易福门IFM 易福门IFM 易福门IFM 易福门IFM 易福门IFM 易福门IFM 易福门IFM 易福门IFM 易福门IFM 易福门IFM
? 压力传感器和压力传感器装置
vms200G 1/8 I V2A -1000...1000 mbar /
-14,5...14,5 PSI /
-100...100 kPa M12 DC PNP/NPN cULus PN7809
G 1/8 I V2A -1...10 bar /
-14,5...145 PSI /
-0,1...1,0 MPa M12 DC PNP/NPN cULus PN7834
G 1/8 I V2A -1...1 bar M8 DC PNP PQ7809
G 1/8 I V2A -1...10 bar M8 DC PNP 输出功能 许可证 订购编号
G 1 A / Aseptoflex vario V4A -5,0...100,0 mbar /
-2,0...40,15 inH2O M12 DC PNP/NPN 3A EHEDG FDA PG2789
G 1 A / Aseptoflex vario V4A -1,00...25,00 bar /
-14,4...362,7 PSI M12 DC PNP/NPN 3A cULus EHEDG FDA PG2793
G 1 A / Aseptoflex vario V4A -1,00...10,00 bar /
-14,5...145,0 PSI M12 DC PNP/NPN 3A cULus EHEDG FDA PG2794
G 1 A / Aseptoflex vario V4A -1,000...4,000 bar /
-14,50...58,00 PSI M12 DC PNP/NPN 3A cULus EHEDG FDA PG2795
G 1 A / Aseptoflex vario V4A -0,124...2,5 bar /
-1,8...36,27 PSI M12 DC PNP/NPN 3A cULus EHEDG FDA PG2796
G 1 A / Aseptoflex vario V4A -0,05...1 bar /
-0,73...14,5 PSI M12 DC PNP/NPN 3A cULus EHEDG FDA PG2797
G 1 A / Aseptoflex vario V4A -12,4...250,0 mbar /
-5,0...100,4 inH2O M12 DC PNP/NPN 3A cULus EHEDG FDA PG2798
G 1 A / Aseptoflex vario V4A -1...1 bar /
-14,5...14,5 PSI M12 DC PNP/NPN 3A cULus EHEDG FDA PG2799
-14,4...362,7 PSI /
-0,100...2,500 MPa M12 DC PNP/NPN 3A cULus EHEDG FDA PI2793
-14,5...145,0 PSI /
-0,100...1,000 MPa M12 DC PNP/NPN 3A cULus EHEDG FDA PI2794
-14,50...58,00 PSI /
-100,0...400,0 kPa M12 DC PNP/NPN 3A cULus EHEDG FDA PI2795
G 1 A / Aseptoflex vario V4A -1000...1000 mbar /
-14,5...14,5 PSI M12 DC PNP/NPN 3A cULus EHEDG FDA PI2799 型号 材料 测量范围 设计 输出功能 许可证 订购编号
Aseptoflex 过程连接 V4A -1,00...25,00 bar /
-14,4...362,7 PSI /
-0,100...2,500 MPa M12 DC PNP 3A cULus EHEDG FDA PIM093
Aseptoflex 过程连接 V4A -1,00...10,00 bar /
-14,5...145,0 PSI /
-0,100...1,000 MPa M12 DC PNP 3A cULus EHEDG FDA PIM094
-14,5...145 PSI M12 DC Profibus PA 3A EHEDG FDA ATEX 1G ATEX 2G ATEX 1D ATEX 2D PMP04A
Aseptoflex 过程连接 V4A -1,00...4,00 bar /
-14,5...58,0 PSI M12 DC Profibus PA 3A EHEDG FDA ATEX 1G ATEX 2G ATEX 1D ATEX 2D PMP05A
-14,5...145 PSI M12 DC Profibus PA 3A cULus EHEDG FDA PMP094
-14,5...58,0 PSI M12 DC Profibus PA 3A cULus EHEDG FDA PMP095
Aseptoflex 过程连接 V4A -0,124...2,5 bar /
-1,8...36,24 PSI M12 DC Profibus PA 3A cULus EHEDG FDA PMP096
