshanghai hangou sales3.50shanghai hangou sales3.20shanghai hangou sales
MTN/MS007Quick-fit to 10-32UNF femaleshanghai hangou sales3.50shanghai hangou sales3.20met
MTN/MS008Quick-fit to M8 female studshanghai hangou sales3.50shanghai hangou sales3.20met
MTN/MS00910-32UNF to male glue studshanghai hangou sales3.50shanghai hangou sales3.20shanghai hangou sales
MTN/MS010Quick-fit to glue stud (for 1020Q/1120Q series)shanghai hangou sales3.50shanghai hangou sales3.20met
MTN/MS0131/4"-28UNF male to glue studshanghai hangou sales3.20shanghai hangou sales356shanghai hangou sales2.70
MTN/MS01410-32UNF male to glue studshanghai hangou sales3.20shanghai hangou sales356shanghai hangou sales2.70
MTN/MS055Quick-fit to M8 male stud (for 1020Q/1120Q series)shanghai hangou sales3.20shanghai hangou sales2.70
MTN/MS0671/4"-28UNF to M8shanghai hangou sales3.50shanghai hangou sales3.20met
MTN/MS0361/4"-28UNF to M6shanghai hangou sales3.50shanghai hangou sales3.20shanghai hangou sales
MTN/MS1241/4"-28UNF to M10shanghai hangou sales3.50shanghai hangou sales3.20shanghai hangou sales
MTN/MS1321/4"-28UNF to M12shanghai hangou sales3.50shanghai hangou sales3.20met
MTN/MS02410-32 UNF grub screwshanghai hangou sales3.50shanghai hangou sales3.20shanghai hangou sales
MTN/MS032M6 x 12mm grub screwshanghai hangou sales3.50shanghai hangou sales3.20shanghai hangou sales
MTN/MS0681/4"-28UNF grub screwshanghai hangou sales3.50shanghai hangou sales3.20shanghai hangou sales
MTN/MS11Quick-fit female - 1/4" UNF malemet
MTN/MS15Quick-fit female - 10-32 UNF maleshanghai hangou sales
MTN/MS034Isolation Adaptor 1/4"-28UNF male to 1/4"-28UNF femaleshanghai hangou sales
MTN/MS062Isolation Adaptor 10-32UNF male to 10-32UNF malemet
MTN/MS093Isolation Adaptor Q/F male to M8 maleshanghai hangou sales
MTN/MS112Isolation Adaptor M8 male to M8 femaleshanghai hangou sales
MTN/MM0011/4"-28UNF male, 35mm, 2 pole type, 20kgsmet
MTN/MM00210-32UNF male, 19mm, 7kgsshanghai hangou sales
MTN/MM0031/4"-28UNF male, 38mm, 2 pole typemet
MTN/MM00410-32UNF male, 35mm, 2 pole type, 20kgsshanghai hangou sales
MTN/MM005Quick-fit male, 35mm, 2 pole type, 20kgsmet
MTN/MM006M6 female, 19mm, 7kgsshanghai hangou sales
MTN/MM007M8 female, 35mm, 2 pole type, 20kgsmet
MTN/MM0081/4"-28UNF male 25.35mm, 2 pole type, 11kgsshanghai hangou sales
MTN/MM00910-32UNF male, 25mm, 2 pole typemet
MTN/MM010Quick-fit male, 25mm, 2 pole typemet
MTN/MM0231/4"-28UNF female, 35mm, 20kgs shanghai hangou sales
MTN/MM027M10 female, 35mm, 2 pole typeshanghai hangou sales
MTN/PS0011/4" UNF , 25mmshanghai hangou sales
MTN/PS0021/4" UNF , 100mmmet
MTN/PS0031/4" UNF , 150mmmet
MTN/PS0041/4" UNF , 200mmshanghai hangou sales
MTN/PS00510-32 UNF , 25mmshanghai hangou sales
MTN/PS00610-32 UNF , 100mmshanghai hangou sales4
MTN/PS00710-32 UNF , 150mmshanghai hangou sales
MTN/PS00810-32 UNF , 200mmshanghai hangou sales
MTNMH001M8 spot face toolmet
MTN/MH010ing stud adhesive (liquid steel type), for 20 -25 glue-on adaptorsmet
MTN/3008Switch box, 8 , , IP65shanghai hangou sales
MTN/3010Switch box, 10 , , IP65shanghai hangou sales
MTN/3012Switch box, 12 , , IP65met
MTN/3014Switch box, 14 , , IP65shanghai hangou sales
MTN/3016Switch box, 16 , , IP65met
MTN/3018Switch box, 18 , , IP65shanghai hangou sales
MTN/3020Switch box, 20 , , IP65shanghai hangou sales
MTN/3025Switch box, 25 , , IP65shanghai hangou sales
