IFM 易福门 位置传感器和识别物体 ? 光电传感器 ? 激光传感器型号 外壳 检测距离 设计 连接 许可证 订购编号
对射式传感器
镜面反射传感器
漫反射传感器
光电距离传感器型号 M18矩形的材料 金属 V4A塑料
检测距离 至 150 m至 1 m至 8 m至60 m型号 发射器 接收器透镜 前面的镜组侧面的镜导线 3- 4-线连接 插头- M8- M1输出 DC PNPDC NPNDC电路 明暗明或暗l特殊规格 低频率滤波器 O5E 56 x 18,2 x 46,8 mm 60 m M12 DC PNP cULus (CCC) O5E700
销售:张龙刚
手机:13817798194 工作QQ: 304158330 QQ: 1491218376 MSN:zlgsh@hotmail.com
O5S 56 x 18,2 x 46,8 mm 60 m M12 DC cULus (CCC) O5S700
OGEL M18 / L = 72 mm 60 m M12 DC PNP cULus (CCC) OGE700
OGEL M18 / L = 72 mm 2 m M12 DC PNP (CCC) OGE701
OGSL M18 / L = 72 mm 60 m M12 DC cULus (CCC) OGS700
OGSL M18 / L = 72 mm 2 m M12 DC cULus (CCC) OGS701
OJSL 35 x 24 x 11 mm 15 m M8 DC cULus (CCC) OJ5016
OJEL 35 x 24 x 11 mm 15 m M8 DC PNP cULus (CCC) OJ5017
OJSL 35 x 24 x 11 mm 1 m M8 DC cULus (CCC) OJ5019
OJEL 35 x 24 x 11 mm 1 m M8 DC PNP cULus (CCC) OJ5020
OJSL 35 x 11 x 24 mm 15 m M8 DC cULus (CCC) OJ5038
OJEL 35 x 11 x 24 mm 15 m M8 DC PNP cULus (CCC) OJ5039
OJEL 35 x 11 x 24 mm 15 m M8 DC NPN cULus (CCC) OJ5040
OJSL 35 x 11 x 24 mm 1 m M8 DC cULus (CCC) OJ5041
OJEL 35 x 11 x 24 mm 1 m M8 DC PNP cULus (CCC) OJ5042
OJSL 35 x 24 x 11 mm 15 m M8 DC cULus (CCC) OJ5116
OJEL 35 x 24 x 11 mm 15 m M8 DC PNP (CCC) OJ5117
OJSL 35 x 11 x 24 mm 15 m M8 DC cULus (CCC) OJ5138
OJEL 35 x 11 x 24 mm 15 m M8 DC PNP cULus (CCC) OJ5139
OJSL 35 x 11 x 24 mm 1 m M8 DC cULus (CCC) OJ5141
OJEL 35 x 11 x 24 mm 1 m M8 DC PNP cULus (CCC) OJ5142
O5H 56 x 18,2 x 46,8 mm 200 mm M12 DC PNP cULus (CCC) O5H700
OGHL M18 / L = 72 mm 200 mm M12 DC PNP cULus (CCC) OGH700
OJHL 35 x 24 x 11 mm 200 mm M8 DC PNP cULus (CCC) OJ5052
OJHL 35 x 24 x 11 mm 200 mm M8 DC NPN cULus (CCC) OJ5053
OJHL 35 x 11 x 24 mm 200 mm M8 DC PNP cULus (CCC) OJ5054
OJHL 35 x 11 x 24 mm 200 mm M8 DC NPN cULus (CCC) OJ5055
OJHL 35 x 24 x 11 mm 150 mm M8 DC PNP cULus (CCC) OJ5056
OJHL 35 x 24 x 11 mm 150 mm M8 DC NPN cULus (CCC) OJ5057
OJHL 35 x 11 x 24 mm 150 mm M8 DC PNP cULus (CCC) OJ5058
OJHL 35 x 24 x 11 mm 200 mm M8 DC PNP cULus (CCC) OJ5152
OJHL 35 x 11 x 24 mm 200 mm M8 DC PNP cULus (CCC) OJ5154
OJHL 35 x 11 x 24 mm 150 mm M8 DC PNP cULus (CCC) OJ5158
O5P 56 x 18,2 x 46,8 mm 15 m M12 DC PNP cULus (CCC) O5P700
OGPL M18 / L = 72 mm 15 m M12 DC PNP cULus (CCC) OGP700
OGPL M18 / L = 72 mm 2 m M12 DC PNP cULus (CCC) OGP701
OJPL 35 x 24 x 11 mm 8 m M8 DC PNP cULus (CCC) OJ5014
OJPL 35 x 11 x 24 mm 8 m M8 DC PNP cULus (CCC) OJ5036
OJPL 35 x 11 x 24 mm 8 m M8 DC NPN cULus (CCC) OJ5037
OJPL 35 x 24 x 11 mm 8 m M8 DC PNP cULus (CCC) OJ5114
OJPL 35 x 11 x 24 mm 8 m M8 DC PNP cULus (CCC) OJ5136型号 外壳 检测距离 设计 连接 许可证 订购编号
O1DL 59 x 42 x 52 mm 10 m M12 DC PNP cULus (CCC) O1D100
O1DL 59 x 42 x 52 mm 10 m M12 DC PNP cULus (CCC) O1D101
O1DL 59 x 42 x 52 mm 3.5 m M12 DC PNP cULus (CCC) O1D102
O1DL 59 x 42 x 52 mm 10 m M12 DC NPN cULus (CCC) O1D103
O1DL 59 x 42 x 52 mm 10 m M12 DC NPN cULus (CCC) O1D104
O1DL 59 x 42 x 52 mm 10 m M12 DC PNP cULus (CCC) O1D105
O1DL 59 x 42 x 52 mm 75 m M12 DC PNP cULus (CCC) O1D106
O1DL 59 x 42 x 52 mm 6 m M12 DC PNP cULus (CCC) O1D155
O1DL 59 x 42 x 52 mm 10 m M12 DC PNP (CCC) O1D405销售:张龙刚
