  • 上海航欧销售TransducerTechniques传感器
  • 发布时间:2024/11/1 10:36:57   修改时间:2024/11/1 10:36:57 浏览次数:709
  • 上海航欧销售TransducerTechniques传感器、TransducerTechniques开关、TransducerTechniques变送器、TransducerTechniques阀、TransducerTechniques数显表
     美国TransducerTechniques公司成立于1979年,从事设计和制造系列的称重传感器,扭矩传感器,传感器和相关仪器仪表。TransducerTechniques公司的传感器的设计重量和力量等多元化的过程控制,可在工厂自动化以及其他数百个应用服务等工业领域测量。
    1.TransducerTechniques称重传感器
    CLC-200KCapacity:200,000lbsCompressionLoadColumn
    CLC-300KCapacity:300,000lbsCompressionLoadColumn
    CLC-400KCapacity:400,000lbsCompressionLoadColumn
    CAL-TEDSN/APlug&PlayOptionwithConnector
    AMM-66SSN/AMathangougAssembly6ftCable
    AMM-612SSN/AMathangougAssembly12ftCable
    AMM-620SSN/AMathangougAssembly20ftCable
    AMM-650SSN/AMathangougAssembly50ftCable
    THA-50-PCapacity:50lbshangouLoadCell
    THA-50-QCapacity:50lbshangouLoadCell
    THA-100-PCapacity:100lbshangouLoadCell
    THA-100-QCapacity:100lbshangouLoadCell
    THA-250-PCapacity:250lbshangouLoadCell
    THA-250-QCapacity:250lbshangouLoadCell
    GS0-1010gramsCalibrationhangouCompression
    GS0-2525gramsCalibrationhangouCompression
    GS0-3030gramsCalibrationhangouCompression
    GS0-5050gramsCalibrationhangouCompression
    GS0-100100gramsCalibrationhangouCompression
    GS0-150150gramsCalibrationhangouCompression
    GS0-250250gramsCalibrationhangouCompression
    GS0-500500gramsCalibrationhangouCompression
    GS0-1K1,000gramsCalibrationhangouCompression
    OPTION-TCN/ATensionCalibrationOption
    ALS-04N/ALoadStem(Dia..200Length.250)
    ALS-06N/ALoadStem(Dia..200Length.375)
    ALS-08N/ALoadStem(Dia..200Length.500)
    MDB-2.52.5lbsCalibrationhangouCompression
    MDB-55lbsCalibrationhangouCompression
    MDB-1010lbsCalibrationhangouCompression
    MDB-2525lbsCalibrationhangouCompression
    MDB-5050lbsCalibrationhangouCompression
    MDB-7575lbsCalibrationhangouCompression
    MDB-100100lbsCalibrationhangouCompression
    MLP-10Capacity:10lbsCalibrationhangouCompression
    MLP-25Capacity:25lbsCalibrationhangouCompression
    MLP-50Capacity:50lbsCalibrationhangouCompression
    MLP-75Capacity:75lbsCalibrationhangouCompression
    MLP-100Capacity:100lbsCalibrationhangouCompression
    MLP-150Capacity:150lbsCalibrationhangouCompression
    MLP-200Capacity:200lbsCalibrationhangouCompression
      MLP-300   Capacity: 300 lbs  Calibration hang ou Compression
      MLP-500   Capacity: 500 lbs  Calibration hang ou Compression
      MLP-750   Capacity: 750 lbs  Calibration hang ou Compression
      MLP-1K    Capacity: 1,000 lbs  Calibration hang ou Compression
      OPTION-CO N/A Mhang oui Connector System Option
      OPTION-DB N/A Dual Bridge
      OPTION-TC N/A Tension Calibration Option
      CAL-TEDS  N/A Plug & Play Option with Connector
      SLB-25    Capacity: 25 lbs  Mhang oui Compression Button
      SLB-50    Capacity: 50 lbs  Mhang oui Compression Button
      SLB-100   Capacity: 100 lbs  Mhang oui Compression Button
      SLB-250   Capacity: 250 lbs  Mhang oui Compression Button
      SLB-500   Capacity: 500 lbs  Mhang oui Compression Button
      SLB-750   Capacity: 750 lbs  Mhang oui Compression Button
