施兰东莞有限公司
  • PARKER派克自动化事业部
  • 发布时间:2008/9/1 22:58:37   修改时间:2008/9/1 22:55:39 浏览次数:7332
  • 施兰企业有限公司
    0769-22325481 22320941  13751371557
    021-33194567/8/9
    MOTORES DE PASSO
    Motor de passo, Nema 23, isolamento
    ES21B-DFR10 MOTOR,ES23,1STK,170V,10FT,DBL
    ES21B-DNR10 MOTOR,ES,23F,1ST,170V,10FT,DBL
    ES21B-DNR10-EC MOTOR,ES21,170V,10FT,ENCODER
    ES21B-SNR10 MOTOR,ES,23F,1ST,170V,10FT,SGL
    ES22B-DNR10 MOTOR,ES,23F,2ST,170V,10FT,DBL
    ES22B-DNR10-EC MOTOR,ES22,170V,10FT,ENCODER
    ES22B-SFR10 MTR,ES,170V,SGL,10',W/FLAT
    ES22B-SNR10 MOTOR,ES,23F,2ST,170V,10FT,SGL
    ES23B-DFR10 MOTOR,ES,23F,3ST,170V,10FT,FL
    ES23B-DFR10-EC MTR,23,170V,10',ENC,W/FLAT
    ES23B-DNR10 MOTOR,ES,23F,3ST,170V,10FT,DBL
    ES23B-DNR10-EC MOTOR,ES23,170V,10FT,ENCODER
    ES23B-SFR10 MOTOR,ES,23F,3ST,170V,10FT,SGL
    ES23B-SKR10 MOTOR,ES,23F,3ST,170V,10FT,SGL
    ES23B-SNR10 MOTOR,ES,23F,3ST,170V,10FT,SGL
    ES31B-DNR10 MOTOR,ES,34F,1ST,170V,10FT,DBL
    ES31B-DNR10-EC MOTOR,ES31,170V,10FT,ENCODER
    ES31B-SFR10 MOTOR,ES,34F,1ST,170V,10FT,SGL
    ES31B-SKR10 MTR,34F,1STK,170V,10',SGL,KEY
    ES31B-SNR10 MOTOR,ES,34F,1ST,170V,10FT,SGL
    ES32B-DFR10 MOTOR,ES,34F,2ST,170V,10FT,DBL
    ES32B-DFR10-EC MOTOR,ES32,170V,10FT,ENCODER
    ES32B-DKR10 MTR,ES,2ST,170V,10',DBL,W/KEY
    ES32B-DKR10-EC MTR/ENC,2ST,10',W/KEY
    ES32B-DNR10 MOTOR,ES,34F,2ST,170V,10FT,DBL
    ES32B-DNR10-EC MOTOR,ES32,170V,10FT,ENCODER
    ES32B-SFR10 MOTOR,ES,34F,2ST,170V,10FT,SGL
    ES32B-SKR10 MOTOR,ES,34F,2ST,170V,10FT,SGL
    ES32B-SNR10 MOTOR,ES,34F,2ST,170V,10FT,SGL
    ES33B-DFR10 MOTOR,ES,34F,3ST,170V,10FT,DBL
    ES33B-DKR10 MOTOR,ES,34F,3ST,170V,10FT,DBL
    ES33B-DNR10 MOTOR,ES,34F,3ST,170V,10FT,DBL
    ES33B-DNR10-EC MOTOR,ES33,170V,10FT,ENCODER
    ES33B-SFR10 MTR,FLAT,3ST,170V,1,SINGLE
    ES33B-SKR10 MOTOR,ES,34F,3ST,170V,10FT,SGL
    ES33B-SNR10 MOTOR,ES,34F,3ST,170V,10FT,SGL
    S蒖IE LV
    High performance
    Cost effective
    Optimized motors for both low-voltage and high-voltage
    applications
    Five frame sizes from size 11 to 34
    Static torques from 5 to 1000 oz-in.
    LV231-01-FL Stepper p/75VDC,flange 23,1 stack, eixo simples,c/ fios livres
    LV231-02-FL Stepper p/75VDC,flange 23,1 stack, eixo duplo, c/ fios livres
    LV231-01-10 Stepper p/75VDC,flange 23,1 stack, eixo simples, c/ cabo
    LV231-02-10 Stepper p/75VDC,flange 23,1 stack, eixo duplo, c/ cabo
    LV232-01-FL Stepper p/75VDC,flange 23,2 stack, eixo simples,c/ fios livres
    LV232-02-FL Stepper p/75VDC,flange 23,2 stack, eixo duplo, c/ fios livres
    LV232-01-10 Stepper p/75VDC,flange 23,2 stack, eixo simples, c/ cabo
    LV232-02-10 Stepper p/75VDC,flange 23,2 stack, eixo duplo, c/ cabo
    LV233-01-FL Stepper p/75VDC,flange 23,3 stack, eixo simples,c/ fios livres
    LV233-02-FL Stepper p/75VDC,flange 23,3 stack, eixo duplo, c/ fios livres
    LV233-01-10 Stepper p/75VDC,flange 23,3 stack, eixo simples, c/ cabo
    LV233-02-10 Stepper p/75VDC,flange 23,3 stack, eixo duplo, c/ cabo
    LV341-01-FL Stepper p/75VDC,flange 34,1 stack, eixo simples,c/ fios livres
    LV341-02-FL Stepper p/75VDC,flange 34,1 stack, eixo duplo, c/ fios livres
    LV341-01-10 Stepper p/75VDC,flange 34,1 stack, eixo simples, c/ cabo
    LV341-02-10 Stepper p/75VDC,flange 34,1 stack, eixo duplo, c/ cabo
    LV342-01-FL Stepper p/75VDC,flange 34,2 stack, eixo simples,c/ fios livres
    LV342-02-FL Stepper p/75VDC,flange 34,2 stack, eixo duplo, c/ fios livres
    LV342-01-10 Stepper p/75VDC,flange 34,2 stack, eixo simples, c/ cabo
    LV342-02-10 Stepper p/75VDC,flange 34,2 stack, eixo duplo, c/ cabo
    LV343-01-FL Stepper p/75VDC,flange 34,3 stack, eixo simples,c/ fios livres
    LV343-02-FL Stepper p/75VDC,flange 34,3 stack, eixo duplo, c/ fios livres
    LV343-01-10 Stepper p/75VDC,flange 34,3 stack, eixo simples, c/ cabo
    LV343-02-10 Stepper p/75VDC,flange 34,3 stack, eixo duplo, c/ cabo
    S蒖IE HV
    High performance
    Cost effective
    applications
    HV231-01-FL Stepper p/75VDC/110VAC,flange 23,1 stack, eixo simples,c/ fios livres
    HV231-02-FL Stepper p/75VDC/110VAC,flange 23,1 stack, eixo duplo, c/ fios livres
    HV231-01-10 Stepper p/75VDC/110VAC,flange 23,1 stack, eixo simples, c/ cabo
    HV231-02-10 Stepper p/75VDC/110VAC,flange 23,1 stack, eixo duplo, c/ cabo
    HV232-01-FL Stepper p/75VDC/110VAC,flange 23,2 stack, eixo simples,c/ fios livres
    HV232-02-FL Stepper p/75VDC/110VAC,flange 23,2 stack, eixo duplo, c/ fios livres
    HV232-01-10 Stepper p/75VDC/110VAC,flange 23,2 stack, eixo simples, c/ cabo
    HV232-02-10 Stepper p/75VDC/110VAC,flange 23,2 stack, eixo duplo, c/ cabo
    HV233-01-FL Stepper p/75VDC/110VAC,flange 23,3 stack, eixo simples,c/ fios livres
    HV233-02-FL Stepper p/75VDC/110VAC,flange 23,3 stack, eixo duplo, c/ fios livres
    HV233-01-10 Stepper p/75VDC/110VAC,flange 23,3 stack, eixo simples, c/ cabo
    HV233-02-10 Stepper p/75VDC/110VAC,flange 23,3 stack, eixo duplo, c/ cabo
    HV341-01-FL Stepper p/75VDC/110VAC,flange 34,1 stack, eixo simples,c/ fios livres
    HV341-02-FL Stepper p/75VDC/110VAC,flange 34,1 stack, eixo duplo, c/ fios livres
    HV341-01-10 Stepper p/75VDC/110VAC,flange 34,1 stack, eixo simples, c/ cabo
    HV341-02-10 Stepper p/75VDC/110VAC,flange 34,1 stack, eixo duplo, c/ cabo
    HV342-01-FL Stepper p/75VDC/110VAC,flange 34,2 stack, eixo simples,c/ fios livres
    HV342-02-FL Stepper p/75VDC/110VAC,flange 34,2 stack, eixo duplo, c/ fios livres
    HV342-01-10 Stepper p/75VDC/110VAC,flange 34,2 stack, eixo simples, c/ cabo
    HV342-02-10 Stepper p/75VDC/110VAC,flange 34,2 stack, eixo duplo, c/ cabo
    HV343-01-FL Stepper p/75VDC/110VAC,flange 34,3 stack, eixo simples,c/ fios livres
    HV343-02-FL Stepper p/75VDC/110VAC,flange 34,3 stack, eixo duplo, c/ fios livres
    HV343-01-10 Stepper p/75VDC/110VAC,flange 34,3 stack, eixo simples, c/ cabo
    HV343-02-10 Stepper p/75VDC/110VAC,flange 34,3 stack, eixo duplo, c/ cabo
    S蒖IE OEM / QM
    GS83-135-MO MOTOR,GS SERIES,83-135
    OEM57-40-MO MOTOR,OEM SERIES,57-40
    OEM57-40-MO-DS23 MOTOR,OEM SERIES,57-40,DOUBLE
    OEM57-40-MO-ENC MOTOR,OEM SERIES,57-40,W/ENC
    OEM57-51-MO MOTOR,OEM SERIES,57-51
    OEM57-51-MO-DS23 MOTOR,OEM SERIES,57-51,DOUBLE
    OEM57-51-MO-ENC MOTOR,OEM SERIES,57-51,W/ENC
    OEM57-83-MO MOTOR,OEM SERIES,57-83
    OEM57-83-MO-DS23 MOTOR,OEM SERIES,57-83,DOUBLE
    OEM57-83-MO-ENC MOTOR,OEM SERIES,57-83,W/ENC
    OEM83-135-MO MOTOR,OEM SERIES,83-135
    OEM83-135-MO-DS34 MOTOR,OEM SERIES,83-135,DOUBLE
    OEM83-135-MO-E MOTOR,OEM83-135,W/ENCODER
    OEM83-62-MO MOTOR,OEM SERIES,83-62
    OEM83-62-MO-DS34 MOTOR,OEM SERIES,83-62,DOUBLE
    OEM83-62-MO-E MOTOR,OEM83-62,W/ENCODER
    OEM83-93-MO MOTOR,OEM SERIES,83-93
    OEM83-93-MO-DS34 MOTOR,OEM SERIES,83-93,DOUBLE
    OEM83-93-MO-E MOTOR,OEM83-93,W/ENCODER
    QM-106-178 MOTOR,QM SERIES,106-178
    QM-106-178-E MOTOR,106-178,QM SERIES,ENC
    QM-106-178-S MOTOR,QM,106-178,SINGLE
    QM-106-205 MOTOR,QM SERIES,106-205
    QM-106-205-E MOTOR,106-205,QM SERIES,ENC
    QM-106-250 MOTOR,QM SERIES,106-250
    QM-106-250-E MOTOR,106-250,QM SERIES,ENC
    QM-57-102 MOTOR,57-102,QM SERIES
    QM-57-102-E MOTOR,57-102,QM SERIES,ENCODER
    QM-57-102-S MOTOR,57-102,QM SERIES,SINGLE
    QM-57-51 MOTOR,57-51,QM SERIES
    QM-57-51-E MOTOR,57-51,QM SERIES,ENCODER
    QM-57-51-S MOTOR,57-51,QM SERIES,SINGLE
    QM-57-83 MOTOR,57-83,QM SERIES
    QM-57-83-E MOTOR,57-83,QM SERIES,ENCODER
    QM-57-83-S MOTOR,57-83,QM SERIES,SINGLE
    QM-83-135 MOTOR,83-135,QM SERIES
    QM-83-135-E MOTOR,83-135,QM SERIES,ENCODER
    QM-83-135-S MOTOR,83-135,QM SERIES,SINGLE
    QM-83-62 MOTOR,83-62,QM SERIES
    QM-83-62-E MOTOR,83-62,QM SERIES,ENCODER
    QM-83-62-S MOTOR,83-62,QM SERIES,SINGLE
    QM-83-93 MOTOR,83-93,QM SERIES
    QM-83-93-E MOTOR,83-93,QM SERIES,ENCODER
    QM-83-93-S MOTOR,83-93,QM SERIES,SINGLE
    S蒖IE OS
    Low cost stepper motors.
    23-frame, Bus voltage 75Vdc ( A ) or 170Vdc ( B )
    OS21A-DFFLY-RE MTR,0S2,75V,DBL,W/FLAT,ENC
    OS21A-DFL10-RC MOTOR,OS57-51,75V,10FT,ENC,FLT
    OS21A-DNFLY MOTOR,OS2(57-51),75V,CE,DOUBLE
    OS21A-DNFLY-HJ MOTOR,OS2(57-51),75V,CE,ENCDR
    OS21A-DNFLY-RE MOTOR,OS2(57-51)75V,CE,ENC
    OS21A-DNL10 MOTOR,OS57-51,DBL,10FT,75V
    OS21A-DNL10-RC MOTOR,OS57-51,75V,10FT,ENC
    OS21A-SFFLY MOTOR,OS2(57-51),75V,CE,SINGLE
    OS21A-SFL10 MOTOR,OS57-51,SGL,FLAT,10',75V
    OS21A-SNFLY MOTOR,OS2(57-51),75V,CE,SINGLE
    OS21A-SNL10 MOTOR,OS57-51,SGL,10FT,75V
    OS21B-DFFLY MOTOR,OS2 (57-51)170V,CE,DBL
    OS21B-DNFLY Motor,OS2 (57-51)170V,CE,DBL
    OS21B-DNFLY-RE MOTOR,OS2(57-51)170V,CE,ENC
    OS21B-DNL10 MOTOR,OS57-51,DBL,10FT,170V
    OS21B-DNL10-RC MOTOR,OS57-51,170V,10FT,ENC
    OS21B-SFFLY MTR,OS2(57-51)170V,CE,SNGL,KEY
    OS21B-SFL10 MOTOR,OS57-51,SGL,10FT,170V
    OS21B-SNFLY Motor, OS2,(57-51)170V,CE,SGL
    OS21B-SNL10 MOTOR,OS57-51,SGL,10FT,170V
    OS22A-DFFLY-RE MTR,OS2,75V,DBL W/FLAT,ENC
    OS22A-DNFLY MOTOR,OS2(57-83),75V,CE,DOUBLE
    OS22A-DNFLY-HJ MOTOR,OS2(57-83),75V,CE,ENCDR
    OS22A-DNFLY-RE MOTOR,OS2(57-83)75V,CE,ENC
    OS22A-DNL10 MOTOR,OS57-83,DBL,10FT,75V
    OS22A-DNL10-RC MOTOR,OS57-83,75V,10FT,ENC
    OS22A-SFL10 MOTOR,OS57-83,SGL,10FT,75V
    OS22A-SNFLY MOTOR,OS2(57-83),75V,CE,SINGLE
    OS22A-SNL10 MOTOR,OS57-83,SGL,10FT,75V
    OS22B-DFFLY MTR,OS2,57-83,170V,DBL W/FLAT
    OS22B-DFFLY-RE MTR,0S2,170V,DBL W/FLAT,ENC
    OS22B-DFL10-RC MOTOR,OS57-83,170V,10FT,ENC
    OS22B-DNFLY Motor,OS2, (57-83)170V,CE,DBL
    OS22B-DNFLY-RE MOTOR,OS2(57-83)170V,CE,ENC
    OS22B-DNL10 MOTOR,OS57-83,DBL,10FT,170V
    OS22B-DNL10-RC MOTOR,OS57-83,170V,10FT,ENC
    OS22B-SFFLY MTR/OS2,57-83,170V,CE,SGL,FLAT
    OS22B-SFL10 MOTOR,OS57-83,SGL,10FT,170V
    OS22B-SNFLY Motor,OS2 (57-83)170V,CE,SGL
    OS22B-SNL10 MOTOR,OS57-83,SGL,10FT,170V
    OS2HA-DFL10-RC MTR,5740,75V,DBL,FLAT,10FT,ENC
    OS2HA-DNFLY MOTOR,OS2(57-40),75V,CE,DOUBLE
    OS2HA-DNFLY-HJ MOTOR,OS2(57-40),75V,CE,ENCDR
    OS2HA-DNFLY-RE MOTOR,OS2(57-40)75V,CE,ENC
    OS2HA-DNL10 MOTOR,OS57-40,DBL,10FT,75V
    OS2HA-DNL10-RC MOTOR,OS57-40,75V,10FT,ENC
    OS2HA-SFFLY MTR,OS2(57-40)75V,SINGLE,FLAT
    OS2HA-SFL10 MOTOR,OS2,57-40,SGL,10FT,75V
    OS2HA-SNFLY MOTOR,OS2(57-40),75V,CE,SINGLE
    OS2HA-SNL10 MOTOR,OS2,57-40,SGL,10FT,75V
    OS2HB-DFL10-RC MOTOR,OS57-40,170V,10FT,ENC
    OS2HB-DNFLY Motor,OS2, (57-40)170V,CE,DBL
    OS2HB-DNFLY-RE MOTOR,OS2(57-40)170V,CE,ENC
    OS2HB-DNL10 MOTOR,OS57-40,DBL,10FT,170V
    OS2HB-DNL10-RC MOTOR,OS57-40,170V,10FT,ENC
    OS2HB-SFL10 MOTOR,OS57-40,SGL,10FT,170V.FL
    OS2HB-SNFLY Motor,OS2,(57-40)170V,CE,SGL
    OS2HB-SNL10 MOTOR,OS57-40,SGL,10FT,170V
    S蒖IE RS
    RS31B-DKS10 MOTOR,RS83-62,170V,10FT,S,DBL
    RS31B-DNNPS MOTOR,RS3(83-62),170V,NPS,DBL
    RS31B-DNP10 MOTOR,RS83-62,170V,10FT,P,DBL
    RS31B-DNP10-EC MOTOR,RS83-62,170V,PAR,-ENC
    RS31B-DNS10 MOTOR,RS83-62,170V,10FT,S,DBL
    RS31B-DNS10-EC MOTOR,RS83-62,170V,SER,ENC
    RS31B-SFNPS MOTOR,RS3(83-62),170V,NPS,SGL
    RS31B-SFS10 MOTOR,RS83-62,170V,10FT,S,SNGL
    RS31B-SKNPS MOTOR,RS3(83-62),170V,NPS,SGL
    RS31B-SKS10 MOTOR,RS83-62,170V,10FT,S,SNGL
    RS31B-SNNPS MOTOR,RS3(83-62),170V,NPS,SGL
    RS31B-SNP10 MOTOR,RS83-62,170V,10FT,P,SNGL
    RS31B-SNS10 MOTOR,RS83-62,170V,10FT,S,SNGL
    RS31C-DFNPS MOTOR,RS31,340V,NPS W/FLAT
    RS31C-DFS10 MTR,RS83,340V,10',S,DBL W/FLAT
    RS31C-DNNPS MOTOR,RS3(83-62),340V,NPS,DBL
    RS31C-DNP10 MOTOR,RS83-62,340V,10FT,P,DBL
    RS31C-DNP10-EC MOTOR,RS83-62,340V,PAR,-ENC
    RS31C-DNS10 MOTOR,RS83-62,340V,10FT,S,DBL
    RS31C-DNS10-EC MOTOR,RS83-62,340V,SER,-ENC
    RS31C-SFNPS MOTOR,RS3(83-62),340V,NPS,SGL
    RS31C-SFP10 MOTOR,RS83-62,340V,10FT,P,SGL
    RS31C-SKNPS MOTOR,RS3(83-62),340V,NPS,SGL
    RS31C-SNNPS MOTOR,RS3(83-62),340V,NPS,SGL
    RS31C-SNP10 MOTOR,RS83-62,340V,10FT,P,SGL
    RS31C-SNS10 MOTOR,RS83-62,340V,10FT,S,SGL
    RS32B-DFP10-EC MTR,RS83-93,170V,DBL,PAR,ENC
    RS32B-DFS10 MOTOR,RS83-93,170V,10FT,S,DBL
    RS32B-DFS10-EC MOTOR,RS83-93,170V,SER,-ENC
    RS32B-DKNPS MOTOR,RS3(83-93),170V,NPS,DBL
    RS32B-DKS10 MOTOR,RS83-93,170V,10FT,S,FLT
    RS32B-DNNPS MOTOR,RS3(83-93),170V,NPS,DBL
    RS32B-DNP10 MOTOR,RS83-93,170V,10FT,P,DBL
    RS32B-DNP10-EC MOTOR,RS83-93,170V,PAR,-ENC
    RS32B-DNS10 MOTOR,RS83-93,170V,10FT,S,DBL
    RS32B-DNS10-EC MOTOR,RS83-93,170V,SER,-ENC
    RS32B-SFS10 MOTOR,RS83-93,170V,10FT,S,SNGL
    RS32B-SKNPS MOTOR,RS3(83-93),170V,NPS,SGL
    RS32B-SKS10 MTR,RS83-93,170V,10',S,SGL,KEY
    RS32B-SNNPS MOTOR,RS3(83-93),170V,NPS,SGL
    RS32B-SNP10 MOTOR,RS83-93,170V,10FT,P,SNGL
    RS32B-SNS10 MOTOR,RS83-93,170V,10FT,S,SNGL
    RS32C-DFNPS MOTOR,RS32,340V,NPS,W/FLAT
    RS32C-DKNPS MOTOR,RS32,340V,KEY,DBL,NPS
    RS32C-DNNPS MOTOR,RS3(83-93),340V,NPS,DBL
    RS32C-DNP10 MOTOR,RS83-93,340V,10FT,P,DBL
    RS32C-DNP10-EC MOTOR,RS83-93,340V,PAR,-ENC
    RS32C-DNS10 MOTOR,RS83-93,340V,10FT,S,DBL
    RS32C-DNS10-EC MOTOR,RS83-93,340V,SER,-ENC
    RS32C-SKNPS MOTOR,RS32,340V,SINGLE,KEY,NPS
    RS32C-SNNPS MOTOR,RS3(83-93),340V,NPS,SGL
    RS32C-SNP10 MOTOR,RS83-93,340V,10FT,P,SGL
    RS32C-SNS10 MOTOR,RS83-93,340V,10FT,S,SGL
    RS33B-DFNPS MOTOR,RS33,170V,NPS,W/FLAT
    RS33B-DFP10 MOTOR,RS83-135,170V,10',FLAT,P
    RS33B-DFS10 MTR,83-135,170V,10FT,FLAT,DBL
    RS33B-DFS10-EC MOTOR,RS83-135,170V,SER,-ENC
    RS33B-DKNPS MOTOR,RS3(83-135),170V,NPS,DBL
    RS33B-DKS10 MOTOR,RS83-135,170V,10FT,KEY,S
    RS33B-DNNPS MOTOR,RS3(83-135),170V,NPS,DBL
    RS33B-DNP10 MOTOR,RS83-135,170V,10FT,P,DBL
    RS33B-DNP10-EC MOTOR,RS83-135,170V,PAR,-ENC
    RS33B-DNS10 MOTOR,RS83-135,170V,10FT,S,DBL
    RS33B-DNS10-EC MOTOR,RS83-135,170V,SER,-ENC
    RS33B-SFNPS MOTOR,RS3(83-135),170V,NPS,SGL
    RS33B-SFS10 MTR,RS83135,170V,10FT,S W/FLAT
    RS33B-SKNPS MOTOR,RS33B,170V,NPS,SGL,KEY
    RS33B-SKS10 MOTOR,RS83-135,170V,10FT,S,SGL
    RS33B-SNNPS MOTOR,RS3(83-135),170V,NPS,SGL
    RS33B-SNP10 MOTOR,RS83-135,170V,10FT,P,SGL
    RS33B-SNS10 MOTOR,RS83-135,170V,10FT,S,SGL
    RS33C-DFNPS MOTOR,RS33,340V,NPS W/FLAT
    RS33C-DFP10 MOTOR,RS83-135,340V,FLAT,10',P
    RS33C-DKNPS MOTOR,RS3(83-135),340V,NPS,DBL
    RS33C-DKP10-EC MOTOR,RS83-135,340V,PAR,-ENC,K
    RS33C-DNNPS MOTOR,RS3(83-135),340V,NPS,DBL
    RS33C-DNP10 MOTOR,RS83-135,340V,10FT,P,DBL
    RS33C-DNP10-EC MOTOR,RS83-135,340V,PAR,-ENC
    RS33C-DNS10 MOTOR,RS83-135,340V,10FT,S,DBL
    RS33C-DNS10-EC MOTOR,RS83-135,340V,SER,-ENC
    RS33C-SKNPS MOTOR,RS3(83-135),340V,NPS,SGL
    RS33C-SNNPS MOTOR,RS3(83-135),340V,NPS,SGL
    RS33C-SNP10 MOTOR,RS83-135,340V,10FT,P,SGL
    RS33C-SNS10 MOTOR,RS83-135,340V,10FT,S,SGL
    RS42C-DKNPS MOTOR,RS4(2 STCK),340V,NPS,DBL
    RS42C-DKP10 MOTOR,RS106-178,340V,10,P,DBL
    RS42C-DKP10-EC MOTOR,RS106-178,340V,PAR,-ENC
    RS42C-DKS10 MOTOR,RS106-178,340V,10,S,DBL
    RS42C-DKS10-EC MOTOR,RS106-178,340V,SER,-ENC
    RS42C-SKNPS MOTOR,RS(2 STACK),340V,NPS,SGL
    RS42C-SKP10 MOTOR,RS106-178,340V,10,P,SGL
    RS42C-SKS10 MOTOR,RS106-178,340V,10,S,SGL
    RS43C-DKNPS MOTOR,RS(106-250),340V,NPS,DBL
    RS43C-DKP10 MOTOR,RS106-250,340V,10,P,DBL
    RS43C-DKP10-EC MOTOR,RS106-250,340V,PAR,-ENC
    RS43C-DKS10 MOTOR,RS106-250,340V,10,S,DBL
    RS43C-DKS10-EC MOTOR,RS106-250,340V,SER,-ENC
    RS43C-SKNPS MOTOR,RS(106-250),340V,NPS,SGL
    RS43C-SKP10 MOTOR,RS106-250,340V,10,P,SGL
    RS43C-SKS10 MOTOR,RS106-250,340V,10,S,SGL
    S蒖IE RE
    RE42B-DKNPS MOTOR,RE106-205,170V,NPS,DBL
    RE42B-DKP10 MOTOR,RE42B,170V,P10,DBL
    RE42B-DKP10-EC MOTOR,RS106-205,170V,PAR,-ENC
    RE42B-DKS10 MOTOR,RE42B,170V,S10,DBL
    RE42B-DKS10-EC MOTOR,RS106-205,170V,SER,-ENC
    RE42B-SKNPS MOTOR,RE106-205,170V,NPS,SGL
    RE42B-SKP10 MOTOR,RE42B,170V,P10,SGL
    RE42B-SKS10 MOTOR,RE42B,170V,S10,SGL
    RE42C-DKNPS MOTOR,RE(106-105),340V,NPS,DBL
    RE42C-DKP10 MOTOR,RE106-205,340V,10,P,DBL
    RE42C-DKP10-EC MOTOR,RE106-205,340V,PAR,-ENC
    RE42C-DKS10 MOTOR,RE106-205,340V,10,S,DBL
    RE42C-DKS10-EC MOTOR,RE106-205,340V,SER,-ENC
    RE42C-SKNPS MOTOR,RE(106-205),340V,NPS,SGL
    RE42C-SKP10 MOTOR,RE106-205,340V,10,P,SGL
    RE42C-SKS10 MOTOR,RE106-205,340V,10,S,SGL
    S蒖IE TS
    High performance.
    34 and 42-frame.
    Used with the GT and ZETA drives at 120 VAC.
    TS31B-DKNPS MOTOR,TS,34F,1STK,170V,NPS,DBL
    TS31B-DKP10 MOTOR,TS31B,170V,P10,DBL
    TS31B-DKP10-EC MOTOR,TS31B,170V,P10,DBL,ENC
    TS31B-DKS10 MOTOR,TS31B,170V,S10,DBL
    TS31B-DKS10-EC MOTOR,TS31B,170V,S10,DBL,ENC
    TS31B-SKNPS MOTOR,TS,34F,1STK,170V,NPS,SGL
    TS31B-SKP10 MOTOR,TS31B,170V,P10,SNGL
    TS31B-SKS10 MOTOR,TS31B,170V,S10,SGL
    TS32B-DKNPS MOTOR,TS,34F,2STK,170V,NPS,DBL
    TS32B-DKP10 MOTOR,TS32B,170V,P10,DBL
    TS32B-DKP10-EC MOTOR,TS32B,170V,P10,DBL,ENC
    TS32B-DKS10 MOTOR,TS32B,170V,S10,DBL
    TS32B-DKS10-EC MOTOR,TS32B,170V,S10,DBL,ENC
    TS32B-SKNPS MOTOR,TS,34F,2STK,170V,NPS,SGL
    TS32B-SKP10 MOTOR,TS32B,170V,P10,SNGL
    TS32B-SKS10 MOTOR,TS32B,170V,S10,SNGL
    TS33B-DKNPS MOTOR,TS,34F,3STK,170V,NPS,DBL
    TS33B-DKP10 MOTOR,TS33B,170V,P10,DBL
    TS33B-DKP10-EC MOTOR,TS33B,170V,P10,DBL,ENC
    TS33B-DKS10 MOTOR,TS33B,170V,S10,DBL
    TS33B-DKS10-EC MOTOR,TS33B,170V,S10,DBL,ENC
    TS33B-SKNPS MOTOR,TS,34F,3STK,170V,NPS,SGL
    TS33B-SKP10 MOTOR,TS33B,170V,P10,SGL
    TS33B-SKS10 MOTOR,TS33B,170V,S10,SNGL
    TS41B-DKNPS MOTOR,TS,42F,1STK,170V,NPS,DBL
    TS41B-DKNPS-EC MOTOR,170V,DBL,ENC,NO Cabo
    TS41B-DKP10 MOTOR,TS41B,170V,P10,DBL
    TS41B-DKP10-EC MOTOR,TS41B,170V,P10,DBL,ENC
    TS41B-DKS10 MOTOR,TS41B,170V,S10,DBL
    TS41B-DKS10-EC MOTOR,TS41B,170V,S10,DBL,ENC
    TS41B-SKNPS MOTOR,TS,42F,1STK,170V,NPS,SGL
    TS41B-SKP10 MOTOR,TS41B,170V,P10,SGL
    TS41B-SKS10 MOTOR,TS41B,170V,S10,SNGL
    TS42B-DKNPS MOTOR,TS,42F,2STK,170V,NPS,DBL
    TS42B-DKP10 MOTOR,TS42B,170V,P10,DBL
    TS42B-DKP10-EC MOTOR,TS42B,170V,P10,DBL,ENC
    TS42B-DKS10 MOTOR,TS42B,170V,S10,DBL
    TS42B-DKS10-EC MOTOR,TS42B,170V,S10,DBL,ENC
    TS42B-SKNPS MOTOR,TS,42F,2STK,170V,NPS,SGL
    TS42B-SKP10 MOTOR,TS42B,170V,P10,DBL
    TS42B-SKS10 MOTOR,TS42B,170V,S10,SNGL
    TS43B-DKNPS MOTOR,TS,42F,3STK,170V,NPS,DBL
    TS43B-DKP10 MOTOR,TS43B,170V,P10,DBL
    TS43B-DKP10-EC MOTOR,TS43B,170V,P10,DBL,ENC
    TS43B-DKS10 MOTOR,TS43B,170V,S10,DBL
    TS43B-DKS10-EC MOTOR,TS43B,170V,S10,DBL,ENC
    TS43B-SKNPS MOTOR,TS,42F,3STK,170V,NPS,SGL
    TS43B-SKP10 MOTOR,TS43B,170V,P10,SGL
    TS43B-SKS10 MOTOR,TS43B,170V,S10,SNGL
    S蒖IE VS
    17, 23 and 34-frame.
