艾讯科技 (Axiomtek)
  • Intel 8代CPU 2.5寸工业主板
  • 发布时间:2013/1/28 18:46:31   修改时间:2023/5/22 16:14:25 浏览次数:2517
  • Pico-ITX SBC,配备第 8 代英特尔?酷睿? i7/i5/i3 和赛扬?处理器、DisplayPort++、HDMI、LVDS 和 2 GbE LAN
    CPU
    • 8th gen Intel? Core? i7/i5/i3 and Celeron? processor onboard
    Chipset
    • SoC integrated
    System Memory
    • 1 x 260-pin DDR4-2400 SO-DIMM, up to 32GB
    BIOS
    • AMI
    COM
    • 2 x RS-232/422/485
    USB
    • 2 x USB 2.0
    • 2 x USB 3.2 Gen1
    Ethernet
    • 1 x 10/100/1000 Mbps (Intel? i219-LM)
    • 1 x 10/100/1000 Mbps (Intel? i211-AT)
    Display
    • 1 x DisplayPort++
    • 1 x HDMI 1.4
    • 1 x LVDS
    Digital I/O
    • 4-channel in/out programmable
    Audio
    • N/A
    Storage
    • 64GB eMMC (optional)
    • 1 x SATA-3
    Expansion
    • 1 x M.2 Key E (PCIe x1, USB 2.0 in 22x30)
    Others
    • I2C
    Battery
    • Lithium 3V/220 mAh
    Power Input
    • 2 x 2-pin connector
    • +12V DC-in only
    • AT Auto Power On function supported
    Power Requirements
    • Intel? Core? i7-8665UE @1.7 GHz 16GB DDR4, max. MS. +12V@2.9A
    • Intel? Core? i5-8365UE @1.6 GHz 16GB DDR4, max. MS. +12V@2.7A
    • Intel? Core? i3-8145UE @2.2 GHz 16GB DDR4, max. MS. +12V@2.3A
    • Intel? Celeron? 4305UE @2.0 GHz 16GB DDR4, max. RMS. +12V@2.0A
    Watchdog Timer
    • 65536 levels, 0 to 65535 sec.
    Hardware Monitoring
    • Yes
    Operating Temperature
    • -20°C to +60°C (-4°F to 140°F)
    Relative Humidity
    • 10% to 95% relative humidity, non-condensing
    Dimensions
    • 100 x 72 mm
    Board Thickness
    • 1.6 mm
    Certifications
    • CE
    Industrial Chassis
    • APC201-i3-8145UE (P/N-E27P201100): Embedded chassis with PICO52RHPGG-i3-8145UE (w/fan), 8GB RAM, 64GB eMMC and 12V/60W adapter
    • I/O: 1 x GbE LAN, 2 x USB 3.2 Gen1, 1 x DisplayPort++, 1 x HDMI, 1 x 12V DC Jack
    • Dimensions (with wall mount ear): 152.5 mm (6”) (W) x 107.5 mm (4.23”) (D) x 50mm (1.97”) (H)
    • Operating Temperature: -10°C to +50°C (+14°F to +122°F)
艾讯科技 (Axiomtek) 于 1990 年成立于台湾,20余年来,作为工控业内的老牌厂商,已成为世界工业计算机领域公认的领先设计者和制造商。自公司初创立起,艾讯科技即以创新的设计、高质量的质量保证和高客户满意度的服务态度而领先业界。 艾讯已在大陆…  更多>>
艾讯科技 (Axiomtek)
联系人:王先生
地址:北京海淀区马连洼北路亿城国际
邮编:100085
电话:13911408386
公司网址:http://www.axiomtek.com
