艾讯科技 (Axiomtek)
  • Intel Atom? x5-E3940 车载船载工控机
  • 发布时间:2013/1/26 0:49:17   修改时间:2023/5/22 16:21:39 浏览次数:2344
  • 采用英特尔凌动? x5-E3940 处理器的无风扇嵌入式系统,适用于车辆和铁路 PC
    CE、FCC、LVD、EN 45545-2 和 EN 50155 认证;符合 ISO7637-2 标准
    英特尔凌动? x5-E3940 处理器
    无风扇,工作温度范围为 -40°C 至 +70°C
    支持 9 至 36 VDC 和 12/24 VDC 典型车载电源输入
    支持 24VDC/36 至 110VDC 铁路电源输入
    紧凑的尺寸,具有多个COM,CANBus和DIO用于通信
    智能点火,用于电源开/关计划、车辆电池保护和不同的电源模式
    适用于交通网关应用
    CPU
    • Intel Atom? x5-E3940 4C @1.6 GHz, TDP: 9.5W
    Chipset
    • SoC integrated
    System Memory
    • 1 x DDR3L-1866 SO-DIMM, up to 8GB
    BIOS
    • AMI
    COM
    • Vehicle: 2 x RS-232/422/485 (4-wire) with shield grounding
    • Railway: 4 x Isolated RS-232/422/485 (4-wire) with shield grounding
    USB
    • 2 x USB 3.0
    PoE
    • N/A
    Ethernet
    • Vehicle: 2 x RJ-45 10/100/1000 Mbps Ethernet (Intel? I210-IT)
    • Railway: 2 x M12 A-coded 10/100/1000 Mbps Ethernet (Intel? i210-IT)
    Display
    • 2 x HDMI 1.4b (with keylock)
    CANbus
    • Vehicle: 2 x Isolated CANBus 2.0 A/B, support SocketCAN
    Digital I/O
    • Vehicle: 1 x DB9 8-bit programmable DIO
    • Railway: 1 x Terminal block isolated DIO 4-in/ 4-out (isolation voltage: 2 kV)
    Audio
    • 1 x Mic-in, 1 x Line-out
    Storage
    • 1 x Internal 2.5" SATA drive (9.5 mm height)
    • 1 x mSATA (occupied 1 x PCI Express Mini Card slot)
    Expansion
    • 2 x Full-size Rev.1.2 PCI Express Mini Card slot:
    • 1 x USB/PCIe with external SIM socket
    • 1 x mSATA/USB/PCIe with external SIM socket
    Others
    • 1 x Reset button
    • 1 x Power button
    • 1 x Remote switch
    • 4 x Antenna opening
    Power Consumption
    • Vehicle: 9 VDC, 3.742A; 36 VDC, 0.907A
    • Railway: 24 VDC, 1.38A; 36VDC - 110VDC, 0.98A - 0.33A
    Power Supply
    • 1 x Terminal block DC-in, (typical: 12/24 VDC) with ACC ignition
    • General use: 1 x Terminal block / M12, 9-36 VDC
    • Vehicle: 1 x Terminal block, 12/24 VDC with smart ignition
    • Railway: 1 x M12, 24 VDC / 36-110 VDC
    Watchdog Timer
    • 255 levels, 1 to 255 sec.
    Construction
    • Aluminum extrusion and heavy-duty steel, IP20
    Operating Temperature
    • -40°C to +70°C (-40°F to +158°F) with W.T. peripheral
    Relative Humidity
    • 0% to 95%, non-condensing
    Vibration
    • 3 Grms w/ SSD (5 to 500Hz, X/Y/Z direction; random, operating)
    • 1 Grms w/ HDD (5 to 500Hz, X/Y/Z direction; random, operating)
    • 2 Grms w/ HDD & Anti-Vibration Kit (5 to 500Hz, X/Y/Z direction; random, operating)
    • MIL-STD-810G, Method 514.6C-VI Category 4 compliant
    Shock
    • N/A
    Dimensions
    (W x D x H)
    • 164.1 x 128 x 44.1 mm (6.46" x 5.04” x 1.74”)
    Weight (net/gross)
    • 1.02 kg (2.24 lb)/1.44 kg (3.17 lb)
    Certifications
    • CE , FCC, LVD, EN 45545-2 and EN 50155 certified
    • ISO 7637-2 compliant
    EOS Support
    • Windows? 10 64-bit, Ubuntu 20.04
    Software Support
    • AXView
    Mounting
    • Wall mount, Din-rail
艾讯科技 (Axiomtek) 于 1990 年成立于台湾,20余年来,作为工控业内的老牌厂商,已成为世界工业计算机领域公认的领先设计者和制造商。自公司初创立起,艾讯科技即以创新的设计、高质量的质量保证和高客户满意度的服务态度而领先业界。 艾讯已在大陆…  更多>>
艾讯科技 (Axiomtek)
联系人:王先生
地址:北京海淀区马连洼北路亿城国际
邮编:100085
电话:13911408386
公司网址:http://www.axiomtek.com
