上海益同仪器仪表有限公司
  • 霍尼韦尔楼宇自控2008年度最新订货型号大全
  • 发布时间:2009/3/18 9:30:32   修改时间:2009/4/21 10:00:47 浏览次数:3913
  • XL50 控制器
    XL50 DDC 22I/O W/O TERM
    XL50-MMI DDC 22I/O INCL. MMI W/O TERM
    XS50 XL50 TERMINAL SET
    XD50-E XL50 EPROM module
    XD50-FC Excel 50 Communication Card for C-Bus
    XD50-FL Excel 50 Communication Card for C-Bus
    XD50B-FCL LON/C-BUS APPL.MOD.FREE PROGR.
    XL50-ACC3 MOUNT ACC. FRONT DOOR
    XL50-FP XL50 package with terminals XS50 and applicationmoduleXD50-FC, without MMI
    XL50-MMI-EP XL50 package with terminals XS50 and applicationmoduleXD50-FC, with MMI
    XL50-MMI-FP XL50 package with terminals XS50 and applicationmoduleXD50-FC, with MMI
    XL50UMMIPCCBLON XL50 FREI PROGR.+XS50+XD50B-FCL
    XL50UMMIPCLON XL50-MMI FREEPROG.+XS50+XD50FL
    XL50UPCCBLON XL50 FREI PROGR.+XS50+XD50B-FCL
    XL50UPCLON XL50 FREE PRORG.+XS50+XD50-FL
    XM500-EU TCP/IP MODEM
    MCD3 AO CONVERTER 1*3POS 1*ON/OFF
    MCE3 Relay Module, Two Spdt Outputs, One Spst Output
    XL1000 Web 控制器
    XL1000B50 Controller Excel Web(R) BACnet DDC
    XL1000B100 Controller Excel Web(R) BACnet DDC
    XL1000B500 EXCEL WEB(R) BACNET CONTROLLER
    XL1000B1000 EXCEL WEB(R) BACNET DDC CONRTOLLER
    XL500 系列 XC 5010C 控制器系列 (2008年03月20号停产)
    XC5010C Excel 500 16-bit CPU module
    XC5210C EXCEL500 CPU WITH HIGH MEMORY
    XP502 POWER SUPPLY
    XD505A C-Bus Interface Submodule Retrofit Kit, 9600 Baud
    XD508 C-Bus High Speed Interface Submodule Retrofit Kit, 1MBaudspeed
    XDL505 APPLICATION MOD.FOR XL500SMART
    XDM506 XL600, 500, 100, 80 Modem Communication Submodule -ProvidesDial-In/Dial-Out for single controllers
    XF521A ANALOG INPUT MODULE
    XF522A ANALOG OUTPUT MODULE
    XF523A DIGITAL INPUT MODULE
    XF524A DIGITAL OUTPUT MODULE
    XF525A Three Position Output Module
    XF526 ANALOGUE INPUT MODULE PT-SENS.
    XF527 ANALOG OUTPUT MOD. W/O SWITCH
    XF529 Digital Output Module
    XF599 Blank Module Slot Cover
    XH561 Excel 500 or 600 Universal Input/Output Module Housing
    XH562H Universal Input/Output Blank Housing Cover
    XHSACC Service package containing 1200 socket coding plugs,200covers for internal bus and 100 service keys
    XW568 BUS CABLE 90 MM
    XW569 BUS CABLE 350 MM
    XL500 Smart XCL5010 控制器系列 (2008年03月20号停产)
    XCL5010 Freely Programmable DDC controller
    XFL521B Distributed I/O, Analog Input Module,12 resolution
    XFL522B Distributed I/O, Analog Output Module,8 resolution
    XFL523B Distributed I/O, Analog Output Module,18 Vdcauxiliaryvoltage supply
    XFL524B Distributed I/O, Analog Output Module,Cycle time 1secwithCPU
    XFLR522B AO MODULE + MANUAL OVERRIDE
    XFLR524B DO MODULE + MANUAL OVERRIDE
    XFR522A Manual Override Module For XFL522B
    XFR524A Manual Override Module For XFL524B
    XSL511 CONNECTOR MODULE
    XSL512 DISCONNECTOR MODULE
    XSL513 TERMINAL BLOCK AI, AO, DI
    XSL514 TERMINAL BLOCK DO
    BNA 建筑网络适配器 / XW582 手持终端
    Q7055A1007 BNA-1C
    Q7055A1015 BNA-2CS 2-BUS DIRECT CONNECT
    Q7055A1023 BNA-2DN 2DIRECT CONNECT DELTA
    XI581AH For controllers XC5010C and XC6010; mounting on EXCEL5000housing XH561
    XI581CH For controllers XC5010C and XC6010; mounting on EXCEL5000housing XH561,mounts directly on the front of a controller
    XI581TW For controllers XC5010C and XC6010; mounting on EXCEL5000housing XH561
    XI582AH For all EXCEL 5000 controllers, desktop model, alsosuitablefor wallmounting
    XI582CH For controllers XC5010C and XC6010; mounting on EXCEL5000housing XH561,mout away from a controller
    XI582-CY For all EXCEL 5000 controllers, desktop model,alsosuitable for wallmounting
    XI582TW For all EXCEL 5000 controllers, desktop model, alsosuitablefor wallmounting
    专用控制器 VAV/FCU/CAV 系列
    Q7750A1005 Excel 10 Zone Manager
    Q7750A2003 Excel 10 Zone Manager
    W7704D1016 XL12 WITH 230 VAC
    W7704D1024 XL12 WITH 100VAC
    W7750B2011 Excel 10 for constant volume air handling unitswithtriac outputs
    W7750C2001 Excel 10 for constant volume air handling unitswithtriac and analog outputs
    W7751D2008 EXCEL10 VAV INTERNAL WIRING
    W7751F2003 EXCEL10 VAV EXTERNAL WIRING
    W7751H2009 XL10 SMART VACONTROLLER FTT
    W7751H2025 Excel 10 smart VAV controller with a premountedML6161Actuator
    W7752D2007 XL10 FANCOIL CONTROLLER230VFTT
    W7752F2002 XL10 FANCOIL CONTROLLER115VFTT
    W7752G2000 XL10 FANCOIL CONTROLLER 3 REL.
