KI M30 / L = 81 mm 15 mm 6 m PVC NAMUR cCSAus FM TIIS ATEX 1G KI5031
KI M30 / L = 81 mm 15 mm 50 m PVC NAMUR cCSAus FM ATEX 1G KI5037
销售:张龙刚
手机:13817798194 工作QQ: 304158330 QQ: 1491218376 MSN:zlgsh@hotmail.com
KI M30 / L = 92 mm 15 mm DIN EN 175301-803 DC PNP (CCC) KI5038
KIE M30 / L = 143 mm 15 mm M12 DC PNP CCC cULus KI5052
KIE M30 / L = 151 mm 15 mm DC PNP ATEX 3D ATEX 3D KI5065
KI M30 / L = 81 mm 15 mm 6 m PVC DC NPN cULus (CCC) KI5081
KI M30 / L = 90 mm 20 mm M12 DC PNP/NPN cULus KI5082
KI M30 / L = 90 mm 20 mm M12 DC PNP cULus KI5083
KI M30 / L = 90 mm 8 mm M12 DC PNP/NPN cULus KI5084
KI M30 / L = 90 mm 8 mm M12 DC PNP cULus KI5085
KI M30 / L = 90 mm 15 mm M12 DC PNP/NPN cULus KI5086
KI M30 / L = 90 mm 15 mm M12 DC PNP cULus KI5087
KI M30 / L = 92 mm 15 mm DIN EN 175301-803 DC PNP (CCC) KI5206
KI M30 / L = 81 mm 15 mm 2 m PVC DC PNP CSA cULus (CCC) KI5207
KNM M30 / L = 116 mm M12 DC PNP (CCC) KN5121 型号 外壳 感应距离 引线 连接 许可证 订购编号
KGE M18 / L = 110 mm 8 mm AC/DC CCC KG0008
KG M18 / L = 84 mm 8 mm 2 m PVC AC/DC CCC KG0009
KG M18 / L = 84 mm 8 mm 2 m PVC AC/DC CCC KG0010
KG M18 / L = 87 mm 12 mm 1/2" AC/DC CCC KG0016
KGE M18 / L = 110 mm 8 mm DC PNP/NPN CCC KG5040
KGE M18 / L = 110 mm 8 mm DC PNP KG5041
KGE M18 / L = 110 mm 8 mm DC PNP KG5042
KG M18 / L = 84 mm 8 mm 2 m PVC DC PNP (CCC) KG5043
KG M18 / L = 84 mm 8 mm 2 m PVC DC PNP cULus (CCC) KG5044
KG M18 / L = 84 mm 8 mm 2 m PVC DC NPN (CCC) KG5045
KG M18 / L = 84 mm 8 mm 2 m PVC DC NPN cULus (CCC) KG5046
KG M18 / L = 84 mm 8 mm 2 m PUR / PVC DC PNP/NPN CCC KG5047
KG M18 / L = 93,8 mm 8 mm M12 DC PNP (CCC) KG5057
KG M18 / L = 87 mm 12 mm M12 DC PNP/NPN cULus KG5065
KG M18 / L = 87 mm 12 mm M12 DC PNP cULus KG5066
KG M18 / L = 77 mm 8 mm 2 m PVC DC PNP/NPN cULus KG5067
KG M18 / L = 77 mm 8 mm 2 m PVC DC PNP cULus KG5069
KG M18 / L = 77 mm 8 mm 10 m PVC DC PNP cULus KG5070
KG M18 / L = 87 mm 8 mm M12 DC PNP cULus KG5071连接 许可证 订购编号
KFA M12 / L = 60 mm 4 mm M12 DC PNP cULus KF5001
KFA M12 / L = 61 mm 8 mm M12 DC PNP cULus KF5002
KFA M12 / L = 60 mm 4 mm M12 DC NPN cULus KF5013
KX5002
KX M34 / L = 92 mm 15 mm 20 m PVC NAMUR cCSAus FM ATEX 1G ATEX 1D ATEX 1G ATEX 1D KX5004 型号 外壳 感应距离 引线 连接 许可证 订购编号
KI M30 / L = 81 mm 15 mm 2 m PVC AC/DC CCC cULus KI0016
KI M30 / L = 81 mm 15 mm 6 m PVC AC/DC cULus CCC KI0017
KI M30 / L = 81 mm 15 mm 2 m PVC AC/DC CCC cULus KI0020
KI M30 / L = 81 mm 15 mm 6 m PVC AC/DC cULus CCC KI0021
KIE M30 / L = 125 mm 15 mm AC/DC CCC cULus KI0024
KI M30 / L = 92 mm 15 mm DIN EN 175301-803 AC/DC CCC KI0040
KIE M30 / L = 151 mm 15 mm AC/DC ATEX 3D ATEX 3D KI0042
KI M30 / L = 90 mm 20 mm 1/2" AC/DC CCC KI0054
