本公司专业销售大型进口各种品牌DCS系统模块备件:AB,ABB Advant OCS,ABB MOD 30/MODCELL,ABB MOD 300,ABB Bailey INFI 90,ABB Procontic,ABB Procontrol,H&B Contronic,Moore APACS,Moore Panel Controllers,Rosemount RS-3,Siemens Iskamatic,Siemens Simatic S5,Siemens Simatic C1,Yokogawa Centum XL,Yokogawa microXL,FOXBORO I/A,Westinghouse,Ovation,Honeywell QCS,Honeywell TDC系列,Honeywell S9000,HITACHI,Mitsubishi PLC,Motorola MVME,ALSTOM MVME,Other VME,TOSHIBA,HP,Yaskawa,FANUC等大型模组,有着充足的库存,交货期快,欢迎来电查询。
厦门兴锐达自动化设备有限公司
联系人:王文光
手机:15359273780
电话:0592-5580707
传真:0592-5580710
邮编:361009
QQ:1282972140
网址:http://www.xrdauto.com
Kuka机器人备件
Kuka Robots - Low Payload Series
Due to their versatility and flexibility, the Kuka Low Payload models are used in most of the manufacturing industries. They are masterful movers in all installation positions, ideal for new space-saving, cost-effective concepts.
Models: KR 5 arc, KR 6, KR 6 arc, KR 15, KR 15 SL, KR 16, KR 16 L6, KR 16 S
Kuka Robots - Medium Payload Series
Medium payload applications can vary from simple handling procedures to more complex assembly applications. The flexible KUKA medium payload robot line is well-suited for this range of tasks.
Models: KR 30, KR 30 L16, KR 60
Kuka Robots - High Payload Series
KUKA high payload robot arms are highly desirable for spot welding and heavy handling applications. They are also very capable of loading and unloading tasks. Their long reach and high flexibility are ideal for industrial settings.
Models: KR 100, KR 140, KR 150, KR 180, KR 210, KR 240
Kuka Robots - Heavy Duty Series
Some applications require a large amount of strength and agility. KUKA's heavy duty model line includes a range of robots that easily fulfill this requirement without out sacrificing speed and accuracy.
Models: KR 360, KR 500, KR 1000
Kuka Robots - High Accuracy Series
The HA series lives up to its reputation for precision. Designed with fine gear configurations and state-of-the-art materials, these robots handle complex and intricate applications.
Models: KR 30 HA, KR 60 HA, KR 100 HA
Kuka Robots - Palletizing Series
Cut costs and increase throughput with Kuka's high-performance palletizing robots. This series combines large work envelopes with top accuracy.
Models: KR 40 PA, KR 50 PA, KR 100 PA
Kuka Robots - Shelf-Mounted Series
This flexible shelf-mounted series offers unparalleled accessibility. With lowered stature and wide reach, they transform applications and handle a variety of payloads.
Models: KR 6 KS, KR 16 KS, KR 16 KS-F, KR 30 KS, KR 60 KS, KR 150 K
Kuka Robots - Press-To-Press Series
With extensive 3500 mm reach and durable framing, the Kuka press tending robots load and unload tirelessly. Use them to speed up production and add versatility to your manufacturing floor.