      SLB-1K    Capacity: 1,000 lbs  Mhang oui Compression Button
      LB0-100   Capacity: 100 lbs  Compression Load Button
      LB0-100A  Capacity: 100 lbs  Compression Load Button
      LB0-250   Capacity: 250 lbs  Compression Load Button
      LB0-500   Capacity: 500 lbs  Compression Load Button
      LB0-750   Capacity: 750 lbs  Compression Load Button
      LB0-1K    Capacity: 1,000 lbs  Compression Load Button
      LB0-2K    Capacity: 2,000 lbs  Compression Load Button
      LB0-3K    Capacity: 3,000 lbs  Compression Load Button
      LB0-5K    Capacity: 5,000 lbs  Compression Load Button
      LB0-10K   Capacity: 10,000 lbs  Compression Load Button
      LB0-15K   Capacity: 15,000 lbs  Compression Load Button
      LB0-20K   Capacity: 20,000 lbs  Compression Load Button
      LB0-30K   Capacity: 30,000 lbs  Compression Load Button
      LB0-50K   Capacity: 50,000 lbs  Compression Load Button
      LBC-100   Capacity: 100 lbs  Compression Load Button
      LBC-100A  Capacity: 100 lbs  Compression Load Button
      LBC-250   Capacity: 250 lbs  Compression Load Button
      LBC-500   Capacity: 500 lbs  Compression Load Button
      LBC-750   Capacity: 750 lbs  Compression Load Button
      LBC-1K    Capacity: 1,000 lbs  Compression Load Button
      LBC-2K    Capacity: 2,000 lbs  Compression Load Button
      LBC-3K    Capacity: 3,000 lbs  Compression Load Button
      LBC-5K    Capacity: 5,000 lbs  Compression Load Button
      LBC-10K   Capacity: 10,000 lbs  Compression Load Button
      LBC-15K   Capacity: 15,000 lbs  Compression Load Button
      LBC-20K   Capacity: 20,000 lbs  Compression Load Button
      LBC-30K   Capacity: 30,000 lbs  Compression Load Button
      LBC-50K   Capacity: 50,000 lbs  Compression Load Button
      LBM-50    Capacity: 50 lbs Calibrated hang ou Compression
      LBM-100   Capacity: 100 lbs Calibrated hang ou Compression
      LBM-200   Capacity: 200 lbs Calibrated hang ou Compression
      LBM-500   Capacity: 500 lbs Calibrated hang ou Compression
      LBM-1K    Capacity: 1,000 lbs Calibrated hang ou Compression
      LBM-2K    Capacity: 2,000 lbs Calibrated hang ou Compression
      LBM-2.5K  Capacity: 2,500 lbs Calibrated hang ou Compression
      LBM-5K    Capacity: 1,000 lbs Calibrated hang ou Compression
      LBM-8K    Capacity: 8,000 lbs Calibrated hang ou Compression
      LBM-10K   Capacity: 10,000 lbs Calibrated hang ou Compression
      MLC-2K    Capacity: 2,000 lbs  Mhang oui Comp Load Column
      MLC-3K    Capacity: 3,000 lbs  Mhang oui Comp Load Column
      MLC-5K    Capacity: 5,000 lbs  Mhang oui Comp Load Column
      MLC-7.5K  Capacity: 7,500 lbs  Mhang oui Comp Load Column
      MLC-10K   Capacity: 10,000 lbs  Mhang oui Comp Load Column
      MLC-15K   Capacity: 15,000 lbs  Mhang oui Comp Load Column
      MLC-20K   Capacity: 20,000 lbs  Mhang oui Comp Load Column
      MLC-30K   Capacity: 30,000 lbs  Mhang oui Comp Load Column
      CLC-50K   Capacity: 50,000 lbs  Compression Load Column
      CLC-100K  Capacity: 100,000 lbs  Compression Load Column
      THA-500-P Capacity: 500 lbs  hang ou Load Cell
      THA-500-Q Capacity: 500 lbs  hang ou Load Cell
