龙人旗下深圳市龙芯世纪科技有限公司
  • 调制解调器及收发器 I / O扩展器 传感器接口 智能卡和SIM卡接口
  • 发布时间:2013/9/9 10:55:01   修改时间:2013/9/9 10:55:01 浏览次数:2941
  • 调制解调器及收发器
    数据接口 - 传输和控制
    Product Datasheet Compliance Description Data Rate Number of Drivers Number of Receivers VCC Min (V) VCC Max (V) tPLH Max (μs) IO Max (μA) IIH Max (mA) Package Type
    NCN5150 NCN5150/D (172.0kB) Pb-free
    Halide free
    Wired M-BUS Slave Transceiver QFN-20
    SOIC-16
    NCV7707 NCV7707/D (306.0kB) Pb-free
    Halide free
    Door-Module Driver-IC SSOP-36 EP
    NCV7383 NCV7383/D (224.0kB) AEC Qualified
    PPAP Capable
    Pb-free
    Halide free
    Clamp 15 FlexRay<sup>TM</sup> Transceiver 10 Mb/s 1 1 4.75 5.25 0.06 60000 16 TSSOP-14
    NCV7424 NCV7424/D (175.0kB) AEC Qualified
    PPAP Capable
    Pb-free
    Halide free
    Quad LIN Transceiver 20 kbaud 4 4 5 27 TSSOP-16
    A5191HRT A5191HRT/D (193.0kB) Pb-free
    Halide free
    Industrial HART-Protocol Modem 1200 baud 1 1 3 5.5 0.02 670 0.0005 LQFP-32
    PLCC-28
    QFN-32
    AMIS-30585 AMIS-30585/D (314.0kB) Pb-free
    Halide free
    Power Line Carrier Modem 1200 baud 1 1 3 3.6 PLCC-28
    AMIS-30600 AMIS-30600/D (201.0kB) AEC Qualified
    PPAP Capable
    Pb-free
    Halide free
    LIN Transceiver 20 kbaud 1 1 7.3 18 50 40000 0.7 SOIC-8
    AMIS-30660 AMIS-30660/D (135.0kB) AEC Qualified
    PPAP Capable
    Pb-free
    Halide free
    CAN Transceiver, High Speed 1 Mb/s 1 1 4.75 5.25 1 45000 8 SOIC-8
    AMIS-30663 AMIS-30663/D (162.0kB) AEC Qualified
    PPAP Capable
    Pb-free
    Halide free
    CAN Transceiver , High Speed 1 Mb/s 1 1 4.75 5.25 1 45000 8 SOIC-8
    AMIS-41682 AMIS-41682-D (264.0kB) AEC Qualified
    PPAP Capable
    Pb-free
    Halide free
    CAN Transceiver, Fault Tolerant , 5.0 V 1 1 4.75 5.25 8 45000 6.3 SOIC-14
    AMIS-41683 AMIS-41682/D (264.0kB) AEC Qualified
    PPAP Capable
    Pb-free
    Halide free
    CAN Transceiver, Fault Tolerant , 3.3 V 1 1 4.75 5.25 8 45000 6.3 SOIC-14
    AMIS-42665 AMIS-42665/D (171.0kB) AEC Qualified
    PPAP Capable
    Pb-free
    Halide free
    CAN Transceiver, High Speed, Low Power 1 Mb/s 1 1 4.75 5.25 1 45000 8 SOIC-8
    AMIS-42670 AMIS-42670/D (150.0kB) Pb-free
    Halide free
    CAN Transceiver, High Speed, for Long Networks 1 Mb/s 1 1 4.75 5.25 1 45000 8 SOIC-8
    AMIS-42671 AMIS-42671/D (176.0kB) Pb-free
    Halide free
    AMIS-42673 AMIS-42673/D (153.0kB) Pb-free
    Halide free
    AMIS-42675 AMIS-42675/D (191.0kB) Pb-free
    Halide free
    AMIS-42700 AMIS-42700/D (206.0kB) AEC Qualified
    PPAP Capable
    Pb-free
    Halide free
    CAN Transceiver, Dual, High Speed 1 Mb/s 2 2 -0.3 7 SOIC-20W
    AMIS-42770 AMIS-42770/D (177.0kB) Pb-free
    Halide free
    CAN Transceiver, Dual, High Speed, for Long Networks 1 Mb/s 1 1 4.75 5.25 1 45000 19.5 SOIC-20W
    AMIS-49200 492X0/D (535.0kB) Pb-free
    Halide free
    Fieldbus Physical Layer Medium Access Unit (MAU) 31.25 kbps 1 1 4.75 6.2 4.7 30000 0.001 LQFP-44
    NQFP-44
    AMIS-49587 AMIS-49587/D (424.0kB) Pb-free
    Halide free
    Power Line Carrier Modem 2400 baud 1 1 3 3.6 QFN-52
    NCN49597 NCN49597/D (303.0kB) Pb-free
    Halide free
    Power Line Carrier Modem 4800 baud 1 1 3 3.6 QFN-52
    NCN49599 NCN49599/D (412.0kB) Pb-free
