厦门兴锐达自动化设备有限公司
  • Panasonic机器人备件
  • 发布时间:2010/6/4 11:57:25   修改时间:2010/6/4 11:57:25 浏览次数:685
  • 本公司专业销售大型进口各种品牌DCS系统模块备件:AB,ABB Advant OCS,ABB MOD 30/MODCELL,ABB MOD 300,ABB Bailey INFI 90,ABB Procontic,ABB Procontrol,H&B Contronic,Moore APACS,Moore Panel Controllers,Rosemount RS-3,Siemens Iskamatic,Siemens Simatic S5,Siemens Simatic C1,Yokogawa Centum XL,Yokogawa microXL,FOXBORO I/A,Westinghouse,Ovation,Honeywell QCS,Honeywell TDC系列,Honeywell S9000,HITACHI,Mitsubishi PLC,Motorola MVME,ALSTOM MVME,Other VME,TOSHIBA,HP,Yaskawa,FANUC等大型模组,有着充足的库存,交货期快,欢迎来电查询。
    厦门兴锐达自动化设备有限公司
    联系人:王文光
    手机:15359273780
    电话:0592-5580707
    传真:0592-5580710
    邮编:361009
    QQ:1282972140
    网址:http://www.xrdauto.com
    Panasonic机器人备件
    Panasonic Workcells
    The PerformArc series is a family of pre-engineered robotic arc welding systems ready to be integrated to optimize your welding performance. With a variety of Panasonic Robot Arms and positioners, this customizable series produces a turnkey solution for factory automation.
    Models: PerformArc 42, PerformArc 52, PerformArc 100, PerformArc 102s, PerformArc 112s, PerformArc 122s, PerformArc 125, PerformArc 150, PerformArc 175, PerformArc 300, more...
    Panasonic Robots - VR Series
    The Panasonic VR Series features a variety of robots that excel at factory automation applications. The smaller robots, such as the VR-004 feature the ability to be inverted on a gantry system. The larger models, such as the VR-120 are ideal for spot welding applications.
    Models: VR-004GII, VR-005CII, VR-006, VR-006L, VR-008, VR-008L, VR-016, VR-032, VR-120HII
    Panasonic Robots - TAWERS Series
    Dedicated arc welding robots from the Panasonic TAWERS robot series are easily integrated for MIG and MAG welding. TA manipulators, WG welders, and embedded arc control technology are combined to provide a fast, high-tech solution to arc welding applications.
    Models: TA-1000WG, TA-1400WG, TA-1600WG, TA-1800WG, TA-1900WG
    Panasonic Robots - AW Series
    Automate affordably with a Panasonic Robot from the AW series. This versatile line of industrial robots can make any factory automation system more profitable with its reliable output capability. From arc welding to material handling, a solution can be found with a Panasonic Robot arm.
    Models: AW-005A, AW-005CL, AW-010A, AW-010C, AW-8010, AW-0660, AW-7000
    Panasonic Teach Pendants
    Panasonic Controllers: TA, G2, C, P, HII, A
    Panasonic VR-004GII Robot
    Applications: Arc Welding, Material Handling, Pick and Place
    Available Panasonic Controllers: G2
     Reach: 947 mm
    Payload: 4 kg
    Full Specifications
    Panasonic VR-005CII Robot
    Applications: Arc Welding, Material Handling, Mig Welding
    Available Panasonic Controllers: C
     Reach: 1259 mm
    Payload: 5 kg
    Full Specifications
    Panasonic VR-006 Robot
    Applications: Arc Welding, Flux Cored Welding, Material Handling
    Available Panasonic Controllers: A, C, G2
     Reach: 1360 mm
    Payload: 6 kg
    Full Specifications
    Panasonic VR-006L Robot
    Applications: Arc Welding, Mig Welding, Tig Welding
     Reach: 1745 mm
    Payload: 6 kg
    Full Specifications
    Panasonic VR-008 Robot
     Reach: 1547 mm
    Payload: 8 kg
    Full Specifications
    Panasonic VR-008L Robot
     Reach: 1895 mm
    Payload: 8 kg
    Full Specifications
    Panasonic VR-016 Robot
    Available Panasonic Controllers: A, G2
     Reach: 1711 mm
    Payload: 16 kg
    Full Specifications
    Panasonic VR-032 Robot
    Applications: Material Handling, Part Transfer, Pick and Place
     Reach: 1866 mm
    Payload: 32 kg
    Full Specifications
    Panasonic VR-120HII Robot
    Applications: Material Handling, Plasma Cutting, Resistance Welding
