深圳凯萨电子有限公司
  • Coto Technology继电器 凯萨电子13817082140
  • 发布时间:2010/11/8 13:40:39   修改时间:2016/8/10 17:22:04 浏览次数:2635
  • 全部是原厂原装正品,国际现货,1到2周的货期交货。价格优惠。
    销售:胡霞霞
    深圳凯萨电子有限公司
    电话:021-51873582-8005
    传真:021-51873582-8008
    手机:13817082140
    邮件/MSN:cindy@kisacn.com
    网址:www.kisacn.com
    QQ:843525089
    凯萨电子13817082140
    1315360 RELAY REED HV SPST 5V Coto Technology
    1315574 RELAY REED HIGH VOLT SPST 12V Coto Technology
    2228841 RELAY REED DIP DPST 5V W/ES Coto Technology
    2593923 RELAY REED SIP SPST 12V W/DIODE Coto Technology
    2593933 簧片继电器 1 FORM A 12V MAG SHIELD DIODE Coto Technology
    2594074 RELAY REED SIP SPST 5V W/COAX-D Coto Technology
    2594288 RELAY REED SIP SPST 12V W/COAX Coto Technology
    2595900 RELAY REED SIP SPST 5V W/DIODE Coto Technology
    2595901 簧片继电器 SIP REED 5 VOLTS 9000 SERIES Coto Technology
    2595909 RELAY REED SIP SPST 5V W/SHIELD Coto Technology
    2595910 RELAY SIP SPST 5V W/DIODE W/SHIE Coto Technology
    2596114 RELAY REED SIP SPST 12V W/DIODE Coto Technology
    2596123 RELAY REED SIP SPST 12V W/SHLD Coto Technology
    2596124 RELAY REED SIP 12V W/SHLD-DIODE Coto Technology
    2597370 RELAY REED SPST .25A 5V SIP Coto Technology
    2597371 RELAY REED SPST .25A 5V SIP Coto Technology
    2597584 RELAY REED SPST .25A 12V SIP Coto Technology
    2597585 RELAY REED SPST .25A 12V SIP Coto Technology
    2597736 RELAY REED SPST .5A 5V SIP Coto Technology
    2597737 RELAY REED SPST .5A 5V SIP Coto Technology
    2597951 RELAY REED SPST .5A 12V SIP Coto Technology
    2626795 RELAY REED SIP SPST 12V Coto Technology
    2626956 簧片继电器 2 FORMA SIP 5V MAG Coto Technology
    2626957 RELAY REED SIP DPST 5V W/DIODE Coto Technology
    2627170 RELAY REED SIP DPST 12V W/O DIOD Coto Technology
    2627171 RELAY REED SIP DPST 12V W/DIODE Coto Technology
    2631338 簧片继电器 1FA HV 5V MAG SH Coto Technology
    2631339 RELAY REED SIP HV SPST 5V SHIELD Coto Technology
    2631552 簧片继电器 1FA HV 12V MAG SH Coto Technology
    2631553 簧片继电器 1FA HV 12V MAG/DI Coto Technology
    2636086 簧片继电器 1 FORMA 5V MAG SH Coto Technology
    2636087 簧片继电器 1 FORMA 5V MAG/DIO Coto Technology
    2666991 RELAY REED SPST 12V J LEAD Coto Technology
    2667142 RELAY REED SPST 5V SMT J-LEAD Coto Technology
    2703301 RELAY REED SPST 5V J LEAD Coto Technology
    2703515 RELAY REED SPST 12V J LEAD Coto Technology
    2739825 RELAY REED SPST 5V J-LEAD Coto Technology
    2740049 RELAY REED SPST 12V RADIAL Coto Technology
    2740190 RELAY REED SPST 5V SMT J-LEAD Coto Technology
    2886287 RELAY REED SPST 5V SMT J-LEAD Coto Technology