KI M30 / L = 81 mm 15 mm 2 m PVC DC PNP cULus (CCC) KI5001
KI M30 / L = 81 mm 15 mm 2 m PVC DC PNP cULus (CCC) KI5002
KI M30 / L = 81 mm 15 mm 6 m PVC DC PNP cULus (CCC) KI5003
KI M30 / L = 81 mm 15 mm 6 m PVC DC PNP cULus (CCC) KI5006
KI M30 / L = 81 mm 15 mm 2 m PVC DC NPN cULus (CCC) KI5015
KI M30 / L = 81 mm 15 mm 2 m PVC DC NPN cULus (CCC) KI5019
KIE M30 / L = 141 mm 15 mm M12 DC PNP ATEX 3D ATEX 3D KI501A
KIE M30 / L = 125 mm 15 mm DC PNP CCC cULus KI5023
KIE M30 / L = 125 mm 15 mm DC NPN cULus (CCC) KI5024
KI M30 / L = 81 mm 15 mm 2 m PVC NAMUR cCSAus FM IECEx TIIS ATEX 1G ATEX 1D ATEX 1G ATEX 1D KI5030
KD 120 x 80 x 30 mm 60 mm 2 m PVC AC/DC CCC KD0012
KD 120 x 80 x 30 mm 60 mm 2 m PVC AC/DC CCC KD0013
KD 120 x 80 x 30 mm 60 mm 2 m PVC DC PNP (CCC) KD5022
KD 120 x 80 x 30 mm 60 mm 2 m PVC DC PNP (CCC) KD5023
KD 120 x 80 x 30 mm 60 mm 2 m PVC DC NPN (CCC) KD5024 型号 外壳 感应距离 引线 连接 许可证 订购编号
KDE 105 x 80 x 40 mm 60 mm AC/DC CCC KD0009
KDE 105 x 80 x 40 mm 60 mm AC/DC ATEX 3D ATEX 3D KD000A
KDE 105 x 80 x 40 mm 60 mm DC PNP ATEX 3D ATEX 3D KD500A
KDE 105 x 80 x 40 mm 60 mm DC PNP (CCC) KD5018
KDE 105 x 80 x 40 mm 60 mm DC NPN (CCC) KD5019
KDE 105 x 80 x 40 mm 60 mm M12 DC PNP (CCC) KD5039
KDE 105 x 80 x 40 mm 60 mm M12 DC PNP (CCC) KD5044 型号 外壳 感应距离 引线 连接 许可证 订购编号
KQ6 48 x 20 x 14 mm 12 mm 2 m PVC 带自动负载识别的1x open整流子(DC PNP或DC NPN) cULus KQ6001
KQ6 48 x 20 x 14 mm 12 mm 2 m PVC 1x open collector DC PNP cULus KQ6002
KQ6 48 x 20 x 14 mm 12 mm M8 / 0,04 m PVC 带自动负载识别的1x open整流子(DC PNP或DC NPN) cULus KQ6003
KQ6 48 x 20 x 14 mm 12 mm M8 / 0,04 m PVC 1x open collector DC PNP cULus KQ6004
KQ6 48 x 20 x 14 mm 12 mm M12 / 0,1 m PVC 1x open collector DC PNP cULus KQ6005 型号 外壳 感应距离 引线 连接 许可证 订购编号
KB ?34 / L = 81 mm 20 mm 2 m PVC AC/DC CCC cULus KB0025
KB ?34 / L = 81 mm 20 mm 6 m PVC AC/DC cULus CCC KB0026
KB ?34 / L = 81 mm 20 mm 2 m PVC AC/DC CCC cULus KB0029
KB ?34 / L = 81 mm 20 mm 2 m PVC DC NPN cULus (CCC) KB5001
KB ?34 / L = 81 mm 20 mm 2 m PVC DC PNP cULus (CCC) KB5002
KB ?34 / L = 81 mm 20 mm 2 m PVC DC NPN cULus (CCC) KB5003
KB ?34 / L = 81 mm 20 mm 2 m PVC DC PNP cULus (CCC) KB5004
KB ?34 / L = 81 mm 20 mm 6 m PVC DC PNP cULus (CCC) KB5008
KB ?34 / L = 81 mm 20 mm 6 m PVC DC PNP cULus (CCC) KB5014
KB ?34 / L = 93 mm 20 mm M12 DC PNP (CCC) KB5062
KB ?34 / L = 93 mm 20 mm M12 DC PNP (CCC) KB5096
KB ?34 / L = 81 mm 20 mm 6 m PVC DC NPN cULus (CCC) KB5205 型号 外壳 感应距离 引线 连接 许可证 订购编号
KX M34 / L = 92 mm 15 mm 2 m PVC NAMUR cCSAus FM ATEX 1G ATEX 1D ATEX 1G ATEX 1D KX5001
KX M34 / L = 92 mm 15 mm 6 m PVC NAMUR cCSAus FM ATEX 1G ATEX 1D ATEX 1G ATEX 1D
位置传感器和识别物体 ? 接近传感器 ? 电容式传感器