    VS12B-DFFLY MOTOR,VS,17 FRAME,2 STACK,FLY
    VS12B-DFR10 MOTOR,VS,17 FRAME,2 STACK,10FT
    VS12B-SFFLY MOTOR,VS,17 FR,SINGLE,2 STK,FL
    VS12B-SFR10 MOTOR,VS,17 FR,SGL,2 STK,10FT
    VS13B-DFFLY MOTOR,VS,17 FRAME,3 STACK,FLY
    VS13B-DFR10 MOTOR,VS,17 FRAME,3 STACK,10FT
    VS13B-SFFLY MOTOR,VS,17 FR,SGL,3 STK,FLY
    VS13B-SFR10 MOTOR,VS,17 FR,SGL,3 STK,10FT
    VS21B-DFFLY MOTOR,VS,23 FRAME,1 STACK,FLY
    VS21B-DFR10 MOTOR,VS,23 FRAME,1 STACK,10FT
    VS21B-SFFLY MOTOR,VS,23 FR,SGL,1 STK,FLY
    VS21B-SFR10 MOTOR,VS,23 FR,SGL,1 STK,10FT
    VS22B-DFFLY MOTOR,VS,23 FRAME,2 STACK,FLY
    VS22B-DFR10 MOTOR,VS,23 FRAME,2 STACK,10FT
    VS22B-SFFLY MOTOR,VS,23 FR,SGL,2 STK,FLY
    VS22B-SFR10 MOTOR,VS,23 FR,SGL,2 STK,10FT
    VS23B-DFFLY MOTOR,VS,23 FRAME,3 STACK,FLY
    VS23B-DFR10 MOTOR,VS,23 FRAME,3 STACK,10FT
    VS23B-SFFLY MOTOR,VS,23 FR,SGL,3 STK,FLY
    VS23B-SFR10 MOTOR,VS,23 FR,SGL,3 STK,10FT
    VS31B-DFFLY MOTOR,VS,34 FRAME,1 STACK,FLY
    VS31B-DFR10 MOTOR,VS,34 FRAME,1 STACK,10FT
    VS31B-SFFLY MOTOR,VS,34 FR,SGL,1 STK,FLY
    VS31B-SFR10 MOTOR,VS,34 FR,SGL,1 STK,10FT
    VS32B-DFFLY MOTOR,VS,34 FRAME,2 STACK,FLY
    VS32B-DFR10 MOTOR,VS,34 FRAME,2 STACK,10FT
    VS32B-SFFLY MOTOR,VS,34 FR,SGL,2 STK,FLY
    VS32B-SFR10 MOTOR,VS,34 FR,SGL,2 STK,10FT
    S
    S57-51-MO MOTOR,S-SERIES,CABLED
    S57-51-MO-E S-SERIES MOTOR W/ENCODER
    S57-51-MO-F MOTOR,S57-51,W/FLAT
    S57-51-MO-S MOTOR,S-SERIES,CABLED
    S57-83-MO MOTOR,S-SERIES,CABLED
    S57-83-MO-E S-SERIES MOTOR W/ENCODER
    S57-83-MO-F MOTOR,S57-83,W/FLAT
    S57-83-MO-S S57-83 MOTOR ONLY, SINGLE
    S57-102-MO MOTOR,S-SERIES,CABLED
    S57-102-MO-E S-SERIES MOTOR W/ENCODER
    S57-102-MO-F MOTOR,S57-102,W/FLAT
    S57-102-MO-S MOTOR,S-SERIES,CABLED
    S83-62-MO MOTOR,S-SERIES,CABLED
    S83-62-MO-E S-SERIES MOTOR W/ENCODER
    S83-62-MO-S MOTOR,S-SERIES,CABLE,SINGLE
    S83-93-MO MOTOR,S-SERIES,CABLED
    S83-93-MO-E S-SERIES MOTOR W/ENCODER
    S83-93-MO-F MOTOR,S83-93,W/FLAT
    S83-93-MO-S MOTOR,S-SERIES,CABLE,SINGLE
    S83-135-MO MOTOR,S-SERIES,CABLED
    S83-135-MO-E S-SERIES MOTOR W/ENCODER
    S83-135-MO-F MOTOR,S83-135,W/FLAT
    S83-135-MO-K MOTOR,S83-135 W/STD KEYWAY
    S83-135-MO-S S83-135 MOTOR ONLY, SINGLE
    S83-135-MO-S-F MOTOR,S83-135,SINGLE,FLAT
    S83-135-MO-S-K MOTOR,S83-135,SINGLE W/KEYWAY
    S106-178-MO MOTOR,S-SERIES,CABLED
    S106-178-MO-E S-SERIES MOTOR W/ENCODER
    S106-178-MO-S S 106-178 MTR,SINGLE
    S106-205-MO MOTOR,S-SERIES,CABLED
    S106-205-MO-E S-SERIES MOTOR W/ENCODER
    S106-205-MO-S S106-205 MOTOR ONLY,SINGLE
    S106-250-MO S106-250 MOTOR ONLY
    S106-250-MO-E S106-250 MOTOR ONLY W/ENCODER
    S106-250-MO-R S106-250 MOTOR ONLY -R
    S106-250-MO-S MOTOR,S-SERIES,CABLED,SINGLE
    Zeta
    ZETA57-102-MO MOTOR,ZETA57-102
    ZETA57-102-MO-E MOTOR,ZETA57-102,ENCODER
    ZETA57-102-MO-S MOTOR,ZETA57-102,SINGLE
    ZETA57-51-MO MOTOR,ZETA57-51
    ZETA57-51-MO-E MOTOR,ZETA57-51,ENCODER
    ZETA57-51-MO-S MOTOR,ZETA57-51,SINGLE
    ZETA57-83-MO MOTOR,ZETA57-83
    ZETA57-83-MO-E MOTOR,ZETA57-83,ENCODER
    ZETA57-83-MO-F MOTOR,ZETA57-83,W/FLAT
    ZETA57-83-MO-S MOTOR,ZETA57-83,SINGLE
    ZETA83-135-MO MOTOR,ZETA83-135
    ZETA83-135-MO-E MOTOR,ZETA83-135,ENCODER
    ZETA83-135-MO-E-K MOTOR,ZETA83-135,ENC,KEYWAY
    ZETA83-135-MO-F MOTOR,ZETA83-135,FLAT
    ZETA83-135-MO-K MOTOR,ZETA83-135 W/KEYWAY
    ZETA83-135-MO-S MOTOR,ZETA83-135,SINGLE
    ZETA83-62-MO MOTOR,ZETA83-62
    ZETA83-62-MO-E MOTOR,ZETA83-62,ENCODER
    ZETA83-62-MO-S MOTOR,ZETA83-62,SINGLE
    ZETA83-93-MO MOTOR,ZETA83-93
    ZETA83-93-MO-E MOTOR,ZETA83-93,ENCODER
    ZETA83-93-MO-E-K MOTOR,ZETA83-93,W/ENC & KEY
    ZETA83-93-MO-F MOTOR,ZETA83-93,W/FLAT
    ZETA83-93-MO-K MOTOR,ZETA83-93 W/STD KEYWAY
    ZETA83-93-MO-S MOTOR,ZETA83-93,SINGLE
    Nema 17
    103-546-5540 motor de passo, Nema17, 4 fios, eixo simples, 0,125 Nm
    103-546-5342 motor de passo, Nema17, 6 fios, eixo simples, 0,19 Nm
    103-547-5240 motor de passo, Nema17, 6 fios, eixo simples, 0,25 Nm
    103-547-5210 motor de passo, Nema17, 6 fios, eixo duplo, 0,25 Nm
    103-H548-0440 motor de passo, alta efici阯cia, Nema17, 6 fios, eixo simples, 0,9A, 0,37 Nm
    50 mm
    103-H6701-0140 motor de passo, alta efici阯cia, 50 mm, 6 fios, eixo simples, 0,7A, 0,38 Nm
    103-H6703-0440 motor de passo, alta efici阯cia, 50 mm, 6 fios, eixo simples, 1,4A, 0,68 Nm
    Nema 23
    103-770-6 motor de passo, Nema 23, 8 fios, eixo simples, 1,0A, 0,62 Nm
    103-770-61 motor de passo, Nema 23, 8 fios, eixo duplo, 0,62 Nm
    103-770-1640 motor de passo, Nema 23, 4 fios, eixo simples, 0,62 Nm
    103-G770-2241 motor de passo, Nema 23, 8 fios, eixo simples, 2,0A, 0,60 Nm
    103-G770-2221 motor de passo, Nema 23, 8 fios, eixo duplo, 2,0A, 0,60 Nm
    103-714-0150 motor de passo, Nema 23, 8 fios, eixo simples, 1,09 Nm
    103-714-0111 motor de passo, Nema 23, 8 fios, eixo duplo, 1,09 Nm
    103-H7123-0140 motor de passo, alta efici阯cia, Nema 23, 6 fios, eixo simples, 0,7A, 1,10 Nm
    103-H7123-0740 motor de passo, alta efici阯cia, Nema 23, 6 fios, eixo simples, 2,2A, 1,10 Nm
    103-H7123-1740 motor de passo, alta efici阯cia, Nema 23, 6 fios, eixo simples, 4A, 1,10 Nm
    103-H7123-1710 motor de passo, alta efici阯cia, Nema 23, 6 fios, eixo duplo, 4A, 1,10 Nm
    103-H7126-0140 motor de passo, alta efici阯cia, Nema 23, 6 fios, eixo simples, 0,75A, 1,65 Nm
    103-H7126-0740 motor de passo, alta efici阯cia, Nema 23, 6 fios, eixo simples, 2,2A, 1,65 Nm
    103-H7126-0710 motor de passo, alta efici阯cia, Nema 23, 6 fios, eixo duplo, 2,2A, 1,65 Nm
    103-H7126-1740 motor de passo, alta efici阯cia, Nema 23, 4 fios, eixo simples, 4A, 1,65 Nm
    103-H7126-1712 motor de passo, alta efici阯cia, Nema 23, 4 fios, eixo duplo, 4A, 1,65 Nm
    103-H7126-6640 motor de passo, alta efici阯cia, Nema 23, 4 fios, eixo simples, 5,6A, 1,65 Nm - IP43
    103-H7126-6610 motor de passo, alta efici阯cia, Nema 23, 4 fios, eixo duplo, 5,6A, 1,65 Nm - IP43
    60 mm
    103-H7823-1741 motor de passo, alta efici阯cia, 60 mm, 4 fios, eixo duplo, 4A, 3,0 Nm
    103-H7823-1711 motor de passo, alta efici阯cia, 60 mm, 4 fios, eixo simples, 4A, 3,0 Nm
    Nema 34
    103-807-6241 motor de passo, Nema 34, 8 fios, eixo simples, bpc 2,7A, 1,7 Nm - IP43
    103-807-6341 motor de passo, Nema 34, 8 fios, eixo simples, bpc 4,3A, 1,7 Nm - IP43
    103-807-6311 motor de passo, Nema 34, 8 fios, eixo duplo, bpc 4,3A, 1,7 Nm - IP43
    103-810-6 motor de passo, Nema 34, 8 fios, eixo simples, bpc 5,6A, 2,75 Nm
    103-814-6541 motor de passo, Nema 34, 8 fios, eixo simples, bpc 6,5A, 3,45 Nm - IP43
    103-814-6511 motor de passo, Nema 34, 8 fios, eixo duplo, bpc 6,5A, 3,45 Nm - IP43
    103-845-6741 motor de passo, Nema 34, 8 fios, eixo simples chaveta, bpc 9,5A, 5,1 Nm - IP43
    103-845-6711 motor de passo, Nema 34, 8 fios, eixo duplo chaveta, bpc 9,5A, 5,1 Nm - IP43
    103-845-67S1 motor de passo, Nema 34, 8 fios, eixo simples chaveta, bpc 9,5A, 5,1 Nm - IP55
    103-845-67S2 motor de passo, Nema 34, 4 fios conector, eixo simples chaveta, bpc 9,5A, 5,1 Nm - IP55
    103-845-67S3 motor de passo, Nema 34, 4 fios conector, eixo simples chaveta, bpc 4,75A, 5,1 Nm - IP55
    103-H8221-6241 motor de passo, alta efici阯cia, Nema 34, 4 fios, eixo simples chaveta, 6A, 3,0 Nm - IP43
    103-H8221-6211 motor de passo, alta efici阯cia, Nema 34, 4 fios, eixo duplo chaveta, 6A, 3,0 Nm - IP43
    103-H8222-6340 motor de passo, alta efici阯cia, Nema 34, 4 fios, eixo simples chaveta, 6A, 5,6 Nm - IP43
    103-H8222-6310 motor de passo, alta efici阯cia, Nema 34, 4 fios, eixo duplo chaveta, 6A, 5,6 Nm - IP43
    103-H8223-6540 motor de passo, alta efici阯cia, Nema 34, 4 fios, eixo simples chaveta, 9A, 7,9 Nm - IP43
    103-H8223-6510 motor de passo, alta efici阯cia, Nema 34, 4 fios, eixo duplo chaveta, 9A, 7,9 Nm - IP43
    Nema 42
    103-8932-6451 motor de passo, Nema 42, 8 fios conector, eixo simples chaveta, bpc 12,7A, 13,3 Nm - IP43
    103-8932-6421 motor de passo, Nema 42, 8 fios conector, eixo duplo chaveta, bpc 12,7A, 13,3 Nm - IP43
    103-8960-6551 motor de passo, Nema 42, 8 fios conector, eixo simples chaveta, bpc 14,1A, 20,6 Nm - IP43
    103-H89222-6541 motor de passo, alta efici阯cia, Nema 42, 4 fios, eixo simples chaveta, 10A, 16,2 Nm - IP43
    103-H89223-6641 motor de passo, alta efici阯cia, Nema 42, 4 fios, eixo simples chaveta, 12A, 24,6 Nm - IP43
    103-H89223-6611 motor de passo, alta efici阯cia, Nema 42, 4 fios, eixo duplo chaveta, 12A, 24,6 Nm - IP43
    ACESS覴IOS MOTORES DE PASSO
    E83 ENCODER,E83,34 FRAME
    OEM750 E AC
    OEM750 Drive OEM750 Microstepping Alimenta玢o 24-75VDC, 0.2-7.5A/fase
    OEM750-INTL OEM750 MICROSTEP DRIVE,INTL
    OEM750X Drive+Controlador OEM750 Microstepping Alimenta玢o 24-75VDC, 0.2-7.5A/fase
    OEM750X-INTL OEM750 INDEXER/DRIVE,-INTL
    OEM750X-M2 Drive+Controlador OEM750 Microstepping Alim. 24-75VDC, 0.2-7.5A/fase c/ RAM
    OEM750X-M2-INTL OEM750X INX/DRIVE,BBRAM,-INTL
    OEMZL6104 OEMZL6104 INDEXER DRIVE
    E-AC Drive E-AC Microstepping Alimenta玢o 95-132VCA, 0.03-3.5A/fase
    XL
    XL25 Ministep Drive 2,5A
    XL25I Ministep Drive/Indexer 2,5A
    XL25CAN Ministep Drive 5A
    XL50 Ministep Drive 5A
    XL50I Ministep Drive/Indexer 5A
    XL50CAN Ministep Drive 8A
    XL80 Ministep Drive 8A
    XL80I Ministep Drive/Indexer 8A
    XLPSU Power Supply XL ViX
    ViX STEPPER
    VIX500IM Ministep Drive/Indexer 2,5A
    VIX250CM Ministep Drive/indexer 5A CAN Open RS485
    VIX500CM Ministep Drive/Index 5A CAN Open RS485
    ZETA
    ZETA EMC KIT ZETA SERIES EMC SHIPKIT
    ZETA12 ZETA12 MICROSTEP DRIVE ONLY
    ZETA240 EMC KIT ZETA240 EMC SHIPKIT
    ZETA4 ZETA4 DRIVE ONLY
    ZETA4-240 ZETA4 240V DRIVE ONLY
    ZETA57-102 ZETA4 SYSTEM W/57-102 MOTOR
    ZETA57-102-E ZETA4 SYSTEM W/57-102,ENCODER
    ZETA57-102-S ZETA4 SYSTEM W/57-102,SINGLE
    ZETA57-51 ZETA4 SYSTEM W/57-51 MOTOR
    ZETA57-51-E ZETA4 SYSTEM W/57-51,ENCODER
    ZETA57-51-S ZETA4 SYSTEM W/57-51 SINGLE
    ZETA57-83 ZETA4 SYSTEM W/57-83 MOTOR
    ZETA57-83-E ZETA4 SYSTEM W/57-83,ENCODER
    ZETA57-83-S ZETA4 SYSTEM W/57-83,SINGLE
    ZETA6104 Drive+Controlador Zeta Microstepping Alimenta玢o 95-132VCA, 4A/fase
    ZETA6104 SHIPKIT ZETA6104 SHIPKIT
    ZETA6104-240 ZETA6104-240 INDEXER DRIVE
    ZETA6104-57-102 ZETA6104 SYSTEM,W/57-102 MOTOR
    ZETA6104-57-102-E ZETA6104 SYSTEM,W/57-102,ENC
    ZETA6104-57-102-S ZETA6104 SYSTEM,W/57-102,SNGL
    ZETA6104-57-51 ZETA6104 SYSTEM W/57-51 MOTOR
    ZETA6104-57-51-E ZETA6104 SYSTEM,W/57-51,ENC
    ZETA6104-57-51-S ZETA6104 SYSTEM,W57-51,SINGLE
    ZETA6104-57-83 ZETA6104 SYSTEM,W/57-83 MOTOR
    ZETA6104-57-83-E ZETA6104 SYSTEM,W/57-83,ENC
    ZETA6104-57-83-S ZETA6104 SYSTEM,W/57-83,SINGLE
    ZETA6104-83-135 ZETA6104 SYSTEM,W/83-135 MOTOR
    ZETA6104-83-135-E ZETA6104 SYSTEM,W/83-135,ENC
    ZETA6104-83-135-EK ZETA6104 SYSTEM,W/83-135,ENC
    ZETA6104-83-135-S ZETA6104 SYSTEM,W/83-135,SNGL
    ZETA6104-83-62 ZETA6104 SYSTEM,W/83-62 MOTOR
    ZETA6104-83-62-E ZETA6104 SYSTEM,W/83-62,ENC
    ZETA6104-83-62-S ZETA6104 SYSTEM,W/83-62,SINGLE
    ZETA6104-83-93 ZETA6104 SYSTEM,W/83-93 MOTOR
    ZETA6104-83-93-E ZETA6104 SYSTEM,W/83-93,ENC
    ZETA6104-83-93-S ZETA6104 SYSTEM,W/83-93,SINGLE
    ZETA6108 ZETA6108 8AMP INDEXER/DRIVE
    ZETA6108/12 SHPKIT SHIPKIT,ZETA6108/6112
    ZETA6112 ZETA6112 12A INDEXER/DRIVE
    ZETA8 ZETA8 MICROSTEP DRIVE ONLY
    ZETA8/12 SHIPKIT SHIPKIT,ZETA8/12 DRIVES
    ZETA83-135-E ZETA4 SYSTEM W/83-135,ENCODER
    ZETA83-135-S ZETA4 SYSTEM W/83-135,SINGLE
    ZETA83-62-E ZETA4 SYSTEM W/83-62,ENCODER
    ZETA83-62-S ZETA4 SYSTEM W/83-62,SINGLE
    ZETA83-93-E ZETA4 SYSTEM W/83-93,ENCODER
    ZETA83-93-S ZETA4 SYSTEM W/83-93,SINGLE
    ACESS覴IOS DRIVES CONTROLADORES PARA M PASSO
    M2-KIT OEM SERIES BATTERY BACKED RAM
    OEM300 OEM300 POWER MODULE
    VM24S VM24 I/O MODULE,SINGLE
    VM50 50 PIN TO SCREW BREAKOUT BOARD
    OEM-HS1 OEM DRIVE LOW CURRENT HEATSINK
    OEM-HS1-M4 OEM LOW CURRENT H/SINK,METRIC
    OEM-HS2 Dissipador de Calor para s閞ie OEM750 - Alta corrente
    OEM-HS2-M4 OEM HIGH CURRENT H/SINK,METRIC
    RP-240 Interface de Opera玢o para Zeta
    RP240 KEYPAD RP240 KEYPAD REPLACEMENT KIT
    RP-240 NEMA4 RP-240 W/NEMA 4 HOUSING
    1825-0240 Fonte de Alimenta玢o 75V p/ OEM750
    6K MOUNTING KIT 6K SERIES SHIPKIT
    6K WORKSHOP 6K SERIES WORKSHOP BINDER
    6K2 6K 2 AXIS CONTROLLER
    6K2-NK 6K 2 AXIS CONTROL,NSK
    6K4 6K 4 AXIS CONTROLLER
    6K4-NK 6K Controlador p/ 4 eixos de stepper ou servo-Doc. ?inclusa
    6K6 6K 6 AXIS CONTROLLER
    6K6-NK 6K 6 AXIS CONTROL,NSK
    6K8 6K 8 AXIS CONTROLLER
    6K8-NK 6K Controlador p/ 8 eixos de stepper ou servo-Doc. ?inclusa
    6K-KIT 6K SERIES SHIPKIT
    6KVI-LIB VIEWPOINT 6K MOTION VI LIBRARY
    ACR
    8020PCE0D2S4A000 ACR8020/PC/E0/D2/S4/A0/0/0
    8020PCE0D400AA00 ACR8020/PC/E0/D4/00/AA/0/0
    8020PCE0S200A000 ACR8020/PC/E0/S2/00/A0/0/0
    8020PCE0S200AA10 ACR8020/PC/E0/S2/00/AA/1/0
    8020PCE0S400A000 ACR8020/PC/E0/S4/00/A0/0/0
    8020PCE0S400A011 ACR8020/PC/E0/S4/00/A0/1/1
    8020PCE0S4S2A000 ACR8020/PC/E0/S4/S2/A0/0/0
    8020PCE10D4D2A810 ACR8020/PC/E10/D4/D2/A8/1/0
    8020PCE10D4D2AA00 ACR8020/PC/E10/D4/D2/AA/0/0
    8020PCE10D4D4A000 ACR8020/PC/E10/D4/D4/A0/0/0
    8020PCE10D4D4A800 ACR8020/PC/E10/D4/D4/A8/0/0
    8020PCE10D4D4A810 ACR8020/PC/E10/D4/D4/A8/1/0
    8020PCE4D200A000 ACR8020/PC/E4/D2/00/A0/0/0
    8020PCE4D200A010 ACR8020/PC/E4/D2/00/A0/1/0
    8020PCE4D200AA10 ACR8020/PC/E4/D2/00/AA/1/0
    8020PCE4D2S2A010 ACR8020/PC/E4/D2/S2/A0/1/0
    8020PCE4D2S2A800 ACR8020/PC/E4/D2/S2/A8/0/0
    8020PCE4D2S4A000 ACR8020/PC/E4/D2/S4/A0/0/0
    8020PCE4D400A000 ACR8020/PC/E4/D4/00/A0/0/0
    8020PCE4D400A010 ACR8020/PC/E4/D4/00/A0/1/0
    8020PCE4D400A800 ACR8020/PC/E4/D4/00/A8/0/0
    8020PCE4D400A810 ACR8020/PC/E4/D4/00/A8/1/0
    8020PCE4D400AA00 ACR8020/PC/E4/D4/00/AA/0/0
    8020PCE4D400AA11 ACR8020/PC/E4/D4/00/AA/1/1
    8020PCE4D4D2A010 ACR8020/PC/E4/D4/D2/A0/1/0
    8020PCE4D4D4A000 ACR8020/PC/E4/D4/D4/A0/0/0
    8020PCE4D4S2A000 ACR8020/PC/E4/D4/S2/A0/0/0
    8020PCE4D4S2A010 ACR8020/PC/E4/D4/S2/A0/1/0
    8020PCE4D4S4A800 ACR8020/PC/E4/D4/S4/A8/0/0
    8020PCE4D4S4A010 ACR8020/PC/E4/D4/S4/AA/0/0
    8020PCE4D4S4AA00 ACR8020/PC/E4/D4/S4/AA/0/0
    8020PCE4D4S4AA01 ACR8020/PC/E4/D4/S4/AA/0/1
    8020PCE4S200A000 ACR8020/PC/E4/S2/00/A0/0/0
    8020PCE4S400A000 ACR8020/PC/E4/S4/00/A0/0/0
    8020PCE4S400AA00 ACR8020/PC/E4/S4/00/AA/0/0
    8020PCE4S4S4A000 ACR8020/PC/E4/S4/S4/A0/0/0
    8020PCE5D400A001 ACR8020/PC/E5/D4/00/A0/0/1
    8020PCE5D400AA01 ACR8020/PC/E5/D4/00/AA/0/1
    8020PCE5D4D2A000 ACR8020/PC/E5/D4/D2/A0/0/0
    8020PCE5D4D2A010 ACR8020/PC/E5/D4/D2/A0/1/0
    8020PCE5D4S4A010 ACR8020/PC/E5/D4/S4/A0/1/0
    8020PCE8D2S4A800 ACR8020/PC/E8/D2/S4/A8/0/0
    8020PCE8D4D2A000 ACR8020/PC/E8/D4/D2/A0/0/0
    8020PCE8D4D2A001 ACR8020/PC/E8/D4/D2/A0/0/1
    8020PCE8D4D2AA01 ACR8020/PC/E8/D4/D2/AA/0/1
    8020PCE8D4D4A000 ACR8020/PC/E8/D4/D4/A0/0/0
    8020PCE8D4D4A010 ACR8020/PC/E8/D4/D4/A0/1/0
    8020PCE8D4D4A800 ACR8020/PC/E8/D4/D4/A8/0/0
    8020PCE8D4D4AA00 ACR8020/PC/E8/D4/D4/AA/0/0
    8020PCE8D4S2A800 ACR8020/PC/E8/D4/S2/A8/0/0
    8020PCE8S400A000 ACR8020/PC/E8/S4/00/A0/0/0
    8020PCE8S4S2A000 ACR8020/PC/E8/S4/S2/A0/0/0
    8020PCX00AAAA0000 ACR8020/PCX/00/AA/AA/00/0/0
    8020PCX40AA480010 ACR8020/PCX/40/AA/48/00/1/0
    8020PCX50AAA00010 ACR8020/PCX/50/AA/A0/00/1/0
    8020PCX50AAA40010 ACR8020/PCX/50/AA/A4/00/1/0
    8020PCX8040408810 ACR8020/PCX/80/40/40/88/1/0
    8020PCX8444400001 ACR8020/PCX/84/44/40/00/0/1
    8020PCX84A8A20001 ACR8020/PCX/84/A8/A2/00/0/1
    8020PCX8844440000 ACR8020/PCX/88/44/44/00/0/0
    8020PCXA04000AA01 ACR8020/PCX/A0/40/00/AA/0/1
    8020PCXA844440000 ACR8020/PCX/A8/44/44/00/0/0
    8020PCXA844448800 ACR8020/PCX/A8/44/44/88/0/0
    8020PSE10D4S4AA00 ACR8020/PS/E10/D4/S4/AA/0/0
    8020PSE4D200A000 ACR8020/PS/E4/D2/00/A0/0/0
    8020PSE4D2S4AA10 ACR8020/PS/E4/D2/S4/AA/1/0
    8020PSE4D400A000 ACR8020/PS/E4/D4/00/A0/0/0
    8020PSE4D400A800 ACR8020/PS/E4/D4/00/A8/0/0
    8020PSE4D4S2A010 ACR8020/PS/E4/D4/S2/A0/1/0
    8020PSE4D4S4A800 ACR8020/PS/E4/D4/S4/A8/0/0
    8020PSE4D4S4AA00 ACR8020/PS/E4/D4/S4/AA/0/0
    8020PSE8D2S4A800 ACR8020/PS/E8/D2/S4/A8/0/0
    8020PSE8D400A810 ACR8020/PS/E8/D4/00/A8/1/0
    8020PSE8D4D4A000 ACR8020/PS/E8/D4/D4/A0/0/0
    8020PSE8D4D4A010 ACR8020/PS/D4/D4/A0/1/0
    8020PSE8D4D4A800 ACR8020/PS/E8/D4/D4/A8/0/0
    8020PSE8D4D4AA10 ACR8020/PS/E8/D4/D4/AA/1/0
    8020PSE8S4S4A000 ACR8020/PS/E8/S4/S4/A0/0/0
    8020PSX40AA480010 ACR8020/PSX/40/AA/48/00/1/0
    8020PSX8444400000 ACR8020/PSX/84/44/40/00/0/0
    8020PSX884444A011 ACR8020/PSX/88/44/44/A0/1/1
    8020PCX5544200001
    1505PCE0S400A000 ACR1505/PC/E0/S4/00/A0/0/0
    1505PCE0S400A800 ACR1505/PC/E0/S4/00/A8/0/0
    1505PCE0S400AA00 ACR1505/PC/E0/S4/00/AA/0/0
    1505PCE4D2S2A000 ACR1505/PC/E4/D2/S2/A0/0/0
    1505PCE4D2S2A800 ACR1505/PC/E4/D2/S2/A8/0/0
    1505PCE4D2S2AA00 ACR1505/PC/E4/D2/S2/AA/0/0
    1505PCE4D400A000 ACR1505/PC/E4/D4/00/A0/0/0
    1505PCE4D400A800 ACR1505/PC/E4/D4/00/A8/0/0
    1505PCE4D400AA00 ACR1505/PC/E4/D4/00/AA/0/0
    1505PCE4S400A000 ACR1505/PC/E4/S4/00/A0/0/0
    1505PCE4S400A000-D ACR1505/PC/E4/S4/00/A0/0/0
    1505PCE4S400A800 ACR1505/PC/E4/S4/00/A8/0/0
    1505PCE4S400AA00 ACR1505/PC/E4/S4/00/AA/0/0
    1505PSE0S400A000 ACR1505/PS/E0/S4/00/A0/0/0
    1505PSE0S400A800 ACR1505/PS/E0/S4/00/A8/0/0
    1505PSE0S400AA00 ACR1505/PS/E0/S4/00/AA/0/0
    1505PSE4D2S2A000 ACR1505/PS/E4/D2/S2/A0/0/0
    1505PSE4D2S2A800 ACR1505/PS/E4/D2/S2/A8/0/0
    1505PSE4D2S2AA00 ACR1505/PS/E4/D2/S2/AA/0/0
    1505PSE4D400A000 ACR1505/PS/E4/D4/00/A0/0/0
    1505PSE4D400A800 ACR1505/PS/E4/D4/00/A8/0/0
    1505PSE4D400AA00 ACR1505/PS/E4/D4/00/AA/0/0
    1505PSE4S400A000 ACR1505/PS/E4/S4/00/A0/0/0
    1505PSE4S400A800 ACR1505/PS/E4/S4/00/A8/0/0
    1505PSE4S400AA00 ACR1505/PS/E4/S4/00/AA/0/0
    9000P0U2M0 ACR9000/P0/U2/M0
    9000P0U4M0 ACR9000/P0/U4/M0
    9000P0U6M0 ACR9000/P0/U6/M0
    9000P0U8M0 ACR9000/P0/U8/M0
    9000P1U2M0 ACR9000/P1/U2/M0 CONTROL
    9000P1U4M0 ACR9000/P1/U4/M0 CONTROL
    9000P1U6M0 ACR9000/P1/U6/M0 CONTROL
    9000P1U8M0 ACR9000/P1/U8/M0 CONTROL
    9000P2U2M0 ACR9000/P2/U2/M0
    9000P2U4M0 ACR9000/P2/U4/M0
    9000P2U6M0 ACR9000/P2/U6/M0
    9000P2U8M0 ACR9000/P2/U8/M0
    9000P3U2M0 ACR9000/P3/U2/M0 CONTROL
    9000P3U4M0 ACR9000/P3/U4/M0 CONTROL
    9000P3U6M0 ACR9000/P3/U6/M0 CONTROL
    9000P3U8M0 ACR9000/P3/U8/M0 CONTROL
    ACESS覴IOS ACROLOOP
    RBC1505-03 ACR1505 BREAKOUT BOX
    RBC8404-03 Caixa de conex鉶 p/ 4 eixos ACR8020 c/ cabo 90cm
    RBC8404-06 Caixa de conex鉶 p/ 4 eixos ACR8020 c/ cabo 1,8m
    RBC8408-03 Caixa de conex鉶 p/ 8 eixos ACR8020 c/ cabo 90cm
    RBC8408-06 Caixa de conex鉶 p/ 8 eixos ACR8020 c/ cabo 1,8m
    RBC8408-BO-06 Caixa de conex鉶 p/ 8 eixos sem cabos
    71-021107-04 Cabo,RBC-DYNASERV,1,2m
    71-021107-10 Cabo,RBC-DYNASERV,10 FT
    71-021108-04 Cabo,RBC-COMPAX,1,2m
    71-021108-10 Cabo,RBC-COMPAX,3m
    71-021110-04 Cabo,RBC-VIX DRIVE,1,2m
    71-021110-10 Cabo,RBC-VIX DRIVE,10 FT
    71-021113-04 Cabo,RBC-STEPPER DRIVE,1,2m
    71-021113-10 Cabo,RBC-STEPPER DRIVE,3m
    71-021599-04 Cabo,ARIES-RBC,1,2m
    71-021599-10 Cabo,ARIES-RBC,10 FT
    SBD08202 2 AXIS DAC
    SBD08204 4 AXIS DAC
    SBD0872-SP1 2 AXIS STEPPER
    SBD0874-SP1 4 AXIS STEPPER
    SBD083 12-BIT ANALOG INPUTS (8)
    SBD07900 16-BIT ANALOG INPUTS (8)
    SOFTWARE ACROLOOP
    ACR-MotionMax1 Software front-end CNC para placa ACR n韛el 1
    ACR-MotionMax2 Software front-end CNC para placa ACR n韛el 2
    ACR-MotionMax3 Software front-end CNC para placa ACR n韛el 3
    ACESS覴IOS 6K
    71-016137-10 CABLE,INX/DRIVE,EMC,10 FT
    71-011468-05 Cabo,AT6450 ADAPTER
    71-013016-01 Cabo,I/O,50PIN,VM50
    71-016999-02 Cabo,VM25 I/O MODULE,2 FT
    71-017003-10 Cabo,6K TO SERVO (CUTOFF),10'
    71-017635-01 Cabo,ETHERNET,X-OVER,RJ45,5FT
    71-017711-10 Cabo,MOTOR,R/T SERIES,LVD,14G
    71-018382-01 Cabo,ENCODER TO 6K,25P-9P
    RP-240 OPERATOR INTERFACE
    SIM8-4X4 VM 4IN/4OUT(GREEN)SIM MODULE
    SIM8-AN-IN EVM32 8 BIT ANALOG INPUT GREEN
    SIM8-AN-OUT MODULE,SIM,8 OUTPUT,ANALOG
    SIM8-IN-EVM32 MODULE,SIM,8 INPUT,EVM32
    SIM8-IN-VM24 MODULE,SIM,8 INPUT,VM24
    SIM8-OUT VM 8 OUTPUT (BLUE) SIM MODULE
    SIM8-OUT-NPN MODULE,SIM,8 OUTPUT,NPN
    SIM8-OUT-PNP MODULE,SIM,8 OUTPUT,PNP
    SIM8-OUT-SSR MODULE,SIM,8 OUTPUT,RELAY
    EVM32-II EVM32-II BASE BOARD
    VM24-BASE1 VM SERIES BASE MODULE,STD
    VM24-BASE2 VM SERIES BASE MODULE,SPLIT
    VM24IN VM24 I/O MODULE,24 INPUT
    VM24OUT VM24 I/O MODULE,24 OUTPUT
    VM25 25 PIN TO SCREW BREAKOUT BOARD
    SOFTWARE
    COMPUCAM-VPAK Soft. Convers鉶 DXF - Linguagem 6000
    MA SERVO TUNER MOTION ARCHITECT SERVO TUNER
    MOTION OCX MOTION OCX TOOLKIT
    MOTION PLANNER MOTION PLANNER
    MTBX-WIN
    DYNASERV
    DMG3-1030B-230B DYNASERV GERA敲O 3
    OUTROS
    VM15-PF MODULE,15P,VIX I/O CONN
    71-021625-10 CABLE,CMD,6K-COMPAX3,10 FT
    71-018234-25 CABLE,MOTOR,610-630,GEM,25 FT
    71-019863-04 CABO GEMINI PARA 6K STEP&DIR
    71-016987-10 CABLE,GEM,ANALOG,COMMAND
    71-018311-25 CABLE,RESOLVER/BRAKE,GEM,25FT
    OEM770X OEM770X INDEXER/SERVO DRIVE
    OEM770T OEM770T TORQUE SERVO DRIVE
    GEM-VM50 GEMINI VM50 B/OUT MODULE,W CBL
    GC-50 CONN,GEMINI,50P,W/TERMINALS
    GC-26 CONN,GEMINI,26P,W/TERMINALS
    71-016945-03 CABLE,GEMINI,DRIVE I/O,50/50
    GFB-KIT KIT,GEMINI CONNECTORS
    IE233 Motor de Passo+drive
    445114-04 EDC-200
    SD12 Drive para motor de passo
    SD12/100 Drive para motor de passo
    SD13 Drive para motor de passo
    SD13/VGLI Drive para motor de passo
    SD15 Drive para motor de passo
    SD15/100 Drive para motor de passo