    2890599 RELAY REED MAG HI-RF 3.3V SMD Coto Technology
    2890609 RELAY REED MAG HI-RF 3.3V J-LEAD Coto Technology
    2890660 RELAY REED MAG HI-RF 5V SMD Coto Technology
    2890670 簧片继电器 Shielded SM Reed Coto Technology
    2904479 RELAY REED MAG HI-RF 3.3V SMD Coto Technology
    2904489 RELAY REED MAG HI-RF 3.3V J-LEAD Coto Technology
    2904540 RELAY REED MAG HI-RF 5V AXIAL Coto Technology
    2904550 RELAY REED MAG HI-RF 5V J-LEAD Coto Technology
    2922446 RELAY REED 4 PIN 5V J-LEAD SMT Coto Technology
    2923176 RELAY REED 8 PIN 5V J-LEAD SMT Coto Technology
    2200-0283 簧片继电器 MICROMIN REED RELAY Coto Technology
    2200-2301 RELAY REED SPST W/ES .5A 5VDC Coto Technology
    2200-2302 RELAY REED SPST W/CS .5A 5VDC Coto Technology
    2204-05-401 RELAY REED SPST .5A 5VDC Coto Technology
    2204-05-411 RELAY REED SPST W/ES .5A 5VDC Coto Technology
    2204-12-301 RELAY REED .5A 12VDC Coto Technology
    2204-12-311 RELAY REED SPST W/ES .5A 12VDC Coto Technology
    2211-05-301 RELAY REED .25A 5VDC SEALED Coto Technology
    2211-12-301 RELAY REED SPDT W/ES .25A 12VDC Coto Technology
    2332-05-000 RELAY REED .5A 5VDC Coto Technology
    2333-05-000 RELAY REED .5A 5VDC Coto Technology
    2333-12-000 RELAY REED .5A 12VDC Coto Technology
    2341-05-000 RELAY REED .5A 5VDC Coto Technology
    2341-12-000 RELAY REED .5A 12VDC Coto Technology
    2342-05-000 RELAY REED .25A 5VDC Coto Technology
    2342-12-000 RELAY REED .25A 12VDC Coto Technology
    2904-12-301 RELAY REED SPST W/ES .5A 12VDC Coto Technology
    2911-05-301 RELAY REED SPDT 5V Coto Technology
    2911-05-311 簧片继电器 Micromin FormC Reed Coto Technology
    2911-05-321 RELAY REED .25A 5VDC Coto Technology
    2911-12-301 RELAY REED SPDT 12V Coto Technology
    2911-12-311 簧片继电器 Micromin FormC Reed Coto Technology
    2911-12-321 RELAY REED .25A 12VDC Coto Technology
    3501-05-511 簧片继电器 Low Thermal EMF Reed Coto Technology
    3502-05-511 簧片继电器 Low Thermal EMF Reed Coto Technology
    3600-0031 簧片继电器 LOW THERMAL EMF Coto Technology
    3602-05-52 簧片继电器 Low Thermal EMF Reed Coto Technology
    5501-24-1 RELAY REED HIGH VOLT SPST 24V Coto Technology
    7101-12-1010 RELAY REED SPST HIGH REL 12V Coto Technology
    7101-12-1011 RELAY REED SPST HIGH REL 12V Coto Technology
    7102-12-1010 RELAY REED DPST HIGH REL 12V Coto Technology
    7102-12-1011 RELAY REED DPST HIGH REL 12V Coto Technology
    7150-12-1000 RELAY REED SPST 12V LATCH Coto Technology
    7201-05-1100 RELAY REED SPST 5V WET Coto Technology
    8001-05-111 RELAY REED DIP SPST .5A 5V Coto Technology
    8041-05-011 簧片继电器 1Form C 5V Diode Coto Technology
