厦门兴锐达自动化设备有限公司
  • Robot Workcells机器人
  • 发布时间:2010/6/4 11:58:19   修改时间:2010/6/4 11:58:19 浏览次数:875
  • 本公司专业销售大型进口各种品牌DCS系统模块备件:AB,ABB Advant OCS,ABB MOD 30/MODCELL,ABB MOD 300,ABB Bailey INFI 90,ABB Procontic,ABB Procontrol,H&B Contronic,Moore APACS,Moore Panel Controllers,Rosemount RS-3,Siemens Iskamatic,Siemens Simatic S5,Siemens Simatic C1,Yokogawa Centum XL,Yokogawa microXL,FOXBORO I/A,Westinghouse,Ovation,Honeywell QCS,Honeywell TDC系列,Honeywell S9000,HITACHI,Mitsubishi PLC,Motorola MVME,ALSTOM MVME,Other VME,TOSHIBA,HP,Yaskawa,FANUC等大型模组,有着充足的库存,交货期快,欢迎来电查询。
    厦门兴锐达自动化设备有限公司
    联系人:王文光
    手机:15359273780
    电话:0592-5580707
    传真:0592-5580710
    邮编:361009
    QQ:1282972140
    网址:http://www.xrdauto.com
    Robot Workcells机器人
    RobotWorx Robot Workcells
    For challenging welding applications that involve multiple parameters or large parts, the best solution is often a custom workcell. RobotWorx can design an affordable workcell that meets the needs of your application.
    Models: RW900, RW1000, RW1050, RW1050S, RW1450, RW2450, Hybrid, more...
    Motoman Robot Workcells
    As an experienced Motoman Integrator, RobotWorx can integrate a Motoman World Solution work cell for a wide variety of industrial applications.
    Models: ArcWorld 1000, ArcWorld 6000, ArcWorld 6200, ArcWorld II50, ArcWorld II100, ArcWorld II100HD, ArcWorld II200, ArcWorld II500, ArcWorld III1000, ArcWorld III6000, more...
    Fanuc Robot Workcells
    Take advantage of the increased productivity and savings provided by one of RobotWorx' custom-built Fanuc workcells. Fanuc workcells are fitted with complete safety environments, tooling, positioners, and much more at an affordable cost.
    Models: Ferris Wheel System, Track System, Gantry System, more...
    Panasonic Robot Workcells
    The PerformArc series is a family of pre-engineered robotic arc welding systems ready to be integrated to optimize your welding performance. With a variety of Panasonic Robot Arms and positioners, this customizable series produces a turnkey solution for factory automation.
    Models: PerformArc 42, PerformArc 52, PerformArc 100, PerformArc 102s, PerformArc 112s, PerformArc 122s, PerformArc 125, PerformArc 150, PerformArc 175, PerformArc 300, more...
    OTC Robot Workcells
    The OTC DAIHEN Almega Workcell series includes a wide selection of Almega manipulators and OTC DAIHEN positioners. These Arc Cell turnkey workcells from OTC increase production and part quality while reducing costs and cycle times.
    Models: AX-HF500, E120, FW250, T60, more...
    RobotWorx RW900
    The RobotWorx RW900 custom workcell features a 180 degree manual turn table and a reconditioned welding robot.
     Motoman Integrator: RW900 with Motoman UP6 and Manual Turntable
    RobotWorx RW1000
    The RW-1000 workcell by RobotWorx is customized to fit your needs.This workcell is equipped with a Fanuc ArcMate 100i robot and a complete safety environment.
     RW1000 - Stationary Table Welding Workcell OTC AX-V4
    RobotWorx RW1050
    Flexibility defines RobotWorx' RW1050 workcell. RobotWorx customizes this welding system to fit your application, product, and facility requirements.
     Servo-Controlled Turntable Workcell - RW1050S
    RobotWorx RW1050S
    Increase your productivity and throughput with the efficient, fully-customizable RW1050S. The RobotWorx RW1050S is a single robot workcell with a servo-controlled table.
    RobotWorx RW1450
    The RW1450 is a custom welding cell designed by RobotWorx. The RW1450 includes a headstock / tailstock positioner and a stationary work table.
     Robot Integration: RW1450 Turnkey Workcell
    RobotWorx RW2450
    The RW2450 is designed for speedy, efficient performance. Twin headstock-tailstocks are 5 feet apart and offer a 450kg maximum capacity.