      THB-100-P Capacity: 100 lbs  hang ou Load Cell
      THB-100-Q Capacity: 100 lbs  hang ou Load Cell
      THB-100-R Capacity: 100 lbs  hang ou Load Cell
      THB-100-S Capacity: 100 lbs  hang ou Load Cell
      THB-250-P Capacity: 250 lbs  hang ou Load Cell
      THB-250-Q Capacity: 250 lbs  hang ou Load Cell
      THB-250-R Capacity: 250 lbs  hang ou Load Cell
      THB-250-S Capacity: 250 lbs  hang ou Load Cell
      THB-500-P Capacity: 500 lbs  hang ou Load Cell
      THB-500-Q Capacity: 500 lbs  hang ou Load Cell
      THB-500-R Capacity: 500 lbs  hang ou Load Cell
      THB-500-S Capacity: 500 lbs  hang ou Load Cell
      THB-1K-P  Capacity: 1,000 lbs  hang ou Load Cell
      THB-1K-Q  Capacity: 1,000 lbs  hang ou Load Cell
      THB-1K-R  Capacity: 1,000 lbs  hang ou Load Cell
      THB-1K-S  Capacity: 1,000 lbs  hang ou Load Cell
      THB-2K-P  Capacity: 2,000 lbs  hang ou Load Cell
      THB-2K-Q  Capacity: 2,000 lbs  hang ou Load Cell
      THB-2K-R  Capacity: 2,000 lbs  hang ou Load Cell
      THB-2K-S  Capacity: 2,000 lbs  hang ou Load Cell
      THC-250-P Capacity: 250 lbs  hang ou Load Cell
      THC-250-Q Capacity: 250 lbs  hang ou Load Cell
      THC-250-R Capacity: 250 lbs  hang ou Load Cell
      THC-250-S Capacity: 250 lbs  hang ou Load Cell
      THC-250-T Capacity: 250 lbs  hang ou Load Cell
      THC-250-V Capacity: 250 lbs  hang ou Load Cell
      THC-500-P Capacity: 500 lbs  hang ou Load Cell
      THC-500-Q Capacity: 500 lbs  hang ou Load Cell
      THC-500-R Capacity: 500 lbs  hang ou Load Cell
      THC-500-S Capacity: 500 lbs  hang ou Load Cell
      THC-500-T Capacity: 500 lbs  hang ou Load Cell
      THC-500-V Capacity: 500 lbs  hang ou Load Cell
      THC-1K-P  Capacity: 1,000 lbs  hang ou Load Cell
      THC-1K-Q  Capacity: 1,000 lbs  hang ou Load Cell
      THC-1K-R  Capacity: 1,000 lbs  hang ou Load Cell
      THC-1K-S  Capacity: 1,000 lbs  hang ou Load Cell
      THC-1K-T  Capacity: 1,000 lbs  hang ou Load Cell
      THC-1K-V  Capacity: 1,000 lbs  hang ou Load Cell
      THC-2K-P  Capacity: 2,000 lbs  hang ou Load Cell
      THC-2K-Q  Capacity: 2,000 lbs  hang ou Load Cell
      THC-2K-R  Capacity: 2,000 lbs  hang ou Load Cell
      THC-2K-S  Capacity: 2,000 lbs  hang ou Load Cell
      THC-2K-T  Capacity: 2,000 lbs  hang ou Load Cell
      THC-2K-V  Capacity: 2,000 lbs  hang ou Load Cell
      THC-3K-P  Capacity: 3,000 lbs  hang ou Load Cell
      THC-3K-Q  Capacity: 3,000 lbs  hang ou Load Cell
      THC-3K-R  Capacity: 3,000 lbs  hang ou Load Cell
      THC-3K-S  Capacity: 3,000 lbs  hang ou Load Cell
      THC-3K-T  Capacity: 3,000 lbs  hang ou Load Cell
      THC-3K-V  Capacity: 3,000 lbs  hang ou Load Cell
      THC-5K-P  Capacity: 5,000 lbs  hang ou Load Cell
      THC-5K-Q  Capacity: 5,000 lbs  hang ou Load Cell
      THC-5K-R  Capacity: 5,000 lbs  hang ou Load Cell
      THC-5K-S  Capacity: 5,000 lbs  hang ou Load Cell
      THC-5K-T  Capacity: 5,000 lbs  hang ou Load Cell
      THC-5K-V  Capacity: 5,000 lbs  hang ou Load Cell
      THC-7.5K-P Capacity: 7,500 lbs  hang ou Load Cell
      THC-7.5K-Q Capacity: 7,500 lbs  hang ou Load Cell