    Halide free
    9.6 kBds flex PLC Modem + PA QFN56 8x8, 0.5P
    NCN5120 NCN5120/D (412.0kB) Pb-free
    Halide free
    KNX Transceiver for Twisted Pair Networks 9600 baud 1 1 3.13 3.47 QFN-40
    NCN5192 NCN5192/D (303.0kB) Pb-free
    Halide free
    Full Feature HART Modem 1200 baud 1 1 3 5.5 0.02 670 0.0005 QFN-32
    NCV7321 NCV7321/D (181.0kB) AEC Qualified
    PPAP Capable
    Pb-free
    Halide free
    LIN Transceiver, Stand Alone 20 kbaud 1 1 SOIC-8
    NCV7340 NCV7340/D (142.0kB) AEC Qualified
    PPAP Capable
    Pb-free
    Halide free
    CAN Transceiver, High Speed, Low Power 1 Mb/s 1 1 4.75 5.25 1 100000 10 SOIC-8
    NCV7341 NCV7341/D (219.0kB) AEC Qualified
    PPAP Capable
    Pb-free
    Halide free
    CAN Transceiver, High Speed, Low Power 1 Mb/s 1 1 4.75 5.25 SOIC-14
    NCV7356 NCV7356/D (275.0kB) AEC Qualified
    PPAP Capable
    Pb-free
    Halide free
    CAN Transceiver, Single Wire 100 kbps 1 1 -0.3 18 6.3 350000 0.05 SOIC-14
    SOIC-8
    NCV7381 NCV7381/D (219.0kB) AEC Qualified
    PPAP Capable
    Pb-free
    Halide free
    Clamp 30 FlexRay&#8482; Transceiver 10 Mb/s 1 1 5.5 50 0.06 60000 17 SSOP-16
    NCV7420 NCV7420/D (256.0kB) AEC Qualified
    PPAP Capable
    Pb-free
    Halide free
    LIN Transceiver with Voltage Regulator 20 kbaud 1 1 5 26 50000 SOIC-14
    NCV7425 NCV7425/D (362.0kB) AEC Qualified
    PPAP Capable
    Pb-free
    Halide free
    LIN Transceiver with 150 mA LDO Linear Voltage Regulator 20 kbaud 1 1 5 28 50 150000 1.6 SOIC-16W EP
    NCV7430 NCV7430/D (357.0kB) AEC Qualified
    PPAP Capable
    Pb-free
    Halide free
    Automotive LIN RGB LED Driver 20 kbaud 3 1 5.5 43 100000 SOIC-14
    NCV7441 NCV7441/D (167.0kB) AEC Qualified
    PPAP Capable
    Pb-free
    Halide free
    CAN Transceiver, Dual, High Speed, Low Power 1 Mb/s 2 2 4.75 5.25 1 100000 20 SOIC-14
    NCV7462 NCV7462/D (414.0kB) AEC Qualified
    PPAP Capable
    Pb-free
    Halide free
    System Basis Chip with LIN, CAN, Two LDO, and HS/LS Drivers 7 2 5 28 250000 SSOP-36 EP
    NCV7471 NCV7471/D (617.0kB) AEC Qualified
    PPAP Capable
    Pb-free
    Halide free
    System Basis Chip with Dual LIN, HS CAN and 500 mA Boost-Buck DC-DC 0 3 2.5 28 SSOP-36 EP
    I / O扩展器
    I2C扩展器 – SMBus扩展器
    安森美半导体提供8位和16位输出/输出(I/O)扩展器。
    Product Datasheet Compliance Status Description I/O Cascadable VCC Min (V) VCC Max (V) Interrupt Output I/O Pullups LED Blink/PWM IO Min (mA) Package Type
    CAT9532 CAT9532/D (174.0kB) Pb-free
    Halide free
    Active I/O Port Expander, I<sup>2</sup>C / SMBus, 16-bit, w/LED Dimming  16 8 Slave ID Addresses 2.3 5.5 No No Yes 25 SOIC-24W
    TQFN-24
    TSSOP-24
    CAT9534 CAT9534/D (150.0kB) Pb-free
    Halide free
    Active I/O Port Expander,  I<sup>2</sup>C / SMBus, 8-bit 8 8 Slave ID Addresses 2.3 5.5 Yes No No 10 TQFN-16
    TSSOP-16
    CAT9552 CAT9552/D (163.0kB) Pb-free
    Halide free
    Active I/O Port Expander, I<sup>2</sup>C, 16-bit, LED Driver with Programmable Blink Rate 16 8 Slave ID Addresses 2.3 5.5 No No Yes 25 SOIC-24W
    TQFN-24
    TSSOP-24
    CAT9554 CAT9554/D (151.0kB) Pb-free
    Halide free
    Active I/O Port Expander, I<sup>2</sup>C / SMBus, 8-bit, w/Interrupt 8 8 Slave ID Addresses 2.3 5.5 Yes Yes No 10 TQFN-16
