本公司专业销售大型进口各种品牌DCS系统模块备件:AB,ABB Advant OCS,ABB MOD 30/MODCELL,ABB MOD 300,ABB Bailey INFI 90,ABB Procontic,ABB Procontrol,H&B Contronic,Moore APACS,Moore Panel Controllers,Rosemount RS-3,Siemens Iskamatic,Siemens Simatic S5,Siemens Simatic C1,Yokogawa Centum XL,Yokogawa microXL,FOXBORO I/A,Westinghouse,Ovation,Honeywell QCS,Honeywell TDC系列,Honeywell S9000,HITACHI,Mitsubishi PLC,Motorola MVME,ALSTOM MVME,Other VME,TOSHIBA,HP,Yaskawa,FANUC等大型模组,有着充足的库存,交货期快,欢迎来电查询。
厦门兴锐达自动化设备有限公司
联系人:王文光
手机:15359273780
电话:0592-5580707
传真:0592-5580710
邮编:361009
QQ:1282972140
网址:http://www.xrdauto.com
OTC机器人备件
OTC Workcells
The OTC DAIHEN Almega Workcell series includes a wide selection of Almega manipulators and OTC DAIHEN positioners. These Arc Cell turnkey workcells from OTC increase production and part quality while reducing costs and cycle times.
Models: AX-HF500, E120, FW250, T60, more...
OTC Robots - AX Series
The OTC DAIHEN Almega AX Robots are large envelope robots designed for customers who demand high quality welding while avoiding fixture interference due to bulky cables. This articulated robot arm interfaces seamlessly with the D series welding power sources.
Models: AX-V4, AX-V6, AX-V16, AX-V35F, AX-V50F, AX-V133, AX-V166, AX-V200, AX-V300F, AX-V500, AX-V4L, AX-V80LF, AX-V120LF, AX-V400L, AX-H3
OTC Robots - MR Series
OTC DAIHEN worked with the Miller Electric Company to develop a line of dedicated arc welding robots that integrate with Miller welding equipment. The resulting MRV arc welding robot arms are an affordable, reliable solution to MIG and MAG welding applications.
Models: MRV-6, MRV-10
OTC Robots - EX Series
Robots in the OTC DAIHEN EX series come in a wide variety of arm lengths and load capacities. These hard-working industrial robots are ready to take on tough welding and plasma cutting applications. Integrate an OTC robot arm and start saving today!
Models: EX-V6, EX-V16, EX-V6L
OTC Robots - AII Series
OTC DAIHEN AII Series robots is a line of robot designed to deliver superior arc welding performances. With slim desgins and wide work envelopes the AII series is ideal for work in compact areas.
Models: AII-B4, AII-V6, AII-V20
OTC Teach Pendants
OTC Controllers: AX21 , AX-C, EX-C
OTC AX-V4 Robot
Applications: Arc Welding, Mig Welding, Tig Welding
Available OTC Controllers: AX-C
Reach: 1410 mm
Payload: 4 kg
Full Specifications
OTC AX-V6 Robot
Reach: 1402 mm
Payload: 6 kg
Full Specifications
OTC AX-V16 Robot
Reach: 1710 mm
Payload: 16 kg
Full Specifications
OTC AX-V35F Robot
Applications: Machine Loading, Machine Tending, Material Handling
Reach: 2002 mm
Payload: 35 kg
Full Specifications
OTC AX-V50F Robot
Applications: Material Handling, Part Transfer, Plasma Cutting
Reach: 2002 mm
Payload: 50 kg
Full Specifications
OTC AX-V133 Robot
Applications: Machine Loading, Material Handling, Palletizing
Reach: 2654 mm
Payload: 133 kg
Full Specifications
OTC AX-V166 Robot
Applications: Machine Tending, Material Handling, Spot Welding
Reach: 2654 mm
Payload: 166 kg
Full Specifications
OTC AX-V200 Robot
Applications: Material Handling, Palletizing, Spot Welding
Reach: 2674 mm
Payload: 200 kg
Full Specifications
OTC AX-V300F Robot
Applications: Machine Tending, Material Handling, Palletizing
Reach: 2534 mm
Payload: 300 kg
Full Specifications
OTC AX-V500 Robot
Reach: 2703 mm
Payload: 500 kg
Full Specifications
OTC AX-V4L Robot
Reach: 2008 mm
Payload: 4 kg
Full Specifications
OTC AX-V80LF Robot
Applications: Machine Tending, Material Handling, Plasma Cutting
Reach: 3088 mm
Payload: 80 kg
Full Specifications
OTC AX-V120LF Robot
Applications: Machine Tending, Material Handling, Pick and Place
Reach: 2544 mm
Payload: 120 kg
Full Specifications
OTC AX-V400L Robot
Reach: 3623 mm
Payload: 400 kg
Full Specifications
OTC AX-H3 Robot
Reach: 800 mm
Payload: 3 kg
Full Specifications
OTC MRV-6 Robot
Reach: 1336 mm
Payload: 6 kg
Full Specifications
OTC MRV-10 Robot
Reach: 1602 mm
Payload: 10 kg
Full Specifications
OTC EX-V6 Robot
Applications: Arc Welding, Plasma Cutting
Available OTC Controllers: EX-C
Reach: 1402 mm
Payload: 6 kg
Full Specifications
OTC EX-V16 Robot
Reach: 1709 mm
Payload: 16 kg
Full Specifications
OTC EX-V6L Robot
Reach: 2031 mm
Payload: 6 kg
Full Specifications
OTC AII-B4 Robot
Available OTC Controllers: AX21
Reach: 1411 mm
Payload: 4 kg
Full Specifications
OTC AII-V6 Robot
Reach: 1402 mm
Payload: 6 kg
Full Specifications
OTC AII-V20 Robot
Applications: Arc Welding, Material Handling
Reach: 1710 mm
Payload: 20 kg
Full Specifications
OTC AX21 Pendant
The OTC AX21 controller is designed to be used with a variety of applications such as arc welding, spot welding, and material handling.
View Pendant
OTC AX-C Pendant
The OTC AX-C controller is a PC bases controller that provides more flexibility to adapt to customized systems. This controller features the ability to control up to 54 axes and nine mechanisms.
View Pendant
OTC EX-C Pendant
The OTC EX-C controller is capable of enhanced system configuration and a multi-task function that provides greater job efficiency.
View Pendant