      THC-7.5K-R Capacity: 7,500 lbs  hang ou Load Cell
      THC-7.5K-S Capacity: 7,500 lbs  hang ou Load Cell
      THC-7.5K-T Capacity: 7,500 lbs  hang ou Load Cell
      THC-7.5K-V Capacity: 7,500 lbs  hang ou Load Cell
      THC-10K-P  Capacity: 10,000 lbs  hang ou Load Cell
      THC-10K-Q  Capacity: 10,000 lbs  hang ou Load Cell
      THC-10K-R  Capacity: 10,000 lbs  hang ou Load Cell
      THC-10K-S  Capacity: 10,000 lbs  hang ou Load Cell
      THC-10K-T  Capacity: 10,000 lbs  hang ou Load Cell
      THC-10K-V  Capacity: 10,000 lbs  hang ou Load Cell
      THD-2K-P  Capacity: 2,000 lbs  hang ou Load Cell
      THD-2K-Q  Capacity: 2,000 lbs  hang ou Load Cell
      THD-2K-R  Capacity: 2,000 lbs  hang ou Load Cell
      THD-2K-S  Capacity: 2,000 lbs  hang ou Load Cell
      THD-2K-T  Capacity: 2,000 lbs  hang ou Load Cell
      THD-2K-V  Capacity: 2,000 lbs  hang ou Load Cell
      THD-2K-W  Capacity: 2,000 lbs  hang ou Load Cell
      THD-2K-Y  Capacity: 2,000 lbs  hang ou Load Cell
      THD-2K-Z  Capacity: 2,000 lbs  hang ou Load Cell
      THD-3K-P  Capacity: 3,000 lbs  hang ou Load Cell
      THD-3K-Q  Capacity: 3,000 lbs  hang ou Load Cell
      THD-3K-R  Capacity: 3,000 lbs  hang ou Load Cell
      THD-3K-S  Capacity: 3,000 lbs  hang ou Load Cell
      THD-3K-T  Capacity: 3,000 lbs  hang ou Load Cell
      THD-3K-V  Capacity: 3,000 lbs  hang ou Load Cell
      THD-3K-W  Capacity: 3,000 lbs  hang ou Load Cell
      THD-3K-Y  Capacity: 3,000 lbs  hang ou Load Cell
      THD-3K-Z  Capacity: 3,000 lbs  hang ou Load Cell
      THD-5K-P  Capacity: 5,000 lbs  hang ou Load Cell
      THD-5K-Q  Capacity: 5,000 lbs  hang ou Load Cell
      THD-5K-R  Capacity: 5,000 lbs  hang ou Load Cell
      THD-5K-S  Capacity: 5,000 lbs  hang ou Load Cell
      THD-5K-T  Capacity: 5,000 lbs  hang ou Load Cell
      THD-5K-V  Capacity: 5,000 lbs  hang ou Load Cell
      THD-5K-W  Capacity: 5,000 lbs  hang ou Load Cell
      THD-5K-Y  Capacity: 5,000 lbs  hang ou Load Cell
      THD-5K-Z  Capacity: 5,000 lbs  hang ou Load Cell
      THD-7.5K-P Capacity: 7,500 lbs  hang ou Load Cell
      THD-7.5K-Q Capacity: 7,500 lbs  hang ou Load Cell
      THD-7.5K-R Capacity: 7,500 lbs  hang ou Load Cell
      THD-7.5K
    Shanghai HangOu Mechanical & Electrical Equipment Co., Ltd. was established in 2006,  and is specializing in the import of mechanical & electrical equipment spare parts, instruments and other products and brands of worldwide. These products are widely used in metallurgy, iron and steel, petrochemicals, energy, aerospace, container terminals, automation, water conservancy, papermaking, power plant, textile, injection molding, rubber, medical treatment, food packaging and other fields.  Our main product lines include: sensors, motors, switches, electronic scale, encoders, controllers, analysis meters,optical fibers, gratings,valves, warning lights, cable, towline, distributor, gearbox, relays, buffers and imported hardware. ShangHai HangOu Mechanical And Electrical Equipment Co.,Ltd
    Address
    Room 905, Building No.1, Guoson Centre, Lane 388, Zhongjiang Road. Shanghai, China.
