本公司专业销售大型进口各种品牌DCS系统模块备件:AB,ABB Advant OCS,ABB MOD 30/MODCELL,ABB MOD 300,ABB Bailey INFI 90,ABB Procontic,ABB Procontrol,H&B Contronic,Moore APACS,Moore Panel Controllers,Rosemount RS-3,Siemens Iskamatic,Siemens Simatic S5,Siemens Simatic C1,Yokogawa Centum XL,Yokogawa microXL,FOXBORO I/A,Westinghouse,Ovation,Honeywell QCS,Honeywell TDC系列,Honeywell S9000,HITACHI,Mitsubishi PLC,Motorola MVME,ALSTOM MVME,Other VME,TOSHIBA,HP,Yaskawa,FANUC等大型模组,有着充足的库存,交货期快,欢迎来电查询。
厦门兴锐达自动化设备有限公司
联系人:王文光
手机:15359273780
电话:0592-5580707
传真:0592-5580710
邮编:361009
QQ:1282972140
网址:http://www.xrdauto.com
Nachi机器人备件
Nachi Robots - MV Series
Remain in tight control of welding and cutting applications with the advanced Nachi MV robot series. Capable of flawless performance and speedy acceleration, these robots feature a servo control system.
Models: MV4, MV6, MV6L, MV16
Nachi Robots - SC Series
The high speeds of the Nachi SC series allow for greater productivity and the space saving design allows for shorter production lines. These light-weight robots allow for easy robot installation and transport.
Models: SC06F, SC15F, SC35F, SC50F, SC80LF, SC120LF, SC300F, SC400L, SC500, SC700DL
Nachi Robots - SG Series
The Nachi SG series is a compact, highly flexible line of robots created for spot welding, material handling, and machine tending applications. The unique design of SG series robots allows for shorter production lines and double installations.
Models: SG160P, SG160R
Nachi Robots - SH Series
The heavy-duty SH robot series provides customers with their choice of floor or shelf mount models. Ideal for spot welding, material handling and machine tending, the SH line of robots offers generous work envelopes and payloads.
Models: SH133, SH166, SH200
Nachi Robots - SA Series
Turn to these powerful Nachi SA series robots for medium to high payload applications ranging from spot welding and machine tending to material handling.
Models: SA130, SA160, SA200
Nachi Robots - VS Series
The small vertically articulated VS robot series features the fastest speeds in its class. By applying high power to the AC servo motor, the standard cycle time is improved to 0.4 seconds.
Models: VS05E
Nachi Robots - MA Series
Nachi's line of MA robots was designed deliver precision and speed in loading and unloading applications.
Models: MA15E
Nachi Robots - ST Series
Nachi's ST series comes in a variety of models, offering a wide range of reaches and payload capacities.
Models: ST166, ST200
Nachi Robots - MC Series
Easy to install into any shop, the Nachi MC Series robots were designed to give superior performances in a variety of material handling applications.
Models: MC20-01, MC35
Nachi Robots - MR Series
The 7-axis Nachi MR20 robot is designed for flexibility and precision-driven performance. Ideal for arc welding and material handling tasks, the MR series is compact and easily to install.
