厦门兴锐达自动化设备有限公司
  • Mitsubishi机器人备件
  • 发布时间:2010/6/4 11:44:01   修改时间:2010/6/4 11:44:01 浏览次数:726
  • 本公司专业销售大型进口各种品牌DCS系统模块备件:AB,ABB Advant OCS,ABB MOD 30/MODCELL,ABB MOD 300,ABB Bailey INFI 90,ABB Procontic,ABB Procontrol,H&B Contronic,Moore APACS,Moore Panel Controllers,Rosemount RS-3,Siemens Iskamatic,Siemens Simatic S5,Siemens Simatic C1,Yokogawa Centum XL,Yokogawa microXL,FOXBORO I/A,Westinghouse,Ovation,Honeywell QCS,Honeywell TDC系列,Honeywell S9000,HITACHI,Mitsubishi PLC,Motorola MVME,ALSTOM MVME,Other VME,TOSHIBA,HP,Yaskawa,FANUC等大型模组,有着充足的库存,交货期快,欢迎来电查询。
    厦门兴锐达自动化设备有限公司
    联系人:王文光
    手机:15359273780
    电话:0592-5580707
    传真:0592-5580710
    邮编:361009
    QQ:1282972140
    网址:http://www.xrdauto.com
    Mitsubishi机器人备件
    Mitsubishi Robots - RV-S Series
    The RV-S series from Mitsubishi offers a wide range of robotic solutions. Designed for speed, these 6-axis vertically articulated robot arms are affordable and capable of boosting production.
    Models: RV-6S, RV-3S, RV-3SJ, RV-6SL, RV-12S, RV-12SL
    Mitsubishi Robots - RV-A Series
    Mitsubishi's RV-A 6-axis robot series is designed for precision and speed. Transform production with robots from this flexible Mitsubishi line.
    Models: RV-1A, RV-2AJ, RV-2A, RV-3AJ, RV-3AL, RV-4A, RV-5AJ
    Mitsubishi Robots - RH-S Series
    Meet and exceed palletizing and assembly goals with this nimble and efficient group of seven Mitsubishi RH-S tabletop SCARA robots. Choose between payloads of 6kg, 12kg, and 18kg.
    Models: RH-6SH, RH-12SH, RH-18SH
    Mitsubishi Robots - RP-H Series
    The small twin-arm SCARA robots of Mitsubishi RP-H series are both accurate and quick moving, making them ideal for small parts handling and other micro applications.
    Models: RP-1AH, RP-3AH, RP-5AH
    Mitsubishi Robots - RV Series
    Mitsubishi's RV robot series offers a range of compact robots designed for applications such as pick and place and sealing.
    Models: RV-M1, RV-M2, RV-E2, RV-E3J
    Mitsubishi Teach Pendants
    Mitsubishi Controllers: CR3-535M, CR2B-574, CR2-532
    Mitsubishi RV-6S Robot
    Applications: Deburring, Machine Loading, Machine Tending
    Available Mitsubishi Controllers: CR2B-574, CR3-535M
     Reach: 696 mm
    Payload: 6 kg
    Full Specifications
    Mitsubishi RV-3S Robot
     Reach: 642 mm
    Payload: 4 kg
    Full Specifications
    Mitsubishi RV-3SJ Robot
    Available Mitsubishi Controllers: CR2-532
     Reach: 641 mm
    Payload: 4 kg
    Full Specifications
    Mitsubishi RV-6SL Robot
     Reach: 902 mm
    Payload: 6 kg
    Full Specifications
    Mitsubishi RV-12S Robot
    Available Mitsubishi Controllers: CR3-535M
     Reach: 1086 mm
    Payload: 12 kg
    Full Specifications
    Mitsubishi RV-12SL Robot
     Reach: 1385 mm
    Payload: 12 kg
    Full Specifications
    Mitsubishi RV-1A Robot
    Applications: Machine Tending, Material Handling, Palletizing
     Reach: 418 mm
    Payload: 1 kg
    Full Specifications
    Mitsubishi RV-2AJ Robot
    Applications: Bonding / Sealing, Material Handling, Packaging
     Reach: 410 mm
    Payload: 2 kg
    Full Specifications
    Mitsubishi RV-2A Robot
    Applications: Machine Tending, Material Handling, Pick and Place
     Reach: 621 mm
    Payload: 2 kg
    Full Specifications
    Mitsubishi RV-3AJ Robot
     Payload: 3 kg
    Full Specifications
    Mitsubishi RV-3AL Robot
     Reach: 843 mm
