艾讯科技 (Axiomtek)
  • 嵌入式无风扇工控机 Intel 10/11代 视觉控制器
  • 发布时间:2013/3/4 21:54:05   修改时间:2023/5/22 15:54:45 浏览次数:2454
  • 无风扇嵌入式系统,带 LGA1200 插槽 第 11 代/第 10 代英特尔酷睿? i9/i7/i5/i3 或赛扬?处理器、英特尔?? H420E、2 个 HDMI、显示端口、6 个 USB、4 个局域网、PCIe x4 插槽和 9 至 48 VDC
    CPU
    • LGA1200 socket 11th/10th gen Intel? Core? i9/i7/i5/i3 or Celeron? processor (35W/65W)
    Chipset
    • Intel? H420E
    System Memory
    • 2 x 260 pin DDR4-2933 non-ECC SO-DIMM, up to 64GB
    BIOS
    • AMI
    COM
    • 2 x RS-232
    • 2 x RS-232/422/485
    USB
    • 5 x USB 3.2 Gen1
    • 1 x USB 2.0
    Ethernet/PoE
    • 4 x GbE LAN (3 x Intel? i210-IT, 1 x Intel? i219-LM)
    Display
    • 2 x HDMI 1.4b (lockable)
    • 1 x DisplayPort 1.2 ++
    Digital I/O
    • N/A
    Audio
    • N/A
    Storage
    • 2 x 2.5” SATA HDD/SSD (up to 15 mm height)
    • 2 x mSATA (enabled in BIOS setting)
    Expansion
    • 2 x Full-size PCI Express Mini Card slot (USB + PCIe + SATA signal)
    • 1 x M.2 Key B 3050 slot (for 5G; USB signal)
    • 1 x Front-access SIM slot with cover (for M.2 Key B)
    • 1 x Internal SIM slot with PCIe Mini Card slot
    • 1 x PCIe x4 slot
    • 1 x Flexible I/O window (Default: 2 x DB9 half-cut bracket)
    Others
    • TPM 2.0
    • 1 x AT/ATX quick switch
    • 1 x Remote switch
    • 5 x Antenna opening
    • 1 x Grounding
    Power
    • 9 to 48 VDC
    Watchdog Timer
    • 255 levels, 1 to 255 sec.
    Construction
    • Aluminum extrusion and heavy-duty steel, IP40
    Operating Temperature
    • -40°C to +70°C (-40°F to +158°F) with 0.7 m/s air flow (CPU TDP 35W)
    • -40°C to +60°C (-40°F to +158°F) with 0.7 m/s air flow (CPU TDP 65W)(with W.T. DRAM & SSD)
    Relative Humidity
    • 10% - 90%, non-condensing
    Vibration
    • IEC 60068-2-64 (w/ SSD: 3Grms STD, random, 5 - 500 Hz, 1 hr/axis)
    Shock
    • IEC 60068-2-27 (w/ SSD: 50G, half-sine, 11 ms duration)
    Dimensions
    (W x D x H)
    • 280 x 210 x 80.5mm (11.02" x 8.26" x 3.16")
    Weight (net/gross)
    • 4.9 kg (10.8 lb)/7 kg (15.43 lb)
    Certifications
    • CE, FCC Class A, UKCA
    EOS Support
    • Win 11/10 IoT, Linux
    Software Support
    • N/A
    Mounting
    • Wall mount kit
    • DIN-rail kit
艾讯科技 (Axiomtek) 于 1990 年成立于台湾,20余年来,作为工控业内的老牌厂商,已成为世界工业计算机领域公认的领先设计者和制造商。自公司初创立起,艾讯科技即以创新的设计、高质量的质量保证和高客户满意度的服务态度而领先业界。 艾讯已在大陆…  更多>>
艾讯科技 (Axiomtek)
联系人:王先生
地址:北京海淀区马连洼北路亿城国际
邮编:100085
电话:13911408386
公司网址:http://www.axiomtek.com