    W7754K1001 XL10 FANCOIL CONTR. NEW HARDW
    W7754P1000 XL10 FANCOIL CONTR. NEW HARDW
    W7754Q1008 XL 10 Fancoil contr.new hardware 24V ( Drawing 50007908)
    W7762B1019 Controller for hydronic installations, Excel 10
    W7763C1016 XL10-CHC CONTROLLER SETPOINT F
    W7763C1024 XL10-CHC HYDRONIC CONTROLLER
    W7763C1032 XL10-CHC HYDRONIC CONTROLLER
    W7763C1081 XL10-CHC CONTROLLER SETPOINT F
    W7763D1030 XL10-CHC CONTROLLER SETP.+/-
    W7763E1003 XL10-CHC HYDRONIC CONTROLLER
    XL800 控制器 XCL8010A
    XCL8010A Excel 800 plant controller
    Panle I/O
    XF821A 8 analog input module (Panel)
    XF822A 8 analog output module (Panel)
    XFR822A 8 analog output module with override (Panel)
    XF823A 12 binary input module (Panel)
    XF824A 6 relay output module (Panel)
    XFR824A 6 relay output module with override (Panel)
    XFR825A Actuator output module with override (Panel)
    Lon I/O
    XFL821A 8 analog input module (LON)
    XFL822A 8 analog output module (LON)
    XFLR822A 8 analog output module with override (LON)
    XFL823A 12 binary input module (LON)
    XFL824A 6 relay output module (LON)
    XFLR824A 6 relay output module with override (LON)
    Terminal socket Model
    XS821-22 Terminal socket for analog input and outputmodules.Thepackage includes 1 terminal socket, 1 connector brideand 1 swivellabel.
    XS823 Terminal socket binary input modules.The package includes1terminal socket, 1 connector bride and 1 swivel label.
    XS824-25 Terminal socket relay output and floatingoutputmodules.The package includes 1 terminal socket, 1 connectorbride,1 cross connector and 1 swivel label.
    Accessary (Optional)
    XS812 Manual disconnector module for analog input, analog outputandbinary input. The manual disconnector is plugged betweentheterminal socket and the electronic module. It allowsmanualdisconnection of individual signals. This is usefulduringstart-up.
    XS812RO Manual disconnector module for relay output.Themanualdisconnector is plugged between the terminal socket andtheelectronic module. It allows manual disconnection ofindividualsignals. This is useful during start-up.
    XS814 10 auxiliary terminal blocks. The auxiliary terminal blockisused for distribution of signals. It includes 2 blocks with7terminals which are connected to each other.
    XS815 20 cross connectors (red in below figure) for connection of6relay commons.One cross connector is included in theterminalsocket package.
    XS817 40 cross connectors (red in below figure) for connection of3relay commons (used if voltage on relay 1…3 is different tovoltageon relay 4…5)
    XS816 10 bus bridges. One bus bridge is included in theterminalsocket package.
    XAL10 10 swivel labels. The swivel label is used to attachtheapplication specific label printed with CARE.One swivel labelisincluded in the terminal socket package.
    XW882 XI582 cable for Excel 800 (a combination of XW586 andXW582can be also used).
    XW885 Download cable for Excel 800 (a combination of XW586 andXW585can be also used).