Models: KR 100 P, KR 120 P
Kuka Teach Pendants
Kuka Controllers: KR C2, KR C2 sr, KR C1
Kuka KR 5 arc Robot
Applications: Arc Welding, Material Handling, Mig Welding
Available Kuka Controllers: KR C2
Reach: 1411 mm
Payload: 5 kg
Full Specifications
Kuka KR 6 Robot
Applications: Arc Welding, Bonding / Sealing, Deburring
Reach: 1570 mm
Payload: 6 kg
Full Specifications
Kuka KR 6 arc Robot
Reach: 1611 mm
Payload: 6 kg
Full Specifications
Kuka KR 15 Robot
Applications: Arc Welding, Dispensing, Foundry
Available Kuka Controllers: KR C1
Reach: 1570 mm
Payload: 15 kg
Full Specifications
Kuka KR 15 SL Robot
Applications: Cleanroom, Deburring, Grinding
Reach: 1503 mm
Payload: 15 kg
Full Specifications
Kuka KR 16 Robot
Applications: Arc Welding, Deburring, Foundry
Reach: 1610 mm
Payload: 16 kg
Full Specifications
Kuka KR 16 L6 Robot
Reach: 1811 mm
Payload: 6 kg
Full Specifications
Kuka KR 16 S Robot
Applications: Arc Welding, Dispensing, Material Handling
Reach: 1611 mm
Payload: 16 kg
Full Specifications
Kuka KR 30 Robot
Applications: Machine Tending, Material Handling, Part Transfer
Reach: 2033 mm
Payload: 30 kg
Full Specifications
Kuka KR 30 L16 Robot
Applications: Arc Welding, Machine Tending, Material Handling
Reach: 3102 mm
Payload: 16 kg
Full Specifications
Kuka KR 60 Robot
Applications: Bonding / Sealing, Deburring, Machine Loading
Reach: 2033 mm
Payload: 60 kg
Full Specifications
Kuka KR 100 Robot
Applications: Deburring, Machine Loading, Machine Tending
Reach: 2400 mm
Payload: 100 kg
Full Specifications
Kuka KR 140 Robot
Applications: Deburring, Material Handling, Material Removal
Reach: 2400 mm
Payload: 140 kg
Full Specifications
Kuka KR 150 Robot
Applications: Machine Tending, Material Handling, Material Removal
Available Kuka Controllers: KR C1, KR C2
Reach: 2700 mm
Payload: 150 kg
Full Specifications
Kuka KR 180 Robot
Applications: Foundry, Machine Loading, Machine Tending
Reach: 2700 mm
Payload: 180 kg
Full Specifications
Kuka KR 210 Robot
Applications: Foundry, Machine Loading, Material Handling
Reach: 2700 mm
Payload: 210 kg
Full Specifications
Kuka KR 240 Robot
Reach: 2700 mm
Payload: 240 kg
Full Specifications
Kuka KR 360 Robot
Reach: 2826 mm
Payload: 360 kg
Full Specifications
Kuka KR 500 Robot
Applications: Foundry, Machine Tending, Material Handling
Reach: 2836 mm
Payload: 500 kg
Full Specifications
Kuka KR 1000 Robot
Reach: 3200 mm
Payload: 1000 kg
Full Specifications
Kuka KR 30 HA Robot
Applications: Machine Tending, Material Handling, Plasma Cutting
Reach: 2033 mm
Payload: 30 kg
Full Specifications
Kuka KR 60 HA Robot
Applications: Material Handling, Pick and Place, Robot Laser Welding
Reach: 2033 mm
Payload: 60 kg
Full Specifications
Kuka KR 100 HA Robot
Reach: 2600 mm
Payload: 100 kg
Full Specifications
Kuka KR 40 PA Robot
Applications: Material Handling, Palletizing, Pick and Place
Reach: 2091 mm
Payload: 40 kg
Full Specifications
Kuka KR 50 PA Robot
Reach: 1991 mm
Payload: 50 kg
Full Specifications
Kuka KR 100 PA Robot
Reach: 3200 mm
Payload: 100 kg
Full Specifications
Kuka KR 6 KS Robot
Reach: 1801 mm
Payload: 6 kg
Full Specifications
Kuka KR 16 KS Robot
Reach: 1801 mm
Payload: 16 kg
Full Specifications
Kuka KR 16 KS-F Robot
Applications: Foundry, Material Handling
Reach: 1801 mm
Payload: 16 kg
Full Specifications
Kuka KR 30 KS Robot
Reach: 2233 mm
Payload: 30 kg
Full Specifications
Kuka KR 60 KS Robot
Reach: 2233 mm
Payload: 60 kg
Full Specifications
Kuka KR 150 K Robot
Applications: Deburring, Machine Tending, Material Handling
Reach: 3500 mm
Payload: 110 kg
Full Specifications
Kuka KR 100 P Robot
Applications: Machine Tending, Material Handling, Palletizing
Reach: 3500 mm
Payload: 100 kg
Full Specifications
Kuka KR 120 P Robot
Applications: Machine Tending, Material Handling, Robotic Assembly
Reach: 3500 mm
Payload: 120 kg
Full Specifications
Kuka KR C2 Pendant
The KUKA KR C2 controller features a plug-and-play functionality that enables rapid start-up.
View Pendant
Kuka KR C2 sr Pendant
The compact KUKA KR C2 sr is a made for small robots who need a high performance controller.
View Pendant
Kuka KR C1 Pendant
The KUKA KR C1 controller is encased in a compact, stackable cabinet. This advanced controller features DeviceNet and Ethernet standard, as well as bus system support.
View Pendant