    8061-05-001 RELAY REED DIP SPDT 5V SMD Coto Technology
    8061-05-101 REED RELAY 5V SHIELDED SMD Coto Technology
    8061-12-001 RELAY REED DIP SPDT 12V SMD Coto Technology
    8061-12-011 RELAY REED DIP SPDT 12V SMD Coto Technology
    8L01-05-001 RELAY REED DIP SPST 5V Coto Technology
    8L01-05-011 簧片继电器 Spartan DIP Relay Coto Technology
    8L01-05-101 RELAY REED DIP SPST 5V W/ES Coto Technology
    8L01-05-111 RELAY REED DIP 5V W/ES-DIODE Coto Technology
    8L01-12-001 RELAY REED DIP SPST 12V Coto Technology
    8L01-12-011 RELAY REED DIP SPST 12V W/DIODE Coto Technology
    8L01-12-101 簧片继电器 Spartan DIP Relay Coto Technology
    8L01-12-111 RELAY REED DIP 12V W/ES-DIODE Coto Technology
    8L01-24-001 RELAY REED DIP SPST 24V Coto Technology
    8L01-24-011 RELAY REED DIP SPST 24V W/DIODE Coto Technology
    8L01-24-101 RELAY REED DIP SPST 24V W/ES Coto Technology
    8L01-24-111 RELAY REED DIP 24V W/ES-DIODE Coto Technology
    8L02-05-00 RELAY REED DIP DPST 5V Coto Technology
    8L02-05-01 簧片继电器 Spartan DIP Relay Coto Technology
    8L02-05-10 RELAY REED DIP DPST 5V W/ES Coto Technology
    8L02-05-11 簧片继电器 Spartan DIP Relay Coto Technology
    8L02-12-00 RELAY REED DIP DPST 12V Coto Technology
    8L02-12-01 RELAY REED DIP DPST 12V W/DIODE Coto Technology
    8L02-12-10 RELAY REED DIP DPST 12V W/ES Coto Technology
    8L02-12-11 RELAY REED DIP 12V W/ES-DIODE Coto Technology
    8L02-24-00 RELAY REED DIP DPST 24V Coto Technology
    8L02-24-01 RELAY REED DIP DPST 24V W/DIODE Coto Technology
    8L02-24-11 RELAY REED DIP 24V W/ES-DIODE Coto Technology
    8L41-05-001 RELAY REED DIP SPDT 5V Coto Technology
    8L41-05-011 RELAY REED DIP SPDT 5V W/DIODE Coto Technology
    8L41-05-101 RELAY REED DIP SPDT 5V W/ES Coto Technology
    8L41-05-111 RELAY REED DIP 5V W/ES-DIODE Coto Technology
    8L41-12-001 簧片继电器 Spartan DIP Relay Coto Technology
    8L41-12-011 RELAY REED DIP SPDT 12V W/DIODE Coto Technology
    8L41-12-101 RELAY REED DIP 12V W/ES Coto Technology
    8L41-12-111 RELAY REED DIP SPDT12V W/ES DIOD Coto Technology
    8L41-24-001 RELAY REED DIP SPDT 24V Coto Technology
    8L41-24-101 RELAY REED DIP SPDT 24V W/ES Coto Technology
    8L41-24-111 RELAY REED DIP 24V W/ES-DIODE Coto Technology
    9001-05-00 簧片继电器 SIP 簧片继电器 Coto Technology
    9001-12-00 RELAY REED SIP SPST 12V Coto Technology
    9002-05-00 簧片继电器 SIP 簧片继电器 Coto Technology
    9002-12-00 RELAY REED SPST .5A 12VDC SIP Coto Technology
    9007-05-00 RELAY REED SIP SPST .5A 5V Coto Technology
    9007-05-40 RELAY REED SIP SPST 5V MAGN SHLD Coto Technology
    9007-12-00 RELAY REED SIP SPST 12V Coto Technology
