宁波金晟杰机电有限公司
  • 宁波金晟杰优价供应ALLIED MOTION电机
  • 发布时间:2012/4/15 20:27:22   修改时间:2012/4/15 20:27:22 浏览次数:1006
  • ALLIED MOTION电机
    ALLIED MOTION代理  ALLIED MOTION美国  ALLIED MOTION价格  ALLIED MOTION经销
    宁波金晟杰机电有限公司供应美国LIED MOTION电机、ALLIED MOTION马达、ALLIED MOTION驱动器、ALLIED MOTION步进电机、ALLIED MOTION齿轮箱、ALLIED MOTION伺服驱动器、ALLIED MOTION伺服电机
    美国ALLIED MOTION是世界著名的运动控制专业厂商。
    主要产品有:COPI编码器、伺服驱动器、伺服电机、Megaflux大扭矩无刷电机、无刷直流电机、永磁直流电机等。ALLIED MOTION电机、直流无刷电机、无芯直流电机、铁芯直流电机、同步马达、扭力电机、伺服马达、驱动器、步进电机、齿轮箱、编码器.
    Motor Maintenance Kit, 230V, for ZU4
     ZU4-series, portable electric Z-Class pumps   ZU4-series, portable electric Z-Class pumps ... reservoirs: 4, 8, 10, 20, 40 litres usable oil ZU4 applications: for intermittent duty cycle and high speed applications ... transport is required and/or on remote locations ZU4 standard electric: manual valve ZU4 electric with LCD: manual ...
        * High-efficiency two speed pump: higher oil flow and bypass pressure: 11,5 l/min at 7 bar; 8,8 l/min at 50 bar; 1,0 l/min at 700 bar
        * 1,25 kW universal motor: high power-to-weight ratio, excellent low-voltage operating characteristics
        * Moulded composite shroud: ergonomic, non-conductive handle for easy transport
        * Steel reservoirs: 4, 8, 10, 20, 40 litres usable oil
        * ZU4 applications: for intermittent duty cycle and high speed applications with medium to large size cylinders and tools, and when frequent pump transport is required and/or on remote locations
        * ZU4 standard electric: manual valve
        * ZU4 electric with LCD: manual or solenoid valves. Back-lit LCD provides self test, diagnostic and read-out capabilities
    * For special requirements many pump options available
    该产品种类齐全 品质优良 如您有意购买 欢迎来电咨询!
宁波金晟杰机电有限公司是浙江省机电行业协会的一家高科技企业,集工程、销售、技术服务于一体的现代化企业,是国内自动化领域具有竞争力的设备供应商。公司主要经营欧美和日韩等发达国家的机电一体化设备、自动化控制设备、通信器材,仪器仪表,…  更多>>
宁波金晟杰机电有限公司
联系人:黄先生
地址:宁波市城市广场41号B座405室
邮编:315175
电话:0574-89081448
公司网址:http://www.ningbojsj.com
  • 在2013/11/11 13:11:00留言
  • 详细留言:我司欲购德国MARX变压器,型号:TS6,3
  • 采购小范 在2013/6/20 10:15:00留言
  • 详细留言:询价: HK 44 DT/2 M-HH 1.6/1.6-H1.6 -C30-A1/450 -VB 11 FM-AR4/11-1-A24 -A 1/450 -VB 11 FM-AR4/11-1-A24 -3X400/230V 50Hz Q:3 HC 12 K/0.94 -VB11 FM-R4R4/4-1-A24 3X400V 50Hz Q:4 VB 11 AM-1/450-AR4/11-1-A24 Q:2
  • 陈雷 在2013/5/16 10:11:00留言
  • 详细留言:SIEMAG 制动器 4C/LEFT 0697569/2 4C/RIGHT 0697570/2各一个