    SD15/VGLI Drive para motor de passo
    SD15-D Drive para motor de passo
    SD15M/100 Drive para motor de passo
    SD15/M Drive para motor de passo
    SDMBKIT Drive para motor de passo
    SD15/CP0097 Drive para motor de passo
    SD15M-D Drive para motor de passo
    PDFX13 Drive para motor de passo
    PDFX15 Drive para motor de passo
    PDFX15-D Drive para motor de passo
    PDS13-2 Drive para motor de passo
    PDS13-2/USA Drive para motor de passo
    PDS15-2 Drive para motor de passo
    PDS15-2/USA Drive para motor de passo
    PDS15-D-2 Drive para motor de passo
    PDS15-D-2/USA Drive para motor de passo
    PDS13E Drive para motor de passo
    PDS15E Drive para motor de passo
    PDS15E-D Drive para motor de passo
    MPA-06 Servo Amplificador
    000001/A PLATENS,M20,SOLID,"Y"
    000083/B PLATEN,M20 TUBE,"X"
    001649/C M20 LEFT Y FORCER
    001650/C M20 RIGHT Y FORCER
    001651/C M20 X FORCER
    01-010885-01 POWER SUPPLY,PMC30E-2,+5,+/-15
    01-012138-01 DISPLAY,RP240,LCD
    01-012157-01 KEYPAD,RP-240 INTERFACE
    01-016986-01 PUR ASSY,50PIN,GEMINI,BRKT OUT
    105GR CABLE-10 CABLE KIT,105GR,GEM RES,10 FT
    105GR CABLE-25 CABLE KIT,105GR,GEM RES,25 FT
    105GS CABLE-10 CABLE KIT,105GS,GEM ENC,10 FT
    105GS CABLE-25 CABLE KIT,105GS,GEM ENC,25 FT
    145GR CABLE-10 CABLE KIT,145GR,GEM RES,10 FT
    145GR CABLE-25 CABLE KIT,145GR,GEM RES,25 FT
    145GS CABLE-10 CABLE KIT,145GS,GEM ENC,10 FT
    145GS CABLE-25 CABLE KIT,145GS,GEM ENC,25 FT
    15D KIT 15D CONNECTOR KIT
    1811-B-123 1811-123 NOVELLUS
    1811-B-124 1811-124 NOVELLUS
    1811-B-125 1811-125 NOVELLUS
    1811-B-KIT 1811 KIT NOVELLUS
    205GP CABLE-10 CABLE KIT,205GP,PT,RES GEM,10'
    205GP CABLE-25 CABLE KIT,205GP,PT,GEM RES,25'
    205GR CABLE-10 CABLE KIT,205GR,GEM RES,10 FT
    205GR CABLE-25 CABLE KIT,205GR,GEM RES,25 FT
    205GS CABLE-10 CABLE KIT,205GS,GEM ENC,10 FT
    205GS CABLE-25 CABLE KIT,205GS,GEM ENC,25 FT
    23CX CABLE-10 CABLE KIT,23CX,COMPAX,10FT
    23CX CABLE-25 CABLE KIT,23 CX,COMPAX,25 FT
    23CX CABLE-35 CABLE KIT,23 CX,COMPAX,35 FT
    23GB CABLE-05 CABLE KIT,23 GB,5 FT
    23GB CABLE-10 CABLE KIT,23 GB,10 FT,W/BRK
    23GB CABLE-100 CABLE KIT,23 GB,100 FT
    23GB CABLE-15 CABLE KIT,23 GB,15 FT
    23GB CABLE-20 CABLE KIT,23 GB,20 FT
    23GB CABLE-25 CABLE KIT,23 GB,25 FT,W/BRK
    23GB CABLE-30 CABLE KIT,23 GB,30 FT
    23GB CABLE-35 CABLE KIT,23 GB,35 FT,W/BRK
    23GB CABLE-40 CABLE KIT,23 GB,40 FT
    23GB CABLE-45 CABLE KIT,23 GB,45 FT
    23GB CABLE-50 CABLE KIT,23 GB,50 FT
    23GB CABLE-60 CABLE KIT,23 GB,60 FT
    23GB CABLE-70 CABLE KIT,23 GB,70 FT
    23GB CABLE-80 CABLE KIT,23 GB,80 FT
    23GB CABLE-90 CABLE KIT,23 GB,90 FT
    23GR CABLE-05 CABLE KIT,23 RES,GEM,5 FT
    23GR CABLE-10 CABLE KIT,23 RES,GEM,10 FT
    23GR CABLE-100 CABLE KIT,23 RES,GEM,100 FT
    23GR CABLE-15 CABLE KIT,23 RES,GEM,15 FT
    23GR CABLE-20 CABLE KIT,23 RES,GEM,20 FT
    23GR CABLE-25 CABLE KIT,23 RES,GEM,25 FT
    23GR CABLE-30 CABLE KIT,23 RES,GEM,30 FT
    23GR CABLE-35 CABLE KIT,23 RES,GEM,35 FT
    23GR CABLE-40 CABLE KIT,23 RES,GEM,40 FT
    23GR CABLE-45 CABLE KIT,23 RES,GEM,45 FT
    23GR CABLE-50 CABLE KIT,23 RES,GEM,50 FT
    23GR CABLE-60 CABLE KIT,23 RES,GEM,60 FT
    23GR CABLE-70 CABLE KIT,23 RES,GEM,70 FT
    23GR CABLE-80 CABLE KIT,23 RES,GEM,80 FT
    23GR CABLE-90 CABLE KIT,23 RES,GEM,90 FT
    23GS CABLE-05 CABLE KIT,23 GS,5 FT
    23GS CABLE-10 CABLE KIT,GS 23,10 FT
    23GS CABLE-100 CABLE KIT,23 GS,100 FT
    23GS CABLE-15 CABLE KIT,23 GS,15 FT
    23GS CABLE-20 CABLE KIT,23 GS,20 FT
    23GS CABLE-25 CABLE KIT,23 GS,25 FT
    23GS CABLE-30 CABLE KIT,23 GS,30 FT
    23GS CABLE-35 CABLE KIT,23 GS,35 FT
    23GS CABLE-40 CABLE KIT,23 GS,40 FT
    23GS CABLE-45 CABLE KIT,23 GS,45 FT
    23GS CABLE-50 CABLE KIT,23 GS,50 FT
    23GS CABLE-60 CABLE KIT,23 GS,60 FT
    23GS CABLE-70 CABLE KIT,23 GS,70 FT
    23GS CABLE-80 CABLE KIT,23 GS,80 FT
    23GS CABLE-90 CABLE KIT,23 GS,90 FT
    23MS CABLE-10 CABLE KIT,MS,10 FT,SIZE 23
    23MS CABLE-25 CABLE KIT,MS,25 FT,SIZE 23
    23MS CABLE-35 CABLE KIT,MS,35 FT,SIZE 23
    23MS-CONN CONNECTOR KIT,MS,SIZE 23,SERVO
    23RS CABLE-10 CABLE KIT,RESOLVER,10 FT
    23RS CABLE-25 CABLE KIT,RESOLVER,25 FT
    23RS CABLE-35 CABLE KIT,23 RS MOTOR,35 FT
    23RS CABLE-50 CABLE KIT,23 RS MOTOR,50 FT
    23TQ CABLE-10 CABLE KIT,TQ/MS,10 FT
    23TQ CABLE-25 CABLE KIT,TQ/MS,25 FT
    23TQ CABLE-35 CABLE KIT,TQ/MS,35 FT
    32-006228-02 SS,CMOS,GATE ARRAY,CUST (DIP)
    34CX CABLE-10 CABLE KIT,34 CX,COMPAX,10 FT
    34CX CABLE-25 CABLE KIT,34 CX,COMPAX,25 FT
    34CX CABLE-35 CABLE KIT,34 CX,COMPAX,35 FT
    4000 WORKSHOP MODEL 4000 WORKSHOP
    41-011690-02 MOTOR,S106-250,NO CABLE
    42-010357-01 THUBMWHEEL SWITCH,1-9,BCD
    43-005560-01 PHOENIX CONNECTOR
    43-005561-01 CONNECTOR
    43-005987-01 PHOENIX CONNECTOR
    43-006606-01 TERMINAL CONNECTOR
    43-006786-01 PHOENIX CONNECTOR
    43-007478-01 13 PIN PHN CONN
    43-007483-01 8 PIN PHOENIX CONN
    43-007484-01 CONN,12P,PLUG,BLACK
    43-008755-01 CONN,9P,PHNX,PLUG,BLACK
    43-008885-01 CONN,11P,PLUG,BLACK
    43-009055-01 CONN,3P,PLUG,BLACK
    43-010668-01 TERM BLOCK,8PIN,5MM
    43-011859-01 CONN,50P, PLUG, HONDA
    43-013264-01 TERM BLK,5P,PHNX,3.81MM PITCH
    43-013573-01 CONN,4P,PHNX,PLUG,.300,20A
    43-013575-01 CONN,7P,PHNX,PLUG,.300,20A
    43-013801-01 CONN,7P,PLUG,CURVED,BLK
    43-013802-01 CONN,13P,PLUG,CURVED,BLK
    43-013891-01 CONNECTOR,MATING,OEM -RC
    43-013969-01 CONN,4P,PLUG,3.5MM
    43-014298-01 CONN,5P,.295,PLUG,EURO,BLK
    43-014340-01 CONN,ENCODER,MS,14-18,SIZE 23
    43-014341-01 CONN,MS,PT06E-14-18,PLUG
    43-014451-01 CONN,12P,MS,MATE,MOTOR
    43-014452-01 CONN,12P,MS,SOC,23 MOTOR
    43-014533-01 CONN,8P,PLUG,.300,20A
    43-014707-01 CONN,5P,PLUG,3.5MM
    43-014708-01 CONN,9P,PLUG,3.5MM
    43-015833-01 CONN,PT02E-185PBOX-CONNECTOR
    43-015834-01 CONN,92 MS,MATING,PT06E-185SSR
    43-015858-01 CONN,PT06E-14/19 PSR
    43-016653-01 CONN,PT01 14-185 SOLDER
    43-017077-01 CONN,20PIN,SOCKET,YPC
    43-017078-01 CONN,20PIN,PLUG,YPC
    43-017079-01 CONN,50 PIN,SOCKET,YPC
    43-017080-01 CONN,50PIN,PLUG,YPC
    43-018500-01 CONN,8P,PLUG,HONDA
    44-000054-01 AC POWER CABLE
    44-007765-01 CABLE
    44-011061-01 WIRE,JUMPER,22AWG,.2",YELLOW
    44-014432-01 SPOOL CABLE,MOTOR,NM92,500 FT
    44-014768-01 AC POWER CABLE,RIGHT ANGLE
    44-015032-01 SPOOL SM23 TQ ENCODER CABLE,500 FT
    44-015224-01 SPOOL SM23 TQ MOTOR CABLE,500 FT
    44-015240-01 SPOOL SM23 MS MOTOR CABLE,500 FT
    44-015837-01 SPOOL CABLE,17COND,24AWG,BRAKE 500FT
    44-017144-SPOOL CABLE,MOK6,100 METER SPOOL
    44-017145-SPOOL CABLE,MOK21,100 METER SPOOL
    44-017146-SPOOL CABLE,MOK11,100 METER SPOOL
    44-017147-SPOOL CABLE,REK14,100 METER SPOOL
    47-015956-01 FERRITE,SPLIT ROUND,0.5"ID
    47-016140-01 FILTER,10A,250VAC,1 PHASE
    47-017900-01 FILTER,16A,250VAC,1 PHASE,EMC
    53-006555-01 BOTTOM COVER,PC-23
    53-006672-01 CONN MTG BRACKET,PC-23
    53-006886-01 BRACKET,CBL,SECURING,PC-23
    53-010704-01 DISPLAY STAND, 4000
    53-017355-01 MEC,SM,CLAMP,MTR SHIELD,GEM
    54-014545-12 MEC,MACH,ORIFICE,LINEAR MOTOR
    54-014580-01 MEC,INSULATOR,CROWN,RESOLVER
    54-017382-01 MEC,MACH,HS,GEM,1.0",SHORT
    58-004319-01 BRACKET,PC-21
    58-007759-01 BEARING,.187 X .50,L-20
    58-011555-01 9PIN RUBBER BOOT
    58-013465-01 MEC,THERMASTRATE,46558801
    58-014831-01 BOOT,7POS,.300,PHOENIX
    58-015578-01 SEAL,SHAFT,NEO SIZES
    58-016050-01 MEC,HDW,R-CLAMP (P-CLIP),5/16
    6000 GEN WORKSHOP 6000 GENERAL WORKSHOP BINDER
    6000 WORKSHOP 6000 SERIES WORKSHOP BINDER
    605GR CABLE-10 CABLE KIT,GEMINI,605,10 FT
    605GR CABLE-25 CABLE KIT,GEMINI,605,25 FT
    605GR CABLE-35 CABLE KIT,GEMINI,605,35 FT
    606GR CABLE-10 CABLE KIT,GEMINI,606,10 FT
    606GR CABLE-25 CABLE KIT,GEMINI,606,25 FT
    606GR CABLE-35 CABLE KIT,GEMINI,606,35 FT
    610GR CABLE-10 CABLE KIT,GEMINI,610 MTR,10 FT
    610GR CABLE-25 CABLE KIT,GEMINI,610 MTR,25 FT
    610GR CABLE-35 CABLE KIT,GEMINI,610 MTR,35 FT
    615GR CABLE-10 CABLE KIT,GEMINI,615 MTR,10 FT
    615GR CABLE-25 CABLE KIT,GEMINI,615 MTR,25 FT
    615GR CABLE-35 CABLE KIT,GEMINI,615 MTR,35 FT
    6200 6200 INDEXER
    620GR CABLE-10 CABLE KIT,GEMINI,620 MTR,10 FT
    620GR CABLE-25 CABLE KIT,GEMINI,620 MTR,25 FT
    620GR CABLE-35 CABLE KIT,GEMINI,620 MTR,35 FT
    6250 6250 2 AXIS SERVO CONTROLLER
    6250 SHIPKIT SHIPKIT,6250 CONTROLLER
    6250-ANI 6250 2 AXIS SERVO CONTROL,-ANI
    6270-ANI-R 6270 2 AXIS HYD CONTRL,-ANI,-R
    630GR CABLE-10 CABLE KIT,GEMINI,630 MTR,10 FT
    630GR CABLE-25 CABLE KIT,GEMINI,630 MTR,25 FT
    630GR CABLE-35 CABLE KIT,GEMINI,630 MTR,35 FT
    635GR CABLE-10 CABLE KIT,GEMINI,635 MTR,10 FT
    635GR CABLE-25 CABLE KIT,GEMINI,635 MTR,25 FT
    635GR CABLE-35 CABLE KIT,GEMINI,635 MTR,35 FT
    640GR CABLE-10 CABLE KIT,GEMINI,640 MTR,10 FT
    640GR CABLE-25 CABLE KIT,GEMINI,640 MTR,25 FT
    640GR CABLE-35 CABLE KIT,GEMINI,640 MTR,35 FT
    6K2-DN 6K2 AXIS CONTROL,DEVICENET
    6K2-DN-NK 6K2 AXIS CONTROL,DEVICENET,-NK
    6K2-NK-R 6K 2 AXIS CONTROL,NO KIT,REFUR
    6K2-PB 6K2 AXIS CONTROL,PROFIBUS
    6K2-PB-NK 6K2 AXIS CONTROL,PROFIBUS,-NK
    6K4-DN 6K4 AXIS CONTROL,DEVICENET
    6K4-DN-NK 6K4 AXIS CONTROL,DEVICENET,-NK
    6K4-NK 6K 4 AXIS CONTROL,NSK
    6K4-NK-R 6K 4 AXIS SERVO CONTROL,-REFUR
    6K4-PB 6K4 AXIS CONTROL,PROFIBUS
    6K4-PB-NK 6K4 AXIS CONTROL,PROFIBUS,-NK
    6K6-DN 6K6 AXIS CONTROL,DEVICENET
    6K6-DN-NK 6K6 AXIS CONTROL,DEVICENET,-NK
    6K6-PB 6K 6 AXIS CONTROLLER W/PROFI
    6K6-PB-NK 6K6 AXIS CONTROL,PROFIBUS,-NK
    6K8-DN 6K8 AXIS CONTROL,DEVICENET
    6K8-DN-NK 6K8 AXIS CONTROL,DEVICENET,-NK
    6K8-NK 6K 8 AXIS CONTROL,NSK
    6K8-NK-R 6K 8 AXIS CONTROL,NO KIT,-REF
    6K8-PB 6K8 AXIS CONTROL,PROFIBUS
    6K8-PB-NK 6K8 AXIS CONTROL,PROFIBUS,-NK
    70CX CABLE-10 CABLE KIT,70 CX,COMPAX,10 FT
    70CX CABLE-25 CABLE KIT,70 CX,COMPAX,25 FT
    70CX CABLE-35 CABLE KIT,70 CX,COMPAX,35 FT
    70GB CABLE-05 CABLE KIT,70 GB,5 FT
    70GB CABLE-10 CABLE KIT,70 GB,10 FT,W/BRK
    70GB CABLE-100 CABLE KIT,70 GB,100 FT
    70GB CABLE-15 CABLE KIT,70 GB,15 FT
    70GB CABLE-20 CABLE KIT,70 GB,20 FT
    70GB CABLE-25 CABLE KIT,70 GB,25 FT,W/BRK
    70GB CABLE-30 CABLE KIT,70 GB,30 FT
    70GB CABLE-35 CABLE KIT,70 GB,35 FT,W/BRK
    70GB CABLE-40 CABLE KIT,70 GB,40 FT
    70GB CABLE-45 CABLE KIT,70 GB,45 FT
    70GB CABLE-50 CABLE KIT,70 GB,50 FT
    70GB CABLE-60 CABLE KIT,70 GB,60 FT
    70GB CABLE-70 CABLE KIT,70 GB,70 FT
    70GB CABLE-80 CABLE KIT,70 GB,80 FT
    70GB CABLE-90 CABLE KIT,70 GB,90 FT
    70GR CABLE-05 CABLE KIT,70 RES,GEM,5 FT
    70GR CABLE-10 CABLE KIT,70 RES,GEM,10 FT
    70GR CABLE-100 CABLE KIT,70 RES,GEM,100 FT
    70GR CABLE-15 CABLE KIT,70 RES,GEM,15 FT
    70GR CABLE-20 CABLE KIT,70 RES,GEM,20 FT
    70GR CABLE-25 CABLE KIT,70 RES,GEM,25 FT
    70GR CABLE-30 CABLE KIT,70 RES,GEM,30 FT
    70GR CABLE-35 CABLE KIT,70 RES,GEM,35 FT
    70GR CABLE-40 CABLE KIT,70 RES,GEM,40 FT
    70GR CABLE-45 CABLE KIT,70 RES,GEM,45 FT
    70GR CABLE-50 CABLE KIT,70 RES,GEM,50 FT
    70GR CABLE-60 CABLE KIT,70 RES,GEM,60 FT
    70GR CABLE-70 CABLE KIT,70 RES,GEM,70 FT
    70GR CABLE-80 CABLE KIT,70 RES,GEM,80 FT
    70GR CABLE-90 CABLE KIT,70 RES,GEM,90 FT
    70GS CABLE-05 CABLE KIT,70 GS,5 FT
    70GS CABLE-10 CABLE KIT,70 GS,10 FT
    70GS CABLE-100 CABLE KIT,70 GS,100 FT
    70GS CABLE-15 CABLE KIT,70 GS,15 FT
    70GS CABLE-20 CABLE KIT,70 GS,20 FT
    70GS CABLE-25 CABLE KIT,70 GS,25 FT
    70GS CABLE-30 CABLE KIT,70 GS,30 FT
    70GS CABLE-35 CABLE KIT,70 GS,35 FT
    70GS CABLE-40 CABLE KIT,70 GS,40 FT
    70GS CABLE-45 CABLE KIT,70 GS,45 FT
    70GS CABLE-50 CABLE KIT,70 GS,50 FT
    70GS CABLE-60 CABLE KIT,70 GS,60 FT
    70GS CABLE-70 CABLE KIT,70 GS,70 FT
    70GS CABLE-80 CABLE KIT,70 GS,80 FT
    70GS CABLE-90 CABLE KIT,70 GS,90 FT
    70MS CABLE-10 CABLE KIT,MS CONN,SIZE70,10 FT
    70MS CABLE-25 CABLE KIT,MS CONN,SIZE70,25 FT
    70MS CABLE-35 CABLE KIT,70 MS MOTOR,35 FT
    70RS CABLE-10 CABLE KIT,RESOLVER,10 FT,70
    70RS CABLE-25 CABLE KIT,RESOLVER,70 FR,25 FT
    70RS CABLE-35 CABLE KIT,70 RS MOTOR,35 FT
    70RS CABLE-50 CABLE KIT,70 RS MOTOR,50 FT
    70TQ CABLE-10 CABLE KIT,TQ MOTOR,10 FOOT
    70TQ CABLE-25 CABLE KIT,TQ MOTOR,25 FOOT
    70TQ CABLE-35 CABLE KIT,TQ MOTOR,35 FT
    71-002490-01 CABLE/25 PIN D TO FLAT
    71-003913-40 SEE CUSTOM PRODUCTS GROUP
    71-003913-50 SEE CUSTOM PRODUCTS GROUP
    71-004210-01 POWER SUPPLY ASSY. CABLE
    71-004921-10 IND/DRIVE, 25D CABLE
    71-005692-03 REPAIR USE ONLY - CX PCA
    71-006085-03 PCA,PC23 MAIN BOARD
    71-006457-03 PC-23 ADAPTER BOARD
    71-006706-02 CABLE,PC23 ADAPTOR,KEYED
    71-007566-10 CABLE,25P,INDEX TO DRIVE
    71-008024-12 L20 MOTOR CABLE TO DRIVE
    71-010432-10 15D-25D DRIVE CBL,FOR 3-4 AXIS
    71-010635-12 CABLE,L20 ACCELEROMETER,12 FT
    71-011468-05 CABLE,AT6450 ADAPTER
    71-011468-15 CABLE,AT6450,80 PIN,ADPT
    71-011858-01 ADAPT CABLE,DYNASERV
    71-012139-10 MOTOR CABLE,S106-250
    71-012234-01 CABLE,50 TO 50 PIN,DYNASERV
    71-012832-05 AT6400 ADAPTER CABLE,5 FT
    71-012832-15 CABLE,AT6400 ADAPTER,15 FOOT
    71-012985-10 DYNASERV TO INDEXER CABLE
    71-013016-01 CABLE,I/O,50PIN,VM50
    71-013099-01 CABLE,OEM MOTOR,23 FRAME
    71-013448-03 OEM670X CONTROLLER BOARD ONLY
    71-014536-10 CABLE,DYNASERV TO 6000 SERVO
    71-014675-10 CABLE,MS 14-12,MTR,PLUG,10 FT
    71-014675-25 CABLE,MS 14-12,MTR,PLUG,25 FT
    71-014675-50 CABLE,MS14-12,MTR,PLUG,50',23
    71-014927-10 CABLE,MOTOR,S106-250,7P
    71-015017-10 CABLE,TQ,MS14-12,MTR/HALL,10'
    71-015017-25 CABLE,TQ,MOTOR,25 FT
    71-015017-35 CABLE,TQ MOTOR,35 FT
    71-015155-01 CABLE,FLYING,COMTRAC,16/23
    71-015158-01 CABLE,TQ,MS14-18,COMTRAC,23
    71-015531-10 CABLE,MS14-12,MTR,PLUG,10 FT
    71-015531-25 CABLE,MS14-12,MTR,PLUG,25 FT
    71-015531-35 CABLE,MS14-12,MTR,PLUG,35',70
    71-015531-50 CABLE,MS14-12,MTR,PLUG,50',70
    71-015532-10 CABLE,MS18-5,MTR,PLUG,10FT,92
    71-015532-25 CABLE,MS18-5,MOTOR,MS,92,25 FT
    71-015532-35 CABLE,MS14-12,MTR,PLUG,35',92
    71-015532-50 CABLE,MS14-12,MTR,PLUG,50',92
    71-015821-01 CABLE,VM16X8,3 CONN
    71-015870-10 CABLE,RESOL,BRAKE,MS14-18,10'
    71-015870-25 CABLE,RESOL,BRAKE,MS14-18,25'
    71-015870-35 CABLE,RESOL,BRAKE,MS14-18,35FT
    71-015870-50 CABLE,RES,BRK,MS14-18,50'
    71-015871-10 CABLE,ENC,BRAKE,MS14-18,10 FT
    71-015871-25 CABLE,ENC,BRAKE,MS14-18,25 FT
    71-015871-35 CABLE,ENC,BRAKE,MS14-18,35 FT
    71-015886-10 CABLE,TQ,ENCODER,NEO
    71-015886-25 CABLE,TQ,ENCODER,NEO,25 FT
    71-015886-35 CABLE,TQ,ENCODER,NEO
    71-016022-10 CABLE,MS14-18,FLEXIBLE,10 FT
    71-016022-25 CABLE,MS14-18,FLEXIBLE,25 FT
    71-016022-35 CABLE,MS14-18,FLEXIBLE,35 FT
    71-016022-50 CABLE,MS14-18,FLEXIBLE,50 FT
    71-016023-10 CABLE,MS14-12,FLEXIBLE,10 FT
    71-016023-25 CABLE,MS14-12,FLEXIBLE,25 FT
    71-016023-35 CABLE,MS14-12,FLEXIBLE,35 FT
    71-016023-50 CABLE,MS14-12,FLEXIBLE,50 FT
    71-016374-10 CABLE,RESOL,MS14-18,FLEX,10 FT
    71-016374-25 CABLE,RESOL,MS14-18,FLEX,25 FT
    71-016374-35 CABLE,RESOL,MS14-18,FLEX,35 FT
    71-016374-50 CABLE,RESOL,MS14-18,FLEX,50 FT
    71-016529-10 CABLE,MS14-12,HI-FLEX,70,10 FT
    71-016529-25 CABLE,MS14-12,HI-FLEX,70,25 FT
    71-016529-35 CABLE,MS14-12,HI-FLEX,70,35 FT
    71-016529-50 CABLE,MS14-12,HI-FLEX,70,50 FT
    71-016530-10 CABLE,MS18-5,HI-FLEX,92,10 FT
    71-016530-25 CABLE,MS18-5,HI-FLEX,92,25 FT
    71-016530-35 CABLE,MS18-5,HI-FLEX,92,35 FT
    71-016530-50 CABLE,MS18-5,HI-FLEX,92,50 FT
    71-016717-10 CABLE,MOTOR,R SERIES,LVD
    71-016939-10 CABLE,RS232/485,6K/GEMINI
    71-016943-10 CABLE,GEMINI,50P,DRIVE I/O,FLY
    71-016949-02 CABLE,I/O EXPANSION,6K,2FT
    71-016949-100 CABLE,I/O EXPANSION,6K,100 FT
    71-016966-10 CABLE,GEMINI STEPPER
    71-016968-10 CABLE,ENCODER,OS SERIES,10 FT
    71-016999-02 CABLE,VM25 I/O MODULE,2 FT
    71-017003-10 CABLE,6K TO SERVO (CUTOFF),10'
    71-017093-10 CABLE,MS14-12,PLUG,16/23,10FT
    71-017093-25 CABLE,MS14-12,PLUG,16/23,25FT
    71-017093-35 CABLE,MS14-12,PL,16/23,GEM,35'
    71-017094-10 CABLE,MS14-12,PLUG,70,GEM,10FT
    71-017094-25 CABLE,MS14-12,PLUG,70,GEM,25FT
    71-017094-35 CABLE,MS14-12,PL,70,GEM,35FT
    71-017095-10 CABLE,MS18-5,PLUG,92,GEM,10FT
    71-017095-25 CABLE,MS18-5,PLUG,92,GEM,25FT
    71-017095-35 CABLE,MS18-5,PLUG,92,GEM,35FT
    71-017349-10 CABLE,EMC,MS14-18,GEM,10FT
    71-017349-35 CABLE,EMC,MS14-18,GEM,35FT
    71-017350-25 CABLE,EMC,BRK,MS14-18,GEM,25FT
    71-017350-35 CABLE,EMC,BRK,MS14-18,GEM,35FT
    71-017635-01 CABLE,ETHERNET,X-OVER,RJ45,5FT
    71-017677-10 CABLE,TQ,MTR,HI-FLEX,10 FT
    71-017677-25 CABLE,TQ,MTR,HI-FLEX,25 FT
    71-017677-35 CABLE,TQ,MTR,HI-FLEX,35 FT
    71-017711-10 CABLE,MOTOR,R/T SERIES,LVD,14G
    71-017978-10 CABLE,DYNASERV TO 6K
    71-017982-10 CABLE,LINEARSERV TO 6K
    71-018183-10 CABLE,GEMINI TO 6K,COMBINED
    71-018234-10 CABLE,MOTOR,610-630,GEM,10 FT
    71-018234-35 CABLE,MOTOR,610-630,GEM,35 FT
    71-018235-10 CABLE,MOTOR,635-640,GEM,10 FT
    71-018235-25 CABLE,MOTOR,635-640,GEM,25 FT
    71-018235-35 CABLE,MOTOR,635-640,GEM,35 FT
    71-018303-05 CABLE,MOTOR,16/23,GEM,5 FT
    71-018303-10 CABLE,MOTOR,16/23,GEM,10 FT
    71-018303-100 CABLE,MOTOR,16/23,GEM,100 FT
    71-018303-15 CABLE,MOTOR,16/23,GEM,15 FT
    71-018303-20 CABLE,MOTOR,16/23,GEM,20 FT
    71-018303-25 CABLE,MOTOR,16/23,GEM,25 FT
    71-018303-30 CABLE,MOTOR,16/23,GEM,30 FT
    71-018303-35 CABLE,MOTOR,16/23,GEM,35 FT
    71-018303-40 CABLE,MOTOR,16/23,GEM,40 FT
    71-018303-45 CABLE,MOTOR,16/23,GEM,45 FT
    71-018303-50 CABLE,MOTOR,16/23,GEM,50 FT
    71-018303-60 CABLE,MOTOR,16/23,GEM,60 FT
    71-018303-70 CABLE,MOTOR,16/23,GEM,70 FT
    71-018303-80 CABLE,MOTOR,16/23,GEM,80 FT
    71-018303-90 CABLE,MOTOR,16/23,GEM,90 FT
    71-018304-05 CABLE,MOTOR,70,GEM,5 FT
    71-018304-10 CABLE,MOTOR,70,GEM,10 FT
    71-018304-100 CABLE,MOTOR,70,GEM,100 FT
    71-018304-15 CABLE,MOTOR,70,GEM,15 FT
    71-018304-20 CABLE,MOTOR,70,GEM,20 FT
    71-018304-25 CABLE,MOTOR,70,GEM,25 FT
    71-018304-30 CABLE,MOTOR,70,GEM,30 FT
    71-018304-35 CABLE,MOTOR,70,GEM,35 FT
    71-018304-40 CABLE,MOTOR,70,GEM,40 FT
    71-018304-45 CABLE,MOTOR,70,GEM,45 FT
    71-018304-50 CABLE,MOTOR,70,GEM,50 FT
    71-018304-60 CABLE,MOTOR,70,GEM,60 FT
    71-018304-70 CABLE,MOTOR,70,GEM,70 FT
    71-018304-80 CABLE,MOTOR,70,GEM,80 FT
    71-018304-90 CABLE,MOTOR,70,GEM,90 FT
    71-018305-05 CABLE,MOTOR,92,GEMINI,5 FT
    71-018305-10 CABLE,MOTOR,92,GEMINI,10 FT
    71-018305-100 CABLE,MOTOR,92,GEMINI,100 FT
    71-018305-15 CABLE,MOTOR,92,GEMINI,15 FT
    71-018305-20 CABLE,MOTOR,92,GEMINI,20 FT
    71-018305-25 CABLE,MOTOR,92,GEMINI,25 FT
    71-018305-30 CABLE,MOTOR,92,GEMINI,30 FT
    71-018305-35 CABLE,MOTOR,92,GEMINI,35 FT
    71-018305-40 CABLE,MOTOR,92,GEMINI,40 FT
    71-018305-45 CABLE,MOTOR,92,GEMINI,45 FT
    71-018305-50 CABLE,MOTOR,92,GEMINI,50 FT
    71-018305-60 CABLE,MOTOR,92,GEMINI,60 FT
    71-018305-70 CABLE,MOTOR,92,GEMINI,70 FT
    71-018305-80 CABLE,MOTOR,92,GEMINI,80 FT
    71-018305-90 CABLE,MOTOR,92,GEMINI,90 FT
    71-018307-05 CABLE,RESOLVER/BRAKE,GEM,5 FT
    71-018307-10 CABLE,RESOLVER/BRAKE,GEM,10 FT
    71-018307-100 CABLE,RESOLVER/BRAKE,GEM,100FT
    71-018307-15 CABLE,RESOLVER/BRAKE,GEM,15 FT
    71-018307-20 CABLE,RESOLVER/BRAKE,GEM,20 FT
    71-018307-25 CABLE,RESOLVER/BRAKE,GEM,25 FT
    71-018307-30 CABLE,RESOLVER/BRAKE,GEM,30 FT
    71-018307-35 CABLE,RESOLVER/BRAKE,GEM,35 FT
    71-018307-40 CABLE,RESOLVER/BRAKE,GEM,40 FT
    71-018307-45 CABLE,RESOLVER/BRAKE,GEM,45 FT
    71-018307-50 CABLE,RESOLVER/BRAKE,GEM,50 FT
    71-018307-60 CABLE,RESOLVER/BRAKE,GEM,60 FT
    71-018307-70 CABLE,RESOLVER/BRAKE,GEM,70 FT
    71-018307-80 CABLE,RESOLVER/BRAKE,GEM,80 FT
    71-018307-90 CABLE,RESOLVER/BRAKE,GEM,90 FT
    71-018308-05 CABLE,ENCODER,GEM,5 FT
    71-018308-10 CABLE,ENCODER,GEM,10 FT
    71-018308-100 CABLE,ENCODER,GEM,100 FT
    71-018308-15 CABLE,ENCODER,GEM,15 FT
    71-018308-20 CABLE,ENCODER,GEM,20 FT
    71-018308-25 CABLE,ENCODER,GEM,25 FT
    71-018308-30 CABLE,ENCODER,GEM,30 FT
    71-018308-35 CABLE,ENCODER,GEM,35 FT
    71-018308-40 CABLE,ENCODER,GEM,40 FT
    71-018308-45 CABLE,ENCODER,GEM,45 FT
    71-018308-50 CABLE,ENCODER,GEM,50 FT
    71-018308-60 CABLE,ENCODER,GEM,60 FT
    71-018308-70 CABLE,ENCODER,GEM,70 FT
    71-018308-80 CABLE,ENCODER,GEM,80 FT
    71-018308-90 CABLE,ENCODER,GEM,90 FT
    71-018309-05 CABLE,ENC/BRAKE,GEM,5 FT
    71-018309-10 CABLE,ENC/BRAKE,GEM,10 FT
    71-018309-100 CABLE,ENC/BRAKE,GEM,100 FT
    71-018309-15 CABLE,ENC/BRAKE,GEM,15 FT
    71-018309-20 CABLE,ENC/BRAKE,GEM,20 FT
    71-018309-25 CABLE,ENC/BRAKE,GEM,25 FT
    71-018309-30 CABLE,ENC/BRAKE,GEM,30 FT
    71-018309-35 CABLE,ENC/BRAKE,GEM,35 FT
    71-018309-40 CABLE,ENC/BRAKE,GEM,40 FT
    71-018309-45 CABLE,ENC/BRAKE,GEM,45 FT
    71-018309-50 CABLE,ENC/BRAKE,GEM,50 FT
    71-018309-60 CABLE,ENC/BRAKE,GEM,60 FT
    71-018309-70 CABLE,ENC/BRAKE,GEM,70 FT
    71-018309-80 CABLE,ENC/BRAKE,GEM,80 FT
    71-018309-90 CABLE,ENC/BRAKE,GEM,90 FT
    71-018311-10 CABLE,RESOLVER/BRAKE,GEM,10 FT
    71-018311-35 CABLE,RESOLVER/BRAKE,GEM,35 FT
    71-018382-01 CABLE,ENCODER TO 6K,25P-9P
    71-018599-10 CABLE,MOTOR,605/6,GEM,10 FT
    71-018599-25 CABLE,MOTOR,605/6,GEM,25 FT
    71-018599-35 CABLE,MOTOR,605/6,GEM,35 FT
    71-019724-10 CABLE,FEEDBACK,6K/SV,9P-15P
    71-019861-04 CABLE,GEMINI,FLYING LEAD
    71-019861-10 CABLE,GEMINI,FLYING LEAD,10FT
    71-019862-04 CABLE,GEMINI,STEP & DIRECTION
    71-019863-04 CABLE,GEMINI TO 6K,UNIVERSAL