    9007-12-40 RELAY REED SIP SPST 12V MAG SHLD Coto Technology
    9007-12-50 RELAY REED SIP SPST 12V Coto Technology
    9007-24-00 RELAY REED SIP SPST 24V Coto Technology
    9007-24-01 RELAY REED SIP SPST 24V Coto Technology
    9007-24-10 RELAY REED SIP SPST 24V EXT SHLD Coto Technology
    9007-24-11 RELAY REED SIP SPST 24V EXT SHLD Coto Technology
    9081-05-00 RELAY REED 242 .5A 5VDC SIP Coto Technology
    9081-12-00 簧片继电器 Spartan SIP Relay Coto Technology
    9081-24-00 RELAY REED 242 .5A 24VDC SIP Coto Technology
    9081C-05-00 簧片继电器 1 FORM C 5V Coto Technology
    9081C-05-10 RELAY REED MINI SIP SPDT-CO 5V Coto Technology
    9081C1-05-00 簧片继电器 1 FORM C 5V Coto Technology
    9081C1-05-10 簧片继电器 1 FORM C 5V MAG SH Coto Technology
    9081C1-12-00 簧片继电器 1 FORM C 12V Coto Technology
    9081C1-12-10 簧片继电器 1 FORM C 12V MAG Coto Technology
    9081C-12-00 RELAY REED MINI SIP SPDT-CO 12V Coto Technology
    9081C-12-10 RELAY REED SIP SPDT-CO 12V SHLD Coto Technology
    9081C1-24-00 簧片继电器 1 FORM C 24V Coto Technology
    9081C1-24-10 簧片继电器 1 FORM C 24V MAG Coto Technology
    9081C-24-00 RELAY REED SIP SPDT-CO 24V Coto Technology
    9081C-24-10 RELAY REED SIP SPDT-CO 24V SHLD Coto Technology
    9091-05-00 RELAY REED SIP SPST .25A 5V Coto Technology
    9201-05-00 簧片继电器 Surf Mnt 簧片继电器 Coto Technology
    9202-05-00 簧片继电器 Surf Mnt 簧片继电器 Coto Technology
    9290-05-00 RELAY REED SPST .5A 5V SMT Coto Technology
    9290-12-00 RELAY REED SPST .5A 12V SMT Coto Technology
    9401-05-00 RELAY REED SPST 5V SMT GULLWING Coto Technology
    9401-12-00 RELAY REED SPST 12V SMT GULL Coto Technology
    9402-05-00 RELAY REED SPST.5A 5VDC GULL SMT Coto Technology
    9802-05-00 RELAY REED SPST 5V SMT GULLWING Coto Technology
    9814-03-00 簧片继电器 Shielded SM Reed Coto Technology
    9814-05-00 RELAY REED MAG HI-RF 5V GULL Coto Technology
    9852-03-00 RELAY REED MAG RF 3.3V GULLWING Coto Technology
    9852-05-00 RELAY REED MAG HI-RF 5V GULLWING Coto Technology
    B10-03B RELAY REED HI-RF BGA 3.3V SPST Coto Technology
    B10-05B RELAY REED HI-RF BGA 5V SPST Coto Technology
    B40-0002B RELAY REED HI-RF BGA 3.3V 4PST Coto Technology
    B40-0003B RELAY REED HI-RF BGA 5V 4PST Coto Technology
    B41-0001 RELAY REED RF 4CH 5VDC BGA SMD Coto Technology
    B41-0002 RELAY REED RF 4CH 3.3V BGA SMD Coto Technology
    MRFL41A05021 簧片继电器 MRFL RELAY 1FA 5V SRC Coto Technology
深圳凯萨电子有限公司
联系人:胡小姐
地址:上海市嘉定区江桥万达广场8号楼915室
邮编:201803
电话:021-51873581--8005
传真:021-51698390
公司网址:http://www.cechina.cn/Company/113890/index.aspx
  • KARENA 在2014/7/10 11:37:00留言
  • 详细留言:INQUIRY