MTN/3040Switch box, 40 , , IP65shanghai hangou sales
MTN/3064Switch box, 64 , , IP65shanghai hangou sales
MTN/9003-HD3 ,
MTN/9004-HD4 ,
MTN/9005-HD5 , shanghai hangou sales
MTN/9006-HD6 , shanghai hangou sales
MTN/9007-HD7 ,
MTN/9008-HD8 , shanghai hangou sales
MTN/9009-HD9 , shanghai hangou sales
MTN/9010-HD10 , shanghai hangou sales
MTN/9011-HD11 , shanghai hangou sales
MTN/9012-HD12 , shanghai hangou sales
MTN/9025-HD25 , shanghai hangou sales
MTN/9040-HD40 , shanghai hangou sales
MTN/9002-GRP2 t
MTN/9003-GRP3 t
MTN/9004-GRP4 shanghai hangou sales
MTN/9005-GRP5 shanghai hangou sales
MTN/9006-GRP6
MTN/9007-GRP7 shanghai hangou sales
MTN/9008-GRP8 t
MTN/9009-GRP9 shanghai hangou sales
MTN/9010-GRP10 shanghai hangou sales
MTN/9011-GRP11 t
MTN/9012-GRP12 t
MTN/9002-ABS2
MTN/9003-ABS3
MTN/9004-ABS4 shanghai hangou sales
MTN/9005-ABS5
MTN/9006-ABS6
MTN/9007-ABS7
MTN/9008-ABS8
MTN/9009-ABS9
MTN/9010-ABS10 shanghai hangou sales
MTN/9011-ABS11 shanghai hangou sales
MTN/9012-ABS12 shanghai hangou sales
Consult the sales office for other sizes
MTN9000-GRP Series Junction Boxes
hangou sales
MTN/VM120KVM120, probe, cable, magnet, spike, case - kit as aboveshanghai hangou sales
MTN/VM110Meter onlymet
MTN/VM120Meter onlymet
MTN/2100Hand held probe with coiled cable (CA418), 1/4"-28UNF
female ingshanghai hangou sales15556shanghai hangou sales14356shanghai hangou sales13256
MTN/CA418Coiled cable assembly TNC to IA110 for use with MTN/2100 hand-held
probeshanghai hangou sales4556shanghai hangou sales4256shanghai hangou sales3856
MTN/1100, , , 2 pin MS connectormet
MTN/CA042Coiled cable assembly 2 pin MS to IA110 for use with MTN/1100shanghai hangou sales
MTN/1020, , , TNC connectormet
MTN/CA043Coiled cable assembly TNC to IA110 for use with MTN/1020shanghai hangou sales
MTN/MM001Magnetic base, 1/4"-28UNF male, 2 pole, 35mm dia, 20Kg forcemet
MTN/PS001Spike probe, stainless steel, 25mm, 1/4"-28UNF maleshanghai hangou sales
MTN/PS002Spike probe, stainless steel, 100mm, 1/4"-28UNF maleshanghai hangou sales
MTN/PS003Spike probe, stainless steel, 150mm, 1/4"-28UNF maleshanghai hangou sales
MTN/PS004Spike probe, stainless steel, 200mm, 1/4"-28UNF maleshanghai hangou sales
MTN/HE001Carrying case with foam cutoutsshanghai hangou sales
MTN/RC0100Recalibration, recommended annuallyshanghai hangou sales
MTN/6000
MTN/HE003Wall ed enclosure to accommodate shanghai hangou rackshanghai hangou sales25056shanghai hangou sales23156
MTN/HE004Wall ed enclosure to accommodate two racksshanghai hangou sales35056shanghai hangou sales32456
MTN/6200
MTN/6100V
MTN/6100GVibration module as above but measuring (g)
MTN/6500-1Temperature module for AD590, 1μA/oK temperature sensormet
MTN/6500-2Temperature module for PT100 2 wireshanghai hangou sales
MTN/6500-3Temperature module for PT100 3 wireshanghai hangou sales
MTN/6500-4Temperature module for 10mV/oC temperature sensorshanghai hangou sales
MTN/MH007Flashing light and sirenshanghai hangou sales
MTN/MH099Flashing light onlyshanghai hangou sales20056shanghai hangou sales18556
A complete 6000 system consists of an electronics rack with power supply,
display, various signal input cards (one reqired for each sensor input) in an
IP65 enclosure with up to 12 s, temperature sensors or eddy
current probes. See the relevant sections for individual sensor prices.
