厦门兴锐达自动化设备有限公司
  • Fanuc Robots
  • 发布时间:2010/6/4 11:33:12   修改时间:2010/6/4 11:33:12 浏览次数:1542
  • 本公司专业销售大型进口各种品牌DCS系统模块备件:AB,ABB Advant OCS,ABB MOD 30/MODCELL,ABB MOD 300,ABB Bailey INFI 90,ABB Procontic,ABB Procontrol,H&B Contronic,Moore APACS,Moore Panel Controllers,Rosemount RS-3,Siemens Iskamatic,Siemens Simatic S5,Siemens Simatic C1,Yokogawa Centum XL,Yokogawa microXL,FOXBORO I/A,Westinghouse,Ovation,Honeywell QCS,Honeywell TDC系列,Honeywell S9000,HITACHI,Mitsubishi PLC,Motorola MVME,ALSTOM MVME,Other VME,TOSHIBA,HP,Yaskawa,FANUC等大型模组,有着充足的库存,交货期快,欢迎来电查询。
    厦门兴锐达自动化设备有限公司
    联系人:王文光
    手机:15359273780
    电话:0592-5580707
    传真:0592-5580710
    邮编:361009
    QQ:1282972140
    网址:http://www.xrdauto.com
    Fanuc机器人备件
    Fanuc Workcells
    Take advantage of the increased productivity and savings provided by one of RobotWorx' custom-built Fanuc workcells. Fanuc workcells are fitted with complete safety environments, tooling, positioners, and much more at an affordable cost.
    Models: Ferris Wheel System, Track System, Gantry System, more...
    Fanuc Robots - ArcMate Series
    Fanuc ArcMate robots are a line of dedicated arc welding robots designed for maximum flexibility and productivity. The small footprint and flexible mounting options make ArcMate robots ideal for most welding applications.
    Models: ArcMate 100, ArcMate 100i, ArcMate 100iB, ArcMate 100iC, ArcMate 120i, ArcMate 120iL, ArcMate 120iB, ArcMate 120iC, ArcMate 50iL, ArcMate 50iB, ArcMate 50iC/5L, ArcMate 120iB/10L
    Fanuc Robots - M Series
    The M Series of Fanuc Robots is designed to handle material handling applications. From pick and place to machine loading, this wide variety of robots has a solution for every handling application.
    Models: M-6i, M-6iB, M-16i, M-16iL, M-16iB, M-710i, M-710iB, M-710iC, M-10iA, M-20iA, M-900iA, M-2000iA, M-1iA, M-3iA
    Fanuc Robots - S Series
    The Fanuc Robots in the S Series are all-purpose industrial automation robots that can do it all! From welding to handling, this Fanuc line represents a large payload range with a variety of work envelopes.
    Models: S-420i, S-420iF, S-420iL, S-420iW, S-430i, S-430iF, S-430iL, S-430iW, S-900i, S900W, S-420S, S-500, S-700, S-500iB, S-900iB, S900H, S900L, S-6, S-10, S-12
    Fanuc Robots - R Series
    Heavy payloads present no problems for the Fanuc Robotics R Series. These hefty robots perform taxing applications, such as material handling and spot welding, with high-speed precision and grace.
    Models: R-1000iA/80F, R-2000iA, R-2000iA/210F, R-2000iB
    Fanuc Robots - LR Mate Series
    Fanuc Robotics delivers a versatile line with the tabletop LR Mate series. Flexible mounting options combine with Fanuc precision to deliver a robot used for a wide variety of handling applications. Cleanroom options are available.
    Models: LR Mate 100i, LR Mate 100iB, LR Mate 200i, LR Mate 200iB, LR Mate 200iC
    Fanuc Robots - Painting Series
    Fanuc painting robots offer a wide range of process advantages that help maximize system performance. They offer precise, reliable, and affordable coating solutions to a wide range of industries.
    Models: Paint Mate 200iA/5L, Paint Mate 200iA, P-50i, P-100, P-120, P-145, P-155, P-200, P-200E, P-200T, P-250iA, P-250iA/15T, P-500, P-10, P-15
    Fanuc Robots - Palletizing Series
    Fanuc Robotics developed a subset of their standard M Series of robots to deliver top performance in palletizing applications. These robots have 2-5 axes and a non-traditional body to maximize throughput at top speeds.
