艾讯科技 (Axiomtek)
  • 12th Gen Intel? Core? i7/i5/i3 车载专用M12工控机
  • 发布时间:2016/6/17 17:51:09   修改时间:2023/5/22 15:13:17 浏览次数:3420
  • 采用第 12 代英特尔?酷睿? i7/i5/i3 处理器的铁路无风扇嵌入式系统
    CPU
    • 12th gen Intel? Core? i7/i5/i3 or Celeron? processor
    Chipset
    • SoC integrated
    System Memory
    • 2 x DDR5-4800 SO-DIMM, up to 64GB
    BIOS
    • AMI
    COM
    • 1 x DB9 serial console or RS-232/422/485
    • More COM ports available from I/O module (optional)
    USB
    • 4 x USB 3.0
    PoE
    • Available from I/O module (optional)
    Ethernet
    • 1 x RJ-45 2.5GbE (Intel? i226-IT)
    Display
    • 2 x Type A HDMI 1.4b (4K)
    CANbus
    Digital I/O
    Audio
    • 1 x Mic-in
    • 1 x Line-out
    Storage
    • 1 x M.2 M key 2280 NVMe SSD (PCIe x4)
    • 2 x Swappable 2.5" SATA drive (9.5 mm height), Intel? RAID 0/1 supported
    Expansion
    • 1 x M.2 Key for 5G/WiFi 6/BT (PCIe/USB)
    • 1 x Full-size Rev.1.2 PCI Express Mini Card slot for LTE/WIFI/BT (PCIe/USB)
    • 2 x nano SIM slot
    • 1 x M.2 Key A+E for WiFi 6/BT (PCIe/USB)
    Others
    • TPM 2.0
    • 1 x Reset button
    • 8 x Antenna opening
    • 1 x Power button
    Power Supply
    • 1 x M12, 24 to 110 VDC
    Power Consumption
    • TBD
    Watchdog Timer
    • 255 levels, 1 to 255 sec.
    Construction
    • Aluminum extrusion and heavy-duty steel, IP30
    Operating Temperature
    • -40°C to +70°C (-40°F to +158°F) with W.T. peripheral
    Relative Humidity
    • 0% to 95%, non-condensing
    Vibration
    • 3 Grms w/ SSD (5 to 500Hz, X/Y/Z direction; random, operating)
    • 1.5 Grms w/ HDD (5 to 500Hz, X/Y/Z direction; random, operating)
    • 2 Grms w/ HDD & Anti-Vibration Kit (5 to 500Hz, X/Y/Z direction; random, operating)
    • MIL-STD-810G, Method 514.6C-VI Category 4 compliant
    Shock
    • EN 50155: EN(IEC) 61373 category 1 class B, half-sine pulse, 5g, 30ms (longitudinal direction), 3g, 30ms (vertical/transverse direction)
    Dimensions
    (W x D x H)
    • 321 x 210.2 x 73.3 mm (12.64" x 8.28" x 2.89") (without wall mount)
    Weight (net/gross)
    • TBD
    Certifications
    • CE (Class A), LVD, FCC (Class A), EN 50155, EN 45545-2
    EOS Support
    • Windows? 10 64-bit, Ubuntu 16.04, Windows? 11 64-bit
    Software Support
    • AXView
    Mounting
    • Wall mount
艾讯科技 (Axiomtek) 于 1990 年成立于台湾,20余年来,作为工控业内的老牌厂商,已成为世界工业计算机领域公认的领先设计者和制造商。自公司初创立起,艾讯科技即以创新的设计、高质量的质量保证和高客户满意度的服务态度而领先业界。 艾讯已在大陆…  更多>>
艾讯科技 (Axiomtek)
联系人:王先生
地址:北京海淀区马连洼北路亿城国际
邮编:100085
电话:13911408386
公司网址:http://www.axiomtek.com