    Tel
    0086-21-51085161
    0086-21-52391901
    Fax
    021-51870910
    021-52391837
    E-Mail
    sales@shhangou.com
    sales@shhangou.com.cn
    Zip Code
    200062
    Website
    www.shhangou.com
    www.shhangou.com.cn
    H705B-020      现货查询上海航欧                         HEDLAND
    BA71 B4 0.37KW IP54 F     现货查询上海航欧                         MGM
    1300637 现货查询上海航欧                         Haldex
    BE-3020U        现货查询上海航欧                         Univer
    170M6419 1600A 690V 现货查询上海航欧                         BUSSMANN
    E82EV551K4C 现货查询上海航欧                         LENZE
    MTN/1185M-100   现货查询上海航欧                         Monitran
    K330AO-C        现货查询上海航欧                         DOMNICK HUNTER DH)
    AG-3050  现货查询上海航欧                         Univer
    MXYZ-20 现货查询上海航欧                 MXYZ-20B        Z-LASER
    EEM33-71        现货查询上海航欧                         NOVO
    4324056204   现货查询上海航欧                         WABCO
    S40-PH-5-M03-PH 10-30VDC PNP 现货查询上海航欧                 QMIS/0P-0F        DATASENSOR
    TS 10       现货查询上海航欧                         SCHRAMM
    GS4200-250    现货查询上海航欧                         ESI-ELLISON
    CH03M-DO-SP-SH1 现货查询上海航欧                         NKE
    DDBVZ-16S-03S/35 现货查询上海航欧                         IMAV
    438F-115-1.5  现货查询上海航欧                         ARTISAN
    603-M     现货查询上海航欧                         DESTACO
    DDBVZ-10S-5C/35   现货查询上海航欧                         IMAV
    FS-925 P/N:161864        现货查询上海航欧                         GEMS
    F1-SU1Z/UV1ZD UN       现货查询上海航欧        6161000203            BERNSTEIN
    6A45  WITH 1.125 BORE WITH KEYWAY * WITH 1.375 BORE WITH KEYWAY      现货查询上海航欧                     ZERO-MAX
    6A52C  WITH 38 mm BORE WITH KEYWAYWITH 38 mm BORE WITH KEYWAY       现货查询上海航欧                     ZERO-MAX
    TH100-AOS      现货查询上海航欧                 TH110-AOS      KIMO
    SONAR-SENSOR-215U1-30BL-L280       现货查询上海航欧                 SONAR-SENSOR 205/215U1-30BL-L430 644-36939-5     LINCOLN
    310 39 RC 120V 50/60HZ       现货查询上海航欧                         HUMPHREY
    BM63刹车组 零件代码(73/74/75/77/78/79/85 现货查询上海航欧                         MGM
    YPCI-LAN-HA-224    现货查询上海航欧                 YPCILANFA224        SUN
    TLC-1004FG20        现货查询上海航欧                         TACO
    CH03M-DO-SP 现货查询上海航欧                         NKE
    Z109REG  9-40VDC/19-28VAC      现货查询上海航欧                Z109REG2-1    SENECA
    adam with 3 m cable 5*0.34 2TLJ020051R0200   现货查询上海航欧                         JOKAB SAFETY
    ST-02G-3A-U2X      现货查询上海航欧                 ST-02G-4A-U2X       METO-FER
    M8YV-A6A-R   现货查询上海航欧                         M-SYSTEM
    SPX-075   现货查询上海航欧                         SEAMETRICS
    C40089-600    现货查询上海航欧                         WICHITA
    M2SES-2AA-R/N      现货查询上海航欧                         M-SYSTEM
    EKCA4 KUC/KUC      现货查询上海航欧                         WAIRCOM
    GF4C(PF090300150002)        现货查询上海航欧                         TER
    FR692-D1        现货查询上海航欧                         PIZZATO
    4.054+APO      现货查询上海航欧                         WINKEL
    T-300N    现货查询上海航欧                         KYOWA
    EV21 21561203 230VAC/0.03A     现货查询上海航欧                 FHF21561212 EV 21 Voice  85 - 265 VAC         FHF
    92B-AAH-CJ3-DM-DJAP-1DG  现货查询上海航欧                         MAC