    Models: M-410, M-410iW, M-410iWW, M-410iHW, M-410iHS, M-410iB, M-420iA, M-421iA, M-430iA/2F
    Fanuc Robots - Rail-Mounted Series
    The Fanuc Robotics Toploader line of robots are overhead rail-mounted robot arms that are designed for machine tending and material handling applications. With the ability to service multiple vertical and horizontal machines, the configuration of the mount improves machine productivity,
    Models: M-6iT, M-16iAT, ArcMate 120iLT, ArcMate 120iB/10LT, M-16iB/10LT, M-16iB/20T, M-710iBT, M-710iC/T, M-710iC/70T, R-2000iB/200T, SR Mate 200i
    Fanuc Robots - F Series
    The Fanuc F series robots are parallel link, servo-driven robots with six degrees of freedom. They are designed for use in a variety of manufacturing and automotive assembly processes.
    Models: F-200iB, F-200iA
    Fanuc Teach Pendants
    Fanuc Controllers: R-30iA, R-30iA Mate, RJ3iC, RJ3iB, RJ3, RJ2, RJ
    Fanuc ArcMate 100 Robot
    Applications: Arc Welding, Mig Welding, Tig Welding
    Available Fanuc Controllers: RJ, RJ2
     Reach: 1368 mm
    Payload: 6 kg
    Full Specifications
    Fanuc ArcMate 100i Robot
    Available Fanuc Controllers: RJ2, RJ3
     Reach: 1368 mm
    Payload: 6 kg
    Full Specifications
    Fanuc ArcMate 100iB Robot
    Applications: Mig Welding, Tig Welding
    Available Fanuc Controllers: RJ3iB
     Reach: 1373 mm
    Payload: 6 kg
    Full Specifications
    Fanuc ArcMate 100iC Robot
    Applications: Arc Welding, Mig Welding, Plasma Cutting
    Available Fanuc Controllers: R-30iA, RJ3iC
     Reach: 1420 mm
    Payload: 10 kg
    Full Specifications
    Fanuc ArcMate 120i Robot
     Reach: 1542 mm
    Payload: 16 kg
    Full Specifications
    Fanuc ArcMate 120iL Robot
     Reach: 1813 mm
    Payload: 10 kg
    Full Specifications
    Fanuc ArcMate 120iB Robot
    Applications: Mig Welding, Plasma Cutting, Tig Welding
     Reach: 1667 mm
    Payload: 20 kg
    Full Specifications
    Fanuc ArcMate 120iC Robot
    Applications: Arc Welding, Plasma Cutting
     Reach: 1811 mm
    Payload: 20 kg
    Full Specifications
    Fanuc ArcMate 50iL Robot
     Reach: 856 mm
    Payload: 3 kg
    Full Specifications
    Fanuc ArcMate 50iB Robot
    Applications: Plasma Cutting
     Reach: 856 mm
    Payload: 3 kg
    Full Specifications
    Fanuc ArcMate 50iC/5L Robot
     Reach: 892 mm
    Payload: 5 kg
    Full Specifications
    Fanuc ArcMate 120iB/10L Robot
     Reach: 1885 mm
    Payload: 10 kg
    Full Specifications
    Fanuc M-6i Robot
    Applications: Arc Welding, Dispensing, Machine Loading
     Reach: 1368 mm
    Payload: 6 kg
    Full Specifications
    Fanuc M-6iB Robot
    Applications: Arc Welding, Pick and Place
     Reach: 1373 mm
    Payload: 6 kg
    Full Specifications
    Fanuc M-16i Robot
    Applications: Arc Welding, Machine Tending, Material Handling
     Reach: 1605 mm
    Payload: 16 kg
    Full Specifications
    Fanuc M-16iL Robot
    Applications: Dispensing, Machine Loading, Machine Tending
     Reach: 1813 mm
    Payload: 10 kg
    Full Specifications
    Fanuc M-16iB Robot
    Applications: Dispensing, Material Handling, Material Removal
     Reach: 1667 mm
    Payload: 20 kg
    Full Specifications
    Fanuc M-710i Robot
    Applications: Deburring, Pick and Place
     Reach: 1706 mm
    Payload: 45 kg
    Full Specifications
    Fanuc M-710iB Robot
    Applications: Bonding / Sealing, Pick and Place, Plasma Cutting
    Available Fanuc Controllers: RJ3, RJ3iB
     Reach: 1706 mm
    Payload: 45 kg
    Full Specifications
    Fanuc M-710iC Robot
    Applications: Bonding / Sealing, Material Handling
     Reach: 2050 mm
    Payload: 50 kg
    Full Specifications
    Fanuc M-10iA Robot
    Applications: Material Handling, Part Transfer, Pick and Place