Models: MR20
Nachi Teach Pendants
Nachi Controllers: AX, AW, AR
Nachi MV4 Robot
Applications: Arc Welding, Mig Welding, Plasma Cutting
Reach: 1411 mm
Payload: 4 kg
Full Specifications
Nachi MV6 Robot
Applications: Arc Welding, Flux Cored Welding, Mig Welding
Available Nachi Controllers: AX
Reach: 1402 mm
Payload: 6 kg
Full Specifications
Nachi MV6L Robot
Applications: Arc Welding, Mig Welding, Tig Welding
Reach: 2006 mm
Payload: 6 kg
Full Specifications
Nachi MV16 Robot
Reach: 1710 mm
Payload: 16 kg
Full Specifications
Nachi SC06F Robot
Applications: Arc Welding, Material Handling, Robotic Assembly
Available Nachi Controllers: AW, AX
Reach: 1370 mm
Payload: 6 kg
Full Specifications
Nachi SC15F Robot
Applications: Arc Welding, Machine Tending, Material Handling
Available Nachi Controllers: AR, AW, AX
Reach: 1587 mm
Payload: 15 kg
Full Specifications
Nachi SC35F Robot
Applications: Arc Welding, Deburring, Material Handling
Available Nachi Controllers: AR, AX
Reach: 2002 mm
Payload: 35 kg
Full Specifications
Nachi SC50F Robot
Applications: Machine Tending, Material Handling, Plasma Cutting
Reach: 2002 mm
Payload: 50 kg
Full Specifications
Nachi SC80LF Robot
Applications: Material Handling, Pick and Place, Plasma Cutting
Reach: 3088 mm
Payload: 80 kg
Full Specifications
Nachi SC120LF Robot
Applications: Machine Tending, Material Handling, Spot Welding
Reach: 2544 mm
Payload: 120 kg
Full Specifications
Nachi SC300F Robot
Applications: Machine Tending, Material Handling, Palletizing
Reach: 2534 mm
Payload: 300 kg
Full Specifications
Nachi SC400L Robot
Applications: Material Handling, Palletizing, Part Transfer
Reach: 3623 mm
Payload: 400 kg
Full Specifications
Nachi SC500 Robot
Reach: 2703 mm
Payload: 500 kg
Full Specifications
Nachi SC700DL Robot
Applications: Machine Loading, Material Handling
Reach: 3972 mm
Full Specifications
Nachi SG160P Robot
Applications: Machine Loading, Machine Tending, Material Handling
Reach: 1350 mm
Payload: 160 kg
Full Specifications
Nachi SG160R Robot
Applications: Machine Loading, Material Handling, Spot Welding
Reach: 1600 mm
Payload: 160 kg
Full Specifications
Nachi SH133 Robot
Reach: 2654 mm
Payload: 133 kg
Full Specifications
Nachi SH166 Robot
Applications: Material Handling, Palletizing, Spot Welding
Reach: 2654 mm
Payload: 166 kg
Full Specifications
Nachi SH200 Robot
Applications: Material Handling, Palletizing, Robotic Assembly
Reach: 2674 mm
Payload: 200 kg
Full Specifications
Nachi SA130 Robot
Applications: Machine Tending, Material Handling, Material Removal
Reach: 2597 mm
Payload: 130 kg
Full Specifications
Nachi SA160 Robot
Reach: 2597 mm
Payload: 160 kg
Full Specifications
Nachi SA200 Robot
Applications: Material Handling, Plasma Cutting, Resistance Welding
Reach: 2424 mm
Payload: 200 kg
Nachi VS05E Robot
Applications: Machine Loading, Material Handling, Robotic Assembly
Reach: 653 mm
Payload: 5 kg
Full Specifications
Nachi MA15E Robot
Applications: Machine Loading, Material Handling, Part Transfer
Reach: 837 mm
Payload: 15 kg
Full Specifications
Nachi ST166 Robot
Applications: Deburring, Machine Loading, Material Handling
Reach: 2654 mm
Payload: 166 kg
Full Specifications
Nachi ST200 Robot
Reach: 2654 mm
Payload: 200 kg
Full Specifications
Nachi MC20-01 Robot
Reach: 1722 mm
Payload: 22 kg
Full Specifications
Nachi MC35 Robot
Reach: 2050 mm
Payload: 35 kg
Full Specifications
Nachi MR20 Robot
Applications: Machine Tending, Material Handling, Packaging
Reach: 1260 mm
Payload: 30 kg
Full Specifications
Nachi AX Pendant
Many hardware and software enhancements are available for the high-performance Nachi AX Controller.
View Pendant
Nachi AW Pendant
This Nachi AW controller provides performance combined with improved menu-driven programming.
View Pendant
Nachi AR Pendant
Benefits & Features: Improved Ergonomic design Used-friendly, easy operation teach pendant Simultaneous 6-axis control Hot Edit 16,000 points memory capacity Menu driven interactiv...
View Pendant