    R-32 现货查询上海航欧                         GIMATIC
    R11-C2-000     现货查询上海航欧                         WILKERSON
    OAB513002A00      现货查询上海航欧                         KENDRION
    81 P ML A3/2 242   现货查询上海航欧                 081P00 8P070A B   OMC
    AGMZO-A-10/210 20      现货查询上海航欧                         ATOS
    SKKT 106/16E 现货查询上海航欧                         SEMIKRON
    HTP25      现货查询上海航欧                         TELCON
    4514A     现货查询上海航欧                         FAIRCHILD
    FR78B-400230        现货查询上海航欧        Art no.3-070-100686              Noratel
    MTN/1185CQ-205米线缆)     现货查询上海航欧                         Monitran
    FDBA-LAN        现货查询上海航欧                         SUN
    CXBA-XCN        现货查询上海航欧                         SUN
    CR8-1/XCR81   现货查询上海航欧                         CABUR
    RVZ-16S-P       现货查询上海航欧                         IMAV
    HP602A-010F1S10 现货查询上海航欧                         HEDLAND
    ATM60-A4A12X12  现货查询上海航欧                         SICK
    B01AN22NO   现货查询上海航欧                         Selet
    M5MS-A-R      现货查询上海航欧                         M-SYSTEM
    D-103      现货查询上海航欧                         GUTEKUNST
    VEM/K21R 63 K 2   现货查询上海航欧                         VEM
    WS6B/24WSB006.502121)        现货查询上海航欧                 OAC006029     HAHN MAGNET
    AS-U30D 现货查询上海航欧                         TAKEX
    KWD2      现货查询上海航欧        E760                 AMK
    VLT10       现货查询上海航欧                 V-VTN16  RIETSCHLE
    TR-0050   现货查询上海航欧                         NOVO
    TR-0025 现货查询上海航欧                         NOVO
    TR-0100   现货查询上海航欧                         NOVO
    94000000FM  现货查询上海航欧                         CAL
    TC-R50 1KΩ+15%   现货查询上海航欧                         OFEL
    MUW250-4    现货查询上海航欧                         VOLFA
    ACCON-NETLINK-USB COMPACT    现货查询上海航欧        161701-USB    161701-PRO        DELTALOGIC
    TOP-3RD-25T   现货查询上海航欧                         NIPPON
    S.G.C VULCATHERM 30789-03        现货查询上海航欧                 30789-22        Vulcanic
    F.205.1G  现货查询上海航欧                         NOVO
    D-249      现货查询上海航欧                         GUTEKUNST
    D634-319C      现货查询上海航欧                         MOOG
    BC-3CP-MD _1/15HP 230V 50/60HZ     现货查询上海航欧                         MARCH PUMP
    UP-10S-PAB+TT       现货查询上海航欧                         IMAV
    FAN39B   现货查询上海航欧        FAN39BN0B             TEXA
    5KH36MNA445AX          现货查询上海航欧        H684                MARATHON
    NTK15X   现货查询上海航欧                         NETTER
    STP-MTR-23079      现货查询上海航欧                         automation direct
    Z1M18B-F-532-PZ   现货查询上海航欧                         Z-LASER
    020PD9   现货查询上海航欧                         Elfin
    D-1000Z-E       现货查询上海航欧                         MUTOH
    50-610-7612   现货查询上海航欧                         SETRAB
    SG-EFS 104 ZK2/1   现货查询上海航欧                         MAYSER
    MGZ-06S-A1/T2/10-04   现货查询上海航欧                         IMAV
    LV200-AW/2/SP1    现货查询上海航欧                         LEM
    ULCRV/R02400        现货查询上海航欧                         WAIRCOM
    S42 C/WS74 电动执行机构(开关型)  现货查询上海航欧                         BRAY CONTROLS
    325PA D=25mm(125现货查询上海航欧                         STAUFF
    137G-2590      现货查询上海航欧                         HEADLINE
