深圳市德威达科技有限公司
  • EDA系列电子压力控制器
  • 发布时间:2012/9/7 10:10:07   修改时间:2012/9/7 10:10:07 浏览次数:1351
  • 产品名称:  EDA电子压力控制器
    产品型号:  EDA
    压力表,开关变送器一体化
    介质: 可兼容的液体或气体.
    接液材质: 316L SS.
    外壳: Glass filled plastic.
    精度: ±1% of F.S. including linearity, hysteresis, and repeatability (indicator and transmitter).
    稳定性: < ±2% of F.S. per year.
    压力限制: Ranges up to 6,000 psi: 1.5 x range; 8,000 psi range: 10,000 psi.
    温度限制: Ambient: 20 to 140°F (-6.6 to 60°C); Process: 0 to 176°F (-18 to 80°C).
    补偿温度限制: 32 to 122°F (0 to 50°C).
    热效应: ±0.05% of F.S./°F.
    显示: 4-digit backlit LCD (Digits: 0.60"H x 0.33"W).
    电源: 12 to 30 VDC/AC.
    能耗: 2.5 watts.
    电气连接: Removable terminal blocks with two 1/2" female NPT conduit connections.
    封装等级: Meets NEMA 4X (IP65).
    预热时间: <10 seconds.
    安装方向: Any position.
    重量: 1.18 lbs (535 g).
    认证: CE and UL.
    开关特性:
    开关类型: 2 SPDT relays.
    电气额定: 5 A @ 120/240VAC, 1 A @ 30 VDC.
    重复性: ±1% of FS (switching only).
    设定点: Adjustable 0-100% of FS.
    开关指示: External LED for each relay on the front panel.
    开关复位: Manual or Automatic.
    变送器特性:
    输出: 4-20 mA, 1-6 VDC, 1-5 VDC, 0-5 VDC, or 0-10 VDC (direct or reverse output selection).
    最小激励电压: 14 VDC.
    零满调整: Menu scalable within the range
    显示单位: psi, kg/cm2, bar, in Hg, ft w.c., kPa, MPa, %FS, in w.c., mbar, cm w.c., mm Hg, or oz/in2 (choices depend on range).
    测试方式: Simulates input over the range without pressuring to easily test switches and transmitter output feature.
    故障保护: For sensor failure, over pressure, high temperature limit, low temperature limit, or keypad short. User chooses if relay is de-energized, energized, or no action. With transmitter option, user chooses an output of 3.6 mA 22 mA, or no action.
    交替: Selectable alternation of set points between the relays for even wear on duplex pump applications.
     选型表:
    举例
    EDA
    W
    N1
    E1
    02
    T0
    NIST
    Series EDAW-N1E1-02T0-NIST Electronic Pressure Controller, weatherproof housing, 1/4" male NPT process connection, (2) 1/2" conduit connections, range 0-20 psig, with NIST certificate.
    系列
    EDA
    封装
    W
    Weatherproof
    连接
    N1
    1/4" Male NPT
    接线口
    E1
    Two 1/2" NPT
    范围
    02
    03
    04
    05
    06
    07
    08
    09
    10
    11
    12
    0-20 psig
    0-60 psig
    0-100 psig
    0-150 psig
    0-300 psig
    0-600 psig
    0-1000 psig
    0-1500 psig
    0-3000 psig
    0-6000 psig
    0-8000 psig
    变送器
    T0
    T1
    T2
    T3
    T4
    T5
    None
    4 to 20 mA
    1 to 5 VDC
    0 to 5 VDC
    1 to 6 VDC
    0 to 10 VDC
    可选
    NIST
    STW
    23444
    NIST Certificate
    Stainless Steel Tag (wired)
    Special Cleaning
美国德威尔(Dwyer)仪器仪表授权中国代理——深圳市德威达科技有限公司深圳市德威达科技有限公司 (Shenzhen Deweida Technology Co., Ltd.)是从事自动控制系统开发和仪器仪表等机电产品销售的高科技专业公司。 公司人员有着多年的工业自动控制和楼宇自动…  更多>>
深圳市德威达科技有限公司
联系人:刘生
地址:深圳市福田区深南中路南侧南光捷佳大厦2001
邮编:518033
电话:0755-83692627,83692637,83692695
传真:0755-83692660
公司网址:http://www.szdwd.com
  • 韩先生 在2013/5/22 14:48:00留言
  • 详细留言:GFC-1144 供货及附件清单 价格
  • 韩先生 在2013/5/22 14:46:00留言
  • 详细留言:GFC-1144