Any complete 6000 monitoring system including 6 or more and
sensors will receive a 5% overall discount.
Model 6050 4 channel monitor
MTN/6050-65
MTN/6200
MTN/6050-4V
MTN/6050-4VT
MONITORING SYSTEMS
MONITORING SYSTEMS
MTN/MH0022 pin MS mating connector, femaleshanghai hangou sales
MTN/MH0083 pin 62GB mating connector, femaleshanghai hangou sales
MTN/CA067BNC plug with strain relief, fitted to cable. For connection to
datalogger having a BNC socketshanghai hangou sales
MTN/CA054BNC socket with dust cap in 90deg bracket, fitted to cable.
For connection to datalogger through accessory cable fitted with BNC plug or
VS0004 vibration switchshanghai hangou sales
MTN/CA0532 pin MS socket to free ends, overbraided ETFE, 5 shanghai hangou salesesshanghai hangou sales
MTN/CA1373 pin 62GB socket to free ends, overbraided ETFE, 5 shanghai hangou salesesshanghai hangou sales
Extra twin core, screened, armoured ETFE cable, per shanghai hangou salese
Above are for connecting remote sensors to switch boxes, junction boxes or
data systems. For other cable assemblies and cables to connect to portable
data loggers please contact the sales office. We will need to know the type of
cable required, length, sensor and measuring device to give a price.
MTN/8301 cable checkershanghai hangou sales
MTN/8302 signal simulatorshanghai hangou sales
MTN/APSU01Battery powered constant current power supply with BNC socket for shanghai hangou
MTN/8001Constant current power supply in DIN rail ed enclosure for use on
24VDCshanghai hangou sales
MTN/8001BNCConstant current power supply in DIN rail ed enclosure for use on
24VDC with integral BNC socketshanghai hangou sales
MTN/VC10Vibration calibrator shanghai hangou sales2,
MTN/EP0802mm range, M8 thread including 1 shanghai hangou salese armoured cableshanghai hangou sales
MTN/EP2005mm range, M16 thread including 1 shanghai hangou salese armoured cableshanghai hangou sales
MTN/EP3408.5mm range, M24 thread including 1 shanghai hangou salese armoured cableshanghai hangou sales
MTN/EP340F8.5mm range, 3 flange including 1 shanghai hangou salese armoured cableshanghai hangou sales
MTN/EP48012mm range, M30 thread including 1 shanghai hangou salese armoured cableshanghai hangou sales
Extra cable (priced per shanghai hangou salese)shanghai hangou sales
Up to a maximum of 9 shanghai hangou saleses including the extension
Alternative probe length and thread sizes available, consult the sales office
MTN/EX--1 shanghai hangou salese extension cableshanghai hangou sales4
Up to a maximum of 9 shanghai hangou saleses including the probe
MTN/ECPDDriver, 0-16VDC gap, -24VDCshanghai hangou sales
MTN/ECPD+24Driver, 0-16VDC gap, +24VDCshanghai hangou sales
