艾讯科技 (Axiomtek)
  • 嵌入式工控机11代 机器人控制器eBOX630A
  • 发布时间:2016/7/21 16:27:42   修改时间:2023/5/22 15:06:58 浏览次数:3056
  • eBOX630A
    无风扇嵌入式系统,配备第 11 代英特尔?酷睿? i7/i5/i3 或赛扬?处理器、2 个 HDMI、1 个显示端口、3 个局域网、6 个 USB、4 个 COM 和 9 至 48 VDC
    CPU
    • Intel? Core? i7-1185G7E/i5-1145G7E/i3-1115G4E or Celeron? 6305E (TDP up to 15W)
    Chipset
    • SoC integrated
    System Memory
    • 2 x 260-pin DDR4-3200 SO-DIMM, up to 64GB
    BIOS
    • AMI
    COM
    • 2 x RS-232/422/485
    • 2 x RS-232
    USB
    • 2 x USB 2.0
    • 4 x USB 3.2 Gen1
    Ethernet/PoE
    • 2 x 10/100/2500 Mbps Ethernet (Intel? i226-IT)
    • 1 x 10/100/2500 Mbps Ethernet (Intel? i226-LM)
    Display
    • 2 x HDMI 1.4b
    • 1 x DisplayPort++ 1.4a
    Digital I/O
    • 1 x 8-CH TTL DIO via DB9 female (4-in/4-out)
    Audio
    • N/A
    Storage
    • 2 x 2.5” swappable SSD/HDD drive bay (max. up 9.5 mm height; RAID 0,1 supported)
    • 1 x M.2 Key M 2280 (PCIe x 4 only)
    Expansion
    • 1 x Full-size PCI Express Mini Card (USB + PCIe signal)
    • 1 x M.2 Key E 2230 (for WiFi)
    • 1 x Front-access SIM slot
    Others
    • TPM 2.0
    • 1 x ATX power switch
    • 1 x Remote power switch
    • 1 x Reset switch
    • 1 x AT/ATX quick switch
    • 4 x Antenna opening
    Power
    • 9 to 48 VDC
    • 1 x Phoenix-type VDC power input connector
    Watchdog Timer
    • 255 levels, 1 to 255 sec.
    Construction
    • Aluminum extrusion and heavy-duty steel, IP40
    Operating Temperature
    • -40°C to +60°C (-40°F to +140°F) with 0.5 m/s air flow (with W.T. DRAM & SSD,CPU TDP 15W)
    Relative Humidity
    • 10% - 95%, non-condensing
    Vibration
    • IEC 60068-2-64 (with SSD: 3Grms STD, random, 5 to 500 Hz, 1 hr/axis)
    Shock
    • IEC 60068-2-27 (with SSD: 50G, half sine, 11 ms duration)
    Dimensions
    (W x D x H)
    • 250 x 170 x 60 mm (9.84” x 6.69” x 2.36”)
    Weight (net/gross)
    • 2.4 kg (5.29 lb)/3.2 kg (7.0 lb)
    Certifications
    • CE, FCC Class A , UKCA
    EOS Support
    • Win 10 IoT, Win 11 IoT, Linux
    Software Support
    • N/A
    Mounting
    • Wall mount kit
    • DIN-rail kit
艾讯科技 (Axiomtek) 于 1990 年成立于台湾,20余年来,作为工控业内的老牌厂商,已成为世界工业计算机领域公认的领先设计者和制造商。自公司初创立起,艾讯科技即以创新的设计、高质量的质量保证和高客户满意度的服务态度而领先业界。 艾讯已在大陆…  更多>>
艾讯科技 (Axiomtek)
联系人:王先生
地址:北京海淀区马连洼北路亿城国际
邮编:100085
电话:13911408386
公司网址:http://www.axiomtek.com