     Reach: 1420 mm
    Payload: 10 kg
    Full Specifications
    Fanuc M-20iA Robot
     Reach: 1811 mm
    Payload: 20 kg
    Full Specifications
    Fanuc M-900iA Robot
    Applications: Foundry, Palletizing, Pick and Place
     Reach: 2650 mm
    Payload: 350 kg
    Full Specifications
    Fanuc M-2000iA Robot
     Reach: 3730 mm
    Payload: 900 kg
    Full Specifications
    Fanuc M-1iA Robot
    Applications: Material Handling, Order Picking, Packaging
     Payload: 1 kg
    Full Specifications
    Fanuc M-3iA Robot
    Applications: Material Handling, Material Removal, Order Picking
     Payload: 6 kg
    Full Specifications
    Fanuc S-420i Robot
    Applications: Material Handling, Resistance Welding, Robotic Assembly
     Reach: 2852 mm
    Payload: 120 kg
    Full Specifications
    Fanuc S-420iF Robot
     Reach: 2850 mm
    Payload: 120 kg
    Full Specifications
    Fanuc S-420iL Robot
    Applications: Material Handling, Palletizing, Spot Welding
     Reach: 3000 mm
    Payload: 75 kg
    Full Specifications
    Fanuc S-420iW Robot
    Applications: Material Handling, Palletizing, Resistance Welding
     Reach: 2850 mm
    Payload: 155 kg
    Full Specifications
    Fanuc S-430i Robot
    Applications: Material Handling, Robotic Assembly, Spot Welding
     Reach: 2643 mm
    Payload: 130 kg
    Full Specifications
    Fanuc S-430iF Robot
    Applications: Material Handling, Spot Welding
     Reach: 2643 mm
    Payload: 130 kg
    Full Specifications
    Fanuc S-430iL Robot
    Applications: Material Handling, Palletizing, Part Transfer
     Reach: 3002 mm
    Payload: 125 kg
    Full Specifications
    Fanuc S-430iW Robot
    Applications: Dispensing, Machine Tending, Material Handling
     Reach: 2643 mm
    Payload: 165 kg
    Full Specifications
    Fanuc S-900i Robot
    Applications: Machine Loading, Material Handling, Packaging
     Reach: 2488 mm
    Payload: 220 kg
    Full Specifications
    Fanuc S900W Robot
    Applications: Machine Loading, Material Handling, Spot Welding
     Reach: 2488 mm
    Payload: 300 kg
    Full Specifications
    Fanuc S-420S Robot
     Reach: 2488 mm
    Payload: 120 kg
    Full Specifications
    Fanuc S-500 Robot
    Applications: Arc Welding, Bonding / Sealing, Grinding
    Available Fanuc Controllers: RJ2, RJ3, RJ3iB
     Reach: 2739 mm
    Payload: 15 kg
    Full Specifications
    Fanuc S-700 Robot
    Applications: Arc Welding, Material Handling, Robotic Assembly
     Reach: 1616 mm
    Payload: 30 kg
    Full Specifications
    Fanuc S-500iB Robot
    Applications: Dispensing, Machine Loading, Material Handling
     Reach: 2757 mm
    Payload: 15 kg
    Full Specifications
    Fanuc S-900iB Robot
    Applications: Machine Loading, Material Handling, Material Removal
     Reach: 2488 mm
    Payload: 200 kg
    Full Specifications
    Fanuc S900H Robot
     Reach: 2488 mm
    Payload: 200 kg
    Full Specifications
    Fanuc S900L Robot
     Reach: 3033 mm
    Payload: 165 kg
    Full Specifications
    Fanuc S-6 Robot
    Applications: Arc Welding, Dispensing, Material Handling
     Reach: 1346 mm
    Payload: 6 kg
    Full Specifications
    Fanuc S-10 Robot
     Reach: 1346 mm
    Payload: 10 kg
    Full Specifications
    Fanuc S-12 Robot
     Reach: 1605 mm
    Payload: 12 kg
    Full Specifications
    Fanuc R-1000iA/80F Robot
     Reach: 2230 mm
    Payload: 80 kg
    Full Specifications
    Fanuc R-2000iA Robot
    Applications: Machine Tending, Material Handling, Robot Laser Welding
     Reach: 2650 mm
    Payload: 165 kg
    Full Specifications
    Fanuc R-2000iA/210F Robot
    Applications: Dispensing, Foundry, Machine Loading
     Reach: 2650 mm
    Payload: 210 kg
    Full Specifications
    Fanuc R-2000iB Robot