     RobotWorx RW2450 Workcell
    RobotWorx Hybrid
    Designed for ultimate savings, the RobotWorx Hybrid Workcell presents an affordable answer to automation challenges.
     New & Used Robot Integration - Hybrid Workcells
    Motoman ArcWorld 1000
    The self-contained Motoman ArcWorld 1000 is a pre-engineered arc welding workcell with a single robot and indexing rotary positioner. It is designed for high-volume production.
     RW1050 with Motoman UP6 Robot For Sale, ArcWorld 1000
    Motoman ArcWorld 6000
    The Motoman ArcWorld 6000 features a single robot on a riser and a headstock / tailstock (HS/TS) part positioner.  Robots such as the Motoman UP6 or UP20 are ideal for this workcell.
     Motoman ArcWorld 6000 with UP20 XRC
    Motoman ArcWorld 6200
    The Motoman AW6200 features dual arc welding robots in the mid- reach and payload range. Positioned upon risers, the robots can simultaneously weld on a large part or multiple smaller parts.
     Motoman ArcWorld 6200 with UP 6 Robot
    Motoman ArcWorld II50
    The ArcWorld II-50 series are a line of industrial-grade robotic welding cells at an economical price. A variety of workcell configurations allow for maximum customization for your application.
    Motoman ArcWorld II100
    The ArcWorld II-100 line of workcells is affordable and ideal for general fabricators. The two-station turntable allows an operator to easily load and unload parts from a single point.
    Motoman ArcWorld II100HD
    Similar to the Motoman ArcWorld II-100, the AW II-100HD is designed to be an all-inclusive welding solution. It features the MSR-300, a heavy-duty servo-controlled turntable with a 300kg payload.
    Motoman ArcWorld II200
    The dual-station Motoman Arc World II-200 easily handles small-to-medium sized parts and quick tooling changes. Two stationary tables provide the positioning for parts.
    Motoman ArcWorld II500
    Two 180kg servo MHT-180 headstock / tailstock positioners provide the part positioning in the Motoman ArcWorld II-500 workcell. It is preassembled on a common platform and designed for easy setup.
    Motoman ArcWorld III1000
    The Motoman ArcWorld III-1000 uses a servo indexing turntable for high speed part positioning. The table is programmed through the robot controller and performs as an additional axis.
    Motoman ArcWorld III6000
    The Motoman Arc World III-6000 industrial robot makes factory automation easier and more profitable for wire-to-weld, high volume, high performance welding applications.
    Motoman ArcWorld IV-4000
    The Motoman ArcWorld IV-4000 family of fully integrated robotic solutions features a high-speed double-ended headstock / tailstock positioner and one robot (AWIV-4000) or two robots (AWIV-4200) for Hy...
    Motoman ArcWorld V-6000
    Motoman's ArcWorld V series workcells utilize up to 44% less floor space by mounting the robots overhead.
    Motoman FabWorld
    Motoman's FabWorld is a modular robotic welding solution that is designed especially for the manufacturer involved in low- to high-volume production runs with large parts that require longer cycle tim...
    Motoman LaserWorld
    The Motoman LaserWorld Solution is pre-engineered and fully integrated to include all automation required for robotic laser cutting or welding.
    Motoman PackWorld
    The Motoman PackWorld is a cost-effective, modular packaging solution ideal for small cartons, bottles and pouches. Multiple configurations are offered to meet specific throughput requirements.
    Motoman PalletWorld
    As a modular turnkey solution, the Motoman PalletWorld is designed to handle the majority of palletizing applications while its standard components keep engineering costs low.
    Motoman PlasmaWorld
    With Motoman's high-performance HP6 or HP20 robot and integrated High Tolerance Plasma Arc Cutting (HTPAC) package, the PlasmaWorld solution delivers near laser quality cuts with minimal capital inves...
    Motoman SpotWorld iv-6000
    Motoman's SpotWorld IV-6000 family of fully integrated robotic solutions features a high-speed positioner and one (SWIV-6000) or two (SWIV-6200) robots for HyperProductivity.
    Fanuc Ferris Wheel System
    The Fanuc Ferris Wheel Workcell is designed to save space and enhance operator safety.
     Fanuc Integrator: Ferris Wheel System with ArcMate 100i Robots
    Fanuc Track System
    The Dual Fanuc Track System allows for nearly 63 foot of travel along a servo controlled track to accommodate applications with large parts and multiple processes.