    XW884 Adapter cable to use XW882 and XW885 with an XL500controller
    XL100C 控制器
    XL100C XL100C WITH INTERFACE F.C-BUS
    XL100C-MMI XL100C+XI582AH+XW582+INTERFACE
    XL100CU CONTROLLER W.INTEGR.COMM.UL916
    XL100CUUKL CONTR.W.INTEGR.COMMUNICATION
    SymmetrE 基本软件及数据库扩展包
    SYMSTARTER-CD310 Includes a 250 point database
    SYM-DB2-5-EXP Expansion Pack - 250 to 500 pnt DB
    SYM-DB5-10-EXP Expansion Pack - 500 to 1000 pnt DB
    SYM-DB10-20-EXP Expansion Pack - 1000 to 2000 pnt DB
    SYM-DB20-35-EXP Expansion Pack - 2001 to 3500 pnt DB
    SYM-DB35-50-EXP Expansion Pack - 3501 to 5000 pnt DB
    SYM-DB50-75-EXP Expansion Pack - 5001 to 7500 pnt DB
    SYM-DB75-10K-EXP Expansion Pack - 7501 to 10000 pnt DB
    SYM-DB10K-15K-EXP Expansion Pack - 10001 to 15000 pnt DB
    SYM-DB15K-20K-EXP Expansion Pack - 15001 to 20000 pnt DB
    SymmetrE 接口选项
    SYM-IF-XL5DIRDIAL SymmetrE Excel 5000 Direct Dial-up Interface
    SYM-IF-ADVDDECL AdvanceDDE
    SYM-IF-BACNET BACnet Client
    SYM-IF-MODBUS Modbus
    SYM-IF-OPCCL OPC Client
    SYM-STB-UP-STN Upgrade Browser Client to Full Station Client
    SYM-OP-LNS LNS Server
    SYM-OP-BACSERV BACnet Server
    SYM-NW-OPCSERV OPC Server
    SYM-OP-DTXL OPC Data Transfer - Local
    SYM-OP-ALMPAG Alarm Pager software license
    SYM-OP-IMM Inegrated Maintenance Manager
    SYM-OP-WEBPCTL Web Point Control
    SymmetrE 升级包
    SYM-OP-LNSUPG Upgrade to LNS 3.2 from LNS 3.0
    SYM-DB0500-UPG SYMMETRE SOFTWARE VERSION UPGRADE WITH 500 POINTDB
    SYM-DB1000-UPG SYMMETRE SOFTWARE VERSION UPGRADE WITH 1000 POINTDB
    SYM-DB2000-UPG SYMMETRE SOFTWARE VERSION UPGRADE WITH 2000 POINTDB
    SYM-DB3500-UPG SYMMETRE SOFTWARE VERSION UPGRADE WITH 3500 POINTDB
    SYM-DB5000-UPG SYMMETRE SOFTWARE VERSION UPGRADE WITH 5000 POINTDB
    SYM-DB7500-UPG SYMMETRE SOFTWARE VERSION UPGRADE WITH 7500 POINTDB
    SYM-DB10K-UPG SYMMETRE SOFTWARE VERSION UPGRADE WITH 10000 POINTDB
    SYM-DB15K-UPG SYMMETRE SOFTWARE VERSION UPGRADE WITH 15000 POINTDB
    SYM-DB20K-UPG SYMMETRE SOFTWARE VERSION UPGRADE WITH 20000POINTDB
    CARE 软件及升级授权
    CARE-70-BASIC Software license for CARE, Open Link PointServer,EPROM Burn Tool and XL-Online without RACL and ASPECDEditor,CARE-KEY replacement+LON Engineering
    CARE-70-FULL Software license for CARE, Open Link PointServer,EPROM Burn Tool and XL-Online without RACL and ASPECDEditor+LonEngineering+LNS License+RACL+ASPECD Editor,CARE-FULL-KEYreplacement
    CARE-70-LNS Software license for CARE, Open Link Point Server,EPROMBurn Tool and XL-Online without RACL and ASPECDEditor+LonEngineering+LNS License
    CARE-FU-LNS Upgrade to LNS
    CARE-FU-LON Upgrade to Lon functionality
    CARE-FU-WEB Upgrade to XL-WEB
    EXCELON EXCELon LonWork Network Management Tool. SoftwareLicenseRequired
    XL-ONLINE Excel Online, Commissioning tool for EXCEL5000Controllers
上海益同仪器仪表有限公司致力于为广大客户提供高效、高质量的楼宇自控系统的业务咨询、设计选型、方案确定、施工安装、现场调试及技术支持,同时专业从事国外著名厂商SEETOP、GREYSTONE、HONEYWELL、VECTOR、HUBA、KROHNE、DWYE…  更多>>
上海益同仪器仪表有限公司
联系人:曹卫东
地址:上海市浦东南路2157号众城商厦9B
邮编:200123
电话:021-50658563-606
传真:021-61629087
公司网址:http://www.eto17.com
  • 孙工 在2023/4/24 21:34:00留言
  • 详细留言:电磁流量计|OPTIFLUX2100W/DN100/IP68JB/T9248|| 1 台
  • 在2022/5/30 16:12:00留言
  • 详细留言:流量计:电话18393413541微信同号(甘肃兰州)速来电
  • 褚佳 在2019/9/29 17:27:00留言
  • 详细留言:DK800/R/TE/C询价
  • 丁国辉 在2018/11/15 10:45:00留言
  • 详细留言:我想得到IFM4080F 规格DN400-neop-mo的详细参数表
  • 康晓猛 在2018/9/14 9:53:00留言
  • 详细留言:流量计OPTIFLUX2000C/03ED/F,DN150,带附件:1套,询价