    Applications: Foundry, Machine Loading, Material Handling
    Available Fanuc Controllers: RJ3iC
     Reach: 2655 mm
    Payload: 165 kg
    Full Specifications
    Fanuc LR Mate 100i Robot
    Applications: Pick and Place, Welding Automation
     Reach: 620 mm
    Payload: 3 kg
    Full Specifications
    Fanuc LR Mate 100iB Robot
     Reach: 620 mm
    Payload: 3 kg
    Full Specifications
    Fanuc LR Mate 200i Robot
     Reach: 700 mm
    Payload: 3 kg
    Full Specifications
    Fanuc LR Mate 200iB Robot
    Applications: Cleanroom, Dispensing, Machine Loading
     Reach: 700 mm
    Payload: 5 kg
    Full Specifications
    Fanuc LR Mate 200iC Robot
    Applications: Arc Welding, Foundry, Pick and Place
    Available Fanuc Controllers: R-30iA Mate
     Reach: 704 mm
    Payload: 5 kg
    Full Specifications
    Fanuc Paint Mate 200iA/5L Robot
    Applications: Dispensing, Painting Automation, Robotic Coating
     Reach: 892 mm
    Payload: 5 kg
    Full Specifications
    Fanuc Paint Mate 200iA Robot
     Reach: 704 mm
    Payload: 5 kg
    Full Specifications
    Fanuc P-50i Robot
     Reach: 1360 mm
    Payload: 7 kg
    Full Specifications
    Fanuc P-100 Robot
    Applications: Bonding / Sealing, Dispensing, Painting Automation
     Reach: 2383 mm
    Payload: 5 kg
    Full Specifications
    Fanuc P-120 Robot
     Reach: 2409 mm
    Payload: 5 kg
    Full Specifications
    Fanuc P-145 Robot
     Reach: 2542 mm
    Payload: 7 kg
    Full Specifications
    Fanuc P-155 Robot
     Reach: 2613 mm
    Payload: 7 kg
    Full Specifications
    Fanuc P-200 Robot
     Reach: 2800 mm
    Payload: 15 kg
    Full Specifications
    Fanuc P-200E Robot
     Reach: 2800 mm
    Payload: 30 kg
    Full Specifications
    Fanuc P-200T Robot
    Applications: Bonding / Sealing, Cleanroom, Dispensing
     Reach: 2308 mm
    Payload: 15 kg
    Full Specifications
    Fanuc P-250iA Robot
    Applications: Cleanroom, Dispensing, Painting Automation
     Reach: 2800 mm
    Payload: 15 kg
    Full Specifications
    Fanuc P-250iA/15T Robot
    Applications: Bonding / Sealing, Painting Automation, Robotic Coating
     Reach: 2800 mm
    Payload: 15 kg
    Full Specifications
    Fanuc P-500 Robot
    Applications: Painting Automation, Robotic Coating, Thermal Spray
     Reach: 3171 mm
    Payload: 8 kg
    Full Specifications
    Fanuc P-10 Robot
     Reach: 1932 mm
    Payload: 60 kg
    Full Specifications
    Fanuc P-15 Robot
    Applications: Cleanroom, Material Handling, Painting Automation
     Reach: 2331 mm
    Payload: 45 kg
    Full Specifications
    Fanuc M-410 Robot
     Reach: 3139 mm
    Payload: 60 kg
    Full Specifications
    Fanuc M-410iW Robot
    Applications: Palletizing
     Reach: 3139 mm
    Payload: 100 kg
    Full Specifications
    Fanuc M-410iWW Robot
     Reach: 3130 mm
    Payload: 400 kg
    Full Specifications
    Fanuc M-410iHW Robot
     Reach: 3139 mm
    Payload: 250 kg
    Full Specifications
    Fanuc M-410iHS Robot
     Reach: 3139 mm
    Payload: 100 kg
    Full Specifications
    Fanuc M-410iB Robot
    Applications: Material Handling, Packaging, Palletizing
     Reach: 3143 mm
    Payload: 160 kg
    Full Specifications
    Fanuc M-420iA Robot
    Applications: Machine Loading, Packaging, Palletizing
     Reach: 1855 mm
    Payload: 40 kg
    Full Specifications
    Fanuc M-421iA Robot
     Reach: 1855 mm
    Payload: 50 kg
    Full Specifications
    Fanuc M-430iA/2F Robot
    Applications: Cleanroom, Order Picking, Packaging
     Reach: 1130 mm
    Payload: 2 kg
    Full Specifications
    Fanuc M-6iT Robot
    Applications: Arc Welding, Machine Loading, Machine Tending
     Reach: 1158 mm
    Payload: 6 kg
    Full Specifications
    Fanuc M-16iAT Robot