    71-020104-10 CABLE,RESOLVER,COMPAX,10 FT
    71-020104-25 CABLE,RESOLVER,COMPAX,25 FT
    71-020104-35 CABLE,RESOLVER,COMPAX,35 FT
    71-020105-10 CABLE,MTR,SBC105,H20,10 FT
    71-020105-25 CABLE,MTR,SBC105,H20,25 FT
    71-020114-10 CABLE,MTR,SBC145,H20/H40,10 FT
    71-020114-25 CABLE,MTR,SBC145,H20/H40,25 FT
    71-020116-10 CABLE,MTR,SBC205,H40,10 FT
    71-020116-25 CABLE,MTR,SBC205,H40,25 FT
    71-020117-10 CABLE,FEEDBACK,SBC ENC,10 FT
    71-020117-25 CABLE,FEEDBACK,SBC ENC,25 FT
    71-020621-10 CABLE,RESOLVER,SBC SERIES,10FT
    71-020621-25 CABLE,RESOLVER,SBC SERIES,25FT
    71-020622-10 CABLE,MTR,PT,SBC205,10 FT
    71-020622-25 CABLE,MTR,PT,SBC205,25 FT
    71-020623-10 CABLE,RESOLVER,PT,SBC,10 FT
    71-020623-25 CABLE,RESOLVER,PT,SBC,25 FT
    71-020710-10 CABLE,PWR-COMM,IBE,FLY,10 FT
    71-020711-05 CABLE,15P,I/O,IBE,5 FT
    71-020711-10 CABLE,15P,I/O,IBE,10 FT
    7153.501-R 7.5A AC SERVO DRIVE
    72-007746-21 ASSY,TOP,L20-LEAN,CP*6048
    73-018496-01 KIT,RESISTOR,OEM770
    7321.100-R STEP/DIR CONTROL MODULE
    7600003-803 OEMZL6 DRIVE,LABEL-AIRE
    83-135-MO-MTS MOTOR,83-135
    92-CONN CONNECTOR KIT,NEO 92 MS SERIES
    92CX CABLE-10 CABLE KIT,92 CX,COMPAX,10 FT
    92CX CABLE-25 CABLE KIT,92 CX,COMPAX,25 FT
    92CX CABLE-35 CABLE KIT,92 CX,COMPAX,35 FT
    92GB CABLE-05 CABLE KIT,92 GB,5 FT
    92GB CABLE-10 CABLE KIT,92 GB,10 FT,W/BRK
    92GB CABLE-100 CABLE KIT,92 GB,100 FT
    92GB CABLE-15 CABLE KIT,92 GB,15 FT
    92GB CABLE-20 CABLE KIT,92 GB,20 FT
    92GB CABLE-25 CABLE KIT,92 GB,25 FT,W/BRK
    92GB CABLE-30 CABLE KIT,92 GB,30 FT
    92GB CABLE-35 CABLE KIT,92 GB,35 FT,W/BRK
    92GB CABLE-40 CABLE KIT,92 GB,40 FT
    92GB CABLE-45 CABLE KIT,92 GB,45 FT
    92GB CABLE-50 CABLE KIT,92 GB,50 FT
    92GB CABLE-60 CABLE KIT,92 GB,60 FT
    92GB CABLE-70 CABLE KIT,92 GB,70 FT
    92GB CABLE-80 CABLE KIT,92 GB,80 FT
    92GB CABLE-90 CABLE KIT,92 GB,90 FT
    92GR CABLE-05 CABLE KIT,92 RES,GEM,5 FT
    92GR CABLE-10 CABLE KIT,92 RES,GEM,10 FT
    92GR CABLE-100 CABLE KIT,92 RES,GEM,100 FT
    92GR CABLE-15 CABLE KIT,92 RES,GEM,15 FT
    92GR CABLE-20 CABLE KIT,92 RES,GEM,20 FT
    92GR CABLE-25 CABLE KIT,92 RES,GEM,25 FT
    92GR CABLE-30 CABLE KIT,92 RES,GEM,30 FT
    92GR CABLE-35 CABLE KIT,92 RES,GEM,35 FT
    92GR CABLE-40 CABLE KIT,92 RES,GEM,40 FT
    92GR CABLE-45 CABLE KIT,92 RES,GEM,45 FT
    92GR CABLE-50 CABLE KIT,92 RES,GEM,50 FT
    92GR CABLE-60 CABLE KIT,92 RES,GEM,60 FT
    92GR CABLE-70 CABLE KIT,92 RES,GEM,92 FT
    92GR CABLE-80 CABLE KIT,92 RES,GEM,80 FT
    92GR CABLE-90 CABLE KIT,92 RES,GEM,90 FT
    92GS CABLE-05 CABLE KIT,92 GS,5 FT
    92GS CABLE-10 CABLE KIT,92 GS,10 FT
    92GS CABLE-100 CABLE KIT,92 GS,100 FT
    92GS CABLE-15 CABLE KIT,92 GS,15 FT
    92GS CABLE-20 CABLE KIT,92 GS,20 FT
    92GS CABLE-25 CABLE KIT,92 GS,25 FT
    92GS CABLE-30 CABLE KIT,92 GS,30 FT
    92GS CABLE-35 CABLE KIT,92 GS,35 FT
    92GS CABLE-40 CABLE KIT,92 GS,40 FT
    92GS CABLE-45 CABLE KIT,92 GS,45 FT
    92GS CABLE-50 CABLE KIT,92 GS,50 FT
    92GS CABLE-60 CABLE KIT,92 GS,60 FT
    92GS CABLE-70 CABLE KIT,92 GS,70 FT
    92GS CABLE-80 CABLE KIT,92 GS,80 FT
    92GS CABLE-90 CABLE KIT,92 GS,90 FT
    92MS CABLE-10 CABLE KIT,MS CONN,NM92,10 FT
    92MS CABLE-25 CABLE KIT,MS CONN,NM92,25 FT
    92MS CABLE-35 CABLE KIT,92 MS MOTOR,35 FT
    92RS CABLE-10 CABLE KIT,RESOLVER,NM92,10 FT
    92RS CABLE-25 CABLE KIT,RESOLVER,NM92,25 FT
    92RS CABLE-35 CABLE KIT,92 RS MOTOR,35 FT
    92RS CABLE-50 CABLE KIT,92 RS MOTOR,50 FT
    990110(1)/B M20 SOLID PLATENS
    990110(2)/E M20 LINEAR MOTOR SYSTEM W/TUBE
    A1 HEDA/ABSOLUTE ENC. INTERFACE
    AG100 ENCODER,ABSOLUTE,W/FLANGE
    AM5 AM5 CUST ID# 0190-70052
    AM5-CP0030 AM5 DRIVE 0.8 AMP OUTPUT
    -ANI ANI KIT FOR OEM6250 ONLY
    APEX10 APEX10 ANALOG SERVO DRIVE
    APEX10 REGEN KIT APEX10 REGEN RESISTOR
    APEX20 APEX20 ANALOG SERVO DRIVE
    APEX40 APEX40 ANALOG SERVO DRIVE
    APEX40 REGEN KIT APEX40 REGEN RSTR & BRACKET
    APEX610-MO-NC-B-R MOTOR,APEX610,NO CBLE,BRK,-R
    APEX6151 APEX6151 10AMP SERVO SYSTEM
    APEX6152 APEX6152 SERVO DRIVE/CONTROL
    APEX6154 APEX6154 SERVO DRIVE/CONTROL
    APEX6154-R APEX6154 SERVO DRIVE/CNTRL,-R
    APEX615N SHIPKIT APEX615N SHIPKIT ONLY
    ASS1/01 D/A MONITOR JUNCTION BOX
    AT6200 AT6200 MAIN ASSY,16 MHZ
    AT6200 120/240V ON AT6200 90-264VAC AUX ASSY ONLY
    AT6200 MAIN ONLY AT6200 MAIN BOARD ONLY
    AT6200-120/240 AT6200 90-264VAC VERSION
    AT6200-AUX1-DC AT6200 OPEN FRAME DC VERSION
    AT6250 120V ONLY AT6250 120V AUX ASSY ONLY
    AT6250 240V ONLY AT6250 240V AUX BOX ONLY
    AT6250 DOS KIT AT6250 DOS SUPPORT DISK
    AT6250 MAIN ONLY AT6250 MAIN BOARD ONLY
    AT6250 MAIN ONLY-R AT6250 MAIN BOARD ONLY-R
    AT6250 SHIPKIT AT6250 SHIPKIT
    AT6250-120V AT6250 MAIN BD & 120V AUX
    AT6250-240V AT6250 MAIN BD & 240V AUX
    AT6250-DC AT6250 MAIN BD & DC AUX
    AT6400 AT6400 MAIN BOARD ONLY
    AT6400 240V ONLY AT6400 240V AUX ASSEMBLY
    AT6400 DC ONLY AT6400 DC ASSY ONLY
    AT6400 DOS KIT AT6400 DOS SUPPORT DISK
    AT6400 MAIN ONLY AT6400 MAIN BOARD, NO CABLES
    AT6400 SHIPKIT AT6400 SHIPKIT ONLY
    AT6400-120V-NSK AT6400 W/120V AUX,NO SHIPKIT
    AT6400-AUX1 ONLY AT6400 AUX1 120V (NO MAIN BD)
    AT6400-AUX1-120V AT6400 MAIN BD W/120V AUX1
    AT6400-AUX1-240V AT6400 MAIN BD W/240V AUX1
    AT6400-AUX1-DC AT6400 W/DC AUX BOARD
    AT6400-AUX1-NSK 120V AUX BOX FOR AT6400,NO SK
    AT6450 120V ONLY AT6450 120V AUX BOX ONLY
    AT6450 240V ONLY AT6450 240V AUX BOX ONLY
    AT6450 DOS KIT AT6450 DOS SUPPORT DISK
    AT6450 MAIN ONLY AT6450 MAIN BOARD ONLY
    AT6450-120V AT6450 MAIN BD & 120V AUX
    AT6450-240V AT6450 MAIN BD & 240V AUX
    AT6450-240V-R AT6450 SERVO CONTROL,240V-R
    AT6450-DC AT6450 MAIN BD & DC AUX
    BD150E/230V ANALOG INPUT SERVO DRIVE 6A
    BD75E/230V ANALOG INPUT SERVO DRIVE
    BDC-10 10 FT CABLE SET
    BDC-100 100 FT CABLE SET
    BDC-25 25 FT CABLE SET
    BDC-50 50 FT CABLE SET
    BDF1/03 HAND HELD TERMINAL
    BDF2/01 HAND HELD TERMINAL
    E-AC E DRIVE AC VERSION STEPPER
    E-DC E-DC STEPPER DRIVE
    EVM32-BASE EVM32 SERIES BASE BOARD
    EVM32-BASE-R EVM32 SERIES BASE BOARD-R
    EVM32-BASE-RIBBON EVM32 BASE BOARD,RIBBON CONN
    F1 RS485 INTERFACE (4 WIRE)
    F2 INTERBUS-S INTERFACE CARD
    F3 PROFIBUS INTERFACE
    F5 RS485 2 WIRE OPTION
    FBK1/08 SINCOS FEEDBACK CARD
    FP31 FRONT PANEL AM5
    FP36 SD12 FRONT PANEL
    FP37 SD13 FRONT PANEL
    FP38 SD15 FRONT PANEL
    FP39 BLANK FRONT PANEL 3U 14HP
    FP48 FRONT PANEL SD15M
    FP50 FRONT PANEL CD60M (14HP 3U)
    FP52 FRONT PANEL CD60M (10HP 3U)
    FP53 FRONT PANEL CD80M (10HP 3U)
    FP54 FRONT PANEL (20HP) BLANK
    FP55 FRONT PANEL (10HP) BLANK
    FP84 BLANK FRONT PANEL, 84 HP
    GBK16/04 CABLE,SINCOS,HDY/HJ,7.5M
    GBK17/04 CABLE,SINCOS,7.5M
    GC-SDA GEMINI GC-SDA STEP/DIR ANI PCA
    GEMINI WORKSHOP GEMINI WORKSHOP BINDER
    GPDM GEMINI PWR DISSIPATION MODULE
    GPDM-R GEMINI PWR DISS. MODULE,-R
    GS83-135-G MOTOR,83-135,W/GEARHEAD
    GS83-135-MO MOTOR,GS83-135
    GT6K-L5 GT6K-L5 STEPPER DRIVE/CONTROL
    GT6K-L5-NK GT6K-L5 STEPPER DRIVE/CONTROL
    GT6K-L8 GT6K-L8 STEPPER DRIVE/CONTROL
    GT6K-L8-NK GT6K-L8 STEPPER DRIVE/CONTROL
    GT6K-SHIPKIT SHIPKIT,GT6K SERIES
    GT6-L5 GEMINI GT6-L5 STEPPER DRIVE
    GT6-L5-NK GEMINI GT6-L5 DRIVE,-NK
    GT6-L5-PB GT6-L5 STEPPER DRIVE/CONT,PROF
    GT6-L5-PB-NK GT6-L5 STEPPER DRIVE/CONT,PROF
    GT6-L8 GEMINI GT6-L8 STEPPER DRIVE
    GT6-L8-NK GEMINI GT6-L8 DRIVE,-NK
    GT6-L8-PB GT6-L8 STEPPER DRIVE/CONT,PROF
    GT6-L8-PB-NK GT6-L8 STEPPER DRIVE/CONT,PROF
    GT6-PB-SHIPKIT SHIPKIT,GT6 SERIES W/PROFIBUS
    GT6-SHIPKIT SHIPKIT,GT6 SERIES,FULL
    GT-L5 GT-L5 GEMINI STEPPER DRIVE
    GT-L5-NK GEMINI GT-L5 STEP DRIVE,NO KIT
    GT-L8 GT-L8 GEMINI STEPPER DRIVE
    GT-L8-NK GEMINI GT-L8 STEP DRIVE,NO KIT
    GT-SHIPKIT SHIPKIT,GT SERIES,FULL
    GV6-H20E GEMINI GV6-H20E SERVO DRIVE
    GV6-H20E-NK GEMINI GV6-H20E DRIVE,-NK
    GV6-H20E-PB GV6-H20 SERVO DRIVE/CONT,PROFI
    GV6-H20E-PB-NK GV6-H20 SERVO DRIVE/CONT,PROFI
    GV6-H20E-PB-NK-DEM GV6-H20 SERVO DRIVE/CONT,PROFI
    GV6-H20R GEMINI GV6-H20R SERVO DRIVE
    GV6-H20R-NK GEMINI GV6-H20R SERVO DRIVE NK
    GV6-H20R-PB GV6-H20R SERVO DRIVE/CONT,PROF
    GV6-H20R-PB-NK GV6-H20R SERVO DRIVE/CONT,PROF
    GV6-H20R-PB-NK-DEM GV6-H20R SERVO DRIVE/CONT,PROF
    GV6-H40E GEMINI GV6-H40E SERVO DRIVE
    GV6-H40E-NK GEMINI GV6-H40E SERVO NO KIT
    GV6-H40E-PB GEMINI GV6-H40E PROFIBUS
    GV6-H40E-PB-NK GEMINI GV6-H40E PROFIBUS NOKIT
    GV6-H40R GEMINI GV6-H40R SERVO DRIVE
    GV6-H40R-NK GEMINI GV6-H40R SERVO NOKIT
    GV6-H40R-PB GEMINI GV6-H40R PROFIBUS
    GV6-H40R-PB-NK GEMINI GV6-H40R PROFIBUS NOKIT
    GV6K-H20E GV6K-H20 SERVO DRIVE/CONTROLLE
    GV6K-H20E-NK GV6K-H20 SERVO DRIVE/CONTROLLE
    GV6K-H20R GV6K-H20R SERVO DRIVE/CONTROLL
    GV6K-H20R-NK GV6K-H20R SERVO DRIVE/CONTROLL
    GV6K-H40E GEMINI GV6K-H40E SERVO DRIVE
    GV6K-H40E-NK GEMINI GV6K-H40E SERVO NOKIT
    GV6K-H40R GEMINI GV6K-H40R SERVO DRIVE
    GV6K-H40R-NK GEMINI GV6K-H40R SERVO NOKIT
    GV6K-L3E GV6K-L3 SERVO DRIVE/CONTROLLER
    GV6K-L3E-NK GV6K-L3 SERVO DRIVE/CONTROLLER
    GV6K-L3R GV6K-L3R SERVO DRIVE/CONTROLLE
    GV6K-L3R-NK GV6K-L3R SERVO DRIVE/CONTROLLE
    GV6K-SHIPKIT SHIPKIT,GV6K SERIES
    GV6K-U12E GV6K-U12 SERVO DRIVE/CONTROLLE
    GV6K-U12E-NK GV6K-U12 SERVO DRIVE/CONTROLLE
    GV6K-U12R GV6K-U12R SERVO DRIVE/CONTROLL
    GV6K-U12R-NK GV6K-U12R SERVO DRIVE/CONTROLL
    GV6K-U3E GV6K-U3 SERVO DRIVE/CONTROLLER
    GV6K-U3E-NK GV6K-U3 SERVO DRIVE/CONTROLLER
    GV6K-U3R GV6K-U3R SERVO DRIVE/CONTROLLE
    GV6K-U3R-NK GV6K-U3R SERVO DRIVE/CONTROLLE
    GV6K-U6E GV6K-U6 SERVO DRIVE/CONTROLLER
    GV6K-U6E-NK GV6K-U6 SERVO DRIVE/CONTROLLER
    GV6K-U6R GV6K-U6R SERVO DRIVE/CONTROLLE
    GV6K-U6R-NK GV6K-U6R SERVO DRIVE/CONTROLLE
    GV6-L3E GEMINI GV6-L3 SERVO DRIVE
    GV6-L3E-NK GEMINI GV6-L3E DRIVE,-NK
    GV6-L3E-PB GV6-L3 SERVO DRIVE/CONT,PROFI
    GV6-L3E-PB-NK GV6-L3 SERVO DRIVE/CONT,PROFI
    GV6-L3E-R GEMINI GV6-L3 SERVO DRIVE -R
    GV6-L3R GEMINI GV6-L3R SERVO DRIVE
    GV6-L3R-NK GEMINI GV6-L3R SERVO DRIVE,-NK
    GV6-L3R-PB GV6-L3R SERVO DRIVE/CONT,PROFI
    GV6-L3R-PB-NK GV6-L3R SERVO DRIVE/CONT,PROFI
    GV6-PB-SHIPKIT SHIPKIT,GV6 SERIES W/PROFIBUS
    GV6-SHIPKIT SHIPKIT,GV6 SERIES,FULL
    GV6-U12E GEMINI GV6-U12E SERVO DRIVE
    GV6-U12E-NK GEMINI GV6-U12E DRIVE,-NK
    GV6-U12E-NK-R GEMINI DRIVE,-NK,-R
    GV6-U12E-PB GV6-U12 SERVO DRIVE/CONT,PROFI
    GV6-U12E-PB-NK GV6-U12 SERVO DRIVE/CONT,PROFI
    GV6-U12E-PB-NK-DEM GV6-U12 SERVO DRIVE/CONT,PROFI
    GV6-U12R GEMINI GV6-U12R SERVO DRIVE
    GV6-U12R-NK GEMINI GV6-U12R SERVO DRIVE NK
    GV6-U12R-PB GV6-U12R SERVO DRIVE/CONT,PROF
    GV6-U12R-PB-NK GV6-U12R SERVO DRIVE/CONT,PROF
    GV6-U12R-PB-NK-DEM GV6-U12R SERVO DRIVE/CONT,PROF
    GV6-U3E GEMINI GV6-U3E DRIVE
    GV6-U3E-NK GEMINI GV6-U3E DRIVE,-NK
    GV6-U3E-NK-R GEMINI GV6-U3E SERVO DRIVE,-R
    GV6-U3E-PB GV6-U3 SERVO DRIVE/CONT,PROFI
    GV6-U3E-PB-NK GV6-U3 SERVO DRIVE/CONT,PROFI
    GV6-U3R GEMINI GV6-U3R SERVO DRIVE,-NK
    GV6-U3R-NK GEMINI GV6-U3R SERVO DRIVE,-NK
    GV6-U3R-PB GV6-U3R SERVO DRIVE/CONT,PROFI
    GV6-U3R-PB-NK GV6-U3R SERVO DRIVE/CONT,PROF
    GV6-U6E GEMINI GV6-U6E SERVO DRIVE
    GV6-U6E-NK GEMINI GV6-U6E DRIVE,-NK
    GV6-U6E-PB GV6-U6 SERVO DRIVE/CONT,PROFI
    GV6-U6E-PB-NK GV6-U6 SERVO DRIVE/CONT,PROFI
    GV6-U6E-R GEMINI GV6-U6E SERVO DRIVE-R
    GV6-U6R GEMINI GV6-U6R SERVO DRIVE
    GV6-U6R-NK GEMINI GV6-U6R SERVO DRIVE,-NK
    GV6-U6R-NK-R GEMINI GV6-U6 RESOLVER DRIVE-R
    GV6-U6R-PB GV6-U6R SERVO DRIVE/CONT,PROFI
    GV6-U6R-PB-NK GV6-U6R SERVO DRIVE/CONT,PROF
    GV-H20E GEMINI GV-H20 SERVO DRIVE
    GV-H20E-NK GEMINI GV-H20E SERVO,NO KIT
    GV-H20E-R GEMINI GV-H20 SERVO DRIVE,-R
    GV-H20R GEMINI GV-H20R SERVO DRIVE
    GV-H20R-NK GEMINI GV-H20R SERVO DRIVE,-NK
    GV-H40E GEMINI GV-H40E SERVO DRIVE
    GV-H40E-NK GEMINI GV-H40E SERVO NO KIT
    GV-H40R GEMINI GV-H40R SERVO DRIVE
    GV-H40R-NK GEMINI GV-H40R SERVO NOKIT
    GV-L3E GEMINI GV-L3 SERVO DRIVE
    GV-L3E-NK GEMINI GV-L3E SERVO DRIVE,-NK
    GV-L3E-R GEMINI GV-L3 SERVO DRIVE,-REF
    GV-L3R GEMINI GV-L3R SERVO DRIVE
    GV-L3R-NK GEMINI GV-L3R SERVO DRIVE,-NK
    GV-SHIPKIT SHIPKIT,GV SERIES,FULL
    GV-U12E GEMINI GV-U12E SERVO DRIVE
    GV-U12E-NK GEMINI GV-U12E SERVO DRIVE,-NK
    GV-U12E-R GEMINI GV-U12E,SERVO DRIVE,-R
    GV-U12R GEMINI GV-U12R SERVO DRIVE
    GV-U12R-NK GEMINI GV-U12R SERVO DRIVE,-NK
    GV-U3E GEMINI GV-U3E SERVO DRIVE
    GV-U3E-NK GEMINI GV-U3E SERVO DRIVE,-NK
    GV-U3E-R GEMINI GV-U3 SERVO DRIVE,-REF
    GV-U3R GEMINI GV-U3R SERVO DRIVE
    GV-U3R-NK GEMINI GV-U3R SERVO DRIVE,-NK
    GV-U6E GEMINI GV-U6E SERVO DRIVE
    GV-U6E-NK GEMINI GV-U6E SERVO DRIVE,-NK
    GV-U6E-R GEMINI GV-U6E SERVO DRIVE,-R
    GV-U6R GEMINI GV-U6R SERVO DRIVE
    GV-U6R-NK GEMINI GV-U6R SERVO DRIVE,-NK
    GV-U6R-R GEMINI,GV-U6R,SERVO DRIVE,-R
    H120I H120I 12A DRIVE INDEXER
    HBMFMOK CONNECTOR,MOTOR,HBMF SERIES
    HBMFREK CONNECTOR,RESOLVER,HBMF SERIES
    HBMR190E6-88S MOTOR,SERVO,190MM
    HBMR190E6-88S-B MOTOR,SERVO,190MM,W/BRAKE
    HBMR190J6-180S SV SERIES MOTOR
    HBMR190J6-260S MOTOR,SERVO,190MM,BRUSHLESS
    HBMR190J6-260S-B MOTOR,SERVO,190MM W/BRAKE
    HD130M-R HD130 W/MICRO STEP 20
    HD130-R 13A-240V DRIVE
    HDMBKIT HD MOTHERBOARD KIT
    ICONN-KIT CONNECTOR KIT,D-SUB,IBE SERIES
    ILES0.55B MOTOR EXIT COLL/INDUCT,16A,2MH
    IPS-500W POWER SUPPLY,500W,48VDC,10A
    IVD1 PROXIMITY SWITCH INTERFACE KIT
    IVD1 PLATE MOUNTING PLATE,FOR JUNCT BOX
    IVD1 SWITCH PROXIMITY SWITCHS,IVD1,3 PER
    IVD1/01 JUNCTION BOX W/2.5M CABLE
    JS6000-R JS6000 ANALOG JOYSTICK-R
    Motor linear
    L20 FORCER
    L25 DRIVE,L25,MINISTEP,2.5A,75V
    L50 DRIVE,L50,MINISTEP,5A,75V
    LB063-042 MAGNET BAR,LB063,42MM
    LB063-084 MAGNET BAR,LB063,84MM
    LB063-210 MAGNET BAR,LB063,210MM
    LB063-336 MAGNET BAR,LB063,336MM
    LB063-462 MAGNET BAR,LB063,462MM
    LB063-588 MAGNET BAR,LB063,588MM
    LB102-042 MAGNET BAR,LB102,42MM
    LB102-084 MAGNET BAR,LB102,84MM
    LB102-210 MAGNET BAR,LB102,210MM
    LB102-336 MAGNET BAR,LB102,336MM
    LB102-462 MAGNET BAR,LB102,462MM
    LB102-588 MAGNET BAR,LB102,588MM
    LB140-042 MAGNET BAR,LB140,42MM
    LB140-084 MAGNET BAR,LB140,84MM
    LB140-210 MAGNET BAR,LB140,210MM
    LB140-336 MAGNET BAR,LB140,336MM
    LB140-462 MAGNET BAR,LB140,462MM
    LB140-588 MAGNET BAR,LB140,588MM
    LM1050-0301-115 LINEARSERV MOTOR/DRIVE SYSTEM
    LM1050-0801-115 LINEARSERV MOTOR/DRIVE SYSTEM
    LM1050-1001-115 LINEARSERV MOTOR/DRIVE SYSTEM
    LM1051-0051-115 LINEARSERV SYSTEM,ULTRA PREC.
    LM1100-0151-230 LINEARSERV MTR/DRIVE SYSTEM
    LM1100-1401-115 LINEARSERV MOTOR/DRIVE SYSTEM
    LM5040-0051-115 LINEARSERV MOTOR/DRIVE SYSTEM
    LM5040-0401-115 LINEARSERV MOTOR/DRIVE SYSTEM
    LM5040-0401-230 LINEARSERV SERVO SYSTEM
    LM5090-0501-115 LINEARSERV MOTOR/DRIVE SYSTEM
    LM5090-1201-115 LINEARSERV MOTOR/DRIVE SYSTEM
    LM5270-0101-115 LINEARSERV SYSTEM
    LM5270-0501-115 LINEARSERV MTR/DRIVE SYSTEM
    LM5270-1101-230 LINEARSERV MOTOR/DRIVE SYSTEM
    LVD5-K LVD5 5A SERVO DRIVE W/KEYPAD
    MC2-R REFURBISHED RACK
    MD3450/230V 3450 MOTOR W/ENCODER
    MD3475/230V 3475 MOTOR W/ENCODER
    ML3475B-10-R REFURBISHED MOTOR
    MODEL ZETA12-R ZETA12 MIRCOSTEP DRIVE ONLY-R
    MOK11/04 CABLE,MOTOR,MOK11
    MOK11/07 CABLE,MOTOR,HAUSER
    MOK14/07 CABLE,MOTOR,HDY142,18.9A,15M
    MOK14/10 CABLE,HDY142-190,30M,HI-FLEX
    MOK15/04 CABLE,MOTOR,HDX70,7.5M
    MOK15/07 CABLE,MOTOR,HDX70,15M
    MOK15/10 CABLE,MOTOR,HDX70,30M
    MOK21/04 CABLE,MOTOR,HDX142/HJ155,7.5M
    MOK21/07 CABLE,MOTOR,HDX142/HBMR190,15M
    MOK21/10 CABLE,MOTOR,HDX142/HBMR190,30M
    MOK23/05 CABLE,MOTOR,HAUSER
    MOK23/07 CABLE,MOTOR,HD SERIES,15M
    MOK42 KIT MOK42 CONNECTOR KIT
    MOK42/04 CABLE,MOTOR,HDY70-115,7.5M
    MOK42/07 CABLE,MOTOR,HDY70-115,15M
    MOK42/10 CABLE,MOTOR,HDY70-115,30M
    MOK43/04 CABLE,MOTOR,HDY55/115,7.5M
    MOK43/07 CABLE,MOTOR,HDY142,15M
    MOK43/10 CABLE,MOTOR,HDY142,30M
    MOK44/04 CABLE,MOTOR,HDY,HI-FLEX
    MOK45/07 CABLE,MOTOR,HDY55/115,15M
    MOK48/20 CABLE,MOTOR,ADAPTER,HDX92/115
    MOK6 KIT CONNECTOR KIT,MOTOR,MOK6
    MOK6/02 CABLE,MOTOR,HDX92/115,2.5M
    MOK6/04 CABLE,MOTOR,HDX92/115,7.5M
    MOK6/07 CABLE,MOTOR,HDX92/115,15M
    MOK6/10 CABLE,MOTOR,HDX92/115,30M
    MOTION BUILDER MOTION BUILDER (2 INSTALL)
    MOTION BUILDER-10 MOTION BUILDER (10 INSTALL)
    MOTION BUILDER-15 MOTION BUILDER (15 INSTALL)
    MOTION BUILDER-25 MOTION BUILDER (25 INSTALL)
    MOTION BUILDER-5 MOTION BUILDER (5 INSTALL)
    MOTION OCX-10 MOTION OCX TOOLKIT,10 INSTALLS
    MOTION OCX-50 MOTION OCX TOOLKIT,50 INSTALLS
    MOTIONA MOTION ARCHITECT
    MTBX-MAC-LV31 MOTION TOOLBOX FOR LABVIEW 3.1
    MTBX-WIN MOTION TOOLBOX,LAB,3.1/4.0,WIN
    MTBX-WIN-UPDATE MOTION TOOLBOX UPGRADE,3.1
    NFI1/01 LINE FILTER,A/C,2500S
    NFI1/02 AC LINE FILTER,S/SL/NMD
    NFI1/06 LINE FILTER,A/C,2500S <10M
    NMD10 POWER SUPPLY MODULE,10KW
    NMD20 POWER SUPPLY MODULE,20KW
    OEM010 OEM010 SINGLE AXIS INDEXER
    OEM023-AT PC INDEXER,3 AXIS, OPEN LOOP
    OEM070 OEM070 SINGLE AXIS SERVO CNTRL
    OEM1000 OEM1000 70V DC POWER SUPPLY
    OEM1000-COVER OEM1000 POWER SUPPLY COVER
    OEM230 2A/70V STEPPER DRIVE
    OEM330 3A/70V STEPPER DRIVE
    OEM530 5A/70V STEPPER DRIVE
    OEM530-D 5A/70V STEPPER DRIVE W/DUMP
    OEM6200 OEM6200 INDEXER
    OEM6200-PR OEM6200 INDEXER,ASIA
    OEM6250 OEM6250 2 AXIS SERVO CONTROL
    OEM6250-ANI OEM6250 2 AX SERVO CNTRL,-ANI
    OEM6250-ANI-BO OEM6250 ANI BOARD ONLY
    OEM6250-BO OEM6250 BOARD ONLY
    OEM750 OEM750 MICROSTEPPING DRIVE
    OEM750X OEM750X DRIVE INDEXER
    OEM750X-M2 OEM750X DRIVE W/BATT BKD RAM
    OEM770SD OEM770 STEP/DIR SERVO DRIVE
    OEM770SD-INTL OEM770 STEP/DIR SERVO DRIVE
    OEM770T-INTL OEM770T TORQUE SERVO DRIVE,INT
    OEM770X-INTL OEM770X INDEXER DRIVE,-INTL
    OEM770X-M2 OEM770X INX/DRIVE,B/BKD RAM
    OEM770X-M2-INTL OEM770X INX/DRIVE,BBRAM,-INTL
    OEMAT6200 OEM AT6200 2 AXIS INDEXER
    OEMAT6400 OEM AT6400 4 AXIS INDEXER
    OEM-E83 ENCODER,OEM SERIES,E83
    OEM-HS2 OEM DRIVE HI CURRENT HEATSINK
    OEMZL4 OEMZL4 4 AMP STEPPER DRIVE
    OEMZL4 KIT SHIPKIT,OEMZL4
    OEMZL6 OEMZL6 6 AMP STEPPER DRIVE
    OEMZL6 KIT SHIPKIT,OEMZL6 DOCU KIT ONLY
    OEMZL6000 KIT SHIPKIT,OEMZL6000
    OF002C-1 DYNASERV EMC FILTER
    OF002C-3 EMC FILTER DM1004/LINEARSERV
    OPT-6000-M 6000 SERIES EXPANDED MEMORY
    OPT-AT6N50-A OPT-AT6N50-A ANALOG INPUT OPT
    OPT-OEM6250-A OEM6250 ANI BOARD ONLY
    P25L POWER SUPPLY,240V DOL
    PARAMETER EDITOR PARAMETER EDITOR
    PC-21 IBM PC/COMPATABILE INDXR
    PC-21 SHIPKIT SHIPKIT,PC-21 INDEXER
    PC-23 3 AXIS IBM COMPATIBLE INDEXER
    PC-23 SHIPKIT SHIPKIT,PC-23 INDEXER
    PC-23-NCM PC23 3 AXIS INDEXER,MOD S/KIT
    PDHX15E 5A DRIVE W/INDEXER
    PDHX15E-57-83 5A DRIVE W/INDEXER,57-83 MOTOR
    PDHX15E-D 5A DRIVE W/INDEX & PWR DUMP
    PDS13 PKGD MINISTEP DRIVE 3A
    PDS13-57-102 PKGD DRIVE W/MTR & 10 FT CABLE
    PDS13-57-51 PKGD DRIVE W/MTR & 10 FT CABLE
    PDS13-57-83 PKGD DRIVE W/MTR & 10 FT CABLE
    PDS13-83-62 PKGD DRIVE W/MTR & 10 FT CABLE
    PDS13E 3A DRIVE W/OSCILLATOR
    PDS15 PACKAGED 5A MINISTEP DRIVE
    PDS15-106-178 PKGD DRIVE W/DUMP,MOTOR,CABLE
    PDS15-106-205 PKGD DRIVE W/DUMP,MOTOR,CABLE
    PDS15-83-135 PKGD DRIVE W/MTR & 10 FT CABLE
    PDS15-83-135-K PKGD DRIVE W/MTR,10 FT,KEYWAY
    PDS15-83-62 PKGD DRIVE W/MTR & 10 FT CABLE
    PDS15-83-93 PKGD DRIVE W/MTR & 10 FT CABLE
    PDS15-83-93-E PKGD DRIVE W/MTR,ENCODER
    PDS15-83-93-S PKGD DRIVE W/MOTOR,CBL,SINGLE
    PDS15-D PKGD 5A MINISTEP DRIVE + DUMP
    PDS15E 5A DRIVE W/OSCILLATOR
    PDS15E-D 5A DRIVE W/OSCILLATOR & DUMP
    PDX13 PKGD MINISTEP INDEXER DRIVE 3A
    PDX13-57-102 PKGD INDX DRIVE W/MTR & CABLE
    PDX13-57-102-S PKGD INDX DRIVE W/SINGLE SHAFT
    PDX13-57-51 PKGD INDX DRIVE W/MTR & CABLE
    PDX13-57-51-E PKGD INX/DRIVE,W/MTR & ENC
    PDX13-57-51-S PKGD 3A DRIVE W/57-51 MOTOR
    PDX13-57-83 PKGD INDX DRIVE W/MTR & CABLE
    PDX13-57-83-S PKGD INDX DRIVE W/MTR/CABLE
    PDX13-83-62 PKGD INDX DRIVE W/MTR & CABLE
    PDX15 PKGD 5A MINISTEP DRIVE,INDEXER
    PDX15-106-178 PKGD INDX DR W/DUMP,MTR,CABLE
    PDX15-106-178-S PKGD INX/DRIVE-D MTR,CBL,SNGL
    PDX15-106-205 PKGD INDX DRIVE W/-D,MTR,CABLE
    PDX15-83-135 PKGD INDX DRIVE W/MTR & CABLE
    PDX15-83-62 PKGD INDX DRIVE W/MTR & CABLE
    PDX15-83-93 PKGD INDX DRIVE W/MTR & CABLE
    PDX15-83-93-E PGD INX/DRIVE W/MTR & ENC
    PDX15-83-93-S PKGD INX/DRIVE W/MTR,CBL,SGL
    PDX15-D 5A MINISTEP DRIVE,INDEX,DUMP
    PDX15-D-83-135-S PDX15 INX/DR W/DUMP,83-135-S
    PK130M-R REFURBIHSED PK130M
    PK2/110V PACKAGED DRIVE 2.0A
    PK2/230V PK2 2A DRIVE,220-240VAC
    PK2-57-102 DRIVE SYSTEM
    PK2-57-51 DRIVE SYSTEM
    PK2-57-83 DRIVE SYSTEM
    PK2-83-62 DRIVE SYSTEM
    PK3/110V PACKAGED DRIVE 3.0A
    PK3-57-102 PACKAGED FULL/HALF STEP SYSTEM
    PK3-57-51 PKG FULL/HALF STEPPING SYSTEM
    PK3-57-51-E PKGD FULL/HALF STEP SYS,ENCOD.
    PK3-57-51-S PKGD FULL/HALF STEP SYS,SINGLE
    PK3-57-83 PKG FULL/HALF STEPPING SYSTEM
    PK3-83-62 PACKAGED FULL/HALF STEP SYSTEM
    PK3-83-93 PACKAGED FULL/HALF STEP SYSTEM
    PKC80M/CP0023 PKC STEPPER DRIVE
    PKH130M-R PACKGD13AMINISTEPDRIVE,LVD,-R
    PM1200B POWER SUPPLY
    PM2000CN POWER SUPPLY,120VDC,16A
    PMCMOTIONA MOTION ARCHITECT FOR PMC
    PO-L20-P12 CUT STD 18" PLATEN TO 12"
    PO-L20-P144 L20 PLATEN
    PO-L20-P18 PLATEN
    PO-L20-P180 SPECIAL PLATEN
    PO-L20-P20 LINEAR PLATEN
    PO-L20-P31.496 PLATEN,800mm,S/1563 ONLY
    PO-L20-P32 32 INCH PLATEN
    PO-L20-P36 PLATEN, LIN. SYS.