    Payload: 3 kg
    Full Specifications
    Mitsubishi RV-4A Robot
     Reach: 634 mm
    Payload: 4 kg
    Full Specifications
    Mitsubishi RV-5AJ Robot
     Reach: 630 mm
    Payload: 5 kg
    Full Specifications
    Mitsubishi RH-6SH Robot
    Applications: Material Handling, Palletizing, Pick and Place
     Reach: 450 mm
    Payload: 6 kg
    Full Specifications
    Mitsubishi RH-12SH Robot
    Applications: Material Handling, Pick and Place, Robotic Assembly
     Reach: 700 mm
    Payload: 12 kg
    Full Specifications
    Mitsubishi RH-18SH Robot
     Reach: 700 mm
    Payload: 18 kg
    Full Specifications
    Mitsubishi RP-1AH Robot
    Applications: Bonding / Sealing, Deburring, Material Handling
     Reach: 236 mm
    Payload: 1 kg
    Full Specifications
    Mitsubishi RP-3AH Robot
     Reach: 335 mm
    Payload: 3 kg
    Full Specifications
    Mitsubishi RP-5AH Robot
    Applications: Bonding / Sealing, Deburring, Dispensing
     Reach: 453 mm
    Payload: 5 kg
    Full Specifications
    Mitsubishi RV-M1 Robot
    Applications: Pick and Place
     Reach: 410 mm
    Payload: 1 kg
    Full Specifications
    Mitsubishi RV-M2 Robot
     Payload: 2 kg
    Full Specifications
    Mitsubishi RV-E2 Robot
    Applications: Bonding / Sealing, Pick and Place
     Reach: 621 mm
    Payload: 2 kg
    Full Specifications
    Mitsubishi RV-E3J Robot
     Reach: 630 mm
    Full Specifications
    Mitsubishi CR3-535M Pendant
    The 3-phase CR3-535M Controller by Mitsubishi is capable of controlling up to 6 axes simultaneously and up to 8 axes for additional control.
     View Pendant
    Mitsubishi CR2B-574 Pendant
    With the capability to control up to 6 axes simultaneously and 9 axes for additional control the Mitsubishi CR2B-574 is a compact lightweight control that is easy to integrate into the factory floor.
     View Pendant
    Mitsubishi CR2-532 Pendant
    The Mitsubishi CR2-532 is compact controller only  weighing approximately 8kg. With the capability of holding up to 88 programs the CR2-532 is operable with dual single phase power supplies.
     View Pendant
厦门兴锐达自动化设备有限公司是一家从事科研开发和工程技术服务的高新技术企业.主营业务:中低压电气,电气自动化,工程设计,技术服务等,是福建省著名的工业电气自动化单位.公司本着"准确,高效,全面,公平,创造财富,提高资源利用率"为宗旨,服务于省内外各…  更多>>
厦门兴锐达自动化设备有限公司
联系人:王文光
地址:厦门市湖里区五缘湾营运中心1号楼2层EF单元
邮编:361009
电话:0592-5580707
传真:0592-5361289
公司网址:http://www.xmxrdauto.com.cn
  • William Almeida 在2015/3/19 1:32:00留言
  • 详细留言:Dear Sirs, We, at Motivax, would be glad to work with your company, in a mutual colaboration. To achieve this goal, we would like to ask your promptly help to quote the selected parts below, giving us your best price for sale: Item 1. Reference: 5501-470. Gás turbine module WOODWARD. 1 UNIT. Item 9. Reference: 5466-031. specific card for Gás turbine Pratt&Whitne. WOODWARD. 9 UNIT. Please make sure to send me the Lead Time to delivery, the weight and dimension of the material. If you are offering an alternative item, please send its datasheet. Best Regards, Mr. WillIam de Almeida Commercial Department Motivax 1982 NW 82nd Ave Miami, FL 33126, USA Phone: +1(786)2205825 7001498012
  • Petruzzi 在2011/10/24 18:44:00留言
  • 详细留言:OMRON R88M-H50030 AC SERVO MOTOR 500W speed 3000 rpm
  • joe scarlotto 在2011/10/5 2:48:00留言
  • 详细留言:Need p/a qty 3 A2260A 745/50 CPU'S
  • 陳薔妃 在2011/4/12 10:00:00留言
  • 详细留言:我想購買Oriental Motor Harmonic Gear Drive UHG50-2B Ratio 1:50 1個是否可報價給我?我们公司是在臺灣,麻煩您了
