艾讯科技 (Axiomtek)
  • J6412 3.5寸工业主板
  • 发布时间:2013/3/4 22:28:50   修改时间:2023/5/22 15:43:28 浏览次数:2961
  • 3.5“ 嵌入式 SBC,采用英特尔赛扬?处理器 N6210/J6412 或英特尔?凌动? x6413E 处理器、HDMI、LVDS、显示端口、可选 eDP、2.5GbE 局域网和千兆以太网局域网
    CPU
    • Intel? Celeron? processor N6210/J6412 or Intel Atom? x6413E processor onboard
    Chipset
    • SoC integrated
    System Memory
    • 1 x 260-pin DDR4-3200 SO-DIMM, up to 32GB
    BIOS
    • AMI
    COM
    • 2 x RS-232/422/485
    • 2 x RS-232
    USB
    • 4 x USB 2.0
    • 2 x USB 3.2 Gen2
    Ethernet
    • 1 x 10/100/1000 Mbps Ethernet with Intel? I211-AT; supports Wake-on LAN, PXE Boot ROM
    • 1 x 10/100/1000/2500 Mbps Ethernet with Intel? I225-LM; supports Wake-on LAN, PXE Boot ROM
    Display
    • 1 x HDMI
    • 1 x DisplayPort
    • 1 x LVDS
    • 1 x eDP (optional)
    Digital I/O
    • 8-channel in/out programmed
    Audio
    • HD Audio link via pin header
    Storage
    • 1 x SATA-600
    Expansion
    • 1 x Full-size PCI Express Mini Card slot (optional)
    • 1 x M.2 Key E (PCIe x1, USB 2.0 in 22 x 30)
    • 1 x M.2 Key B (PCIe x1, USB 3.2 Gen1, USB 2.0 in 30 x 42 or 30 x 50)
    Others
    • TPM 2.0 (optional)
    • SMBus (compatible with I2C)
    Battery
    • Lithium 3V/220mAH
    Power Input
    • 2 x 2-pin connector
    • +12V to 24V DC-in
    • AT Auto Power On function supported
    Power Requirements
    • N/A
    Watchdog Timer
    • 65536 levels, 1 to 65535 sec.
    Hardware Monitoring
    • Yes
    Operating Temperature
    • -20°C to +70°C (-4°F to 158°F) for Intel? Celeron? processor
    • -40°C to +85°C (-40°F to 185°F) for Intel? Atom? x6413E processor
    Relative Humidity
    • 10% to 95% relative humidity, non-condensing
    Dimensions
    • 146 x 104 mm
    Board Thickness
    • 1.6 mm
    Certifications
    • CE
    Industrial Chassis
    • N/A
艾讯科技 (Axiomtek) 于 1990 年成立于台湾,20余年来,作为工控业内的老牌厂商,已成为世界工业计算机领域公认的领先设计者和制造商。自公司初创立起,艾讯科技即以创新的设计、高质量的质量保证和高客户满意度的服务态度而领先业界。 艾讯已在大陆…  更多>>
艾讯科技 (Axiomtek)
联系人:王先生
地址:北京海淀区马连洼北路亿城国际
邮编:100085
电话:13911408386
公司网址:http://www.axiomtek.com