    PO-L20-P54 PLATEN
    PO-L20-P72 PLATEN
    PO-L20-P9 NINE INCH PLATEN
    PO-L20-P9.45 PLATEN,240mm,S/1563 ONLY
    PO-L20-P96 PLATEN, LIN. SYS
    PS-60W POWER SUPPLY,60 WATT,24VDC
    PS7H-3450-DRIVE-R DIGITAL BRUSHLESS SERVO,REFURB
    PS7HX-3450B/DOL-R REFURBISHED PS7HX SYSTEM
    PSCS ASIA PSC ASIA SEMINAR
    PSCS EURO PSC EURO SEMINAR
    PSCS PRIMER PSCS SEMINAR PRIMER
    PSCS SEMINAR PSC SEMINAR
    REK14/04 CABLE,RESOL,HDX142/HBMR190,7.5
    REK14/07 CABLE,RESOL,HDX142/HBMR190,15M
    REK14/10 CABLE,RESOL,HDX142/HBMR190,30M
    REK15/04 CABLE,RESOLVER,HDX70,7.5M
    REK15/07 CABLE,RESOLVER,HDX70,15M
    REK15/10 CABLE,RESOLVER,HDX70,30M
    REK19/05 CABLE,RESOLVER,HAUSER
    REK19/07 CABLE,RESOLVER,HD SERIES,15M
    REK32 KIT REK32 CONNECTOR KIT
    REK32/04 CABLE,RESOLVER,HDY SERIES,7.5M
    REK32/07 CABLE,RESOLVER,HDY SERIES,15M
    REK32/10 CABLE,RESOLVER,HDY SERIES,30M
    REK33/04 CABLE,RESOLVER,HDY/HJ,7.5M
    REK33/07 CABLE,RESOLVER,HDY,15M
    REK37/20 CABLE,RES,ADAPTER,HDX92/115,.5
    REK5 KIT CONNECTOR KIT,RESOLVER,REK5
    REK5/01 CABLE,RESOLVER,HDX92/115
    REK5/04 CABLE,RESOLVER,HDX92/115,7.5M
    REK5/07 CABLE,RESOLVER,HDX92/115,15M
    REK5/10 CABLE,RESOLVER,HDX92/115,30M
    REK6/03 CABLE,RESOLVER,HD SERIES,5M
    RM-106-178 MOTOR 106-178
    RM-106-205 MTR W/CABLE FOR CC/SC RACKS
    RM-162-308 MOTOR 162-308
    RP-240 KEYPAD RP240 KEYPAD REPLACEMENT KIT
    S/SX MULTIPACK S/SX 6 DRIVE PACKAGING
    S1 SINCOS OPTION
    S10 CABLE KIT,RS,10',SERIES
    S106-178 S8 SYSTEM
    S106-178-E S8 SYSTEM W/ENCODER
    S106-178-S S8 SYSTEM W/106-178-S
    S106-205 S8 SYSTEM
    S106-205-E S8 SYSTEM W/ENCODER
    S106-205-S S8 SYSTEM W/SINGLE SHAFT
    S106-250 S8 SYSTEM W/106-250 MTR
    S106-250-E S8 SYSTEM W/ENCODER
    S106-250-S S8 SYSTEM W/106-250,SINGLE
    S3-57-102 S3 SYSTEM W/57-102 MOTOR
    S3-57-102-E S3 SYSTEM W/ENCODER
    S3-57-102-S S3 SYSTEM W/SINGLE SHAFT
    S3-57-51 S3 SYSTEM
    S3-57-51-E S3 SYSTEM W/ENCODER
    S3-57-51-S S3 SYSTEM W/SINGLE SHAFT
    S3-57-83 S3 SYSTEM
    S3-57-83-E S3 SYSTEM W/ENCODER
    S3-57-83-S S3 SYSTEM W/SINGLE SHAFT
    S3-83-135 S3 SYSTEM
    S3-83-135-E S3 SYSTEM W/ENCODER
    S3-83-135-S S3 SYSTEM W/SINGLE SHAFT
    S3-83-62 S3 SYSTEM
    S3-83-62-E S3 SYSTEM W/ENCODER
    S3-83-62-S S3 SYSTEM W/SINGLE SHAFT
    S3-83-93 S3 SYSTEM
    S3-83-93-E S3 SYSTEM W/ENCODER
    S3-83-93-S S3 SYSTEM W/SINGLE SHAFT
    S3-DRIVE ASIA S3 DRIVE
    S57-102 S6 SYSTEM
    S57-102-E S6 SYSTEM W/ENCODER
    S57-102-MO MOTOR,S-SERIES,CABLED
    S57-102-MO-E S-SERIES MOTOR W/ENCODER
    S57-102-MO-F MOTOR,S57-102,W/FLAT
    S57-102-MO-S MOTOR,S-SERIES,CABLED
    S57-102-S S6 SYSTEM
    S57-51 S6 SYSTEM
    S57-51-E S6 SYSTEM W/ENCODER
    S57-51-MO MOTOR,S-SERIES,CABLED
    S57-51-MO-E S-SERIES MOTOR W/ENCODER
    S57-51-MO-F MOTOR,S57-51,W/FLAT
    S57-51-MO-S MOTOR,S-SERIES,CABLED
    S57-51-NSK S6 SYSTEM,NO SHIPKIT
    S57-51-S S6 SYSTEM
    S57-83 S6 SYSTEM
    S57-83-E S6 SYSTEM W/ENCODER
    S57-83-MO MOTOR,S-SERIES,CABLED
    S57-83-MO-E S-SERIES MOTOR W/ENCODER
    S57-83-MO-F MOTOR,S57-83,W/FLAT
    S57-83-MO-S S57-83 MOTOR ONLY, SINGLE
    S57-83-NSK S6 SYSTEM,NO SHIPKIT
    S57-83-S S6-SYSTEM
    S6 SHIPKIT S6 DRIVE SHIPKIT
    S6-DRIVE S-DRIVE,6 AMP
    S8 SHIPKIT S8 DRIVE SHIPKIT
    S83-135 S6 SYSTEM
    S83-135-E S6 SYSTEM W/ENCODER
    S83-135-MO MOTOR,S-SERIES,CABLED
    S83-135-MO-E S-SERIES MOTOR W/ENCODER
    S83-135-MO-F MOTOR,S83-135,W/FLAT
    S83-135-MO-K MOTOR,S83-135 W/STD KEYWAY
    S83-135-MO-S S83-135 MOTOR ONLY, SINGLE
    S83-135-MO-S-F MOTOR,S83-135,SINGLE,FLAT
    S83-135-MO-S-K MOTOR,S83-135,SINGLE W/KEYWAY
    S83-135-S S6-SYSTEM
    S83-62 S6 SYSTEM
    S83-62-E S6 SYSTEM W/ENCODER
    S83-62-MO MOTOR,S-SERIES,CABLED
    S83-62-MO-E S-SERIES MOTOR W/ENCODER
    S83-62-MO-S MOTOR,S-SERIES,CABLE,SINGLE
    S83-62-S S6 SYSTEM W/SINGLE SHAFT MTR
    S83-93 S6 SYSTEM
    S83-93-E S6 SYSTEM W/ENCODER
    S83-93-MO MOTOR,S-SERIES,CABLED
    S83-93-MO-E S-SERIES MOTOR W/ENCODER
    S83-93-MO-F MOTOR,S83-93,W/FLAT
    S83-93-MO-S MOTOR,S-SERIES,CABLE,SINGLE
    S83-93-S S6 SYSTEM
    S8-DRIVE S-DRIVE,8 AMP
    S8-DRIVE-AMP INC. S8 DRIVE,AMP INC.
    S8-DRIVE-AMP-V2 S8 DRIVE,AMP INC.,W/7PIN HDR
    S8-DRIVE-AMP-V2-1 S8 DRIVE AMP INC,W/CONN,CABLE
    SC10 RACK FOR 1-AXIS DRIVE
    SC20 RACK FOR 2-AXIS DRIVE
    SC30 RACK FOR 3-AXIS DRIVES
    SC40 RACK FOR 4-AXIS DRIVES
    SC50 OPTO SD RACK 5 AXIS
    SC60 OPTO SD RACK 6 AXIS
    SD12 2A 60V DRIVE FULL/HALF STEP
    SD13 3A 60V DRIVE FULL/HALF STEP
    SD15 5A 60V DRIVE FULL/HALF STEP
    SD15-D FULL/HALF 5A/60V DRIVE W/DUMP
    SD15M MINISTEP 5A/60V DRIVE
    SD15M/100 MINISTEP 5A/60V DRIVE,100MM
    SD15M-D MINISTEP 5A/60V DRIVE W/DUMP
    SDB4 SDB4 STEP & DIRECTION BUFFER
    SDCMBKIT OPTO SDMBKIT
    SDMBKIT SD MOTHERBOARD KIT
    SDPD SD/PD DUMP CARD
    SERVO MANAGER SERVO MANAGER FOR COMPAX DRIVE
    SERVO TUNER-OEM MOTION ARCHITECT SERVO TUNER
    SFK S-SERIES FAN KIT
    SIM8-OUT-RLY10 MODULE,SIM,8 OUTPUT,RELAY
    SIMS PRIMER SOLUTIONS IN MOTION PRIMER
    SK130 KEYPAD KEYPAD,SK130,SLVD SERIES
    SL06304AH-10N MTR,LIN,SL063,4 PL,HL,10 FT
    SL06304AH-10W MTR,LIN,SL063,4 PL,HL,10,W
    SL06304AH-25N MTR,LIN,SL063,4 PL,HL,25 FT
    SL06304AH-25W MTR,LIN,SL063,4 PL,HL,25,W
    SL06304AH-FLN MTR,LIN,SL063,4 PL,HL,FLY
    SL06304AH-FLW MTR,LIN,SL063,4 PL,HL,FLY,W
    SL06304AN-10N MTR,LIN,SL063,4 PL,10 FT
    SL06304AN-10W MTR,LIN,SL063,4 PL,10 FT,W
    SL06304AN-25N MTR,LIN,SL063,4 PL,25 FT
    SL06304AN-25W MTR,LIN,SL063,4 PL,25,W
    SL06304AN-FLN MTR,LIN,SL063,4 PL,FLY
    SL06304AN-FLW MTR,LIN,SL063,4 PL,FLY,W
    SL06306AH-10N MTR,LIN,SL063,6 PL,HL,10 FT
    SL06306AH-10W MTR,LIN,SL063,6 PL,HL,10,W
    SL06306AH-25N MTR,LIN,SL063,6 PL,HL,25 FT
    SL06306AH-25W MTR,LIN,SL063,6 PL,HL,25,W
    SL06306AH-FLN MTR,LIN,SL063,6 PL,HL,FLY
    SL06306AH-FLW MTR,LIN,SL063,6 PL,HL,FLY,W
    SL06306AN-10N MTR,LIN,SL063,6 PL,10 FT
    SL06306AN-10W MTR,LIN,SL063,6 PL,10 FT,W
    SL06306AN-25N MTR,LIN,SL063,6 PL,25 FT
    SL06306AN-25W MTR,LIN,SL063,6 PL,25,W
    SL06306AN-FLN MTR,LIN,SL063,6 PL,FLY
    SL06306AN-FLW MTR,LIN,SL063,6 PL,FLY,W
    SL06308AH-10N MTR,LIN,SL063,8 PL,HL,10 FT
    SL06308AH-10W MTR,LIN,SL063,8 PL,HL,10,W
    SL06308AH-25N MTR,LIN,SL063,8 PL,HL,25 FT
    SL06308AH-25W MTR,LIN,SL063,8 PL,HL,25,W
    SL06308AH-FLN MTR,LIN,SL063,8 PL,HL,FLY
    SL06308AH-FLW MTR,LIN,SL063,8 PL,HL,FLY,W
    SL06308AN-10N MTR,LIN,SL063,8 PL,10 FT
    SL06308AN-10W MTR,LIN,SL063,8 PL,10 FT,W
    SL06308AN-25N MTR,LIN,SL063,8 PL,25 FT
    SL06308AN-25W MTR,LIN,SL063,8 PL,25,W
    SL06308AN-FLN MTR,LIN,SL063,8 PL,FLY
    SL06308AN-FLW MTR,LIN,SL063,8 PL,FLY,W
    SL06310AH-10N MTR,LIN,SL063,10 PL,HL,10 FT
    SL06310AH-10W MTR,LIN,SL063,10 PL,HL,10,W
    SL06310AH-25N MTR,LIN,SL063,10 PL,HL,25 FT
    SL06310AH-25W MTR,LIN,SL063,10 PL,HL,25,W
    SL06310AH-FLN MTR,LIN,SL063,10 PL,HL,FLY
    SL06310AH-FLW MTR,LIN,SL063,10 PL,HL,FLY,W
    SL06310AN-10N MTR,LIN,SL063,10 PL,10 FT
    SL06310AN-10W MTR,LIN,SL063,10 PL,10 FT,W
    SL06310AN-25N MTR,LIN,SL063,10 PL,25 FT
    SL06310AN-25W MTR,LIN,SL063,10 PL,25,W
    SL06310AN-FLN MTR,LIN,SL063,10 PL,FLY
    SL06310AN-FLW MTR,LIN,SL063,10 PL,FLY,W
    SL06312AH-10N MTR,LIN,SL063,12 PL,HL,10 FT
    SL06312AH-10W MTR,LIN,SL063,12 PL,HL,10,W
    SL06312AH-25N MTR,LIN,SL063,12 PL,HL,25 FT
    SL06312AH-25W MTR,LIN,SL063,12 PL,HL,25,W
    SL06312AH-FLN MTR,LIN,SL063,12 PL,HL,FLY
    SL06312AH-FLW MTR,LIN,SL063,12 PL,HL,FLY,W
    SL06312AN-10N MTR,LIN,SL063,12 PL,10 FT
    SL06312AN-10W MTR,LIN,SL063,12 PL,10 FT,W
    SL06312AN-25N MTR,LIN,SL063,12 PL,25 FT
    SL06312AN-25W MTR,LIN,SL063,12 PL,25,W
    SL06312AN-FLN MTR,LIN,SL063,12 PL,FLY
    SL06312AN-FLW MTR,LIN,SL063,12 PL,FLY,W
    SL10204AH-10N MTR,LIN,SL102,4 PL,HL,10 FT
    SL10204AH-10W MTR,LIN,SL102,4 PL,HL,10,W
    SL10204AH-25N MTR,LIN,SL102,4 PL,HL,25 FT
    SL10204AH-25W MTR,LIN,SL102,4 PL,HL,25,W
    SL10204AH-FLN MTR,LIN,SL102,4 PL,HL,FLY
    SL10204AH-FLW MTR,LIN,SL102,4 PL,HL,FLY,W
    SL10204AN-10N MTR,LIN,SL102,4 PL,10 FT
    SL10204AN-10W MTR,LIN,SL102,4 PL,10 FT,W
    SL10204AN-25N MTR,LIN,SL102,4 PL,25 FT
    SL10204AN-25W MTR,LIN,SL102,4 PL,25,W
    SL10204AN-FLN MTR,LIN,SL102,4 PL,FLY
    SL10204AN-FLW MTR,LIN,SL102,4 PL,FLY,W
    SL10206AH-10N MTR,LIN,SL102,6 PL,HL,10 FT
    SL10206AH-10W MTR,LIN,SL102,6 PL,HL,10,W
    SL10206AH-25N MTR,LIN,SL102,6 PL,HL,25 FT
    SL10206AH-25W MTR,LIN,SL102,6 PL,HL,25,W
    SL10206AH-FLN MTR,LIN,SL102,6 PL,HL,FLY
    SL10206AH-FLW MTR,LIN,SL102,6 PL,HL,FLY,W
    SL10206AN-10N MTR,LIN,SL102,6 PL,10 FT
    SL10206AN-10W MTR,LIN,SL102,6 PL,10 FT,W
    SL10206AN-25N MTR,LIN,SL102,6 PL,25 FT
    SL10206AN-25W MTR,LIN,SL102,6 PL,25,W
    SL10206AN-FLN MTR,LIN,SL102,6 PL,FLY
    SL10206AN-FLW MTR,LIN,SL102,6 PL,FLY,W
    SL10208AH-10N MTR,LIN,SL102,8 PL,HL,10 FT
    SL10208AH-10W MTR,LIN,SL102,8 PL,HL,10,W
    SL10208AH-25N MTR,LIN,SL102,8 PL,HL,25 FT
    SL10208AH-25W MTR,LIN,SL102,8 PL,HL,25,W
    SL10208AH-FLN MTR,LIN,SL102,8 PL,HL,FLY
    SL10208AH-FLW MTR,LIN,SL102,8 PL,HL,FLY,W
    SL10208AN-10N MTR,LIN,SL102,8 PL,10 FT
    SL10208AN-10W MTR,LIN,SL102,8 PL,10 FT,W
    SL10208AN-25N MTR,LIN,SL102,8 PL,25 FT
    SL10208AN-25W MTR,LIN,SL102,8 PL,25,W
    SL10208AN-FLN MTR,LIN,SL102,8 PL,FLY
    SL10208AN-FLW MTR,LIN,SL102,8 PL,FLY,W
    SL10210AH-10N MTR,LIN,SL102,10 PL,HL,10 FT
    SL10210AH-10W MTR,LIN,SL102,10 PL,HL,10,W
    SL10210AH-25N MTR,LIN,SL102,10 PL,HL,25 FT
    SL10210AH-25W MTR,LIN,SL102,10 PL,HL,25,W
    SL10210AH-FLN MTR,LIN,SL102,10 PL,HL,FLY
    SL10210AH-FLW MTR,LIN,SL102,10 PL,HL,FLY,W
    SL10210AN-10N MTR,LIN,SL102,10 PL,10 FT
    SL10210AN-10W MTR,LIN,SL102,10 PL,10 FT,W
    SL10210AN-25N MTR,LIN,SL102,10 PL,25 FT
    SL10210AN-25W MTR,LIN,SL102,10 PL,25,W
    SL10210AN-FLN MTR,LIN,SL102,10 PL,FLY
    SL10210AN-FLW MTR,LIN,SL102,10 PL,FLY,W
    SL10212AH-10N MTR,LIN,SL102,12 PL,HL,10 FT
    SL10212AH-10W MTR,LIN,SL102,12 PL,HL,10,W
    SL10212AH-25N MTR,LIN,SL102,12 PL,HL,25 FT
    SL10212AH-25W MTR,LIN,SL102,12 PL,HL,25,W
    SL10212AH-FLN MTR,LIN,SL102,12 PL,HL,FLY
    SL10212AH-FLW MTR,LIN,SL102,12 PL,HL,FLY,W
    SL10212AN-10N MTR,LIN,SL102,12 PL,10 FT
    SL10212AN-10W MTR,LIN,SL102,12 PL,10 FT,W
    SL10212AN-25N MTR,LIN,SL102,12 PL,25 FT
    SL10212AN-25W MTR,LIN,SL102,12 PL,25,W
    SL10212AN-FLN MTR,LIN,SL102,12 PL,FLY
    SL10212AN-FLW MTR,LIN,SL102,12 PL,FLY,W
    SL14004AH-10N MTR,LIN,SL140,4 PL,HL,10 FT
    SL14004AH-10W MTR,LIN,SL140,4 PL,HL,10,W
    SL14004AH-25N MTR,LIN,SL140,4 PL,HL,25 FT
    SL14004AH-25W MTR,LIN,SL140,4 PL,HL,25,W
    SL14004AH-FLN MTR,LIN,SL140,4 PL,HL,FLY
    SL14004AH-FLW MTR,LIN,SL140,4 PL,HL,FLY,W
    SL14004AN-10N MTR,LIN,SL140,4 PL,10 FT
    SL14004AN-10W MTR,LIN,SL140,4 PL,10 FT,W
    SL14004AN-25N MTR,LIN,SL140,4 PL,25 FT
    SL14004AN-25W MTR,LIN,SL140,4 PL,25,W
    SL14004AN-FLN MTR,LIN,SL140,4 PL,FLY
    SL14004AN-FLW MTR,LIN,SL140,4 PL,FLY,W
    SL14006AH-10N MTR,LIN,SL140,6 PL,HL,10 FT
    SL14006AH-10W MTR,LIN,SL140,6 PL,HL,10,W
    SL14006AH-25N MTR,LIN,SL140,6 PL,HL,25 FT
    SL14006AH-25W MTR,LIN,SL140,6 PL,HL,25,W
    SL14006AH-FLN MTR,LIN,SL140,6 PL,HL,FLY
    SL14006AH-FLW MTR,LIN,SL140,6 PL,HL,FLY,W
    SL14006AN-10N MTR,LIN,SL140,6 PL,10 FT
    SL14006AN-10W MTR,LIN,SL140,6 PL,10 FT,W
    SL14006AN-25N MTR,LIN,SL140,6 PL,25 FT
    SL14006AN-25W MTR,LIN,SL140,6 PL,25,W
    SL14006AN-FLN MTR,LIN,SL140,6 PL,FLY
    SL14006AN-FLW MTR,LIN,SL140,6 PL,FLY,W
    SL14008AH-10N MTR,LIN,SL140,8 PL,HL,10 FT
    SL14008AH-10W MTR,LIN,SL140,8 PL,HL,10,W
    SL14008AH-25N MTR,LIN,SL140,8 PL,HL,25 FT
    SL14008AH-25W MTR,LIN,SL140,8 PL,HL,25,W
    SL14008AH-FLN MTR,LIN,SL140,8 PL,HL,FLY
    SL14008AH-FLW MTR,LIN,SL140,8 PL,HL,FLY,W
    SL14008AN-10N MTR,LIN,SL140,8 PL,10 FT
    SL14008AN-10W MTR,LIN,SL140,8 PL,10 FT,W
    SL14008AN-25N MTR,LIN,SL140,8 PL,25 FT
    SL14008AN-25W MTR,LIN,SL140,8 PL,25,W
    SL14008AN-FLN MTR,LIN,SL140,8 PL,FLY
    SL14008AN-FLW MTR,LIN,SL140,8 PL,FLY,W
    SL14010AH-10N MTR,LIN,SL140,10 PL,HL,10 FT
    SL14010AH-10W MTR,LIN,SL140,10 PL,HL,10,W
    SL14010AH-25N MTR,LIN,SL140,10 PL,HL,25 FT
    SL14010AH-25W MTR,LIN,SL140,10 PL,HL,25,W
    SL14010AH-FLN MTR,LIN,SL140,10 PL,HL,FLY
    SL14010AH-FLW MTR,LIN,SL140,10 PL,HL,FLY,W
    SL14010AN-10N MTR,LIN,SL140,10 PL,10 FT
    SL14010AN-10W MTR,LIN,SL140,10 PL,10 FT,W
    SL14010AN-25N MTR,LIN,SL140,10 PL,25 FT
    SL14010AN-25W MTR,LIN,SL140,10 PL,25,W
    SL14010AN-FLN MTR,LIN,SL140,10 PL,FLY
    SL14010AN-FLW MTR,LIN,SL140,10 PL,FLY,W
    SL14012AH-10N MTR,LIN,SL140,12 PL,HL,10 FT
    SL14012AH-10W MTR,LIN,SL140,12 PL,HL,10,W
    SL14012AH-25N MTR,LIN,SL140,12 PL,HL,25 FT
    SL14012AH-25W MTR,LIN,SL140,12 PL,HL,25,W
    SL14012AH-FLN MTR,LIN,SL140,12 PL,HL,FLY
    SL14012AH-FLW MTR,LIN,SL140,12 PL,HL,FLY,W
    SL14012AN-10N MTR,LIN,SL140,12 PL,10 FT
    SL14012AN-10W MTR,LIN,SL140,12 PL,10 FT,W
    SL14012AN-25N MTR,LIN,SL140,12 PL,25 FT
    SL14012AN-25W MTR,LIN,SL140,12 PL,25,W
    SL14012AN-FLN MTR,LIN,SL140,12 PL,FLY
    SL14012AN-FLW MTR,LIN,SL140,12 PL,FLY,W
    SLVD5 SLVD5 SERVO DRIVE W/ KEYPAD
    SLVD5-NKP SLVD 5 AMP SERVO DRIVE,NO KEYP
    SMA055-10V SERVO AMPLIFIER,SMA055-10V
    SMA090-20 SERVO AMPLIFIER,SMA090-20
    SMA090-20V SERVO AMPLIFIER,SMA090-20V
    SMA090-30 SERVO AMPLIFIER,SMA090-30
    SMA090-30V SERVO AMPLIFIER,SMA090-30V
    SMA180-10 SERVO AMPLIFIER,SMA180-10
    SMA180-10V SERVO AMPLIFIER,SMA180-10V
    SMA180-20 SERVO AMPLIFIER,SMA180-20
    SMA180-20V SERVO AMPLIFIER,SMA180-20V
    SMA180-30 SERVO AMPLIFIER,SMA180-30
    SMA180-30V SERVO AMPLIFIER,SMA180-30V
    SMA190-26R SERVO AMPLIFIER,SMA190-26R
    SMA225-20 SERVO AMPLIFIER,SMA225-20
    SMA225-20V SERVO AMPLIFIER,SMA225-20V
    SMAHS1 SMA HEATSINK,SMAHS1
    SMAHSR SMA HEATSINK,SMAHSR
    SMP075-10 75V POWER SUPPLY,SMP075-10
    SMP150-05 150V POWER SUPPLY,SMP150-05
    SMPFAN SMA POWER SUPPLY FAN KIT
    SR1008B62-4MN*1C DYNASERV SERVO DRIVE
    SR1300A6-3SN DYNASERV SERVO DRIVE
    SSK14/01 CABLE,HEDA,MASTER/SLAVE,1M
    SSK14/02 CABLE,HEDA,MASTER/SLAVE,2.5M
    SSK15/01 CABLE,HEDA,SLAVE/SLAVE,1M
    SSK15/02 CABLE,HEDA,SLAVE/SLAVE,2.5M
    SSK6/02 TEACH PENDANT CABLE-2.5M
    SSK6/10 CABLE,TEACH PENDANT,10M
    SVAC-0300 CABLE KIT,SVAC SERIES,3M
    SVAC-0750 CABLE KIT,SVAC SERIES,7.5M
    SVAC-1500 CABLE KIT,SVAC SERIES,15M
    SVAC-3000 CABLE KIT,SVAC SERIES,30M
    SVAHX1200S/232 SVAHX1200S SERVO DRIVE/CONTROL
    SVHX8500S/232 SVHX8500S SERVO DRIVE/CONTROL
    SX106-178 SX8 SYSTEM
    SX106-178-A SX8 SYSTEM,-A
    SX106-178-E SX8 SYSTEM
    SX106-178-S SX8 SYSTEM W/106-178-S
    SX106-178-S-A SX8 SYSTEM W/SINGLE SHAFT,-A
    SX106-205 SX8 SYSTEM
    SX106-205-A SX8 SYSTEM, -A
    SX106-205-E SX8 SYSTEM
    SX106-205-S SX8 SYSTEM W/106-205MTR,SINGLE
    SX106-205-S-A SX8 SYSTEM,SINGLE SHAFT,-A
    SX106-250 SX8 SYSTEM W106-250 MTR
    SX106-250-A SX8 SYSTEM,106-250,-A
    SX106-250-E SX8 SYSTEM W/ENCODER
    SX106-250-S SX8 SYSTEM,106-250 MTR,SINGLE
    SX106-250-S-A SX8 SYSTEM,SINGLE SHAFT,-A
    SX3-57-102 SX3 SYSTEM
    SX3-57-102-A SX3 SYSTEM,-A
    SX3-57-102-E SX3 SYSTEM W/ENCODER
    SX3-57-102-S SX3 SYSTEM W/SINGLE SHAFT
    SX3-57-102-S-A SX3 SYSTEM,SINGLE SHAFT,-A
    SX3-57-51 SX3 SYSTEM
    SX3-57-51-A SX3 SYSTEM,-A
    SX3-57-51-E SX3 SYSTEM W/ENCODER
    SX3-57-51-S SX3 SYSTEM W/SINGLE SHAFT
    SX3-57-51-S-A SX3 SYSTEM,SINGLE SHAFT,-A
    SX3-57-83 SX3 SYSTEM
    SX3-57-83-A SX3 SYSTEM,-A
    SX3-57-83-E SX3 SYSTEM W/ENCODER
    SX3-57-83-S SX3 SYSTEM W/SINGLE SHAFT
    SX3-57-83-S-A SX3 SYSTEM,SINGLE SHAFT,-A
    SX3-83-135 SX3 SYSTEM
    SX3-83-135-A SX3 SYSTEM,-A
    SX3-83-135-E SX3 SYSTEM W/ENCODER
    SX3-83-135-S SX3 SYSTEM W/SINGLE SHAFT
    SX3-83-135-S-A SX3 SYSTEM,SINGLE SHAFT,-A
    SX3-83-62 SX3 SYSTEM
    SX3-83-62-A SX3 SYSTEM,-A
    SX3-83-62-E SX3 SYSTEM W/ENCODER
    SX3-83-62-S SX3 SYSTEM W/SINGLE SHAFT
    SX3-83-62-S-A SX3 SYSTEM,SINGLE SHAFT,-A
    SX3-83-93 SX3 SYSTEM
    SX3-83-93-A SX3 SYSTEM,-A
    SX3-83-93-E SX3 SYSTEM W/ENCODER
    SX3-83-93-S SX3 SYSTEM W/SINGLE SHAFT
    SX3-83-93-S-A SX3 SYSTEM,SINGLE SHAFT,-A
    SX3-DRIVE SX3 DRIVE ONLY
    SX3-DRIVE-A SX3 DRIVE ONLY,-A
    SX57-102 SX6 SYSTEM
    SX57-102-A SX6 SYSTEM,-A
    SX57-102-E SX6 SYSTEM W/ENCODER
    SX57-102-S SX6 SYSTEM,W/SINGLE SHAFT MTR
    SX57-102-S-A SX6 SYSTEM,SINGLE SHAFT,-A
    SX57-51 SX6 SYSTEM
    SX57-51-A SX6 SYSTEM,-A
    SX57-51-E SX6 SYSTEM W/ENCODER
    SX57-51-S SX6 SYSTEM,SINGLE
    SX57-51-S-A SX6 SYSTEM,SINGLE SHAFT,-A
    SX57-83 SX6 SYSTEM
    SX57-83-A SX6 SYSTEM,-A
    SX57-83-E SX6 SYSTEM W/ENCODER
    SX57-83-S SX6 DRIVE,57-83 MTR,SINGLE
    SX57-83-S-A SX6 SYSTEM,SINGLE SHAFT,-A
    SX6 SHIPKIT SX6 DRIVE SHIPKIT
    SX6-DRIVE SX-DRIVE,6 AMP
    SX6-DRIVE-A SX-DRIVE,6 AMP,-A
    SX8 SHIPKIT SX8 DRIVE SHIPKIT
    SX83-135 SX6 SYSTEM
    SX83-135-A SX6 SYSTEM,-A
    SX83-135-E SX6 SYSTEM
    SX83-135-S SX6 SYSTEM
    SX83-135-S-A SX6 SYSTEM,SINGLE SHAFT,-A
    SX83-62 SX6 SYSTEM
    SX83-62-A SX6 SYSTEM,-A
    SX83-62-E SX6 SYSTEM W/ENCODER
    SX83-62-S SX6 SYSTEM,SINGLE
    SX83-62-S-A SX6 SYSTEM,SINGLE SHAFT,-A
    SX83-93 SX6 SYSTEM
    SX83-93-A SX6 SYSTEM,-A
    SX83-93-E SX6 SYSTEM W/ENCODER
    SX83-93-S SX6 SYSTEM W/83-93-S
    SX83-93-S-A SX6 SYSTEM,SINGLE SHAFT,-A
    SX8-DRIVE SX-DRIVE,8 AMP
    SX8-DRIVE-A SX-DRIVE,8 AMP,-A
    SXF106-178 SXF8 SYSTEM W/106-178 MOTOR
    SXF106-178-A SXF8 SYSTEM,-A
    SXF106-178-E SXF8 SYSTEM W/106-178MTR&ENCDR
    SXF106-205 SXF8 SYSTEM W/106-205 MOTOR
    SXF106-205-A SXF8 SYSTEM,-A
    SXF106-205-E SXF8 SYSTEM W/106-205MTR&ENCDR
    SXF106-205-S SXF SYSTEM,106-205,SINGLE
    SXF106-205-S-A SXF8 SYSTEM,SINGLE SHAFT,-A
    SXF106-250 SXF8 SYSTEM W/160-250 MOTOR
    SXF106-250-A SXF8 SYSTEM,-A
    SXF106-250-E SXF8 SYSTEM W/106-250MTR&ENCDR
    SXF3-57-102 SXF3 SYSTEM
    SXF3-57-102-A SXF3 SYSTEM,-A
    SXF3-57-102-E SXF3 SYSTEM W/ENCODER
    SXF3-57-51 SXF3 SYSTEM
    SXF3-57-51-A SXF3 SYSTEM,-A
    SXF3-57-51-E SXF3 SYSTEM W/ENCODER
    SXF3-57-83 SXF3 SYSTEM
    SXF3-57-83-A SXF3 SYSTEM,-A
    SXF3-57-83-E SXF3 SYSTEM W/ENCODER
    SXF3-83-135 SXF3 SYSTEM
    SXF3-83-135-A SXF3 SYSTEM,-A
    SXF3-83-135-E SXF3 SYSTEM W/ENCODER
    SXF3-83-62 SXF3 SYSTEM
    SXF3-83-62-A SXF3 SYSTEM,-A
    SXF3-83-62-E SXF3 SYSTEM W/ENCODER
    SXF3-83-93 SXF3 SYSTEM
    SXF3-83-93-A SXF3 SYSTEM,-A
    SXF3-83-93-E SXF3 SYSTEM W/ENCODER
    SXF3-DRIVE SXF3 DRIVE ONLY
    SXF3-DRIVE-A SXF3 DRIVE ONLY,-A
    SXF57-102 SXF6 SYSTEM W/57-102 MOTOR
    SXF57-102-A SXF6 SYSTEM,-A
    SXF57-102-E SXF6 SYSTEM W/57-102 MTR&ENCDR
    SXF57-51 SXF6 SYSTEM W/57-51 MOTOR
    SXF57-51-A SXF6 SYSTEM,-A
    SXF57-51-E SXF6 SYSTEM W/57-51 MTR&ENCDR
    SXF57-83 SXF6 SYSTEM W/57-83 MOTOR
    SXF57-83-A SXF6 SYSTEM,-A
    SXF57-83-E SXF6 SYSTEM W/57-83 MTR&ENCDR
    SXF6-DRIVE 6AMP SXF DRIVE ONLY
    SXF6-DRIVE-A SXF-DRIVE,6 AMP,-A
    SXF83-135 SXF6 SYSTEM W/83-135 MOTOR
    SXF83-135-A SXF6 SYSTEM,-A
    SXF83-135-E SXF6 SYSTEM W/83-135 MTR&ENCDR
    SXF83-135-S SXF SYSTEM,83-135 MOTOR,SINGLE
    SXF83-135-S-A SXF6 SYSTEM,SINGLE SHAFT,-A
    SXF83-62 SXF6 SYSTEM W/83-62 MOTOR
    SXF83-62-A SXF6 SYSTEM,-A
    SXF83-62-E SXF6 SYSTEM W/83-62 MTR&ENCDR
    SXF83-93 SXF6 SYSTEM W/83-93 MOTOR
    SXF83-93-A SXF6 SYSTEM,-A
    SXF83-93-E SXF6 SYSTEM W/83-93 MTR&ENCDR
    SXF8-DRIVE 8AMP SXF DRIVE ONLY
    SXF8-DRIVE-A SXF-DRIVE,8 AMP,-A
    T34 ENC KIT SIZE T34 ENCODER KIT,E83
    T34 ENC PLATE SIZE T34 ENCODER MTG PLATE
    T42 ENC KIT SIZE T42 ENCODER KIT,E106P
    T42 ENC PLATE SIZE T42 ENCODER MTG PLATE
    TO119-R TRANSFORMER FOR SC RACK,REFURB
    TO120 450VA TRANSFORMER SD
    TO124-R TRANSFORMER/HD130,REFURB
    TO138-R 500VA TRANSFORMER,UD2/5,REFURB
    TO170 1.2KVA TRANSFORMER BL
    TO171 2.5KVA TRANSFORMER BL
    TO182 1.4KVA TRANSFORMER UD12
    TO193 300VA TRANSFORMER SUPER SD
    TO194 600VA TRANSFORMER SUPER SD
    TO73 1.2KVA TRANSFORMER
    TO92 600VA TRANSFORMER
    TQ10 TQ10 SERVO DRIVE
    TQ10-EHS TQ10 SERVO DRIVE W/ENCL,FAN
    TQ10-ENCL TQ10 ENCLOSURE
    TQ10-HS3 TQ10 FAN KIT
    TQ10SD TQ10 SERVO DRIVE,STEP + DIR
    TQ10SD-EHS TQ10 STEP/DIR SERVO W/ENCL,FAN
    TQ10X TQ10 SERVO INDEXER DRIVE
    TQ10X-EHS TQ10 INX/DRIVE W/ENCL,FAN
    TQFLEX CABLE-10 CABLE KIT,TQ MOTOR,FLEX,10 FT
    TQFLEX CABLE-25 CABLE KIT,TQ MOTOR,FLEX,25 FT
    TQFLEX CABLE-35 CABLE KIT,TQ MOTOR,FLEX,35 FT
    VM15 VM15 I/O BREAKOUT,IBE SERIES
    VM16/8 VM I/O MODULE,16INPUT,8OUTPUT
    VM24S VM24 I/O MODULE,SINGLE
    VM25 VM25 I/O MODULE W/CABLE
    VM25-NC VM25 I/O MODULE,NO CABLE
    VM50 50 PIN TO SCREW BREAKOUT BOARD
    VM60 60 PIN TO SCREW BREAKOUT BOARD
    VM8/16 VM I/O MODULE,16INPUT,8OUTPUT
    WIN-LV40 TO 41/50 MTBX UPDATE LV 40 TO 4.1/5 WIN
    Z605-MO-NC-R MTR, Z605, MO CABLE, REFURB
    Z610-MO-NC-R Z610 MOTOR, NO CABLE, REFURB
    Z900-DRIVE-240V-R Z900 SERVO DRIVE ONLY,REFURB
    Z910-MO-NC MOTOR,Z900 SERIES,NO
    Z930-MO-NC-R MOTOR,Z900 SERIES,NO CABLES -R
    Z940-MO-NC MOTOR,Z900 SERIES,NO
    ZETA12 ZETA12 MICROSTEP DRIVE ONLY
    ZETA4 ZETA4 DRIVE ONLY
    ZETA4-240 ZETA4 240V DRIVE ONLY
    ZETA57-102 ZETA4 SYSTEM W/57-102 MOTOR
    ZETA57-102-E ZETA4 SYSTEM W/57-102,ENCODER
    ZETA57-102-MO MOTOR,ZETA57-102
    ZETA57-102-MO-E MOTOR,ZETA57-102,ENCODER
    ZETA57-102-MO-S MOTOR,ZETA57-102,SINGLE
    ZETA57-102-S ZETA4 SYSTEM W/57-102,SINGLE
    ZETA57-51 ZETA4 SYSTEM W/57-51 MOTOR
    ZETA57-51-E ZETA4 SYSTEM W/57-51,ENCODER
    ZETA57-51-MO MOTOR,ZETA57-51
    ZETA57-51-MO-E MOTOR,ZETA57-51,ENCODER
    ZETA57-51-MO-S MOTOR,ZETA57-51,SINGLE
    ZETA57-51-S ZETA4 SYSTEM W/57-51 SINGLE
    ZETA57-83 ZETA4 SYSTEM W/57-83 MOTOR
    ZETA57-83-E ZETA4 SYSTEM W/57-83,ENCODER
    ZETA57-83-MO MOTOR,ZETA57-83
    ZETA57-83-MO-E MOTOR,ZETA57-83,ENCODER
    ZETA57-83-MO-F MOTOR,ZETA57-83,W/FLAT
    ZETA57-83-MO-S MOTOR,ZETA57-83,SINGLE
    ZETA57-83-S ZETA4 SYSTEM W/57-83,SINGLE
    ZETA6104 ZETA6104 DRIVE ONLY
    ZETA6104-240 ZETA6104-240 INDEXER DRIVE
    ZETA6104-240-R ZETA6104-240 INDEXERF DRIVE-R
    ZETA6104-57-102 ZETA6104 SYSTEM,W/57-102 MOTOR
    ZETA6104-57-102-E ZETA6104 SYSTEM,W/57-102,ENC
    ZETA6104-57-102-M ZETA6104 SYSTEM,W/57-102,XMEM
    ZETA6104-57-102-ME ZETA6104 SYS,W,57-102,ENC,XMEM
    ZETA6104-57-102-MS ZETA6104 SYS,W/57-102,SNGL,MEM
    ZETA6104-57-102-S ZETA6104 SYSTEM,W/57-102,SNGL