     Reach: 1605 mm
    Payload: 16 kg
    Full Specifications
    Fanuc ArcMate 120iLT Robot
     Reach: 1813 mm
    Payload: 10 kg
    Full Specifications
    Fanuc ArcMate 120iB/10LT Robot
     Reach: 1735 mm
    Payload: 10 kg
    Full Specifications
    Fanuc M-16iB/10LT Robot
     Reach: 1735 mm
    Payload: 10 kg
    Full Specifications
    Fanuc M-16iB/20T Robot
    Applications: Material Handling, Plasma Cutting, Press Tending
     Reach: 1517 mm
    Payload: 20 kg
    Full Specifications
    Fanuc M-710iBT Robot
     Reach: 1706 mm
    Payload: 70 kg
    Full Specifications
    Fanuc M-710iC/T Robot
     Reach: 1900 mm
    Payload: 50 kg
    Full Specifications
    Fanuc M-710iC/70T Robot
     Reach: 1900 mm
    Payload: 70 kg
    Full Specifications
    Fanuc R-2000iB/200T Robot
     Reach: 2207 mm
    Payload: 200 kg
    Full Specifications
    Fanuc SR Mate 200i Robot
    Applications: Machine Loading, Machine Tending, Material Handling
     Reach: 1158 mm
    Payload: 8 kg
    Full Specifications
    Fanuc F-200iB Robot
     Reach: 437 mm
    Payload: 100 kg
    Full Specifications
    Fanuc F-200iA Robot
     Reach: 437 mm
    Payload: 100 kg
    Full Specifications
    Fanuc R-30iA Pendant
    The Fanuc R-30iA system controller is advanced technology in a proven, reliable design.
     View Pendant
    Fanuc R-30iA Mate Pendant
    The compact R-30iA Mate controller is built on the reliability of the standard FANUC R-30iA controller. It is available as a rack mount that fits into a standard 19" electronics rack.
     View Pendant
    Fanuc RJ3iC Pendant
    The high performance Fanuc RJ3iC robot controller provides a level of intelligence never offered before.
     View Pendant
    Fanuc RJ3iB Pendant
    The Fanuc RJ3iB uses advanced technology packaged in a proven, reliable and efficient controller design.
     View Pendant
    Fanuc RJ3 Pendant
    The advanced technology of the Fanuc R-J3 controller makes it a proven, reliable third generation controller.
     View Pendant
    Fanuc RJ2 Pendant
    The Fanuc R-J2 controller incorporates the most advanced and proven technology to improve total system performance while simplifying overall cell and system integration.
     View Pendant
    Fanuc RJ Pendant
    The Fanuc RJ controller programs easily for multiple applications. Servo amps, I/O boards, and the CPU are easily accessible through a front panel in the dust-proof, air cooled cabinet.
     View Pendant
厦门兴锐达自动化设备有限公司是一家从事科研开发和工程技术服务的高新技术企业.主营业务:中低压电气,电气自动化,工程设计,技术服务等,是福建省著名的工业电气自动化单位.公司本着"准确,高效,全面,公平,创造财富,提高资源利用率"为宗旨,服务于省内外各…  更多>>
厦门兴锐达自动化设备有限公司
联系人:王文光
地址:厦门市湖里区五缘湾营运中心1号楼2层EF单元
邮编:361009
电话:0592-5580707
传真:0592-5361289
公司网址:http://www.xmxrdauto.com.cn
  • William Almeida 在2015/3/19 1:32:00留言
  • 详细留言:Dear Sirs, We, at Motivax, would be glad to work with your company, in a mutual colaboration. To achieve this goal, we would like to ask your promptly help to quote the selected parts below, giving us your best price for sale: Item 1. Reference: 5501-470. Gás turbine module WOODWARD. 1 UNIT. Item 9. Reference: 5466-031. specific card for Gás turbine Pratt&Whitne. WOODWARD. 9 UNIT. Please make sure to send me the Lead Time to delivery, the weight and dimension of the material. If you are offering an alternative item, please send its datasheet. Best Regards, Mr. WillIam de Almeida Commercial Department Motivax 1982 NW 82nd Ave Miami, FL 33126, USA Phone: +1(786)2205825 7001498012
  • Petruzzi 在2011/10/24 18:44:00留言
  • 详细留言:OMRON R88M-H50030 AC SERVO MOTOR 500W speed 3000 rpm
  • joe scarlotto 在2011/10/5 2:48:00留言
  • 详细留言:Need p/a qty 3 A2260A 745/50 CPU'S
  • 陳薔妃 在2011/4/12 10:00:00留言
  • 详细留言:我想購買Oriental Motor Harmonic Gear Drive UHG50-2B Ratio 1:50 1個是否可報價給我?我们公司是在臺灣,麻煩您了
