艾讯科技 (Axiomtek)
  • Intel 12代 工业大母板 工业主板IMB540
  • 发布时间:2013/3/11 23:08:42   修改时间:2023/5/22 15:29:07 浏览次数:3568
  • ATX 主板,带 LGA1700 插槽 第 13 代/第 12 代英特尔酷睿? i9/i7/i5/i3、奔腾?或赛扬?处理器、英特尔?? R680E、USB 3.2 Gen2、SATA 3.0、GbE 和 2.5GbE LAN、VGA、DisplayPort++、DVI-D 和 HDMI
    CPU
    • LGA1700 socket 13th/12th gen Intel? Core? i9/i7/i5/i3, Pentium? or Celeron? processor (Up to 125W)
    Chipset
    • Intel? R680E
    System Memory
    • 4 x 288-pin DDR4-3200 ECC/Non-ECC un-buffered Long-DIMM, up to 128GB (ECC memory is available for Intel? R680E only)
    BIOS
    • AMI
    COM
    • 4 x RS-232 (internal box header)
    • 2 x RS-232/422/485 (rear I/O)
    USB
    • 4 x USB 3.2 Gen2x1 (10Gbps, rear I/O)
    • 2 x Dual USB 3.2 Gen1x1 (5Gbps, internal box header)
    • 4 x USB 2.0 (internal pin header)
    • 1 x USB 2.0 (internal 180D type A)
    Ethernet
    • 1 x 10/100/1000/2500 Mbps (Intel? I225-LM; Intel? AMT with Intel vPro?)
    • 1 x 10/100/1000 Mbps (Intel? I211-AT)
    Display
    • 1 x VGA
    • 1 x HDMI 1.4b
    • 1 x Displayport++ (DP 1.2)
    • 1 x DVI-D
    Digital I/O
    • 8-channel programmable
    Audio
    • HD Codec audio as MIC-in/Line-in/Line-out
    Storage
    • 4 x SATA-600 with RAID 0/1/5/10
    • M.2 Key M 2280 in support of PCIe x4 via CPU
    Expansion
    • 2 x PCIe Gen4 x16 slot (signal: x16 + x0 or x8 + x8)
    • 3 x PCIe x4 slot open-ended (1 x Gen3 + 2 x Gen4) (signal by PCH)
    • 1 x PCIe Mini Card slot (signal: PCIe x1)
    • 2 x 32-bit PCI slot, default clock is 33 Mhz, PCI clock could be selected between 33 or 66 MHz by jumper (signal by PCH)
    Others
    • 1 x PS/2 keyboard (internal box header)
    • 1 x PS/2 mouse (internal box header)
    Battery
    • Lithium 3 V/ 220 mAH
    TPM
    • TPM 2.0 (optional)
    Watchdog Timer
    • 255 levels, 1 to 255 sec.
    Hardware Monitoring
    • Yes
    Operating Temperature
    • 0°C to +60°C (+32°F to +140°F)
    Relative Humidity
    • 10% to 95% relative humidity, non-condensing
    Dimensions
    • 305 x 244 mm
    Board Thickness
    • 1.6 mm
    Certifications
    • CE
艾讯科技 (Axiomtek) 于 1990 年成立于台湾,20余年来,作为工控业内的老牌厂商,已成为世界工业计算机领域公认的领先设计者和制造商。自公司初创立起,艾讯科技即以创新的设计、高质量的质量保证和高客户满意度的服务态度而领先业界。 艾讯已在大陆…  更多>>
艾讯科技 (Axiomtek)
联系人:王先生
地址:北京海淀区马连洼北路亿城国际
邮编:100085
电话:13911408386
公司网址:http://www.axiomtek.com