    ZETA6104-57-51 ZETA6104 SYSTEM W/57-51 MOTOR
    ZETA6104-57-51-E ZETA6104 SYSTEM,W/57-51,ENC
    ZETA6104-57-51-M ZETA6104 SYSTEM,W/57-51,XMEM
    ZETA6104-57-51-ME ZETA6104 SYS,W/57-51,ENC,XMEM
    ZETA6104-57-51-MS ZETA6104 SYS,W/57-51,SNGL,XMEM
    ZETA6104-57-51-S ZETA6104 SYSTEM,W57-51,SINGLE
    ZETA6104-57-83 ZETA6104 SYSTEM,W/57-83 MOTOR
    ZETA6104-57-83-E ZETA6104 SYSTEM,W/57-83,ENC
    ZETA6104-57-83-M ZETA6104 SYSTEM,W/57-83,XMEM
    ZETA6104-57-83-ME ZETA6104 SYS,W/57-83,ENC,XMEM
    ZETA6104-57-83-MS ZETA6104 SYS,W/57-83,SNGL,XMEM
    ZETA6104-57-83-S ZETA6104 SYSTEM,W/57-83,SINGLE
    ZETA6104-83-135 ZETA6104 SYSTEM,W/83-135 MOTOR
    ZETA6104-83-135-E ZETA6104 SYSTEM,W/83-135,ENC
    ZETA6104-83-135-EK ZETA6104 SYSTEM,W/83-135,ENC
    ZETA6104-83-135-M ZETA6104 SYSTEM,W/83-135,XMEM
    ZETA6104-83-135-ME ZETA6104 SYS,W/83-135,ENC,XMEM
    ZETA6104-83-135-MS ZETA6104 SYS,W/83-135,SNGL,MEM
    ZETA6104-83-135-S ZETA6104 SYSTEM,W/83-135,SNGL
    ZETA6104-83-62 ZETA6104 SYSTEM,W/83-62 MOTOR
    ZETA6104-83-62-E ZETA6104 SYSTEM,W/83-62,ENC
    ZETA6104-83-62-M ZETA6104 SYSTEM,W/83-62,XMEM
    ZETA6104-83-62-MS ZETA6104 SYS,W/83-62,SNGL,XMEM
    ZETA6104-83-62-S ZETA6104 SYSTEM,W/83-62,SINGLE
    ZETA6104-83-93 ZETA6104 SYSTEM,W/83-93 MOTOR
    ZETA6104-83-93-E ZETA6104 SYSTEM,W/83-93,ENC
    ZETA6104-83-93-M ZETA6104 SYSTEM,W/83-93,XMEM
    ZETA6104-83-93-ME ZETA6104 SYS,W/83-93,ENC,XMEM
    ZETA6104-83-93-MS ZETA6104 SYS,W/83-93,SNGL,XMEM
    ZETA6104-83-93-S ZETA6104 SYSTEM,W/83-93,SINGLE
    ZETA6108 ZETA6108 8AMP INDEXER/DRIVE
    ZETA6112 ZETA6112 12A INDEXER/DRIVE
    ZETA8 ZETA8 MICROSTEP DRIVE ONLY
    ZETA83-135 ZETA4 SYSTEM W/83-135 MOTOR
    ZETA83-135-E ZETA4 SYSTEM W/83-135,ENCODER
    ZETA83-135-MO MOTOR,ZETA83-135
    ZETA83-135-MO-E MOTOR,ZETA83-135,ENCODER
    ZETA83-135-MO-E-K MOTOR,ZETA83-135,ENC,KEYWAY
    ZETA83-135-MO-F MOTOR,ZETA83-135,FLAT
    ZETA83-135-MO-K MOTOR,ZETA83-135 W/KEYWAY
    ZETA83-135-MO-S MOTOR,ZETA83-135,SINGLE
    ZETA83-135-S ZETA4 SYSTEM W/83-135,SINGLE
    ZETA83-62 ZETA4 SYSTEM,W/83-62 MOTOR
    ZETA83-62-E ZETA4 SYSTEM W/83-62,ENCODER
    ZETA83-62-MO MOTOR,ZETA83-62
    ZETA83-62-MO-E MOTOR,ZETA83-62,ENCODER
    ZETA83-62-MO-S MOTOR,ZETA83-62,SINGLE
    ZETA83-62-S ZETA4 SYSTEM W/83-62,SINGLE
    ZETA83-93 ZETA4 SYSTEM W/83-93 MOTOR
    ZETA83-93-E ZETA4 SYSTEM W/83-93,ENCODER
    ZETA83-93-MO MOTOR,ZETA83-93
    ZETA83-93-MO-E MOTOR,ZETA83-93,ENCODER
    ZETA83-93-MO-E-K MOTOR,ZETA83-93,W/ENC & KEY
    ZETA83-93-MO-F MOTOR,ZETA83-93,W/FLAT
    ZETA83-93-MO-K MOTOR,ZETA83-93 W/STD KEYWAY
    ZETA83-93-MO-S MOTOR,ZETA83-93,SINGLE
    ZETA83-93-S ZETA4 SYSTEM W/83-93,SINGLE
    ZETA8-R ZETA8 MICROSTEP DRIVE ONLY,-R
    RTA
    HGD 04 drive para motor de passo, 0,75 ?2A fase, 32 ?75 Vdc, 200,400 e 800 ppv
    HGD 06 drive para motor de passo, 2,3 ?6A fase, 32 ?75 Vdc, 200,400 e 800 ppv
    GAC 03 drive para motor de passo, 4 ?10A fase, 42 ?62 Vac, 200,400 e 800 ppv
    GAC 04 drive para motor de passo, 5 ?12A fase, 69 ?100 Vac, 200,400 e 800 ppv
    SDC 04 drive para motor de passo, 0,8 ?1,5A fase, 32 ?75 Vdc, 400 ?4000 ppv
    SDC 05 drive para motor de passo, 1,7 ?3A fase, 32 ?75 Vdc, 400 ?4000 ppv
    SDC 06 drive para motor de passo, 3,4 ?6A fase, 32 ?75 Vdc, 400 ?4000 ppv
    SAC 25 drive para motor de passo, 1,7 ?3A fase, 24 ?50 Vac, 400 ?4000 ppv
    SAC 26 drive para motor de passo, 3,4 ?6A fase, 24 ?50 Vac, 400 ?4000 ppv
    BCW02 drive para motor de passo, 5,8 ?14A fase, 130 ?175 Vac, 200,400 e 800 ppv
    GMD 02 drive para motor de passo, eurocard, m醲 1,6 ?6A fase, 55 ?85 Vdc, 200,400 ou 800 ppv
    GMD 03 drive para motor de passo, eurocard, m醲 4 ?10A fase, 55 ?85 Vdc, 200,400 ou 800 ppv
    GMD 04 drive para motor de passo, eurocard, m醲 5 ?12A fase, 95 ?140 Vdc, 200,400 ou 800 ppv
    GMD 06 drive para motor de passo, eurocard, m醲 5 ?12A fase, 160 ?190 Vdc, 200,400 ou 800 ppv
    GMH 05 drive para motor de passo, eurocard, m醲 1,6 ?3A fase, 55 ?85 Vdc, 400 ?4000 ppv
    GMH 06 drive para motor de passo, eurocard, m醲 3,5 ?6A fase, 55 ?85 Vdc, 400 ?4000 ppv
    GMH 07 drive para motor de passo, eurocard, m醲 7 ?12A fase, 55 ?85 Vdc, 400 ?4000 ppv
    MIND A3 drive para motor de passo, 5,7 ?10A fase, 55 ?85 Vdc, 400 ?4000 ppv
    MIND A4 drive para motor de passo, 4,55 ?8A fase, 95 ?140 Vdc, 400 ?4000 ppv
    MIND A5 drive para motor de passo, 6,7 ?12A fase, 120 ?180 Vdc, 400 ?4000 ppv
    MIND S3 drive/indexer para motor de passo, 5,7 ?10A fase, 55 ? 85 Vdc, 400 ?4000 ppv
    MIND S4 drive/indexer para motor de passo, 4,55 ?8A fase, 95 ? 140 Vdc, 400 ?4000 ppv
    MIND S5 drive/indexer para motor de passo, 6,7 ?12A fase, 120 ? 180 Vdc, 400 ?4000 ppv
    Acess髍ios
    KCMIND S Kit conector para MINDS
    K START MIND S Kit start para MIND S, soft e documenta玢o
    CASDC1M Cabo de fonte para HGD/SDC, 1m
    CMSDC1M Cabo de motor para HGD/SDC/SAC, 1m
    CMSDC2M Cabo de motor para HGD/SDC/SAC, 2m
    CLSDC1M Cabo de sinal para HGD/SDC/SAC, 1m
    CLSDC2M Cabo de sinal para HGD/SDC/SAC, 2m
    KCSDC Kit de conectores para HDG e SDC
    KCSDC10 Kit de conectores p/ HDG e SDC, 10 pe鏰s
    KCSAC Kit de conectores para SAC
    KCSAC10 Kit de conectores para SAC, 10 unidades
    DI41- BRACKET [for HGD/SDC/SAC]
    DSSDC Dissipador para SDC/SAC, i > 4A
    KFSDC Suporte de fixa玢o para SDC/SAC
    SPS75G-3 M骴ulo fonte chaveada 110 ?220Vac x 75 Vdc @ 2,8A, 185W
    RMM 36 Cart鉶 gerador de rampa
    OFM 30 Cart鉶 gerador de rampa
    OFM 40P, OFM 40E Cart鉶 gerador de rampa
    OFM 60 Cart鉶 gerador de rampa
    FFM 04 Cart鉶 gerador de rampa
    VOM20.N Cart鉶 gerador de rampa
    EURORACK 10.5?/td> Eurorack 10,5"
    EURORACK 12?/td> Eurorack 12"
    EURORACKS 19?/td> Eurorack 19"
    MM4.1 Motherboard GMD, GMH
    PM2.1 Motherboard PS
    PS03, PS04, PS06 Fonte de alimenta玢o
    COOLING UNIT Unidade de ventila玢o
    INCA 01 Cart鉶 indexer
    CABLE INCA 0,3 Mt Cabo p/ cart鉶 INCA, 300 mm
    CABLE INCA 3 Cabo p/ cart鉶 INCA, 3 m
    CABLE INCA 8 Cabo p/ cart鉶 INCA, 8 m
    RJ 11 / DB9 Adaptador conector RJ11 p/ DB9
    K START INCA 01 Kit start para INCA 01, soft e documenta玢o
    SP 27 Transformador
    SP 26 Transformador
    RTA Nema17
    103-546-5540 motor de passo, Nema17, 4 fios, eixo simples, 0,125 Nm
    103-546-5342 motor de passo, Nema17, 6 fios, eixo simples, 0,19 Nm
    103-547-5240 motor de passo, Nema17, 6 fios, eixo simples, 0,25 Nm
    103-547-5210 motor de passo, Nema17, 6 fios, eixo duplo, 0,25 Nm
    103-H548-0440 motor de passo, alta efici阯cia, Nema17, 6 fios, eixo simples, 0,9A, 0,37 Nm
    RTA Nema17
    103-H6701-0140 motor de passo, alta efici阯cia, 50 mm, 6 fios, eixo simples, 0,7A, 0,38 Nm
    103-H6703-0440 motor de passo, alta efici阯cia, 50 mm, 6 fios, eixo simples, 1,4A, 0,68 Nm
    RTA Nema23
    103-770-6 motor de passo, Nema 23, 8 fios, eixo simples, 1,0A, 0,62 Nm
    103-770-61 motor de passo, Nema 23, 8 fios, eixo duplo, 0,62 Nm
    103-770-1640 motor de passo, Nema 23, 4 fios, eixo simples, 0,62 Nm
    103-G770-2241 motor de passo, Nema 23, 8 fios, eixo simples, 2,0A, 0,60 Nm
    103-G770-2221 motor de passo, Nema 23, 8 fios, eixo duplo, 2,0A, 0,60 Nm
    103-714-0150 motor de passo, Nema 23, 8 fios, eixo simples, 1,09 Nm
    103-714-0111 motor de passo, Nema 23, 8 fios, eixo duplo, 1,09 Nm
    103-H7123-0140 motor de passo, alta efici阯cia, Nema 23, 6 fios, eixo simples, 0,7A, 1,10 Nm
    103-H7123-0740 motor de passo, alta efici阯cia, Nema 23, 6 fios, eixo simples, 2,2A, 1,10 Nm
    103-H7123-1740 motor de passo, alta efici阯cia, Nema 23, 6 fios, eixo simples, 4A, 1,10 Nm
    103-H7123-1710 motor de passo, alta efici阯cia, Nema 23, 6 fios, eixo duplo, 4A, 1,10 Nm
    103-H7126-0140 motor de passo, alta efici阯cia, Nema 23, 6 fios, eixo simples, 0,75A, 1,65 Nm
    103-H7126-0740 motor de passo, alta efici阯cia, Nema 23, 6 fios, eixo simples, 2,2A, 1,65 Nm
    103-H7126-0710 motor de passo, alta efici阯cia, Nema 23, 6 fios, eixo duplo, 2,2A, 1,65 Nm
    103-H7126-1740 motor de passo, alta efici阯cia, Nema 23, 4 fios, eixo simples, 4A, 1,65 Nm
    103-H7126-1712 motor de passo, alta efici阯cia, Nema 23, 4 fios, eixo duplo, 4A, 1,65 Nm
    103-H7126-6640 motor de passo, alta efici阯cia, Nema 23, 4 fios, eixo simples, 5,6A, 1,65 Nm - IP43
    103-H7126-6610 motor de passo, alta efici阯cia, Nema 23, 4 fios, eixo duplo, 5,6A, 1,65 Nm - IP43
    RTA Nema60
    103-H7823-1741 motor de passo, alta efici阯cia, 60 mm, 4 fios, eixo duplo, 4A, 3,0 Nm
    103-H7823-1711 motor de passo, alta efici阯cia, 60 mm, 4 fios, eixo simples, 4A, 3,0 Nm
    RTA Nema34
    103-807-6241 motor de passo, Nema 34, 8 fios, eixo simples, bpc 2,7A, 1,7 Nm - IP43
    103-807-6341 motor de passo, Nema 34, 8 fios, eixo simples, bpc 4,3A, 1,7 Nm - IP43
    103-807-6311 motor de passo, Nema 34, 8 fios, eixo duplo, bpc 4,3A, 1,7 Nm - IP43
    103-810-6 motor de passo, Nema 34, 8 fios, eixo simples, bpc 5,6A, 2,75 Nm
    103-814-6541 motor de passo, Nema 34, 8 fios, eixo simples, bpc 6,5A, 3,45 Nm - IP43
    103-814-6511 motor de passo, Nema 34, 8 fios, eixo duplo, bpc 6,5A, 3,45 Nm - IP43
    103-845-6741 motor de passo, Nema 34, 8 fios, eixo simples chaveta, bpc 9,5A, 5,1 Nm - IP43
    103-845-6711 motor de passo, Nema 34, 8 fios, eixo duplo chaveta, bpc 9,5A, 5,1 Nm - IP43
    103-845-67S1 motor de passo, Nema 34, 8 fios, eixo simples chaveta, bpc 9,5A, 5,1 Nm - IP55
    103-845-67S2 motor de passo, Nema 34, 4 fios conector, eixo simples chaveta, bpc 9,5A, 5,1 Nm - IP55
    103-845-67S3 motor de passo, Nema 34, 4 fios conector, eixo simples chaveta, bpc 4,75A, 5,1 Nm - IP55
    103-H8221-6241 motor de passo, alta efici阯cia, Nema 34, 4 fios, eixo simples chaveta, 6A, 3,0 Nm - IP43
    103-H8221-6211 motor de passo, alta efici阯cia, Nema 34, 4 fios, eixo duplo chaveta, 6A, 3,0 Nm - IP43
    103-H8222-6340 motor de passo, alta efici阯cia, Nema 34, 4 fios, eixo simples chaveta, 6A, 5,6 Nm - IP43
    103-H8222-6310 motor de passo, alta efici阯cia, Nema 34, 4 fios, eixo duplo chaveta, 6A, 5,6 Nm - IP43
    103-H8223-6540 motor de passo, alta efici阯cia, Nema 34, 4 fios, eixo simples chaveta, 9A, 7,9 Nm - IP43
    103-H8223-6510 motor de passo, alta efici阯cia, Nema 34, 4 fios, eixo duplo chaveta, 9A, 7,9 Nm - IP43
    RTA Nema42
    103-8932-6451 motor de passo, Nema 42, 8 fios conector, eixo simples chaveta, bpc 12,7A, 13,3 Nm - IP43
    103-8932-6421 motor de passo, Nema 42, 8 fios conector, eixo duplo chaveta, bpc 12,7A, 13,3 Nm - IP43
    103-8960-6551 motor de passo, Nema 42, 8 fios conector, eixo simples chaveta, bpc 14,1A, 20,6 Nm - IP43
    103-H89222-6541 motor de passo, alta efici阯cia, Nema 42, 4 fios, eixo simples chaveta, 10A, 16,2 Nm - IP43
    103-H89223-6641 motor de passo, alta efici阯cia, Nema 42, 4 fios, eixo simples chaveta, 12A, 24,6 Nm - IP43
    103-H89223-6611 motor de passo, alta efici阯cia, Nema 42, 4 fios, eixo duplo chaveta, 12A, 24,6 Nm - IP43
    Redutores - Bayside
    NE23 Redutor in-line, Nema 23, de 003 ?100, backlash 20 arc-min, efici阯cia 92".
    NE34-003 redutor nema, standard backlash, fator red. 3:1
    NE34-003LB redutor nema, low backlash, fator red. 3:1
    NE34-005 redutor nema, standard backlash, fator red. 5:1
    NE34-005LB redutor nema, low backlash, fator red. 5:1
    NE34-008 redutor nema, standard backlash, fator red. 8:1
    NE34-008LB redutor nema, low backlash, fator red. 8:1
    NE34-010 redutor nema, standard backlash, fator red. 10:1
    NE34-010LB redutor nema, low backlash, fator red. 10:1
    NE34-015 redutor nema, standard backlash, fator red. 15:1
    NE34-015LB redutor nema, low backlash, fator red. 15:1
    NE34-020 redutor nema , standard backlash, fator red. 20:1
    NE34-020LB redutor nema , low backlash, fator red. 20:1
    NE34-030 redutor nema, standard backlash, fator red. 30:1
    NE34-030LB redutor nema, low backlash, fator red. 30:1
    NE34-050 redutor nema, standard backlash, fator red. 50:1
    NE34-050LB redutor nema, low backlash, fator red. 50:1
    NE34-100 redutor nema, standard backlash, fator red. 100:1
    NE34-100LB redutor nema, low backlash, fator red. 100:1
    NE34 Redutor in-line, Nema 34, de 003 ?100, backlash 20 arc-min, efici阯cia 92".
    NE42-003 redutor nema, standard backlash, fator red. 3:1
    NE42-003LB redutor nema, low backlash, fator red. 3:1
    NE42-005 redutor nema, standard backlash, fator red. 5:1
    NE42-005LB redutor nema, low backlash, fator red. 5:1
    NE42-008 redutor nema, standard backlash, fator red. 8:1
    NE42-008LB redutor nema, low backlash, fator red. 8:1
    NE42-010 redutor nema, standard backlash, fator red. 10:1
    NE42-010LB redutor nema, low backlash, fator red. 10:1
    NE42-015 redutor nema, standard backlash, fator red. 15:1
    NE42-015LB redutor nema, low backlash, fator red. 15:1
    NE42-020 redutor nema, standard backlash, fator red. 20:1
    NE42-020LB redutor nema, low backlash, fator red. 20:1
    NE42-030 redutor nema, standard backlash, fator red. 30:1
    NE42-030LB redutor nema, low backlash, fator red. 30:1
    NE42-050 redutor nema, standard backlash, fator red. 50:1
    NE42-050LB redutor nema, low backlash, fator red. 50:1
    NE42-100 redutor nema, standard backlash, fator red. 100:1
    NE42-100LB redutor nema, low backlash, fator red. 100:1
    NE42 Redutor in-line, Nema 42, de 003 ?100, backlash 20 arc-min, efici阯cia 92".
    NE23 kits de montagem
    NE34 kits de montagem
    NE42 kits de montagem
    NR23S-001 redutor nema, standard backlash, fator red. 1:1
    NR23S-003 redutor nema, standard backlash, fator red. 3:1
    NR23S-005 redutor nema, standard backlash, fator red. 5:1
    NR23S-008 redutor nema, standard backlash, fator red. 8:1
    NR23S-010 redutor nema, standard backlash, fator red. 10:1
    NR23S-015 redutor nema, standard backlash, fator red. 15:1
    NR23S-020 redutor nema, standard backlash, fator red. 20:1
    NR23S-030 redutor nema, standard backlash, fator red. 30:1
    NR23S-050 redutor nema, standard backlash, fator red. 50:1
    NR23S-100 redutor nema, standard backlash, fator red. 100:1
    NR23S Redutor right-angle, Nema 23, de 001 ?100, backlash 30 arc-min, efici阯cia 92".
    NR34S-001 redutor nema, standard backlash, fator red. 1:1
    NR34S-001LB redutor nema,low backlash, fator red. 1:1
    NR34S-003 redutor nema, standard backlash, fator red. 3:1
    NR34S-003LB redutor nema, low backlash, fator red. 3:1
    NR34S-005 redutor nema, standard backlash, fator red. 5:1
    NR34S-005LB redutor nema, low backlash, fator red. 5:1
    NR34S-008 redutor nema, standard backlash, fator red. 8:1
    NR34S-008LB redutor nema, low backlash, fator red. 8:1
    NR34S-010 redutor nema, standard backlash, fator red. 10:1
    NR34S-010LB redutor nema, low backlash, fator red. 10:1
    NR34S-015 redutor nema, standard backlash, fator red. 15:1
    NR34S-015LB redutor nema, low backlash, fator red. 15:1
    NR34S-020 redutor nema, standard backlash, fator red. 20:1
    NR34S-020LB redutor nema, low backlash, fator red. 20:1
    NR34S-030 redutor nema, standard backlash, fator red. 30:1
    NR34S-030LB redutor nema, low backlash, fator red. 30:1
    NR34S-050 redutor nema, standard backlash, fator red. 50:1
    NR34S-050LB redutor nema, low backlash, fator red. 50:1
    NR34S-100 redutor nema, standard backlash, fator red. 100:1
    NR34S-100LB redutor nema, low backlash, fator red. 100:1
    NR34S Redutor right-angle, Nema 34, de 001 ?100, backlash 30 arc-min, efici阯cia 92".
    NR42S-001 redutor nema, standard backlash, fator red. 1:1
    NR42S-001LB redutor nema, low backlash, fator red. 1:1
    NR42S-003 redutor nema, standard backlash, fator red. 3:1
    NR42S-003LB redutor nema, low backlash, fator red. 3:1
    NR42S-005 redutor nema, standard backlash, fator red. 5:1
    NR42S-005LB redutor nema, low backlash, fator red. 5:1
    NR42S-008 redutor nema, standard backlash, fator red. 8:1
    NR42S-008LB redutor nema, low backlash, fator red. 8:1
    NR42S-010 redutor nema, standard backlash, fator red. 10:1
    NR42S-010LB redutor nema, low backlash, fator red. 10:1
    NR42S-015 redutor nema , standard backlash, fator red. 15:1
    NR42S-015LB redutor nema, low backlash, fator red. 15:1
    NR42S-020 redutor nema, standard backlash, fator red. 20:1
    NR42S-020LB redutor nema, low backlash, fator red. 20:1
    NR42S-030 redutor nema, standard backlash, fator red. 30:1
    NR42S-030LB redutor nema, low backlash, fator red. 30:1
    NR42S-050 redutor nema, standard backlash, fator red. 50:1
    NR42S-050LB redutor nema, low backlash, fator red. 50:1
    NR42S-100 redutor nema, standard backlash, fator red. 100:1
    NR42S-100LB redutor nema, low backlash, fator red. 100:1
    NR42S Redutor right-angle, Nema 42, de 001 ?100, backlash 30 arc-min, efici阯cia 92".
    NR23 kits de montagem
    NR34 kits de montagem
    NR42 kits de montagem
    PG60-005 redutor planet醨io, standard backlash, fator red.5:1
    PG60-008 redutor planet醨io, standard backlash, fator red. 8:1
    PG60-010 redutor planet醨io, standard backlash, fator red. 10:1
    PG60-015 redutor planet醨io, standard backlash, fator red. 15:1
    PG60-020 redutor planet醨io, standard backlash, fator red. 20:1
    PG60-030 redutor planet醨io, standard backlash, fator red. 30:1
    PG60-050 redutor planet醨io, standard backlash, fator red. 50:1
    PG60-100 redutor planet醨io, standard backlash, fator red. 100:1
    PG60 Redutor planet醨io, in-line, 60mm, de 005 ?100, backlash 10 arc-min, efici阯cia 90".
    PG90-005 redutor planet醨io, standard backlash, fator red.5:1
    PG90-008 redutor planet醨io, standard backlash, fator red. 8:1
    PG90-010 redutor planet醨io, standard backlash, fator red. 10:1
    PG90-015 redutor planet醨io, standard backlash, fator red. 15:1
    PG90-020 redutor planet醨io, standard backlash, fator red. 20:1
    PG90-030 redutor planet醨io, standard backlash, fator red. 30:1
    PG90-050 redutor planet醨io, standard backlash, fator red. 50:1
    PG90-100 redutor planet醨io, standard backlash, fator red. 100:1
    PG90 Redutor planet醨io, in-line, 90mm, de 005 ?100, backlash 10 arc-min, efici阯cia 90".
    PG115-005 redutor planet醨io, standard backlash, fator red.5:1
    PG115-008 redutor planet醨io, standard backlash, fator red. 8:1
    PG115-010 redutor planet醨io, standard backlash, fator red. 10:1
    PG115-015 redutor planet醨io, standard backlash, fator red. 15:1
    PG115-020 redutor planet醨io, standard backlash, fator red. 20:1
    PG115-030 redutor planet醨io, standard backlash, fator red. 30:1
    PG115-050 redutor planet醨io, standard backlash, fator red. 50:1
    PG115-100 redutor planet醨io, standard backlash, fator red. 100:1
    PG115 Redutor planet醨io, in-line, 115mm, de 005 ?100, backlash 10 arc-min, efici阯cia 90".
    PG142-005 redutor planet醨io, standard backlash, fator red.5:1
    PG142-008 redutor planet醨io, standard backlash, fator red. 8:1
    PG142-010 redutor planet醨io, standard backlash, fator red. 10:1
    PG142-015 redutor planet醨io, standard backlash, fator red. 15:1
    PG142-020 redutor planet醨io, standard backlash, fator red. 20:1
    PG142-030 redutor planet醨io, standard backlash, fator red. 30:1
    PG142-050 redutor planet醨io, standard backlash, fator red. 50:1
    PG142-100 redutor planet醨io, standard backlash, fator red. 100:1
    PG142 Redutor planet醨io, in-line, 142mm, de 005 ?100, backlash 10 arc-min, efici阯cia 90".
    PG180-005 redutor planet醨io, standard backlash, fator red.5:1
    PG180-008 redutor planet醨io, standard backlash, fator red. 8:1
    PG180-010 redutor planet醨io, standard backlash, fator red. 10:1
    PG180-015 redutor planet醨io, standard backlash, fator red. 15:1
    PG180-020 redutor planet醨io, standard backlash, fator red. 20:1
    PG180-030 redutor planet醨io, standard backlash, fator red. 30:1
    PG180-050 redutor planet醨io, standard backlash, fator red. 50:1
    PG180-100 redutor planet醨io, standard backlash, fator red. 100:1
    PG180 Redutor planet醨io, in-line, 180mm, de 005 ?100, backlash 10 arc-min, efici阯cia 90".
    PG90-005LB redutor planet醨io, low backlash, fator red. 5:1
    PG90-008LB redutor planet醨io, low backlash, fator red. 8:1
    PG90-010LB redutor planet醨io, low backlash, fator red. 10:1
    PG90-015LB redutor planet醨io, low backlash, fator red. 15:1
    PG90-020LB redutor planet醨io, low backlash, fator red. 20:1
    PG90-030LB redutor planet醨io, low backlash, fator red. 30:1
    PG90-050LB redutor planet醨io, low backlash, fator red. 50:1
    PG90-100LB redutor planet醨io, low backlash, fator red. 100:1
    PG90-LB Redutor planet醨io, in-line, 90mm, de 005 ?100, backlash 5 arc-min, efici阯cia 90".
    PG115-005LB redutor planet醨io, low backlash, fator red. 5:1
    PG115-008LB redutor planet醨io, low backlash, fator red. 8:1
    PG115-010LB redutor planet醨io, low backlash, fator red. 10:1
    PG115-015LB redutor planet醨io, low backlash, fator red. 15:1
    PG115-020LB redutor planet醨io, low backlash, fator red. 20:1
    PG115-030LB redutor planet醨io, low backlash, fator red. 30:1
    PG115-050LB redutor planet醨io, low backlash, fator red. 50:1
    PG115-100LB redutor planet醨io, low backlash, fator red. 100:1
    PG115-LB Redutor planet醨io, in-line, 115mm, de 005 ?100, backlash 5 arc-min, efici阯cia 90".
    PG142-005LB redutor planet醨io, low backlash, fator red. 5:1
    PG142-008LB redutor planet醨io, low backlash, fator red. 8:1
    PG142-010LB redutor planet醨io, low backlash, fator red. 10:1
    PG142-015LB redutor planet醨io, low backlash, fator red. 15:1
    PG142-020LB redutor planet醨io, low backlash, fator red. 20:1
    PG142-030LB redutor planet醨io, low backlash, fator red. 30:1
    PG142-050LB redutor planet醨io, low backlash, fator red. 50:1
    PG142-100LB redutor planet醨io, low backlash, fator red. 100:1
    PG142-LB Redutor planet醨io, in-line, 142mm, de 005 ?100, backlash 5 arc-min, efici阯cia 90".
    PG180-005LB redutor planet醨io, low backlash, fator red. 5:1
    PG180-008LB redutor planet醨io, low backlash, fator red. 8:1
    PG180-010LB redutor planet醨io, low backlash, fator red. 10:1
    PG180-015LB redutor planet醨io, low backlash, fator red. 15:1
    PG180-020LB redutor planet醨io, low backlash, fator red. 20:1
    PG180-030LB redutor planet醨io, low backlash, fator red. 30:1
    PG180-050LB redutor planet醨io, low backlash, fator red. 50:1
    PG180-100LB redutor planet醨io, low backlash, fator red. 100:1
    PG180-LB Redutor planet醨io, in-line, 180mm, de 005 ?100, backlash 5 arc-min, efici阯cia 90".
