艾讯科技 (Axiomtek)
  • M12 千兆网卡 POE
  • 发布时间:2013/1/28 18:42:25   修改时间:2023/5/22 16:18:24 浏览次数:3265
  • 2 端口/4 端口 PCI 高速 1GigE PoE 卡,带 M12 X 编码
    Bus Type
    • PCI Express x4
    Connector
    • 2 or 4 GbE LANs (M12 x-coded) by Intel? i210-AT controller, support 9.5KB jumbo frame and IEEE 1588
    • IEEE 802.3at compliant, each port delivers up to 30W at 54 VDC
    Power Connector
    • 4-pin Molex & 6-pin ATX power connector
    • 12 VDC or 24 VDC
    Power Requirements
    • Power from PCIe slot (max. 20W PoE power output)
    • 2.1A @ +12V
    • 1.2A @ +3.3V
    • Power from ATX power connector (max. 120W PoE power output)
    • 12A @ +12V or 6A @ +24V
    • 1.2A @ +3.3V (from PCIe slot)
    • Power from Molex power connector (max. 60W PoE power output)
    Operating Temperature
    • 0°C to +60°C (+32°F to +140°F) (with airflow)
    Relative Humidity
    • 10% to 95%, non-condensing
    Dimensions
    • 168 x 111 mm
    Certifications
    • CE
    Software
    • N/A
    OS
    • Windows? 7/10 (32/64-bit)
    Intel Core? i7-2610UE/ i3-2340UE/ CeleronB810 processor
    2 x 204-pin DDR3-1066/1333 SODIMM max. up to 16 GB
    8 x isolated RS-232/422/485 (COM1 ~ 8)
    1 x DVI-I
    2 x DisplayPort
    1 x Audio (Mic-in/Line-out)
    2 x 10/100/1000Mbps Ethernet
    4 x USB 2.0
    2 x USB 3.0
    8 x isolated DI/DO
    2 x SMA type connector opening for antenna
    1 x VDC power input connector
    1 x ATX power switch
    -20°C ~ +70°C (-4°F ~ +158°F) (with W.T. SSD)
    192 mm (7.56") (W) x 230 mm (9.06") (D) x 100 mm (3.9") (H)
    订货信息:
    &eBOX730-860-FL-2610UE-DC
    Fanless embedded system with IntelCore? i7-2610UE 2.4
    GHz processor, VGA, DVI, 2 DisplayPort, 2 10/100/1000Mbps
    Ethernet, 6 USB, 8 isolated RS232/422/485, wide-range DC-in
    &eBOX730-860-FL-2340UE-DC
    Fanless embedded system with IntelCore? i3-2340UE 1.3
    &eBOX730-860-FL-B810E-DC
    Fanless embedded system with IntelCeleronB810E 1.6
艾讯科技 (Axiomtek) 于 1990 年成立于台湾,20余年来,作为工控业内的老牌厂商,已成为世界工业计算机领域公认的领先设计者和制造商。自公司初创立起,艾讯科技即以创新的设计、高质量的质量保证和高客户满意度的服务态度而领先业界。 艾讯已在大陆…  更多>>
艾讯科技 (Axiomtek)
联系人:王先生
地址:北京海淀区马连洼北路亿城国际
邮编:100085
电话:13911408386
公司网址:http://www.axiomtek.com