Aseptoflex 过程连接 V4A -50...1000 mbar /
-0,73...14,5 PSI M12 DC Profibus PA 3A cULus EHEDG FDA PMP097
Aseptoflex 过程连接 V4A -1,0...25 bar /
-15...363 PSI /
-0,1...2,5 MPa M12 DC PNP/NPN
3A cULus EHEDG FDA PF2053
-14,4...362,7 PSI /
-0,100...2,500 MPa M12 DC 3A cULus EHEDG FDA PI1093
-14,5...145,0 PSI /
-0,100...1,000 MPa M12 DC 3A cULus EHEDG FDA PI1094
Aseptoflex 过程连接 V4A -1,000...4,000 bar /
-100,0...400,0 kPa M12 DC 3A cULus EHEDG FDA PI1095
Aseptoflex 过程连接 V4A -50...1000 mbar M12 DC 3A cULus EHEDG FDA PI1097
Aseptoflex 过程连接 V4A -12,4...250,0 mbar M12 DC 3A cULus EHEDG FDA PI1098
Aseptoflex 过程连接 V4A -1000...1000 mbar M12 DC 3A cULus EHEDG FDA PI1099
-14,4...362,7 PSI /
3A cULus EHEDG FDA PI2093
-14,5...145,0 PSI /
3A cULus EHEDG FDA PI2094
3A cULus EHEDG FDA PI2095
Aseptoflex 过程连接 V4A -1000...1000 mbar M12 DC PNP/NPN
3A cULus EHEDG FDA PI2099
-14,4...362,7 PSI /
-0,100...2,500 MPa M12 DC PNP/NPN 3A cULus EHEDG FDA PI7093
-14,5...145,0 PSI /
-0,100...1,000 MPa M12 DC PNP/NPN 3A cULus EHEDG FDA PI7094
-15...363 PSI /
-0,1...2,5 MPa M12 3线DC ; 2线DC 3A cULus EHEDG FDA PL2053
Aseptoflex 过程连接 V4A -1...25 bar /
-15...363 PSI /
-0,1...2,5 MPa M12 DC 3A cULus EHEDG FDA PM2053
Aseptoflex 过程连接 V4A -0,99...4,00 bar /
-14,4...58,0 PSI /
-99...400 kPa M12 DC 3A cULus EHEDG FDA PM2055设计 输出功能 许可证 订购编号
G ? A / M5 I V2A -1...1 bar M12 DC cULus PA3509
?" NPT A/M5I V4A -14,5...0 PSI M12 DC cULus PX3229
G ? A / M5 I V4A -1...10 bar M12 DC cULus PX3524 型号 材料 测量范围 设计 输出功能 许可证 订购编号
?" NPT V2A -1...0 bar M12 DC cULus PA6229
?" NPT V2A -14,5...14,5 PSI M12 DC PNP/NPN
cULus PN2209
?" NPT V2A -1...1 bar /
-30...30 inHg /
-100...100 kPa 1/2" AC / 三端双向可控硅开关元件triac cULus PN4229
?" NPT V2A -14,5...14,5 PSI /
-1000...1000 mbar M12 DC PNP/NPN cULus PN7209
?" NPT A/M5I V4A -14,5...0 PSI M12 DC cULus PX3229 型号 材料 测量范围 设计 输出功能 许可证 订购编号
G 1 A V4A -1,00...25,00 bar /
-14,4...362,7 PSI /
-0,100...2,500 MPa M12 DC PNP 3A cULus EHEDG FDA PIM693
G 1 A V4A -1,00...10,00 bar /
-14,5...145,0 PSI /
-0,100...1,000 MPa M12 DC PNP 3A cULus EHEDG FDA PIM694
G 1 A V4A -0,99...1,00 bar /
-30...30 inHg /
-99...100 kPa M12 DC PNP/NPN
3A cULus EHEDG FDA PF2609
G 1 A V4A -1,0...100 bar /
-10...1450 PSI /
-0,10...10,0 MPa M12 DC PNP/NPN