    RA60-005 redutor 90? standard backlash, fator red.5:1
    RA60-008 redutor 90? standard backlash, fator red.8:1
    RA60-010 redutor 90? standard backlash, fator red.10:1
    RA60-015 redutor 90? standard backlash, fator red.15:1
    RA60-020 redutor 90? standard backlash, fator red.20:1
    RA60-030 redutor 90? standard backlash, fator red.30:1
    RA60-050 redutor 90? standard backlash, fator red.50:1
    RA60-100 redutor 90? standard backlash, fator red.100:1
    RA60 Redutor planet醨io, right-angle, 60mm, de 005 ?100
    RA90-005 redutor 90? standard backlash, fator red.5:1
    RA90-005LB redutor 90? low backlash, fator red.5:1
    RA90-008 redutor 90? standard backlash, fator red.8:1
    RA90-008LB redutor 90? low backlash, fator red.8:1
    RA90-010 redutor 90? standard backlash, fator red.10:1
    RA90-010LB redutor 90? low backlash, fator red.10:1
    RA90-015 redutor 90? standard backlash, fator red.15:1
    RA90-015LB redutor 90? low backlash, fator red.15:1
    RA90-020 redutor 90? standard backlash, fator red.20:1
    RA90-020LB redutor 90? low backlash, fator red.20:1
    RA90-030 redutor 90? standard backlash, fator red.30:1
    RA90-030LB redutor 90? low backlash, fator red.30:1
    RA90-050 redutor 90? standard backlash, fator red.50:1
    RA90-050LB redutor 90? low backlash, fator red.50:1
    RA90-100 redutor 90? standard backlash, fator red.100:1
    RA90-100LB redutor 90? low backlash, fator red.100:1
    RA90 Redutor planet醨io, right-angle, 90mm, de 005 ?100
    RA115-005 redutor 90? standard backlash, fator red.5:1
    RA115-005LB redutor 90? low backlash, fator red.5:1
    RA115-008 redutor 90? standard backlash, fator red.8:1
    RA115-008LB redutor 90? low backlash, fator red.8:1
    RA115-010 redutor 90? standard backlash, fator red.10:1
    RA115-010LB redutor 90? low backlash, fator red.10:1
    RA115-015 redutor 90? standard backlash, fator red.15:1
    RA115-015LB redutor 90? low backlash, fator red.15:1
    RA115-020 redutor 90? standard backlash, fator red.20:1
    RA115-020LB redutor 90? low backlash, fator red.20:1
    RA115-030 redutor 90? standard backlash, fator red.30:1
    RA115-030LB redutor 90? low backlash, fator red.30:1
    RA115-50 redutor 90? standard backlash, fator red.50:1
    RA115-50LB redutor 90? low backlash, fator red.50:1
    RA115-100 redutor 90? standard backlash, fator red.100:1
    RA115-100LB redutor 90? low backlash, fator red.100:1
    RA115 Redutor planet醨io, right-angle, 115mm, de 005 ?100
    RA142-005 redutor 90? standard backlash, fator red.5:1
    RA142-005LB redutor 90? low backlash, fator red.5:1
    RA142-008 redutor 90? standard backlash, fator red.8:1
    RA142-008LB redutor 90? low backlash, fator red.8:1
    RA142-010 redutor 90? standard backlash, fator red.10:1
    RA142-010LB redutor 90? low backlash, fator red.10:1
    RA142-015 redutor 90? standard backlash, fator red.15:1
    RA142-015LB redutor 90? low backlash, fator red.15:1
    RA142-020 redutor 90? standard backlash, fator red.20:1
    RA142-020LB redutor 90? low backlash, fator red.20:1
    RA142-030 redutor 90? standard backlash, fator red.30:1
    RA142-030LB redutor 90? low backlash, fator red.30:1
    RA142-50 redutor 90? standard backlash, fator red.50:1
    RA142-50LB redutor 90? low backlash, fator red.50:1
    RA142-100 redutor 90? standard backlash, fator red.100:1
    RA142-100LB redutor 90? low backlash, fator red.100:1
    RA142 Redutor planet醨io, right-angle, 142mm, de 005 ?100
    RA180-005 redutor 90? standard backlash, fator red.5:1
    RA180-005LB redutor 90? low backlash, fator red.5:1
    RA180-008 redutor 90? standard backlash, fator red.8:1
    RA180-008LB redutor 90? low backlash, fator red.8:1
    RA180-010 redutor 90? standard backlash, fator red.10:1
    RA180-010LB redutor 90? low backlash, fator red.10:1
    RA180-015 redutor 90? standard backlash, fator red.15:1
    RA180-015LB redutor 90? low backlash, fator red.15:1
    RA180-020 redutor 90? standard backlash, fator red.20:1
    RA180-020LB redutor 90? low backlash, fator red.20:1
    RA180-030 redutor 90? standard backlash, fator red.30:1
    RA180-030LB redutor 90? low backlash, fator red.30:1
    RA180-50 redutor 90? standard backlash, fator red.50:1
    RA180-50LB redutor 90? low backlash, fator red.50:1
    RA180-100 redutor 90? standard backlash, fator red.100:1
    RA180-100LB redutor 90? low backlash, fator red.100:1
    RA180 Redutor planet醨io, right-angle, 180mm, de 005 ?100
    PS40-004 redutor planet醨io helicoidal, standard backlash, fator red. 4:1
    PS40-005 redutor planet醨io helicoidal, standard backlash, fator red. 5:1
    PS40-007 redutor planet醨io helicoidal, standard backlash, fator red. 7:1
    PS40-010 redutor planet醨io helicoidal, standard backlash, fator red. 10:1
    PS40-016 redutor planet醨io helicoidal, standard backlash, fator red. 16:1
    PS40-020 redutor planet醨io helicoidal, standard backlash, fator red. 20:1
    PS40-025 redutor planet醨io helicoidal, standard backlash, fator red. 25:1
    PS40-040 redutor planet醨io helicoidal, standard backlash, fator red. 40:1
    PS40-050 redutor planet醨io helicoidal, standard backlash, fator red. 50:1
    PS40-070 redutor planet醨io helicoidal, standard backlash, fator red. 70:1
    PS40-100 redutor planet醨io helicoidal, standard backlash, fator red. 100:1
    PS40 Redutor planet醨io, in-line, helicoidal, 40mm, de 005 ? 100
    PS60-003 redutor planet醨io helicoidal, standard backlash, fator red. 3:1
    PS60-003LB redutor planet醨io helicoidal, low backlash, fator red. 3:1
    PS60-005 redutor planet醨io helicoidal, standard backlash, fator red. 5:1
    PS60-005LB redutor planet醨io helicoidal, low backlash, fator red. 5:1
    PS60-007 redutor planet醨io helicoidal, standard backlash, fator red. 7:1
    PS60-007LB redutor planet醨io helicoidal, low backlash, fator red. 7:1
    PS60-010 redutor planet醨io helicoidal, standard backlash, fator red. 10:1
    PS60-010LB redutor planet醨io helicoidal, low backlash, fator red. 10:1
    PS60-015 redutor planet醨io helicoidal, standard backlash, fator red. 15:1
    PS60-015LB redutor planet醨io helicoidal, low backlash, fator red. 15:1
    PS60-020 redutor planet醨io helicoidal, standard backlash, fator red. 20:1
    PS60-020LB redutor planet醨io helicoidal, low backlash, fator red. 20:1
    PS60-025 redutor planet醨io helicoidal, standard backlash, fator red. 25:1
    PS60-025LB redutor planet醨io helicoidal, low backlash, fator red. 25:1
    PS60-030 redutor planet醨io helicoidal, standard backlash, fator red. 30:1
    PS60-030LB redutor planet醨io helicoidal, low backlash, fator red. 30:1
    PS60-040 redutor planet醨io helicoidal, standard backlash, fator red. 40:1
    PS60-040LB redutor planet醨io helicoidal, low backlash, fator red. 40:1
    PS60-050 redutor planet醨io helicoidal, standard backlash, fator red. 50:1
    PS60-050LB redutor planet醨io helicoidal, low backlash, fator red. 50:1
    PS60-070 redutor planet醨io helicoidal, standard backlash, fator red. 70:1
    PS60-070LB redutor planet醨io helicoidal, low backlash, fator red. 70:1
    PS60-100 redutor planet醨io helicoidal, standard backlash, fator red. 100:1
    PS60-100LB redutor planet醨io helicoidal, low backlash, fator red. 100:1
    PS60 Redutor planet醨io, in-line, helicoidal, 60mm, de 005 ? 100
    PS90-003 redutor planet醨io helicoidal, standard backlash, fator red. 3:1
    PS90-003LB redutor planet醨io helicoidal, low backlash, fator red. 3:1
    PS90-005 redutor planet醨io helicoidal, standard backlash, fator red. 5:1
    PS90-005LB redutor planet醨io helicoidal, low backlash, fator red. 5:1
    PS90-007 redutor planet醨io helicoidal, standard backlash, fator red. 7:1
    PS90-007LB redutor planet醨io helicoidal, low backlash, fator red. 7:1
    PS90-010 redutor planet醨io helicoidal, standard backlash, fator red. 10:1
    PS90-010LB redutor planet醨io helicoidal, low backlash, fator red. 10:1
    PS90-015 redutor planet醨io helicoidal, standard backlash, fator red. 15:1
    PS90-015LB redutor planet醨io helicoidal, low backlash, fator red. 15:1
    PS90-020 redutor planet醨io helicoidal, standard backlash, fator red. 20:1
    PS90-020LB redutor planet醨io helicoidal, low backlash, fator red. 20:1
    PS90-025 redutor planet醨io helicoidal, standard backlash, fator red. 25:1
    PS90-025LB redutor planet醨io helicoidal, low backlash, fator red. 25:1
    PS90-030 redutor planet醨io helicoidal, standard backlash, fator red. 30:1
    PS90-030LB redutor planet醨io helicoidal, low backlash, fator red. 30:1
    PS90-040 redutor planet醨io helicoidal, standard backlash, fator red. 40:1
    PS90-040LB redutor planet醨io helicoidal, low backlash, fator red. 40:1
    PS90-050 redutor planet醨io helicoidal, standard backlash, fator red. 50:1
    PS90-050LB redutor planet醨io helicoidal, low backlash, fator red. 50:1
    PS90-070 redutor planet醨io helicoidal, standard backlash, fator red. 70:1
    PS90-070LB redutor planet醨io helicoidal, low backlash, fator red. 70:1
    PS90-100 redutor planet醨io helicoidal, standard backlash, fator red. 100:1
    PS90-100LB redutor planet醨io helicoidal, low backlash, fator red. 100:1
    PS90 Redutor planet醨io, in-line, helicoidal, 90mm, de 005 ? 100
    PS115-003 redutor planet醨io helicoidal, standard backlash, fator red. 3:1
    PS115-003LB redutor planet醨io helicoidal, low backlash, fator red. 3:1
    PS115-005 redutor planet醨io helicoidal, standard backlash, fator red. 5:1
    PS115-005LB redutor planet醨io helicoidal, low backlash, fator red. 5:1
    PS115-007 redutor planet醨io helicoidal, standard backlash, fator red. 7:1
    PS115-007LB redutor planet醨io helicoidal, low backlash, fator red. 7:1
    PS115-010 redutor planet醨io helicoidal, standard backlash, fator red. 10:1
    PS115-010LB redutor planet醨io helicoidal, low backlash, fator red. 10:1
    PS115-015 redutor planet醨io helicoidal, standard backlash, fator red. 15:1
    PS115-015LB redutor planet醨io helicoidal, low backlash, fator red. 15:1
    PS115-020 redutor planet醨io helicoidal, standard backlash, fator red. 20:1
    PS115-020LB redutor planet醨io helicoidal, low backlash, fator red. 20:1
    PS115-025 redutor planet醨io helicoidal, standard backlash, fator red. 25:1
    PS115-025LB redutor planet醨io helicoidal, low backlash, fator red. 25:1
    PS115-030 redutor planet醨io helicoidal, standard backlash, fator red. 30:1
    PS115-030LB redutor planet醨io helicoidal, low backlash, fator red. 30:1
    PS115-040 redutor planet醨io helicoidal, standard backlash, fator red. 40:1
    PS115-040LB redutor planet醨io helicoidal, low backlash, fator red. 40:1
    PS115-050 redutor planet醨io helicoidal, standard backlash, fator red. 50:1
    PS115-050LB redutor planet醨io helicoidal, low backlash, fator red. 50:1
    PS115-070 redutor planet醨io helicoidal, standard backlash, fator red. 70:1
    PS115-070LB redutor planet醨io helicoidal, low backlash, fator red. 70:1
    PS115-100 redutor planet醨io helicoidal, standard backlash, fator red. 100:1
    PS115-100LB redutor planet醨io helicoidal, low backlash, fator red. 100:1
    PS115 Redutor planet醨io, in-line, helicoidal, 115mm, de 005 ? 100
    PS142-003 redutor planet醨io helicoidal, standard backlash, fator red. 3:1
    PS142-003LB redutor planet醨io helicoidal, low backlash, fator red. 3:1
    PS142-005 redutor planet醨io helicoidal, standard backlash, fator red. 5:1
    PS142-005LB redutor planet醨io helicoidal, low backlash, fator red. 5:1
    PS142-007 redutor planet醨io helicoidal, standard backlash, fator red. 7:1
    PS142-007LB redutor planet醨io helicoidal, low backlash, fator red. 7:1
    PS142-010 redutor planet醨io helicoidal, standard backlash, fator red. 10:1
    PS142-010LB redutor planet醨io helicoidal, low backlash, fator red. 10:1
    PS142-015 redutor planet醨io helicoidal, standard backlash, fator red. 15:1
    PS142-015LB redutor planet醨io helicoidal, low backlash, fator red. 15:1
    PS142-020 redutor planet醨io helicoidal, standard backlash, fator red. 20:1
    PS142-020LB redutor planet醨io helicoidal, low backlash, fator red. 20:1
    PS142-025 redutor planet醨io helicoidal, standard backlash, fator red. 25:1
    PS142-025LB redutor planet醨io helicoidal, low backlash, fator red. 25:1
    PS142-030 redutor planet醨io helicoidal, standard backlash, fator red. 30:1
    PS142-030LB redutor planet醨io helicoidal, low backlash, fator red. 30:1
    PS142-040 redutor planet醨io helicoidal, standard backlash, fator red. 40:1
    PS142-040LB redutor planet醨io helicoidal, low backlash, fator red. 40:1
    PS142-050 redutor planet醨io helicoidal, standard backlash, fator red. 50:1
    PS142-050LB redutor planet醨io helicoidal, low backlash, fator red. 50:1
    PS142-070 redutor planet醨io helicoidal, standard backlash, fator red. 70:1
    PS142-070LB redutor planet醨io helicoidal, low backlash, fator red. 70:1
    PS142-100 redutor planet醨io helicoidal, standard backlash, fator red. 100:1
    PS142-100LB redutor planet醨io helicoidal, low backlash, fator red. 100:1
    PS142 Redutor planet醨io, in-line, helicoidal, 142mm, de 005 ? 100
    PS180-003 redutor planet醨io helicoidal, standard backlash, fator red. 3:1
    PS180-003LB redutor planet醨io helicoidal, low backlash, fator red. 3:1
    PS180-005 redutor planet醨io helicoidal, standard backlash, fator red. 5:1
    PS180-005LB redutor planet醨io helicoidal, low backlash, fator red. 5:1
    PS180-007 redutor planet醨io helicoidal, standard backlash, fator red. 7:1
    PS180-007LB redutor planet醨io helicoidal, low backlash, fator red. 7:1
    PS180-010 redutor planet醨io helicoidal, standard backlash, fator red. 10:1
    PS180-010LB redutor planet醨io helicoidal, low backlash, fator red. 10:1
    PS180-015 redutor planet醨io helicoidal, standard backlash, fator red. 15:1
    PS180-015LB redutor planet醨io helicoidal, low backlash, fator red. 15:1
    PS180-020 redutor planet醨io helicoidal, standard backlash, fator red. 20:1
    PS180-020LB redutor planet醨io helicoidal, low backlash, fator red. 20:1
    PS180-025 redutor planet醨io helicoidal, standard backlash, fator red. 25:1
    PS180-025LB redutor planet醨io helicoidal, low backlash, fator red. 25:1
    PS180-030 redutor planet醨io helicoidal, standard backlash, fator red. 30:1
    PS180-030LB redutor planet醨io helicoidal, low backlash, fator red. 30:1
    PS180-040 redutor planet醨io helicoidal, standard backlash, fator red. 40:1
    PS180-040LB redutor planet醨io helicoidal, low backlash, fator red. 40:1
    PS180-050 redutor planet醨io helicoidal, standard backlash, fator red. 50:1
    PS180-050LB redutor planet醨io helicoidal, low backlash, fator red. 50:1
    PS180-070 redutor planet醨io helicoidal, standard backlash, fator red. 70:1
    PS180-070LB redutor planet醨io helicoidal, low backlash, fator red. 70:1
    PS180-100 redutor planet醨io helicoidal, standard backlash, fator red. 100:1
    PS180-100LB redutor planet醨io helicoidal, low backlash, fator red. 100:1
    PS180 Redutor planet醨io, in-line, helicoidal, 180mm, de 005 ? 100
    PS220-003 redutor planet醨io helicoidal, standard backlash, fator red.3:1
    PS220-003LB redutor planet醨io helicoidal, low backlash, fator red. 3:1
    PS220-005 redutor planet醨io helicoidal, standard backlash, fator red. 5:1
    PS220-005LB redutor planet醨io helicoidal, low backlash, fator red. 5:1
    PS220-007 redutor planet醨io helicoidal, standard backlash, fator red. 7:1
    PS220-007LB redutor planet醨io helicoidal, low backlash, fator red. 7:1
    PS220-010 redutor planet醨io helicoidal, standard backlash, fator red. 10:1
    PS220-010LB redutor planet醨io helicoidal, low backlash, fator red. 10:1
    PS220-015 redutor planet醨io helicoidal, standard backlash, fator red. 15:1
    PS220-015LB redutor planet醨io helicoidal, low backlash, fator red. 15:1
    PS220-020 redutor planet醨io helicoidal, standard backlash, fator red. 20:1
    PS220-020LB redutor planet醨io helicoidal, low backlash, fator red. 20:1
    PS220-025 redutor planet醨io helicoidal, standard backlash, fator red. 25:1
    PS220-025LB redutor planet醨io helicoidal, low backlash, fator red. 25:1
    PS220-030 redutor planet醨io helicoidal, standard backlash, fator red. 30:1
    PS220-030LB redutor planet醨io helicoidal, low backlash, fator red. 30:1
    PS220-040 redutor planet醨io helicoidal, standard backlash, fator red. 40:1
    PS220-040LB redutor planet醨io helicoidal, low backlash, fator red. 40:1
    PS220-050 redutor planet醨io helicoidal, standard backlash, fator red. 50:1
    PS220-050LB redutor planet醨io helicoidal, low backlash, fator red. 50:1
    PS220-070 redutor planet醨io helicoidal, standard backlash, fator red. 70:1
    PS220-070LB redutor planet醨io helicoidal, low backlash, fator red. 70:1
    PS220-100 redutor planet醨io helicoidal, standard backlash, fator red. 100:1
    PS220-100LB redutor planet醨io helicoidal, low backlash, fator red. 100:1
    PS220 Redutor planet醨io, in-line, helicoidal, 220mm, de 005 ? 100
    PS300-003 redutor planet醨io helicoidal, standard backlash, fator red.3:1
    PS300-003LB redutor planet醨io helicoidal, low backlash, fator red. 3:1
    PS300-005 redutor planet醨io helicoidal, standard backlash, fator red. 5:1
    PS300-005LB redutor planet醨io helicoidal, low backlash, fator red. 5:1
    PS300-007 redutor planet醨io helicoidal, standard backlash, fator red. 7:1
    PS300-007LB redutor planet醨io helicoidal, low backlash, fator red. 7:1
    PS300-010 redutor planet醨io helicoidal, standard backlash, fator red. 10:1
    PS300-010LB redutor planet醨io helicoidal, low backlash, fator red. 10:1
    PS300-015 redutor planet醨io helicoidal, standard backlash, fator red. 15:1
    PS300-015LB redutor planet醨io helicoidal, low backlash, fator red. 15:1
    PS300-020 redutor planet醨io helicoidal, standard backlash, fator red. 20:1
    PS300-020LB redutor planet醨io helicoidal, low backlash, fator red. 20:1
    PS300-025 redutor planet醨io helicoidal, standard backlash, fator red. 25:1
    PS300-025LB redutor planet醨io helicoidal, low backlash, fator red. 25:1
    PS300-030 redutor planet醨io helicoidal, standard backlash, fator red. 30:1
    PS300-030LB redutor planet醨io helicoidal, low backlash, fator red. 30:1
    PS300-040 redutor planet醨io helicoidal, standard backlash, fator red. 40:1
    PS300-040LB redutor planet醨io helicoidal, low backlash, fator red. 40:1
    PS300-050 redutor planet醨io helicoidal, standard backlash, fator red. 50:1
    PS300-050LB redutor planet醨io helicoidal, low backlash, fator red. 50:1
    PS300-070 redutor planet醨io helicoidal, standard backlash, fator red. 70:1
    PS300-070LB redutor planet醨io helicoidal, low backlash, fator red. 70:1
    PS300-100 redutor planet醨io helicoidal, standard backlash, fator red. 100:1
    PS300-100LB redutor planet醨io helicoidal, low backlash, fator red. 100:1
    PS300 Redutor planet醨io, in-line, helicoidal, 300mm, de 005 ? 100
    RB90-001 redutor sem fim/coroa, standard backlash, fator red. 1:1
    RB90-001LB redutor sem fim/coroa, low backlash, fator red. 1:1
    RB90-002 redutor sem fim/coroa, low backlash, fator red. 2:1
    RB90LB redutor sem fim/coroa, low backlash, fator red. 2:1
    RB90-003 redutor sem fim/coroa, low backlash, fator red. 3:1
    RB90-003LB redutor sem fim/coroa, low backlash, fator red. 3:1
    RB90 redutor sem-fim-coroa, 1 ?3
    RB115-001 redutor sem fim/coroa, standard backlash, fator red. 1:1
    RB115-001LB redutor sem fim/coroa, standard backlash, fator red. 1:1
    RB115-002 redutor sem fim/coroa, standard backlash, fator red. 2:1
    RB115-002LB redutor sem fim/coroa, standard backlash, fator red. 2:1
    RB115-003 redutor sem fim/coroa, standard backlash, fator red. 3:1
    RB115-003LB redutor sem fim/coroa, standard backlash, fator red. 3:1
    RB115 redutor sem-fim-coroa, 1 ?3
    RB142-001 redutor sem fim/coroa, standard backlash, fator red. 3:1
    RB142-001LB redutor sem fim/coroa, standard backlash, fator red. 1:1
    RB142-002 redutor sem fim/coroa, standard backlash, fator red. 2:1
    RB142-002LB redutor sem fim/coroa, standard backlash, fator red. 2:1
    RB142-003 redutor sem fim/coroa, standard backlash, fator red. 3:1
    RB142-003LB redutor sem fim/coroa, standard backlash, fator red. 3:1
    RB142 redutor sem-fim-coroa, 1 ?3
    RB180-001 redutor sem fim/coroa, standard backlash, fator red. 1:1
    RB180-001LB redutor sem fim/coroa, standard backlash, fator red. 1:1
    RB180-002 redutor sem fim/coroa, standard backlash, fator red. 2:1
    RB180-002LB redutor sem fim/coroa, standard backlash, fator red. 2:1
    RB180-003 redutor sem fim/coroa, standard backlash, fator red. 3:1
    RB180-003LB redutor sem fim/coroa, standard backlash, fator red. 3:1
    RB180 redutor sem-fim-coroa, 1 ?3
    RB220-001 redutor sem fim/coroa, standard backlash, fator red. 1:1
    RB220-001LB redutor sem fim/coroa, standard backlash, fator red. 1:1
    RB220-002 redutor sem fim/coroa, standard backlash, fator red. 2:1
    RB220-002LB redutor sem fim/coroa, standard backlash, fator red. 2:1
    RB220-003 redutor sem fim/coroa, standard backlash, fator red. 3:1
    RB220-003LB redutor sem fim/coroa, standard backlash, fator red. 3:1
    RB220 redutor sem-fim-coroa, 1 ?3
    RD90-001
    RD90-001LB
    RD90-002
    RD90-002LB
    RD90-003
    RD90-003LB
    RD90-009
    RD90-009LB
    RD90-015
    RD90-015LB
    RD90-021
    RD90-021LB
    RD90-030
    RD90-030LB
    RD90 ??
    RD115-001
    RD115-001LB
    RD115-002
    RD115-002LB
    RD115-003
    RD115-003LB
    RD115-009
    RD115-009LB
    RD115-015
    RD115-015LB
    RD115-021
    RD115-021LB
    RD115-030
    RD115-030LB
    RD115
    RD142-001
    RD142-001LB
    RD142-002
    RD142-002LB
    RD142-003
    RD142-003LB
    RD142-009
    RD142-009LB
    RD142-015
    RD142-015LB
    RD142-021
    RD142-021LB
    RD142-030
    RD142-030LB
    RD142
    RD180-001
    RD180-001LB
    RD180-002
    RD180-002LB
    RD180-003
    RD180-003LB
    RD180-009
    RD180-009LB
    RD180-015
    RD180-015LB
    RD180-021
    RD180-021LB
    RD180-030
    RD180-030LB
    RD180
    RD220-001
    RD220-001LB
    RD220-002
    RD220-002LB
    RD220-003
    RD220-003LB
    RD220-009
    RD220-009LB
    RD220-015
    RD220-015LB
    RD220-021
    RD220-021LB
    RD220-030
    RD220-030LB
    RD220
    RT90-003 redutor panet醨io helicoidal 90?sem eixo, standard blacklash, fator red. 3:1
    RT90-003LB redutor panet醨io helicoidal 90?sem eixo, standard blacklash, fator red. 3:1
    RT90-009 redutor panet醨io helicoidal 90?sem eixo, standard blacklash, fator red. 9:1
    RT90-009LB redutor panet醨io helicoidal 90?sem eixo, standard blacklash, fator red. 9:1
    RT90-015 redutor panet醨io helicoidal 90?sem eixo, standard blacklash, fator red. 15:1
    RT90-015LB redutor panet醨io helicoidal 90?sem eixo, standard blacklash, fator red. 15:1
    RT90-021 redutor panet醨io helicoidal 90?sem eixo, standard blacklash, fator red. 21:1
    RT90-021LB redutor panet醨io helicoidal 90?sem eixo, standard blacklash, fator red. 21:1
    RT90-030 redutor panet醨io helicoidal 90?sem eixo, standard blacklash, fator red. 30:1
    RT90-030LB redutor panet醨io helicoidal 90?sem eixo, standard blacklash, fator red. 30:1
    RT90 sem eixo
    RT115-003 redutor planet醨io helicoidal 90?sem eixo, standard backlash, fator red. 3:1
    RT115-003LB redutor planet醨io helicoidal 90?sem eixo, low backlash, fator red. 3:1
    RT115-009 redutor planet醨io helicoidal 90?sem eixo, standard backlash, fator red. 9:1
    RT115-009LB redutor planet醨io helicoidal 90?sem eixo, low backlash, fator red. 9:1
    RT115-015 redutor planet醨io helicoidal 90?sem eixo, standard backlash, fator red. 15:1
    RT115-015LB redutor planet醨io helicoidal 90?sem eixo, low backlash, fator red. 15:1
    RT115-021 redutor planet醨io helicoidal 90?sem eixo, standard backlash, fator red. 21:1
    RT115-021LB redutor planet醨io helicoidal 90?sem eixo, low backlash, fator red. 21:1
    RT115-030 redutor planet醨io helicoidal 90?sem eixo, standard backlash, fator red. 30:1
    RT115-030LB redutor planet醨io helicoidal 90?sem eixo, low backlash, fator red. 30:1
    RT115
    RT142-003 redutor planet醨io helicoidal 90?sem eixo, standard backlash, fator red. 3:1
    RT142-003LB redutor planet醨io helicoidal 90?sem eixo, low backlash, fator red. 3:1
    RT142-009 redutor planet醨io helicoidal 90?sem eixo, standard backlash, fator red. 9:1
    RT142-009LB redutor planet醨io helicoidal 90?sem eixo, low backlash, fator red. 9:1
    RT142-015 redutor planet醨io helicoidal 90?sem eixo, standard backlash, fator red. 15:1
    RT142-015LB redutor planet醨io helicoidal 90?sem eixo, low backlash, fator red. 15:1
    RT142-021 redutor planet醨io helicoidal 90?sem eixo, standard backlash, fator red. 21:1
    RT142-021LB redutor planet醨io helicoidal 90?sem eixo, low backlash, fator red. 21:1
    RT142-030 redutor planet醨io helicoidal 90?sem eixo, standard backlash, fator red. 30:1
    RT142-030LB redutor planet醨io helicoidal 90?sem eixo, low backlash, fator red. 30:1
    RT142
    RT180-003 redutor planet醨io helicoidal 90?sem eixo, standard backlash, fator red. 3:1
    RT180-003LB redutor planet醨io helicoidal 90?sem eixo, low backlash, fator red. 3:1
    RT180-009 redutor planet醨io helicoidal 90?sem eixo, standard backlash, fator red. 9:1
    RT180-009LB redutor planet醨io helicoidal 90?sem eixo, low backlash, fator red. 9:1
    RT180-015 redutor planet醨io helicoidal 90?sem eixo, standard backlash, fator red. 15:1
    RT180-015LB redutor planet醨io helicoidal 90?sem eixo, low backlash, fator red. 15:1
    RT180-021 redutor planet醨io helicoidal 90?sem eixo, standard backlash, fator red. 21:1
    RT180-021LB redutor planet醨io helicoidal 90?sem eixo, standard backlash, fator red. 21:2
    RT180-030 redutor planet醨io helicoidal 90?sem eixo, standard backlash, fator red. 21:3
    RT180-030LB redutor planet醨io helicoidal 90?sem eixo, standard backlash, fator red. 21:4
    RT180
    RT220-003 redutor planet醨io helicoidal 90?sem eixo, standard backlash, fator red. 3:1
    RT220-003LB redutor planet醨io helicoidal 90?sem eixo, standard backlash, fator red. 3:1
    RT220-009 redutor planet醨io helicoidal 90?sem eixo, standard backlash, fator red. 9:1
    RT220-009LB redutor planet醨io helicoidal 90?sem eixo, standard backlash, fator red. 9:1
    RT220-015 redutor planet醨io helicoidal 90?sem eixo, standard backlash, fator red. 15:1
    RT220-015LB redutor planet醨io helicoidal 90?sem eixo, standard backlash, fator red. 15:1
    RT220-021 redutor planet醨io helicoidal 90?sem eixo, standard backlash, fator red. 21:1
    RT220-021LB redutor planet醨io helicoidal 90?sem eixo, standard backlash, fator red. 21:1
    RT220-030 redutor planet醨io helicoidal 90?sem eixo, standard backlash, fator red. 30:1
    RT220-030LB redutor planet醨io helicoidal 90?sem eixo, standard backlash, fator red. 30:1
    RT220
    PX60-003 redutor planet醨io helicoidal low cost
    PX60-003LB redutor planet醨io helicoidal low cost
    PX60-005 redutor planet醨io helicoidal low cost
    PX60-005LB redutor planet醨io helicoidal low cost
    PX60-007 redutor planet醨io helicoidal low cost
    PX60-007LB redutor planet醨io helicoidal low cost
    PX60-010 redutor planet醨io helicoidal low cost
    PX60-010LB redutor planet醨io helicoidal low cost
    PX60-015 redutor planet醨io helicoidal low cost
    PX60-015LB redutor planet醨io helicoidal low cost
    PX60-020 redutor planet醨io helicoidal low cost
    PX60-020LB redutor planet醨io helicoidal low cost
    PX60-025 redutor planet醨io helicoidal low cost
    PX60-025LB redutor planet醨io helicoidal low cost
    PX60-030 redutor planet醨io helicoidal low cost
    PX60-030LB redutor planet醨io helicoidal low cost
    PX60-050 redutor planet醨io helicoidal low cost
    PX60-050LB redutor planet醨io helicoidal low cost
    PX60-070 redutor planet醨io helicoidal low cost
    PX60-070LB redutor planet醨io helicoidal low cost
    PX60-100 redutor planet醨io helicoidal low cost
    PX60-100LB redutor planet醨io helicoidal low cost
    PX60 Redutor planet醨io, in-line, helicoidal, 60mm, de 003 ? 100, low cost
    PX90-003 redutor planet醨io helicoidal low cost
    PX90-003LB redutor planet醨io helicoidal low cost
    PX90-005 redutor planet醨io helicoidal low cost
    PX90-007 redutor planet醨io helicoidal low cost
    PX90-010 redutor planet醨io helicoidal low cost
    PX90-015 redutor planet醨io helicoidal low cost
    PX90-020 redutor planet醨io helicoidal low cost
    PX90-025 redutor planet醨io helicoidal low cost
    PX90-030 redutor planet醨io helicoidal low cost
    PX90-050 redutor planet醨io helicoidal low cost
    PX90-070 redutor planet醨io helicoidal low cost
    PX90-100 redutor planet醨io helicoidal low cost
    PX90-005LB redutor planet醨io helicoidal low cost
    PX90-007LB redutor planet醨io helicoidal low cost
    PX90-010LB redutor planet醨io helicoidal low cost
    PX90-015LB redutor planet醨io helicoidal low cost
    PX90-020LB redutor planet醨io helicoidal low cost
    PX90-025LB redutor planet醨io helicoidal low cost
    PX90-030LB redutor planet醨io helicoidal low cost
    PX90-050LB redutor planet醨io helicoidal low cost
    PX90-070LB redutor planet醨io helicoidal low cost
    PX90-100LB redutor planet醨io helicoidal low cost
    PX90 Redutor planet醨io, in-line, helicoidal, 90mm, de 003 ? 100, low cost
    PX115-003 redutor planet醨io helicoidal low cost
    PX115-003LB redutor planet醨io helicoidal low cost
    PX115-005 redutor planet醨io helicoidal low cost
    PX115-005LB redutor planet醨io helicoidal low cost
    PX115-007 redutor planet醨io helicoidal low cost
    PX115-007LB redutor planet醨io helicoidal low cost
    PX115-010 redutor planet醨io helicoidal low cost
    PX115-010LB redutor planet醨io helicoidal low cost
    PX115-015 redutor planet醨io helicoidal low cost
    PX115-015LB redutor planet醨io helicoidal low cost
    PX115-020 redutor planet醨io helicoidal low cost
    PX115-020LB redutor planet醨io helicoidal low cost
    PX115-025 redutor planet醨io helicoidal low cost
    PX115-025LB redutor planet醨io helicoidal low cost
    PX115-030 redutor planet醨io helicoidal low cost
    PX115-030LB redutor planet醨io helicoidal low cost
    PX115-050 redutor planet醨io helicoidal low cost
    PX115-050LB redutor planet醨io helicoidal low cost
    PX115-070 redutor planet醨io helicoidal low cost
    PX115-070LB redutor planet醨io helicoidal low cost
    PX115-100 redutor planet醨io helicoidal low cost
    PX115-100LB redutor planet醨io helicoidal low cost
    PX115 Redutor planet醨io, in-line, helicoidal, 115mm, de 003 ? 100, low cost
    RS60-005 redutor planet醨io helicoidal 90 graus
    RS60-010 redutor planet醨io helicoidal 90 graus
    RS60-015 redutor planet醨io helicoidal 90 graus
    RS60-020 redutor planet醨io helicoidal 90 graus
    RS60-025 redutor planet醨io helicoidal 90 graus
    RS60-030 redutor planet醨io helicoidal 90 graus
    RS60-040 redutor planet醨io helicoidal 90 graus
    RS60-050 redutor planet醨io helicoidal 90 graus
    RS60-100 redutor planet醨io helicoidal 90 graus
    RS60 Redutor planet醨io, right-angle, helicoidal, 60mm, de 005 ?100
    RS90-005 redutor planet醨io helicoidal 90 graus
    RS90-005LB redutor planet醨io helicoidal 90 graus
    RS90-010 redutor planet醨io helicoidal 90 graus
    RS90-010LB redutor planet醨io helicoidal 90 graus
    RS90-015 redutor planet醨io helicoidal 90 graus
    RS90-015LB redutor planet醨io helicoidal 90 graus
    RS90-020 redutor planet醨io helicoidal 90 graus
    RS90-020LB redutor planet醨io helicoidal 90 graus
    RS90-025 redutor planet醨io helicoidal 90 graus
    RS90-025LB redutor planet醨io helicoidal 90 graus
    RS90-030 redutor planet醨io helicoidal 90 graus
    RS90-030LB redutor planet醨io helicoidal 90 graus
    RS90-040 redutor planet醨io helicoidal 90 graus
    RS90-040LB redutor planet醨io helicoidal 90 graus
    RS90-050 redutor planet醨io helicoidal 90 graus
    RS90-050LB redutor planet醨io helicoidal 90 graus
    RS90-100 redutor planet醨io helicoidal 90 graus
    RS90-100LB redutor planet醨io helicoidal 90 graus
    RS90 Redutor planet醨io, right-angle, helicoidal, 90mm, de 005 ?100
    RS115-005 redutor planet醨io helicoidal 90 graus
    RS115-005LB redutor planet醨io helicoidal 90 graus
    RS115-010 redutor planet醨io helicoidal 90 graus
    RS115-010LB redutor planet醨io helicoidal 90 graus
    RS115-015 redutor planet醨io helicoidal 90 graus
    RS115-015LB redutor planet醨io helicoidal 90 graus
    RS115-020 redutor planet醨io helicoidal 90 graus
    RS115-020LB redutor planet醨io helicoidal 90 graus
    RS115-025 redutor planet醨io helicoidal 90 graus
    RS115-025LB redutor planet醨io helicoidal 90 graus
    RS115-030 redutor planet醨io helicoidal 90 graus
    RS115-030LB redutor planet醨io helicoidal 90 graus
    RS115-040 redutor planet醨io helicoidal 90 graus
    RS115-040LB redutor planet醨io helicoidal 90 graus
    RS115-050 redutor planet醨io helicoidal 90 graus
    RS115-050LB redutor planet醨io helicoidal 90 graus
    RS115-100 redutor planet醨io helicoidal 90 graus
    RS115-100LB redutor planet醨io helicoidal 90 graus
    RS115 Redutor planet醨io, right-angle, helicoidal, 115mm, de 005 ?100
    RS142-005 redutor planet醨io helicoidal 90 graus
    RS142-005LB redutor planet醨io helicoidal 90 graus
    RS142-010 redutor planet醨io helicoidal 90 graus
    RS142-010LB redutor planet醨io helicoidal 90 graus
    RS142-015 redutor planet醨io helicoidal 90 graus
    RS142-015LB redutor planet醨io helicoidal 90 graus
    RS142-020 redutor planet醨io helicoidal 90 graus
    RS142-020LB redutor planet醨io helicoidal 90 graus
    RS142-025 redutor planet醨io helicoidal 90 graus
    RS142-025LB redutor planet醨io helicoidal 90 graus
    RS142-030 redutor planet醨io helicoidal 90 graus
    RS142-030LB redutor planet醨io helicoidal 90 graus
    RS142-040 redutor planet醨io helicoidal 90 graus
    RS142-040LB redutor planet醨io helicoidal 90 graus
    RS142-050 redutor planet醨io helicoidal 90 graus
    RS142-050LB redutor planet醨io helicoidal 90 graus
    RS142-100 redutor planet醨io helicoidal 90 graus
    RS142-100LB redutor planet醨io helicoidal 90 graus
    RS142 Redutor planet醨io, right-angle, helicoidal, 142mm, de 005 ?100
    RS180-005 redutor planet醨io helicoidal 90 graus
    RS180-005LB redutor planet醨io helicoidal 90 graus
    RS180-010 redutor planet醨io helicoidal 90 graus
    RS180-010LB redutor planet醨io helicoidal 90 graus
    RS180-015 redutor planet醨io helicoidal 90 graus
    RS180-015LB redutor planet醨io helicoidal 90 graus
    RS180-020 redutor planet醨io helicoidal 90 graus
    RS180-020LB redutor planet醨io helicoidal 90 graus
    RS180-025 redutor planet醨io helicoidal 90 graus
    RS180-025LB redutor planet醨io helicoidal 90 graus
    RS180-030 redutor planet醨io helicoidal 90 graus
    RS180-030LB redutor planet醨io helicoidal 90 graus
    RS180-040 redutor planet醨io helicoidal 90 graus
    RS180-040LB redutor planet醨io helicoidal 90 graus
    RS180-050 redutor planet醨io helicoidal 90 graus
    RS180-050LB redutor planet醨io helicoidal 90 graus
    RS180-100 redutor planet醨io helicoidal 90 graus
    RS180-100LB redutor planet醨io helicoidal 90 graus
    RS180 Redutor planet醨io, right-angle, helicoidal, 180mm, de 005 ?100
    RS220-005 redutor planet醨io helicoidal 90 graus
    RS220-005LB redutor planet醨io helicoidal 90 graus
    RS220-010 redutor planet醨io helicoidal 90 graus
    RS220-010LB redutor planet醨io helicoidal 90 graus
    RS220-015 redutor planet醨io helicoidal 90 graus
    RS220-015LB redutor planet醨io helicoidal 90 graus
    RS220-020 redutor planet醨io helicoidal 90 graus
    RS220-020LB redutor planet醨io helicoidal 90 graus
    RS220-025 redutor planet醨io helicoidal 90 graus
    RS220-025LB redutor planet醨io helicoidal 90 graus
    RS220-030 redutor planet醨io helicoidal 90 graus
    RS220-030LB redutor planet醨io helicoidal 90 graus
    RS220-040 redutor planet醨io helicoidal 90 graus
    RS220-040LB redutor planet醨io helicoidal 90 graus
    RS220-050 redutor planet醨io helicoidal 90 graus
    RS220-050LB redutor planet醨io helicoidal 90 graus
    RS220-100 redutor planet醨io helicoidal 90 graus
    RS220-100LB redutor planet醨io helicoidal 90 graus
    RS220 Redutor planet醨io, right-angle, helicoidal, 220mm, de 005 ?100
    RS300-005 redutor planet醨io helicoidal 90 graus
    RS300-005LB redutor planet醨io helicoidal 90 graus
    RS300-010 redutor planet醨io helicoidal 90 graus
    RS300-010LB redutor planet醨io helicoidal 90 graus
    RS300-015 redutor planet醨io helicoidal 90 graus
    RS300-015LB redutor planet醨io helicoidal 90 graus
    RS300-020 redutor planet醨io helicoidal 90 graus
    RS300-020LB redutor planet醨io helicoidal 90 graus
    RS300-025 redutor planet醨io helicoidal 90 graus
    RS300-025LB redutor planet醨io helicoidal 90 graus
    RS300-030 redutor planet醨io helicoidal 90 graus
    RS300-030LB redutor planet醨io helicoidal 90 graus
    RS300-040 redutor planet醨io helicoidal 90 graus
    RS300-040LB redutor planet醨io helicoidal 90 graus
    RS300-050 redutor planet醨io helicoidal 90 graus
    RS300-050LB redutor planet醨io helicoidal 90 graus
    RS300-100 redutor planet醨io helicoidal 90 graus
    RS300-100LB redutor planet醨io helicoidal 90 graus
    RS300 Redutor planet醨io, right-angle, helicoidal, 300mm, de 005 ?100
    PS90-010-MT90-010-001 Redutor Bayside Frame 90 10:1 preparado para motor Apex610
    PS180-030-MT180-030-053 Redutor Bayside Frame 180 30:1 preparado para motor RELIANCE P14A5729 OR P14A5755
    NE34-010-MM34-000 Redutor Bayside Frame 34 10:1 preparado para motor OEM83-93 MO
    PX90-010-MX90-010-005 Redutor Bayside Frame 90 10:1 preparado para motor BE344 LJ
    Redutores - Zenith
    Redutores planet醨ios Nema 23 com flanges de adapta玢o j?inclusa
    NEN-023-003 Redutor planet醨io Nema 23, in-line, 3:1, backlash <12 arc-min, efici阯cia > 92", vida 10.000H, sa韉a nominal 33Nm, <63dB, single stage, 7500 rpm.
