艾讯科技 (Axiomtek)
  • 嵌入式无风扇12代13代 3D视觉控制器 eBOX671B
  • 发布时间:2016/7/21 16:38:54   修改时间:2023/5/22 16:51:09 浏览次数:2509
  • eBOX671B
    无风扇嵌入式系统,带 LGA1700 插槽 第 13 代/第 12 代英特尔?酷睿? i9/i7/i5/i3 或赛扬?处理器、英特尔? R680E、2 个 HDMI、1 个显示端口、6 个 USB、4 个局域网、MXM 3.1 A 型和 9 至 36 VDC
    CPU
    • LGA1700 socket 13th/12th Gen Intel? Core? i9/i7/i5/i3 & Celeron? processor (35W/65W)
    Chipset
    • Intel? R680E
    System Memory
    • 2 x 262-pin DDR5-4800 SO-DIMM, up to 64GB
    BIOS
    • AMI
    COM
    • 2 x RS-232/422/485 with autoflow
    • 2 x RS-232
    USB
    • 2 x USB 3.2 Gen1
    • 4 x USB 3.2 Gen2
    Ethernet/PoE
    • 3 x 2.5 GbE (Intel? i226-IT)
    • 1 x GbE LAN (Intel? i219-LM)
    • 4 PoE by request (PoE IEEE802.3at, up to 60W)
    Display
    • 2 x HDMI 1.4b (1 x lockable)
    • 1 x DisplayPort 1.4a
    • 2 x DisplayPort 1.4a via optional MXM kit
    Digital I/O
    • N/A
    Audio
    • 1 x Audio (MIC-in/Line-out); by request
    Storage
    • 2 x 2.5" SATA HDD/SSD (up to 15 mm height; RAID 0,1 supported)
    • 1 x NVMe by M.2 Key M 2280
    • 1 x mSATA (enable in BIOS setting)
    Expansion
    • 1 x Full-size PCI Express Mini Card slot (USB 2.0 + PCIe + SIM + mSATA signal)
    • 1 x M.2 Key M 2280 socket (for storage)
    • 1 x M.2 Key E 2230 socket (for Wi-Fi 6E)
    • 1 x M.2 Key B 3052 socket (for 5G)
    • 1 x Internal SIM slot for PCIe Mini Card slot
    • 1 x MXM3.1 type A connector
    • 1 x Flexible IO window (Default: 2 x DB9 half-cut bracket)
    Others
    • TPM 2.0
    • 1 x Power button
    • 1 x Remote switch
    • 1 x Front access SIM slot with cover (for M.2 Key B)
    • 1 x Reset switch connector
    • 5 x Antenna opening
    • 1 x Grounding screw
    Power
    • 9 to 36 VDC with ACC ignition
    • 1 x Phoenix type VDC power input connector
    Watchdog Timer
    • 255 levels, 1 to 255 sec.
    Construction
    • Aluminum extrusion and heavy-duty steel, IP40
    Operating Temperature
    • Without MXM module:
    • -40°C to +65°C (-40°F to +140°F) (with W.T. DRAM & SSD, CPU TDP 35W)
    • -40°C to +55°C (-40°F to +122°F) (with W.T. DRAM & SSD, CPU TDP 65W)
    • With MXM module:
    • -40°C to +55°C (-40°F to +122°F) (with W.T. DRAM & SSD & MXM kit, CPU TDP 35W)
    Relative Humidity
    • 10% - 90%, non-condensing
    Vibration
    • IEC 60068-2-64 (w/ SSD: 3Grms STD, random, 5 - 500 Hz, 1 hr/axis)
    Shock
    • IEC 60068-2-27 (w/ SSD: 50G, half-sine, 11 ms duration)
    Dimensions
    (W x D x H)
    • 280 mm (11.02") (W) x 210 mm (8.26") (D) x 80.5 mm (3.16") (H)
    Weight (net/gross)
    • 4.9 kg (10.8 lb)/7 kg (15.43 lb)
    Certifications
    • CE, FCC Class A, UKCA
    EOS Support
    • Win 10 IoT, Win 11 IoT, Linux
    Software Support
    • N/A
    Mounting
    • Wall mount kit
    • DIN-rail kit
艾讯科技 (Axiomtek) 于 1990 年成立于台湾,20余年来,作为工控业内的老牌厂商,已成为世界工业计算机领域公认的领先设计者和制造商。自公司初创立起,艾讯科技即以创新的设计、高质量的质量保证和高客户满意度的服务态度而领先业界。 艾讯已在大陆…  更多>>
艾讯科技 (Axiomtek)
联系人:王先生
地址:北京海淀区马连洼北路亿城国际
邮编:100085
电话:13911408386
公司网址:http://www.axiomtek.com