    MAS-2 300-400-500-600A     现货查询上海航欧                         ELEKTROBA
    RJ1A60D20U   现货查询上海航欧                         CARLO GAVAZZI
    φ40TIPO CPU-CORSA ;行程1310mm 现货查询上海航欧        40/1310 CPU          WAIRCOM
    RT424012        现货查询上海航欧                         SCHRACK
    HP0652A10ANP01 现货查询上海航欧                         MP-FILTRI
    FTVR /MCOEVR 输入:0-100V 输出:0-10V tropicalized < 50ms 115/230Vac Class: 0.5        现货查询上海航欧                 MROVS1         FRER
    A-1 DN125 PN16    现货查询上海航欧                         STENFLEX
    MTN/1185CM-25   现货查询上海航欧                         Monitran
    MPZ-10S-A+B-B02   现货查询上海航欧                         IMAV
    YS212AF94V6DG4  现货查询上海航欧                         KONAN
    RIEGEL 0 NP/TP OHNE RASTUNG   现货查询上海航欧        073535            EUCHNER
    CEV58M-00167      现货查询上海航欧                 CEV582M-10167     TR
    972-0DP10      现货查询上海航欧        MSIP-REM-YVP                Vipa
    AZ16-12ZVRK-M16 现货查询上海航欧                         SCHMERSAL
    EFS2000-11114(G)  现货查询上海航欧                         SENSORIK
    MTN/1185CM8-25F        现货查询上海航欧                         Monitran
    PI 3115 PS 10  现货查询上海航欧        60020368                MAHLE
    PI 3108 PS 10,订货号:77680341     现货查询上海航欧        60020422                MAHLE
    PI 2205 SMX VST 3 现货查询上海航欧                 PI 2205 PS VST 3     MAHLE
    FCPA132SB-4   现货查询上海航欧                 FCPA132S 4/PHE     AC-MOTOREN
    S42 C/W:S01手柄  现货查询上海航欧                         BRAY CONTROLS
    MS7114,0.25KW,50HZ,230/400V(/Y),1.3A/0.75A,1390r/min,绝缘F,IP55,S1,Art NO:521332     现货查询上海航欧                 YE3-71M1-4    OLAER
    1UHH2    现货查询上海航欧                         DAYTON
    XCSD30F  现货查询上海航欧                 XCSD1060W012VAD       CABUR
    RF3-0050-4     现货查询上海航欧                         MTE
    35A-SCC-DFFJ-2KJ   现货查询上海航欧                         MAC
    8CB250  142096JB        现货查询上海航欧                         AIRFLEX
    QE3 现货查询上海航欧                         HUMPHREY
    ZPUU1-100BL-L670         现货查询上海航欧        664-34009-3        ZPUU1-100BL-L670/664-85324-5  LINCOLN
    SZL-WL-E-N     现货查询上海航欧                 SZL-WL-E-C01H       HONEYWELL
    9914-0965      现货查询上海航欧                         PULSOTRONIC
    TE500C12D2A1A6+T1-1/2P8 现货查询上海航欧                         GREYSTONE
    EH9997/084 AC/DC24V US=12-70V       现货查询上海航欧        0045504          DOLD
    41PP        现货查询上海航欧                         HUMPHREY
    1//2'NPT 1.4539 HH500 VAC(50/60HZ) PALL:00890     现货查询上海航欧                         BADGER
    240839    现货查询上海航欧                         DORNER
    M435       现货查询上海航欧                         MERCOTAC
    KE160-80        现货查询上海航欧                 KE160-80G      GOPA
    GDB-5F40        现货查询上海航欧                         MELEC
    LV-31       现货查询上海航欧                 LVN-10     OMEGA
    NTS 120 NFL   现货查询上海航欧                         NETTER
    11020 24V/220mA DC    现货查询上海航欧                 11021      W&T
    No.2PN    现货查询上海航欧                         SANTEST
  • 杜振一 在2024/12/11 13:59:00留言
  • 详细留言:购买Teknic, inc品牌的CPM-SDHP-N0563A-ELS
  • 罗经理 在2024/12/4 9:50:00留言
  • 详细留言:(MPL)/ 502-V-G-RANGE-F 我想购买这个
  • 王金龙 在2024/11/29 20:58:00留言
  • 详细留言:我需要寻找一些Coelbo产品
  • 在2024/11/13 14:14:00留言
  • 详细留言:AM22242R025010 28PCS需求
  • 在2024/10/5 10:11:00留言
  • 详细留言:mox cpu