    Available Panasonic Controllers: HII
     Reach: 2490 mm
    Payload: 120 kg
    Full Specifications
    Panasonic TA-1000WG Robot
    Available Panasonic Controllers: G2, TA
     Reach: 1068 mm
    Payload: 6 kg
    Full Specifications
    Panasonic TA-1400WG Robot
     Reach: 1374 mm
    Payload: 6 kg
    Full Specifications
    Panasonic TA-1600WG Robot
     Reach: 1598 mm
    Payload: 8 kg
    Full Specifications
    Panasonic TA-1800WG Robot
     Reach: 1796 mm
    Payload: 8 kg
    Full Specifications
    Panasonic TA-1900WG Robot
     Reach: 1895 mm
    Payload: 6 kg
    Full Specifications
    Panasonic AW-005A Robot
     Reach: 1335 mm
    Payload: 5 kg
    Full Specifications
    Panasonic AW-005CL Robot
    Applications: Arc Welding, Plasma Cutting
     Reach: 1335 mm
    Payload: 5 kg
    Full Specifications
    Panasonic AW-010A Robot
    Applications: Arc Welding, Material Handling, Plasma Cutting
     Reach: 1613 mm
    Payload: 10 kg
    Full Specifications
    Panasonic AW-010C Robot
     Reach: 1613 mm
    Payload: 10 kg
    Full Specifications
    Panasonic AW-8010 Robot
     Reach: 1613 mm
    Payload: 10 kg
    Full Specifications
    Panasonic AW-0660 Robot
    Applications: Arc Welding, Machine Loading, Material Handling
     Reach: 1270 mm
    Payload: 5 kg
    Full Specifications
    Panasonic AW-7000 Robot
     Reach: 1424 mm
    Payload: 10 kg
    Full Specifications
    Panasonic TA Pendant
    The Panasonic TA controller is part of the TAWERS robot line and features an integrated power source. It has the ability to control six axes simultaneously.
     View Pendant
    Panasonic G2 Pendant
    The Panasonic G2 Robot Controller is a 64-bit RISC processor-based controller with a Windows CE-based teach pendant. It provides a user-friendly interface which enhances productivity.
     View Pendant
    Panasonic C Pendant
    The Panasonic C style cabinet has a CV welder integrated into the controller.
     View Pendant
    Panasonic P Pendant
    The Panasonic P controller offers the same advantages as the C series, but includes a pulse welder integrated into the cabinet.
     View Pendant
    Panasonic HII Pendant
    The Panasonic HII utilizes a dual CPU-32 bit RISC for enhanced processing speed - up to 50% over the previous model.
     View Pendant
    Panasonic A Pendant
    The Panasonic A style controller is a space-saving cabinet that does not include an integrated internal welder.
     View Pendant
厦门兴锐达自动化设备有限公司是一家从事科研开发和工程技术服务的高新技术企业.主营业务:中低压电气,电气自动化,工程设计,技术服务等,是福建省著名的工业电气自动化单位.公司本着"准确,高效,全面,公平,创造财富,提高资源利用率"为宗旨,服务于省内外各…  更多>>
厦门兴锐达自动化设备有限公司
联系人:王文光
地址:厦门市湖里区五缘湾营运中心1号楼2层EF单元
邮编:361009
电话:0592-5580707
传真:0592-5361289
公司网址:http://www.xmxrdauto.com.cn
  • William Almeida 在2015/3/19 1:32:00留言
  • 详细留言:Dear Sirs, We, at Motivax, would be glad to work with your company, in a mutual colaboration. To achieve this goal, we would like to ask your promptly help to quote the selected parts below, giving us your best price for sale: Item 1. Reference: 5501-470. Gás turbine module WOODWARD. 1 UNIT. Item 9. Reference: 5466-031. specific card for Gás turbine Pratt&Whitne. WOODWARD. 9 UNIT. Please make sure to send me the Lead Time to delivery, the weight and dimension of the material. If you are offering an alternative item, please send its datasheet. Best Regards, Mr. WillIam de Almeida Commercial Department Motivax 1982 NW 82nd Ave Miami, FL 33126, USA Phone: +1(786)2205825 7001498012
  • Petruzzi 在2011/10/24 18:44:00留言
  • 详细留言:OMRON R88M-H50030 AC SERVO MOTOR 500W speed 3000 rpm
  • joe scarlotto 在2011/10/5 2:48:00留言
  • 详细留言:Need p/a qty 3 A2260A 745/50 CPU'S
  • 陳薔妃 在2011/4/12 10:00:00留言
  • 详细留言:我想購買Oriental Motor Harmonic Gear Drive UHG50-2B Ratio 1:50 1個是否可報價給我?我们公司是在臺灣,麻煩您了