    TSSOP-16
    CAT9554A CAT9554A/D (151.0kB) Pb-free
    Halide free
    TSSOP-16
    CAT9555 CAT9555/D (170.0kB) Pb-free
    Halide free
    Active I/O Port Expander, I<sup>2</sup>C / SMBus, 16-bit, w/Interrupt 16 8 Slave ID Addresses 2.3 5.5 Yes Yes No 10 SOIC-24W
    TQFN-24
    TSSOP-24
    CAT9557 CAT9557/D (171.0kB) Pb-free
    Halide free
    Active I/O Port  Expander, I<sup>2</sup>C / SMBus, 8-bit, w/Reset 8 8 Slave ID Addresses 2.3 5.5 No No No 10 SOIC-16
    TQFN-16
    TSSOP-16
    LC709004A ENA0165/D (120.0kB) Pb-free
    Halide free
    Active I/O Expander for Microcontroller 16 2 6 SOIC-24 W / MFP-24SJ
    LC709006A EN8265-D (123.0kB) Pb-free Active I/O Expander for Microcontroller 24 2 6 SOIC-36 W / MFP-36SDJ
    PCA9535E PCA9535E/D (205.0kB) Pb-free
    Halide free
    Active I/O Port Expander, I<sup>2</sup>C, 16-bit, Low-Power w/Interrupt 16 1.65 5.5 Yes No No 25 QFN-24
    SOIC-24
    TSSOP-24
    PCA9655E PCA9655E/D (209.0kB) Pb-free
    Halide free
    Active I/O Port Expander, I<sup>2</sup>C, 16-bit, Remote Low Voltage w/Interrupt 16 5.5 1.65 Yes Yes 25 QFN-24
    SOIC-24
    TSSOP-24
    传感器接口
    双可变磁阻传感器接口
    安森美半导体提供双可变磁阻传感器接口器件。
    Product Datasheet Compliance Status Description Channels VCC Min (V) VCC Max (V) IT Max (mA) VI Typ (V) TA Min (°C) TA Max (°C) Package Type
    NCS37010 NCS37010/D (174.0kB) Pb-free ActiveNEW Single CT UL943 compliant self-test GFCI   6 12 2.2 1.8 -40 85
    Halide free
    NCS37012 NCS37012/D (131.0kB) Pb-free ActiveNEW Single CT GFCI with Self-Test 1 6 12 1 12 -40 85 QFN-16
    Halide free TSSOP-20
    NCS37000 NCS37000/D (128.0kB) Pb-free Active Single CT GFCI Signal Processor 1 6 12 1.5 1.8 -40 125 QFN-16
    Halide free
    NCS37005 NCS37005/D (120.0kB) Pb-free Active GFCI Controller with Direct Drive CT Interface   6 18     -40 85 QFN-16
    Halide free TSSOP-16
    NCV1124 NCV1124/D (172.0kB) AEC Qualified Active Dual Variable-Reluctance Sensor Interface 2 4.5 5.5 5 250 -40 125 SOIC-8
    智能卡和SIM卡接口
    智能卡接口 – SIM卡接口
    安森美半导体提供智能卡接口器件和用于SIM卡供电电路的SIM卡接口。
    Product Datasheet Compliance Status Description VCC Min (V) VCC Max (V) IT Typ (mA) II(standby) Max (μA) fClock Max (MHz) Package Type
    NCN8026 NCN8026A/D (160.0kB) Pb-free ActiveNEW Compact Low Power Smart Card Interface 1.6 5.5 1 3 27 QFN-24
    Halide free
    NCN4555 NCN4555/D (139.0kB) Pb-free Active SIM Card Interface Power Supply/Level Translator 1.8 5.5 0.03 4 5 QFN-16
    Halide free
    NCN4557 NCN4557/D (173.0kB) Pb-free Active Dual SIM Card / Smart Card Interface 1.8 5.5 0.03 3 5 QFN-16
    Halide free
    NCN6001 NCN6001/D (614.0kB) Pb-free Active Compact Smart Card Interface 2.7 6 0.5 60 40 TLLGA-20
    NCN6804 NCN6804 /D (335.0kB) Pb-free Active Dual Smart Card Interface 2.7 5.5 0.1 100 40 QFN-32
    Halide free
    NCN8024 NCN8024/D (174.0kB) Pb-free Active Smart Card Interface 4.5 5.5 6 1000 18 SOIC-28W
    Halide free TSSOP-28
    NCN8024R NCN8024R/D (172.0kB) Pb-free Active Smart Card Interface 2.7 5.5 4 61 27 SOIC-28W
    Halide free
    NCN8025 NCN8025/D (184.0kB) Pb-free Active Smart Card Interface 2.7 5.5 4 61 27 QFN-16
    Halide free QFN-24
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
