龙人旗下深圳市龙芯世纪科技有限公司
  • 超级电容器充电器
  • 发布时间:2013/7/25 9:22:18   修改时间:2013/7/25 9:22:18 浏览次数:2037
  • 超级电容器充电器
    凌力尔特提供了一个线性、开关和转换电容器 IC 产品库,专为给超级电容器充电而设计。这些器件拥有输入或输出电流限制、自动电池平衡以及众多的保护功能。
    超级电容器充电器
    Product Vin Min  (V) Vin Max  (V) Output Current  (A) Vout Maximum  Topology  Features  Comments  Packages
    LT3663 7 36 1.2 5.5V Buck Programmable Output Current Limit, Overvoltage Protection, Integrated Boost Diode 1.2A, 1.5MHz Step-Down Switching Regulator with Output Current Limit DFN-8
    LT3761 4.5 60 10 100V Buck, Boost, Buck-Boost, Sepic Resistor Set Switching Frequency, Rail-to-Rail Current Sense, Open LED Protection 60Vin LED Controller with Internal PWM Generator MS-16
    LT3796 6 100 10 Buck, Boost, Buck-Boost, Sepic Constant Current Constant Voltage, True Color PWM Dimming, Soft Start, Resistor Set Frequency, External Synchronization 100V Constant-Current and Constant-Voltage Controller with Dual Current Sense TSSOP-28
    LTC3125 1.6 5.5 1 5.25V Boost Programmable Input Current Limit, Burst Mode, Output Disconnect, Soft Start 1.2A Synchronous Step-Up DC/DC Converter with Input Current Limit DFN-8
    LTC3127 1.8 5.5 1 5.25V Buck-Boost Programmable Input Current Limit, Burst Mode, Output Disconnect 1A Buck-Boost DC/DC Converer wiht Porgrammable Input Current Limit DFN-10, MS-12
    LTC3225 3 5.5 0.15 4.8V, 5.3V Charge Pump Programmable Charge Current, Automatic Cell Balancing 150mA Supercapacitor Charger, Selectable 2.4V or 2.65V Per Cell DFN-10
    LTC3225 3 5.5 0.15 4V, 4.5V Charge Pump Programmable Charge Current, Automatic Cell Balancing 150mA Supercapacitor Charger, Selectable 2V or 2.25V Per Cell DFN-10
    LTC3226 2.5 5.5 0.315 5.3V Charge Pump Automatic Cell Balancing, PowerPath Control 2-Cell Supercapacitor Charger with Backup PowerPath Controller QFN-16
    LTC3606B 2.5 5.5 0.8 5V Buck Programmable Input Current Limit, Power Good, Soft Start 800mA Synchronous Step-Down DC/DC with Average Input Current Limit DFN-8
    LTC3619 2.5 5.5 0.8 5V Buck Programmable Input Current Limit, Burst Mode, Power Good, Soft Start 400mA/800mA Synchronous Step-Down DC/DC with Average Input Current Limit MS-10, DFN-10
    LTC3619B 2.5 5.5 0.8 5V Buck Programmable Input Current Limit, Power Good, Soft Start 400mA/800mA Synchronous Step-Down DC/DC with Average Input Current Limit MS-10, DFN-10
    LTC3625 2.7 5.5 1 4.8V, 5.3V Buck, Boost Programmable Charge Current, Automatic Cell Balancing 1A High Efficiency 2-Cell Supercapacitor Charger with Automatic Cell Balancing DFN-12
    LTC3625 2.7 5.5 1 4V, 4.5V Buck, Boost Programmable Charge Current, Automatic Cell Balancing 1A High Efficiency 2-Cell Supercapacitor Charger with Automatic Cell Balancing DFN-12
    LTC4425 2.7 5.5 3 5.5V Linear Programmable Current Limit Linear SuperCap Charger with Current-Limited Ideal Diode and V/I Monitor DFN-12, MS-12
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