    Fanuc Gantry System
    A gantry robot system mounts a robot arm on an overhead track, creating a horizontal plane that the robot can travel and extending the work envelope.
     Fanuc ArcMate 120i RJ3 Gantry System
    Panasonic PerformArc 42
    The PerformArc 42 comes equipped with a dual station work table and a 6 axis arc welding robot.
     Mobile Robot Demo: Panasonic PerformArc 42
    Panasonic PerformArc 52
    The Panasonic PerformArc 52 is a versatile arc welding system that is easy to integrate into any automation floor.
    Panasonic PerformArc 100
    Pre-wired and pre-assembled the Panasonic PerformArc100 is capable of being up and running within hours of arrival.
    Panasonic PerformArc 102s
    The Panasonic PerformArc 102S is a versatile industrial robot workcell that is well-suited for almost any production job.
    Panasonic PerformArc 112s
    The Panasonic PerformArc 112S is a versatile industrial robot workcell capable of almost any production job. Features: VR-006G II arc welding 6-axis robot manipulator with a 1360mm reach.
    Panasonic PerformArc 122s
    One of the most versatile industrial robotic workcells on the market, the Panasonic PerformArc 122S is a great choice for any arc welding project.
    Panasonic PerformArc 125
    The PerformArc 125 arc welding system is a versatile, welding robot that is easy to integrate onto the factory floor.
    Panasonic PerformArc 150
    The PerformArc150 robotic system is equipped with a Panasonic six-axis robot and a high speed electric indexer that is capable of handling heavy payloads.
    Panasonic PerformArc 175
    The PerformArc 175 arc welding system is a versatile, welding robot that is easy to integrate onto the factory floor.
    Panasonic PerformArc 300
    The PerformArc 300 arc welding system provides a versatile, compact solution for multiple settings. Achieve your production goals with this complete workcell.
     Panasonic PerformArc 350 - Robotic Welding, PerformArc 300
    OTC AX-HF500
    DAIHEN Almega Series Arc Cells are shipped pre-assembled to reduce installation time. All are designed with forklift pockets to allow for easy placement in your manufacturing area.
    OTC E120
    The DAIHEN Almega E Series Arc Cell is perfectly suited for production runs of medium to high volume.It has service access doors and the operator loads parts from outside the workcell.
    OTC FW250
    The DAIHEN Almega FW Series Arc Cell is shipped as pre-engineered modular components to reduce installation time.
    OTC T60
    The DAIHEN Almega T Series Arc Cells are shipped pre-assembled to reduce installation time. All are designed with forklift pockets to allow for easy placement in your manufacturing area.
厦门兴锐达自动化设备有限公司是一家从事科研开发和工程技术服务的高新技术企业.主营业务:中低压电气,电气自动化,工程设计,技术服务等,是福建省著名的工业电气自动化单位.公司本着"准确,高效,全面,公平,创造财富,提高资源利用率"为宗旨,服务于省内外各…  更多>>
厦门兴锐达自动化设备有限公司
联系人:王文光
地址:厦门市湖里区五缘湾营运中心1号楼2层EF单元
邮编:361009
电话:0592-5580707
传真:0592-5361289
公司网址:http://www.xmxrdauto.com.cn
  • 劉治安 在2025/7/8 16:34:00留言
  • 详细留言:安川HW9171094-A請惠予報價
  • William Almeida 在2015/3/19 1:32:00留言
  • 详细留言:Dear Sirs, We, at Motivax, would be glad to work with your company, in a mutual colaboration. To achieve this goal, we would like to ask your promptly help to quote the selected parts below, giving us your best price for sale: Item 1. Reference: 5501-470. Gás turbine module WOODWARD. 1 UNIT. Item 9. Reference: 5466-031. specific card for Gás turbine Pratt&Whitne. WOODWARD. 9 UNIT. Please make sure to send me the Lead Time to delivery, the weight and dimension of the material. If you are offering an alternative item, please send its datasheet. Best Regards, Mr. WillIam de Almeida Commercial Department Motivax 1982 NW 82nd Ave Miami, FL 33126, USA Phone: +1(786)2205825 7001498012
  • Petruzzi 在2011/10/24 18:44:00留言
  • 详细留言:OMRON R88M-H50030 AC SERVO MOTOR 500W speed 3000 rpm
  • joe scarlotto 在2011/10/5 2:48:00留言
  • 详细留言:Need p/a qty 3 A2260A 745/50 CPU'S