    NEN-023-005 Redutor planet醨io Nema 23, in-line, 5:1, backlash <12 arc-min, efici阯cia > 92", vida 10.000H, sa韉a nominal 37Nm, <63dB, single stage, 7500 rpm.
    NEN-023-010 Redutor planet醨io Nema 23, in-line, 10:1, backlash <12 arc-min, efici阯cia > 92", vida 10.000H, sa韉a nominal 14Nm, <63dB, single stage, 7500 rpm.
    NEN-023-015 Redutor planet醨io Nema 23, in-line, 15:1, backlash <15 arc-min, efici阯cia > 92", vida 10.000H, sa韉a nominal 37Nm, <63dB, dual stage, 7500 rpm.
    NEN-023-050 Redutor planet醨io Nema 23, in-line, 50:1, backlash <15 arc-min, efici阯cia > 92", vida 10.000H, sa韉a nominal 37Nm, <63dB, dual stage, 7500 rpm.
    Redutores planet醨ios Nema 34 com flanges de adapta玢o j?inclusa
    NEN-034-003 Redutor planet醨io Nema 34, in-line, 3:1, backlash <12 arc-min, efici阯cia > 92", vida 10.000H, sa韉a nominal 80Nm, <66dB, single stage, 7500 rpm.
    NEN-034-005 Redutor planet醨io Nema 34, in-line, 3:1, backlash <12 arc-min, efici阯cia > 92", vida 10.000H, sa韉a nominal 88Nm, <66dB, single stage, 7500 rpm.
    NEN-034-010 Redutor planet醨io Nema 34, in-line, 10:1, backlash <12 arc-min, efici阯cia > 92", vida 10.000H, sa韉a nominal 37Nm, <66dB, single stage, 7500 rpm.
    NEN-034-015 Redutor planet醨io Nema 34, in-line, 15:1, backlash <15 arc-min, efici阯cia > 92", vida 10.000H, sa韉a nominal 88Nm, <66dB, dual stage, 7500 rpm.
    NEN-034-050 Redutor planet醨io Nema 34, in-line, 15:1, backlash <15 arc-min, efici阯cia > 92", vida 10.000H, sa韉a nominal 88Nm, <66dB, dual stage, 7500 rpm.
    Redutores planet醨ios Nema 42 com flanges de adapta玢o j?inclusa
    NEN-042-003 Redutor planet醨io Nema 42, in-line, 3:1, backlash <12 arc-min, efici阯cia > 92", vida 10.000H, sa韉a nominal 200Nm, <68dB, single stage, 6000 rpm.
    NEN-042-005 Redutor planet醨io Nema 42, in-line, 5:1, backlash <12 arc-min, efici阯cia > 92", vida 10.000H, sa韉a nominal 365Nm, <68dB, single stage, 6000 rpm.
    NEN-042-010 Redutor planet醨io Nema 42, in-line, 10:1, backlash <12 arc-min, efici阯cia > 92", vida 10.000H, sa韉a nominal 110Nm, <68dB, single stage, 6000 rpm.
    NEN-042-015 Redutor planet醨io Nema 42, in-line, 15:1, backlash <15 arc-min, efici阯cia > 92", vida 10.000H, sa韉a nominal 365Nm, <68dB, single stage, 6000 rpm.
    NEN-042-050 Redutor planet醨io Nema 42, in-line, 15:1, backlash <15 arc-min, efici阯cia > 92", vida 10.000H, sa韉a nominal 365Nm, <68dB, single stage, 6000 rpm.
    Redutores planet醨ios 60 mm e flanges de adapta玢o
    PRN-060-005 Redutor planet醨io de precis鉶, in-line, 60mm, red. 5:1, backlash <5 arc-min, efici阯cia > 96", vida 15.000H, sa韉a nominal 53Nm, <60dB
    PRN-060-010 Redutor planet醨io de precis鉶, in-line, 60mm, red. 10:1, backlash <5 arc-min, efici阯cia > 96", vida 15.000H, sa韉a nominal 17Nm, <60dB
    PRN-060-015 Redutor planet醨io de precis鉶, in-line, 60mm, red. 15:1, backlash <5 arc-min, efici阯cia > 96", vida 15.000H, sa韉a nominal 53Nm, <60dB
    PRN-060-025 Redutor planet醨io de precis鉶, in-line, 60mm, red. 25:1, backlash <5 arc-min, efici阯cia > 96", vida 15.000H, sa韉a nominal 53Nm, <60dB
    UTN-060-005 Redutor planet醨io, in-line, 60mm, red. 5:1, backlash <10 arc-min, efici阯cia > 94", vida 10.000H, sa韉a nominal 48Nm, <62dB
    UTN-060-010 Redutor planet醨io, in-line, 60mm, red. 10:1, backlash <10 arc-min, efici阯cia > 94", vida 10.000H, sa韉a nominal 16Nm, <62dB
    UTN-060-015 Redutor planet醨io, in-line, 60mm, red. 15:1, backlash <10 arc-min, efici阯cia > 94", vida 10.000H, sa韉a nominal 48Nm, <62dB
    UTN-060-025 Redutor planet醨io, in-line, 60mm, red. 25:1, backlash <10 arc-min, efici阯cia > 94", vida 10.000H, sa韉a nominal 48Nm, <62dB
    VLN-060-005 Redutor planet醨io de baixo custo, in-line, 60mm, red. 5:1, backlash <12 arc-min, efici阯cia > 92", vida 10.000H, sa韉a nominal 41Nm, <63dB
    VLN-060-010 Redutor planet醨io de baixo custo, in-line, 60mm, red. 10:1, backlash <12 arc-min, efici阯cia > 92", vida 10.000H, sa韉a nominal 15Nm, <63dB
    VLN-060-015 Redutor planet醨io de baixo custo, in-line, 60mm, red. 15:1, backlash <15 arc-min, efici阯cia > 92", vida 10.000H, sa韉a nominal 41Nm, <63dB
    VLN-060-025 Redutor planet醨io de baixo custo, in-line, 60mm, red. 25:1, backlash <15 arc-min, efici阯cia > 92", vida 10.000H, sa韉a nominal 41Nm, <63dB
    60-ADAPT-0015 Flange de adapta玢o para motores; S83-xxx, ZETA83-xxx, QM83-xxx, OEM-83-xxx
    60-ADAPT-0005 Flange de adapta玢o para motores; APEX 602, 604
    60-ADAPT-0002 Flange de adapta玢o para motores; APEX 603 ,605 ,606 ,610
    60-ADAPT-0007 Flange de adapta玢o para motores; BE23x
    60-ADAPT-0004 Flange de adapta玢o para motores; BE34x
    60-ADAPT-0004 Flange de adapta玢o para motores; J034x, N034x
    60-ADAPT-0005 Flange de adapta玢o para motores; J070x, N070x
    60-ADAPT-0002 Flange de adapta玢o para motores; J092x, N092x
    60-ADAPT-0011 Flange de adapta玢o para motores; Sxx57-xxx,ZETA57-xxx, QM57-xxx, OEM57-xxx, OS2x
    60-ADAPT-0015 Flange de adapta玢o para motores; RS 3x
    60-ADAPT-0013 Flange de adapta玢o para motores; SM16x, SE16x
    60-ADAPT-0011 Flange de adapta玢o para motores; SM23x, SE 23x
    60-ADAPT-0007 Flange de adapta玢o para motores; SM & SE 231, 232, 233 -L (long shaft)
    60-ADAPT-0015 Flange de adapta玢o para motores; TS 31, 32
    Redutores planet醨ios 92 mm e flanges de adapta玢o
    PRN-092-005 Redutor planet醨io de precis鉶, in-line, 92mm, red. 5:1, backlash <4 arc-min, efici阯cia > 96", vida 15.000H, sa韉a nominal 112Nm, <62dB
    PRN-092-010 Redutor planet醨io de precis鉶, in-line, 92mm, red. 10:1, backlash <4 arc-min, efici阯cia > 96", vida 15.000H, sa韉a nominal 71Nm, <62dB
    PRN-092-015 Redutor planet醨io de precis鉶, in-line, 92mm, red. 15:1, backlash <4 arc-min, efici阯cia > 94", vida 15.000H, sa韉a nominal 115Nm, <62dB
    PRN-092-025 Redutor planet醨io de precis鉶, in-line, 92mm, red. 25:1, backlash <4 arc-min, efici阯cia > 94", vida 15.000H, sa韉a nominal 112Nm, <62dB
    PRN-092-100 Redutor planet醨io de precis鉶, in-line, 92mm, red. 100:1, backlash <4 arc-min, efici阯cia > 94", vida 15.000H, sa韉a nominal 112Nm, <62dB
    UTN-092-005 Redutor planet醨io, in-line, 92mm, red. 5:1, backlash <10 arc-min, efici阯cia > 94", vida 10.000H, sa韉a nominal 98Nm, <65dB
    UTN-092-010 Redutor planet醨io, in-line, 92mm, red. 10:1, backlash <10 arc-min, efici阯cia > 94", vida 10.000H, sa韉a nominal 62Nm, <65dB
    UTN-092-015 Redutor planet醨io, in-line, 92mm, red. 15:1, backlash <10 arc-min, efici阯cia > 92", vida 10.000H, sa韉a nominal 98Nm, <65dB
    UTN-092-025 Redutor planet醨io, in-line, 92mm, red. 25:1, backlash <10 arc-min, efici阯cia > 92", vida 10.000H, sa韉a nominal 98Nm, <65dB
    VLN-092-005 Redutor planet醨io de baixo custo, in-line, 92mm, red. 5:1, backlash <12 arc-min, efici阯cia > 92", vida 10.000H, sa韉a nominal 83Nm, <66dB
    VLN-092-010 Redutor planet醨io de baixo custo, in-line, 92mm, red. 10:1, backlash <12 arc-min, efici阯cia > 92", vida 10.000H, sa韉a nominal 53Nm, <66dB
    VLN-092-015 Redutor planet醨io de baixo custo, in-line, 92mm, red. 15:1, backlash <15 arc-min, efici阯cia > 92", vida 10.000H, sa韉a nominal 83Nm, <66dB
    VLN-092-025 Redutor planet醨io de baixo custo, in-line, 92mm, red. 25:1, backlash <15 arc-min, efici阯cia > 92", vida 10.000H, sa韉a nominal 83Nm, <66dB
    VLN-092-100 Redutor planet醨io de baixo custo, in-line, 92mm, red. 100:1, backlash <15 arc-min, efici阯cia > 92", vida 10.000H, sa韉a nominal 83Nm, <66dB
    92-ADAPT-0016 Flange de adapta玢o para motores; S83-xxx, ZETA83-xxx, QM83-xxx, OEM-83-xxx
    92-ADAPT-0021 Flange de adapta玢o para motores; APEX 603 ,605 ,606 ,610
    92-ADAPT-0011 Flange de adapta玢o para motores; BE23x
    92-ADAPT-0007 Flange de adapta玢o para motores; BE34x
    92-ADAPT-0007 Flange de adapta玢o para motores; J034x, N034x
    92-ADAPT-0009 Flange de adapta玢o para motores; J070x, N070x
    92-ADAPT-0002 Flange de adapta玢o para motores; J092x, N092x
    92-ADAPT-0016 Flange de adapta玢o para motores; RS 3x
    92-ADAPT-0024 Flange de adapta玢o para motores; RS42; RE42
    92-ADAPT-0033 Flange de adapta玢o para motores; S106-250
    92-ADAPT-0033 Flange de adapta玢o para motores; S106-178
    92-ADAPT-0011 Flange de adapta玢o para motores; Sxx57-xxx,ZETA57-xxx, QM57-xxx, OEM57-xxx, OS2x
    92-ADAPT-0011 Flange de adapta玢o para motores; SM 231, 232, 233
    92-ADAPT-0016 Flange de adapta玢o para motores; TS 31, 32, 33
    92-ADAPT-0024 Flange de adapta玢o para motores; TS 4xB
    Redutores planet醨ios 115 mm e flanges de adapta玢o
    PRN-115-005 Redutor planet醨io de precis鉶, in-line, 115mm, red. 5:1, backlash <3 arc-min, efici阯cia > 96", vida 15.000H, sa韉a nominal 325Nm, <65dB
    PRN-115-010 Redutor planet醨io de precis鉶, in-line, 115mm, red. 10:1, backlash <3 arc-min, efici阯cia > 96", vida 15.000H, sa韉a nominal 186Nm, <65dB
    PRN-115-015 Redutor planet醨io de precis鉶, in-line, 115mm, red. 15:1, backlash <3 arc-min, efici阯cia > 96", vida 15.000H, sa韉a nominal 325Nm, <65dB
    PRN-115-025 Redutor planet醨io de precis鉶, in-line, 115mm, red. 25:1, backlash <3 arc-min, efici阯cia > 96", vida 15.000H, sa韉a nominal 325Nm, <65dB
    UTN-115-005 Redutor planet醨io, in-line, 115mm, red. 5:1, backlash <8 arc-min, efici阯cia > 94", vida 10.000H, sa韉a nominal 282Nm, <67dB
    UTN-115-010 Redutor planet醨io, in-line, 115mm, red. 10:1, backlash <8 arc-min, efici阯cia > 94", vida 10.000H, sa韉a nominal 162Nm, <67dB
    UTN-115-015 Redutor planet醨io, in-line, 115mm, red. 15:1, backlash <8 arc-min, efici阯cia > 94", vida 10.000H, sa韉a nominal 282Nm, <67dB
    UTN-115-025 Redutor planet醨io, in-line, 115mm, red. 25:1, backlash <8 arc-min, efici阯cia > 94", vida 10.000H, sa韉a nominal 282Nm, <67dB
    VLN-115-005 Redutor planet醨io de baixo custo, in-line, 115mm, red. 5:1, backlash <12 arc-min, efici阯cia > 92", vida 10.000H, sa韉a nominal 240Nm, <68dB
    VLN-115-010 Redutor planet醨io de baixo custo, in-line, 115mm, red. 10:1, backlash <12 arc-min, efici阯cia > 92", vida 10.000H, sa韉a nominal 137Nm, <68dB
    VLN-115-015 Redutor planet醨io de baixo custo, in-line, 115mm, red. 15:1, backlash <15 arc-min, efici阯cia > 92", vida 10.000H, sa韉a nominal 240Nm, <68dB
    VLN-115-025 Redutor planet醨io de baixo custo, in-line, 115mm, red. 25:1, backlash <15 arc-min, efici阯cia > 92", vida 10.000H, sa韉a nominal 240Nm, <68dB
    115-ADAPT-0005 Flange de adapta玢o para motores; S83-xxx, ZETA83-xxx, QM83-xxx, OEM-83-xxx
    115-ADAPT-0004 Flange de adapta玢o para motores; APEX 603 ,605 ,606 ,610
    115-ADAPT-0006 Flange de adapta玢o para motores; APEX 620,630
    115-ADAPT-0012 Flange de adapta玢o para motores; APEX 635, 640; Z 635, 640, 920
    115-ADAPT-0005 Flange de adapta玢o para motores; BE34x
    115-ADAPT-0003 Flange de adapta玢o para motores; J092x, N092x
    115-ADAPT-0005 Flange de adapta玢o para motores; RS 31, 32, 33
    115-ADAPT-0008 Flange de adapta玢o para motores; RS 43
    115-ADAPT-0008 Flange de adapta玢o para motores; RS42; RE42;
    115-ADAPT-0007 Flange de adapta玢o para motores; S106-250
    115-ADAPT-0007 Flange de adapta玢o para motores; S106-178
    115-ADAPT-0008 Flange de adapta玢o para motores; S106-205
    115-ADAPT-0008 Flange de adapta玢o para motores; TS 4xB
    Redutores planet醨ios 142 mm e flanges de adapta玢o
    PRN-142-005 Redutor planet醨io de precis鉶, in-line, 142mm, red. 5:1, backlash <3 arc-min, efici阯cia > 96", vida 15.000H, sa韉a nominal 741Nm, <68dB
    PRN-142-010 Redutor planet醨io de precis鉶, in-line, 142mm, red. 10:1, backlash <3 arc-min, efici阯cia > 96", vida 15.000H, sa韉a nominal 408Nm, <68dB
    PRN-142-015 Redutor planet醨io de precis鉶, in-line, 142mm, red. 15:1, backlash <3 arc-min, efici阯cia > 96", vida 15.000H, sa韉a nominal 741Nm, <68dB
    PRN-142-025 Redutor planet醨io de precis鉶, in-line, 142mm, red. 25:1, backlash <3 arc-min, efici阯cia > 96", vida 15.000H, sa韉a nominal 741Nm, <68dB
    UTN-142-005 Redutor planet醨io, in-line, 142mm, red. 5:1, backlash <8 arc-min, efici阯cia > 94", vida 10.000H, sa韉a nominal 645Nm, <70dB
    UTN-142-010 Redutor planet醨io, in-line, 142mm, red. 10:1, backlash <8 arc-min, efici阯cia > 94", vida 10.000H, sa韉a nominal 355Nm, <70dB
    UTN-142-015 Redutor planet醨io, in-line, 142mm, red. 15:1, backlash <8 arc-min, efici阯cia > 94", vida 10.000H, sa韉a nominal 645Nm, <70dB
    UTN-142-025 Redutor planet醨io, in-line, 142mm, red. 25:1, backlash <8 arc-min, efici阯cia > 94", vida 10.000H, sa韉a nominal 645Nm, <70dB
    VLN-142-005 Redutor planet醨io de baixo custo, in-line, 115mm, red. 5:1, backlash <12 arc-min, efici阯cia > 92", vida 10.000H, sa韉a nominal 581Nm, <71dB
    VLN-142-010 Redutor planet醨io de baixo custo, in-line, 115mm, red. 10:1, backlash <12 arc-min, efici阯cia > 92", vida 10.000H, sa韉a nominal 320Nm, <71dB
    VLN-142-015 Redutor planet醨io de baixo custo, in-line, 115mm, red. 15:1, backlash <15 arc-min, efici阯cia > 92", vida 10.000H, sa韉a nominal 581Nm, <71dB
    VLN-142-025 Redutor planet醨io de baixo custo, in-line, 115mm, red. 25:1, backlash <15 arc-min, efici阯cia > 92", vida 10.000H, sa韉a nominal 581Nm, <71dB
    142-ADAPT-0004 Flange de adapta玢o para motores; APEX 635, 640; Z 635, 640, 920
    142-ADAPT-0014 Flange de adapta玢o para motores; BE34x
    142-ADAPT-0016 Flange de adapta玢o para motores; J092x, N092x
    Redutores - SMH-MH
    P301PN0030M060/075/11/40 Redutor planet醨io para motores SMH e MH
    P301PN0030M080/100/19/40 Redutor planet醨io para motores SMH e MH
    P301PN0040M060/075/11/40 Redutor planet醨io para motores SMH e MH
    P301PN0040M080/100/19/40 Redutor planet醨io para motores SMH e MH
    P301PN0050M060/075/11/40 Redutor planet醨io para motores SMH e MH
    P301PN0050M080/100/19/40 Redutor planet醨io para motores SMH e MH
    P301PN0070M060/075/11/40 Redutor planet醨io para motores SMH e MH
    P301PN0070M080/100/14/40 Redutor planet醨io para motores SMH e MH
    P301PN0070M080/100/19/40 Redutor planet醨io para motores SMH e MH
    P301PN0100M060/075/11/40 Redutor planet醨io para motores SMH e MH
    P301PN0100M060/075/14/40 Redutor planet醨io para motores SMH e MH
    P301PN0100M070/090/16/40 Redutor planet醨io para motores SMH e MH
    P301PN0100M073/098/09/32 Redutor planet醨io para motores SMH e MH
    P301PN0100M080/100/19/40 Redutor planet醨io para motores SMH e MH
    P301PV0030M080/100/14/40 Redutor planet醨io para motores SMH e MH
    P301PV0030M080/100/19/40 Redutor planet醨io para motores SMH e MH
    P301PV0040M080/100/14/40 Redutor planet醨io para motores SMH e MH
    P301PV0050M080/100/14/40 Redutor planet醨io para motores SMH e MH
    P301PV0050M080/100/19/40 Redutor planet醨io para motores SMH e MH
    P301PV0070M080/100/14/40 Redutor planet醨io para motores SMH e MH
    P301PV0070M080/100/19/40 Redutor planet醨io para motores SMH e MH
    P301PV0100M080/100/14/40 Redutor planet醨io para motores SMH e MH
    P301PV0100M080/100/19/40 Redutor planet醨io para motores SMH e MH
    P312PN0150M060/075/11/40 Redutor planet醨io para motores SMH e MH
    P312PN0150M080/100/19/40 Redutor planet醨io para motores SMH e MH
    P312PN0200M060/075/11/40 Redutor planet醨io para motores SMH e MH
    P312PN0250M060/075/11/40 Redutor planet醨io para motores SMH e MH
    P312PN0250M080/100/19/40 Redutor planet醨io para motores SMH e MH
    P312PN0350M060/075/11/40 Redutor planet醨io para motores SMH e MH
    P312PN0490M060/075/11/40 Redutor planet醨io para motores SMH e MH
    P312PN0700M060/075/11/40 Redutor planet醨io para motores SMH e MH
    P312PN1000M060/075/11/40 Redutor planet醨io para motores SMH e MH
    P401PE0030M080/100/14/40 Redutor planet醨io para motores SMH e MH
    P401PE0050M080/100/14/40 Redutor planet醨io para motores SMH e MH
    P401PE0070M080/100/14/40 Redutor planet醨io para motores SMH e MH
    P401PE0100M080/100/14/40 Redutor planet醨io para motores SMH e MH
    P401PN0030M080/100/14/40 Redutor planet醨io para motores SMH e MH
    P401PN0030M080/100/19/40 Redutor planet醨io para motores SMH e MH
    P401PN0030M095/115/19/40 Redutor planet醨io para motores SMH e MH
    P401PN0040M080/100/14/40 Redutor planet醨io para motores SMH e MH
    P401PN0040M080/100/19/40 Redutor planet醨io para motores SMH e MH
    P401PN0050M080/100/14/40 Redutor planet醨io para motores SMH e MH
    P401PN0050M080/100/19/40 Redutor planet醨io para motores SMH e MH
    P401PN0050M095/115/24/45 Redutor planet醨io para motores SMH e MH
    P401PN0070M080/100/14/40 Redutor planet醨io para motores SMH e MH
    P401PN0070M080/100/19/40 Redutor planet醨io para motores SMH e MH
    P401PN0100M073/098/13/40 Redutor planet醨io para motores SMH e MH
    P401PN0100M080/100/14/40 Redutor planet醨io para motores SMH e MH
    P401PN0100M080/100/19/40 Redutor planet醨io para motores SMH e MH
    P401PN0100M095/115/19/40 Redutor planet醨io para motores SMH e MH
    P401PN0100M110/130/19/40 Redutor planet醨io para motores SMH e MH
    P401PV0030M095/115/19/40 Redutor planet醨io para motores SMH e MH
    P401PV0030M110/130/24/50 Redutor planet醨io para motores SMH e MH
    P401PV0040M095/115/19/40 Redutor planet醨io para motores SMH e MH
    P401PV0040M110/130/24/50 Redutor planet醨io para motores SMH e MH
    P401PV0050M095/115/19/40 Redutor planet醨io para motores SMH e MH
    P401PV0050M110/130/24/50 Redutor planet醨io para motores SMH e MH
    P401PV0070M095/115/19/40 Redutor planet醨io para motores SMH e MH
    P401PV0070M110/130/24/50 Redutor planet醨io para motores SMH e MH
    P401PV0100M095/115/19/40 Redutor planet醨io para motores SMH e MH
    P401PV0100M110/130/24/50 Redutor planet醨io para motores SMH e MH
    P412GN0250M080/100/14/40 Redutor planet醨io para motores SMH e MH
    P412PN0150M080/100/14/40 Redutor planet醨io para motores SMH e MH
    P412PN0150M080/100/19/40 Redutor planet醨io para motores SMH e MH
    P412PN0150M95/115/19/40 Redutor planet醨io para motores SMH e MH
    P412PN0200M080/100/14/40 Redutor planet醨io para motores SMH e MH
    P412PN0200M080/100/19/40 Redutor planet醨io para motores SMH e MH
    P412PN0250M080/100/14/40 Redutor planet醨io para motores SMH e MH
    P412PN0250M080/100/19/40 Redutor planet醨io para motores SMH e MH
    P412PN0350M080/100/14/40 Redutor planet醨io para motores SMH e MH
    P412PN0350M080/100/19/40 Redutor planet醨io para motores SMH e MH
    P412PN0490M080/100/14/40 Redutor planet醨io para motores SMH e MH
    P412PN0490M080/100/19/40 Redutor planet醨io para motores SMH e MH
    P412PN0700M080/100/14/40 Redutor planet醨io para motores SMH e MH
    P412PN0700M080/100/19/40 Redutor planet醨io para motores SMH e MH
    P412PN1000M080/100/14/40 Redutor planet醨io para motores SMH e MH
    P412PN1000M080/100/19/40 Redutor planet醨io para motores SMH e MH
    P501GV0040M130/165/24/58 Redutor planet醨io para motores SMH e MH
    P501PE0030M095/115/19/40 Redutor planet醨io para motores SMH e MH
    P501PE0050M095/115/19/40 Redutor planet醨io para motores SMH e MH
    P501PE0070M095/115/19/40 Redutor planet醨io para motores SMH e MH
    P501PE0100M095/115/19/40 Redutor planet醨io para motores SMH e MH
    P501PN0030M095/115/19/40 Redutor planet醨io para motores SMH e MH
    P501PN0030M110/130/24/50 Redutor planet醨io para motores SMH e MH
    P501PN0040M095/115/19/40 Redutor planet醨io para motores SMH e MH
    P501PN0050M095/115/19/40 Redutor planet醨io para motores SMH e MH
    P501PN0050M110/130/24/50 Redutor planet醨io para motores SMH e MH
    P501PN0070M095/115/19/40 Redutor planet醨io para motores SMH e MH
    P501PN0070M095/115/24/45 Redutor planet醨io para motores SMH e MH
    P501PN0070M110/130/24/50 Redutor planet醨io para motores SMH e MH
    P501PN0100M095/115/19/40 Redutor planet醨io para motores SMH e MH
    P501PN0100M110/130/24/50 Redutor planet醨io para motores SMH e MH
    P501PV0030M130/165/24/58 Redutor planet醨io para motores SMH e MH
    P501PV0030M130/165/32/58 Redutor planet醨io para motores SMH e MH
    P501PV0040M130/165/24/58 Redutor planet醨io para motores SMH e MH
    P501PV0040M130/165/32/58 Redutor planet醨io para motores SMH e MH
    P501PV0050M130/165/24/58 Redutor planet醨io para motores SMH e MH
    P501PV0050M130/165/32/58 Redutor planet醨io para motores SMH e MH
    P501PV0070M130/165/24/58 Redutor planet醨io para motores SMH e MH
    P501PV0070M130/165/32/58 Redutor planet醨io para motores SMH e MH
    P501PV0100M130/165/24/58 Redutor planet醨io para motores SMH e MH
    P501PV0100M130/165/32/58 Redutor planet醨io para motores SMH e MH
    P512PN0150M095/115/19/40 Redutor planet醨io para motores SMH e MH
    P512PN0150M110/130/24/50 Redutor planet醨io para motores SMH e MH
    P512PN0200M095/115/19/40 Redutor planet醨io para motores SMH e MH
    P512PN0200M110/130/24/50 Redutor planet醨io para motores SMH e MH
    P512PN0250M095/115/19/40 Redutor planet醨io para motores SMH e MH
    P512PN0250M110/130/24/50 Redutor planet醨io para motores SMH e MH
    P512PN0350M095/115/19/40 Redutor planet醨io para motores SMH e MH
    P512PN0350M110/130/24/50 Redutor planet醨io para motores SMH e MH
    P512PN0490M095/115/19/40 Redutor planet醨io para motores SMH e MH
    P512PN0490M110/130/24/50 Redutor planet醨io para motores SMH e MH
    P512PN0700M110/130/24/50 Redutor planet醨io para motores SMH e MH
    P512PN1000M110/130/24/50 Redutor planet醨io para motores SMH e MH
    P512PN1000M95/115/19/40 Redutor planet醨io para motores SMH e MH
    P512PV0250M130/165/24/50 Redutor planet醨io para motores SMH e MH
    P512SPN0500KX401VF0020M Redutor planet醨io para motores SMH e MH
    P701PN0030M130/165/24/60 Redutor planet醨io para motores SMH e MH
    P701PN0030M130/165/32/60 Redutor planet醨io para motores SMH e MH
    P701PN0040M130/165/24/60 Redutor planet醨io para motores SMH e MH
    P701PN0040M180/215/38/80 Redutor planet醨io para motores SMH e MH
    P701PN0050M130/165/24/60 Redutor planet醨io para motores SMH e MH
    P701PN0050M130/165/32/60 Redutor planet醨io para motores SMH e MH
    P701PN0070M130/165/24/60 Redutor planet醨io para motores SMH e MH
    P701PN0070M130/165/32/60 Redutor planet醨io para motores SMH e MH
    P701PN0100M130/165/24/60 Redutor planet醨io para motores SMH e MH
    P701PN0100M130/165/32/60 Redutor planet醨io para motores SMH e MH
    P701PV0070M180/215/38/80 Redutor planet醨io para motores SMH e MH
    P701PV0200M130/215/24/50 Redutor planet醨io para motores SMH e MH
    P712PN0200M130/165/24/58 Redutor planet醨io para motores SMH e MH
    P712PN0250M130/165/24/58 Redutor planet醨io para motores SMH e MH
    P712PN0250M130/165/32/58 Redutor planet醨io para motores SMH e MH
    P712PN0350M130/165/24/58 Redutor planet醨io para motores SMH e MH
    P712PN0490M130/165/24/50 Redutor planet醨io para motores SMH e MH
    P712PN0490M130/165/32/58 Redutor planet醨io para motores SMH e MH
    P712PN0700M130/165/24/58 Redutor planet醨io para motores SMH e MH
    P712PN1000M130/165/24/58 Redutor planet醨io para motores SMH e MH
    P712PV0200M130/215/24/50 Redutor planet醨io para motores SMH e MH
    P801PN0030M180/215/38/80 Redutor planet醨io para motores SMH e MH
    P801PN0050M180/215/38/80 Redutor planet醨io para motores SMH e MH
    P801PN0070M180/215/38/80 Redutor planet醨io para motores SMH e MH
    P801PN0100M180/215/38/80 Redutor planet醨io para motores SMH e MH
    P801PV0100M130/165/24/58 Redutor planet醨io para motores SMH e MH
    P812PN0150M180/215/38/80 Redutor planet醨io para motores SMH e MH
    P812PN0250M180/215/38/80 Redutor planet醨io para motores SMH e MH
施兰自动化设备有限公司是一家专业从事欧、美、日、韩等工业产品代理的服务性企业。我公司的主要业务推广代理产品及承接自动化系统、工程设计、成套安装及调试,我们的产品广泛应用在电力、石化、冶金、机械、造纸、食品、轻工、纺织、制造、环…  更多>>
施兰东莞有限公司
联系人:韩滔
地址:莞城区八达路
邮编:523100
电话:0769-22325481
传真:0769-22320941
公司网址:http://www.ctrl-tech.cn
  • 龙先生 在2019/1/23 8:49:00留言
  • 详细留言:SL06308AH-10N
  • MARK 在2012/11/16 7:14:00留言
  • 详细留言:你好,我需要PARKER MOTION CONTROL, SD 15M/100的价格,我公司在新西兰,能尽快联系我吗?电子邮件:MARK@TROPHYWHOLESALERS.CO.NZ. 谢谢MARK
  • andy ng 在2011/4/4 0:12:00留言
  • 详细留言:parker bayside model: rb115-002 ratio 2:1
  • andy ng 在2011/3/30 13:52:00留言
  • 详细留言:parker bayside gearhead. model: rb115-002
  • 梁晓虎 在2009/9/30 8:43:00留言
  • 详细留言:SJME-02AMA4C SJDE-02APA 以上两个型号的详细参数或提供技术资料,谢谢您!