3A cULus EHEDG FDA PF2652
G 1 A V4A -1,0...25 bar /
-15...363 PSI /
3A cULus EHEDG FDA PF2653
-14,4...362,7 PSI /
FDA ATEX 3G ATEX 3D PI003A
G 1 A V4A -5,0...100,0 mbar M12 DC 3A EHEDG FDA PI1689
-14,4...362,7 PSI /
-0,100...2,500 MPa M12 DC 3A cULus EHEDG FDA PI1693
-14,5...145,0 PSI /
-0,100...1,000 MPa M12 DC 3A cULus EHEDG FDA PI1694
G 1 A V4A -1,000...4,000 bar /
-100,0...400,0 kPa M12 DC 3A cULus EHEDG FDA PI1695
G 1 A V4A -0,124...2,500 bar M12 DC 3A cULus EHEDG FDA PI1696
G 1 A V4A -50...1000 mbar M12 DC 3A cULus EHEDG FDA PI1697
G 1 A V4A -12,4...250,0 mbar M12 DC 3A cULus EHEDG FDA PI1698
G 1 A V4A -1000...1000 mbar M12 DC 3A cULus EHEDG FDA PI1699
G 1 A V4A -1,0...100,0 bar /
-15...1450 PSI /
-0,10...10,00 MPa M12 DC PNP/NPN
3A cULus EHEDG FDA PI2692
-14,4...362,7 PSI /
3A cULus EHEDG FDA PI2693
-14,5...145,0 PSI /
3A cULus EHEDG FDA PI2694
3A cULus EHEDG FDA PI2695
G 1 A V4A -1000...1000 mbar M12 DC PNP/NPN
3A cULus EHEDG FDA PI2699
-14,4...362,7 PSI /
-14,5...145,0 PSI /
G 1 A V4A -1...100 bar /
-10...1450 PSI /
-0,1...10 MPa M12 3线DC ; 2线DC 3A cULus EHEDG FDA PL2652
-15...363 PSI /
-0,1...2,5 MPa M12 3线DC ; 2线DC 3A cULus EHEDG FDA PL2653
G 1 A V4A -1...25 bar /
-15...363 PSI /
-0,1...2,5 MPa M12 3线DC ; 2线DC 3A cULus EHEDG FDA PM2653
G 1 A V4A -1,0...150,0 bar M12 DC PNP/NPN
EHEDG FDA PY2692 型号 材料 测量范围 设计 输出功能 许可证 订购编号
G ? A V4A -1,0...25 bar /
-15...363 PSI /
cULus FDA PF2953
G ? A V4A -1,00...25,00 bar /
-14,4...362,7 PSI /
cULus FDA PI2993
G ? A V4A -1,00...10,00 bar /
-14,5...145,0 PSI /
cULus FDA PI2994
G ? A V4A -1,000...4,000 bar /
cULus FDA PI2995
G ? A V4A -50...1000 mbar M12 DC PNP/NPN
cULus FDA PI2997
-14,4...362,7 PSI /
-0,100...2,500 MPa M12 DC PNP/NPN cULus FDA PI7993 型号 材料 测量范围 设计 输出功能 许可证 订购编号
G ? I V2A -1...0 bar M12 DC cULus PA3029
G ? I V2A -1...0 bar M12 DC cULus PA9029
G ? I V4A -1000...0 mbar M12 DC PNP
cULus PE3029
G ? I V2A -1000...1000 mbar M12 DC PNP/NPN cULus PE7009
G ? I V2A -1000...0 mbar M12 DC PNP
ATEX 3D PN009A
G ? I V2A -1000...1000 mbar /
cULus PN2009
cULus PN3029
G ? I V2A -1000...1000 mbar M12 DC PNP/NPN cULus PN7009 型号 材料 测量范围 设计 输出功能 许可证 订购编号
-14,5...14,5 PSI /
-14,5...145 PSI /
G 1/8 I V2A -1...10 bar M8 DC PNP PQ7834 销售:张龙刚
手机:13817798194
