  • 上海航欧ARIS电机ARIS调节阀ARIS变送器
  • 发布时间:2025/3/14 16:11:20   修改时间:2025/3/14 16:11:20 浏览次数:39
  • 上海航欧ARIS电机ARIS调节阀ARIS变送器ARIS调节器ARIS蝶阀ARIS执行机构ARIS显示屏ARIS开关ARIS执行器ARIS液压伺服缸ARIS伺服器ARIS伺服电动机
    ARIS    PD35
    ARIS    PE55-06
    ARIS    BE41-21003
    ARIS    ACTUATINGDRIVE|K3006230V\50HZ,IP54 0429-4002-01003
    ARIS    EF06-1
    ARIS    K3006/1242-84873-01001
    ARIS    FNr.1420-6259-01010;Typ:EF 1 MA333312
    ARIS    PE40-08
    ARIS Antriebe und Steuerungen GmbH    PE30-08
    aris    FNr: 0736-67622-01002
    aris    6443LI 230V 50/60HZ 18VA 375/450RPM 92MA 0.56??F Nr.000429
    ARIS    N5 RD-S/DN 250d 230V 50??60??HZ FNr??0620-62724-01001
    Aris    PMR2 0700002 NR:0216-52001-001
    ARIS     0542-61428-02010 N-B1-E
    Aris    K3006 FNR.1137-5461-01059
    ARIS    FNr:1142-5481-02040
    ARIS    FNr:1219-83411-01003
    Aris    K3012,Stroke -- 300mm;actuating force --- 1200N;voltage --- 230V/50Hz;actuating speed --- 1.7(2) sec;
    ARIS    PD35 90 degrees, bushings for the plum-shaped CH.22, counterclockwise 81020/06
    ARIS    PE55-06 S4, 90 degrees, bushings for the plum-shaped CH.27, counterclockwise 81928/03
    ARIS    N 5 1209-82710-01003 30 s / 90??+ PMR 3
    ARIS    Typ:NL-90/120 FNr:1209-82710-02017 230V 50/60Hz 18VA 120Nm 90?? IP65
    ARIS    FNr:0908-4966-01008 Typ:EF1
    ARIS    NL-90/120
    Aris    Type: K3012 1,7/1200 2ZW RP19; Rated power: 0,031 kw; Nominal voltage: 220,000 V; Nominal voltage: 230,000 V; Nominal frequency: 60,000 hz; Nominal frequency: 50,000 hz; Degree of protection: IP54; Stroke: 300,000
    ARIS    TYP.N5 FNr.1117-79726-01002
    Aris    1206-S2453-02002 N5L SNR107504
    ARIS    0906-71866-01002??N6S DN1120d
    aris    PE60-08 0087.00033
  • 蔡莉 在2025/2/26 15:49:00留言
  • 详细留言:CTC AC184—1A 需求报价及购买方式
  • 刘飞 在2025/2/21 11:49:00留言
  • 详细留言:SB35HF140-50F10/112-1这个型号的蓄能器是否有货
  • 江生 在2025/2/13 14:39:00留言
  • 详细留言:K2BB47-11A,230VAC,50/60Hz 风机或者电机是否有现货?