MTN/ECPD/78Driver, 0-10VDC gap, +24VDCshanghai hangou sales
MTN/ECPD/604-20mA vibration, three wireshanghai hangou sales
MTN/ECPD/854-20mA gap, three wireshanghai hangou sales
MTN/ECPD2AC4-20mA vibration, two wire loop poweredshanghai hangou sales
MTN/ECPD2DC4-20mA gap, two wire loop poweredshanghai hangou sales
MTN/P2424V DC power supply housed in die-cast box with glanded , 240 or
110 volts input to power above drivers.shanghai hangou sales
MTN/RC0600Eddy Probe recalibration and certification in factory.met上海航欧机电设备有限公司成立于2006年,专业从事进口机电设备、仪器仪表等备品备件的销售,是经营世界各地进口设备机电配件的企业。上海航欧公司与众多品牌电子元件供应商建立有良好的合作关系,在欧美、日本等地形成了稳定的供应网络,良好的供应商关系和多年的行业经验,使我们在价格及货期上有优势。经销产品供应的行业涉及冶金、钢铁、石化、能源、航天、集装箱码头、汽车、水利、造纸、电厂、纺织、注塑、橡胶、食品包装等。我们热忱地希望尽我们的努力,力争优惠的产品价格,供货周期以及服务质量,能够为您解决进口备件方面的问题。进口产品主要有:传感器,测速电机,接近开关,电子尺,编码器,控制器、分析仪,光纤,光栅,插装阀,电缆,拖链,分配器,马达,减速机,继电器、缓冲器和进口五金等
170M7083 现货查询
2015091125170x149x8.1, DK108 现货查询
21D000589171 220V 现货查询
ZE65M 171-01052171-01052 现货查询
17109-2 现货查询
17122NNKR
现货查询
171271A10 现货查询
1714 现货查询
171E2N.C.D0005 现货查询
172.366.100.201.000 现货查询
17225-15 现货查询
1734-ACNR 现货查询
1734-AENTR 现货查询
1734-IE4C 现货查询
1734-IT2I 现货查询
1734-IV8 现货查询
1734-OV8E 现货查询
1734sc-IE4CH 现货查询
17411100 现货查询
17411300 现货查询
17413200 现货查询
17414500 现货查询
17421 现货查询
17422
现货查询
1746-NI4 现货查询
1746-OW16 现货查询
17511400 现货查询
17511900 现货查询
17524 现货查询
17546 现货查询
17566 现货查询
175P5H-TP-1 现货查询
1761-CBL-AS03 现货查询
1762-IF2OF2 现货查询
1762-IF4 现货查询
1762-OF4 现货查询
1762SC-IF8U 现货查询
1762sc-IF8u 现货查询
1763.80.NR 2-10BAR 现货查询
1769-PA2 现货查询
176B4000 现货查询
24-0159-6028 177-300-096 现货查询
177-300-113 现货查询
179-990-603 10m 现货查询
1790-001-114 现货查询
17E416W670G1 现货查询
17K912 现货查询
17OCT00 p/n 8255 0012 现货查询
17P BU-LOET PG9 现货查询
17R203 现货查询
18-611-20 现货查询
18-75C12NT1370 现货查询
18.601G-4001-R-1-5-100-200-1-000 现货查询
18/30 L1 500 SI 现货查询
979-08066 18/30R3/500-MSC 现货查询
F0018391800-DRR000-1101 现货查询
180003-112-0001 现货查询
F0019591800V-RRRDII-1221-00 现货查询
1805-262-31 现货查询
18077 现货查询
0806133214180L-4 22.043 TECCB35-MM 现货查询
1810 DN10 38# 现货查询
1813-02-D 3/8" 现货查询
S5N-MA-5-B01-PP 1814PK
现货查询
PT170241816124-1 现货查询
1820-1111
现货查询
18201A-2 现货查询
1824210220 现货查询
18333.01.0/1 现货查询
183939 DN15/PN25 现货查询
183B-124BAAA 现货查询
18412 现货查询
1851-239-10 现货查询
1860462-21-T-UL 1860423-21-T 现货查询
1877303 现货查询
1877403 现货查询
188.12.X.X.1.1.PS Incl. Diaphragm, excl.
body 现货查询
188.12.X.X.4.1.PS Incl. Diaphragm, excl.
body 现货查询
188.15.7.1.1.1.PS
316L 188.15.16.1.1.1R 现货查询
188.15.7.1.1.2.PS
316L 188.15.16.1.1.2R 现货查询
1892PS 现货查询
18E11Z1B1-1B21 (ACD6EDC) 现货查询
18F11Z1B1-1B21 (ACD7EDC) 现货查询
19-7-3633 现货查询
703303819/940.122.A/φ12/φ13 现货查询
703303919/940.122.A/φ13/φ13 现货查询
190.234.100.201.000 现货查询
190.235.100.201.000 现货查询
1900-1611-A1GB04 现货查询
1900100065 现货查询
190387
20090ASSAGO-MILANO-ITALY 现货查询
