许可证 订购编号
O1DL 59 x 42 x 52 mm 10 m M12 DC PNP cULus (CCC) O1D100
O1DL 59 x 42 x 52 mm 10 m M12 DC PNP cULus (CCC) O1D101
O1DL 59 x 42 x 52 mm 3.5 m M12 DC PNP cULus (CCC) O1D102
O1DL 59 x 42 x 52 mm 10 m M12 DC NPN cULus (CCC) O1D103
O1DL 59 x 42 x 52 mm 10 m M12 DC NPN cULus (CCC) O1D104
O1DL 59 x 42 x 52 mm 10 m M12 DC PNP cULus (CCC) O1D105
O1DL 59 x 42 x 52 mm 75 m M12 DC PNP cULus (CCC) O1D106
O1DL 59 x 42 x 52 mm 6 m M12 DC PNP cULus (CCC) O1D155
O1DL 59 x 42 x 52 mm 10 m M12 DC PNP (CCC) O1D405
证 订购编号
O5E 56 x 18,2 x 46,8 mm 60 m M12 DC PNP cULus (CCC) O5E700
O5S 56 x 18,2 x 46,8 mm 60 m M12 DC cULus (CCC) O5S700
OGEL M18 / L = 72 mm 60 m M12 DC PNP cULus (CCC) OGE700
OGEL M18 / L = 72 mm 2 m M12 DC PNP (CCC) OGE701
OGSL M18 / L = 72 mm 60 m M12 DC cULus (CCC) OGS700
OGSL M18 / L = 72 mm 2 m M12 DC cULus (CCC) OGS701
OJSL 35 x 24 x 11 mm 15 m M8 DC cULus (CCC) OJ5016
OJEL 35 x 24 x 11 mm 15 m M8 DC PNP cULus (CCC) OJ5017
OJSL 35 x 24 x 11 mm 1 m M8 DC cULus (CCC) OJ5019
OJEL 35 x 24 x 11 mm 1 m M8 DC PNP cULus (CCC) OJ5020
OJSL 35 x 11 x 24 mm 15 m M8 DC cULus (CCC) OJ5038
OJEL 35 x 11 x 24 mm 15 m M8 DC PNP cULus (CCC) OJ5039
OJEL 35 x 11 x 24 mm 15 m M8 DC NPN cULus (CCC) OJ5040
OJSL 35 x 11 x 24 mm 1 m M8 DC cULus (CCC) OJ5041
OJEL 35 x 11 x 24 mm 1 m M8 DC PNP cULus (CCC) OJ5042
OJSL 35 x 24 x 11 mm 15 m M8 DC cULus (CCC) OJ5116
OJEL 35 x 24 x 11 mm 15 m M8 DC PNP (CCC) OJ5117
OJSL 35 x 11 x 24 mm 15 m M8 DC cULus (CCC) OJ5138
OJEL 35 x 11 x 24 mm 15 m M8 DC PNP cULus (CCC) OJ5139
OJSL 35 x 11 x 24 mm 1 m M8 DC cULus (CCC) OJ5141
OJEL 35 x 11 x 24 mm 1 m M8 DC PNP cULus (CCC) OJ5142
订购编号
O5H 56 x 18,2 x 46,8 mm 200 mm M12 DC PNP cULus (CCC) O5H700
OGHL M18 / L = 72 mm 200 mm M12 DC PNP cULus (CCC) OGH700
OJHL 35 x 24 x 11 mm 200 mm M8 DC PNP cULus (CCC) OJ5052
OJHL 35 x 24 x 11 mm 200 mm M8 DC NPN cULus (CCC) OJ5053
OJHL 35 x 11 x 24 mm 200 mm M8 DC PNP cULus (CCC) OJ5054
OJHL 35 x 11 x 24 mm 200 mm M8 DC NPN cULus (CCC) OJ5055
OJHL 35 x 24 x 11 mm 150 mm M8 DC PNP cULus (CCC) OJ5056
OJHL 35 x 24 x 11 mm 150 mm M8 DC NPN cULus (CCC) OJ5057
OJHL 35 x 11 x 24 mm 150 mm M8 DC PNP cULus (CCC) OJ5058
OJHL 35 x 24 x 11 mm 200 mm M8 DC PNP cULus (CCC) OJ5152
OJHL 35 x 11 x 24 mm 200 mm M8 DC PNP cULus (CCC) OJ5154
OJHL 35 x 11 x 24 mm 150 mm M8 DC PNP cULus (CCC) OJ5158
设计 连接 许可证 订购编号
O5P 56 x 18,2 x 46,8 mm 15 m M12 DC PNP cULus (CCC) O5P700
OGPL M18 / L = 72 mm 15 m M12 DC PNP cULus (CCC) OGP700
OGPL M18 / L = 72 mm 2 m M12 DC PNP cULus (CCC) OGP701
OJPL 35 x 24 x 11 mm 8 m M8 DC PNP cULus (CCC) OJ5014
OJPL 35 x 11 x 24 mm 8 m M8 DC PNP cULus (CCC) OJ5036
OJPL 35 x 11 x 24 mm 8 m M8 DC NPN cULus (CCC) OJ5037
OJPL 35 x 24 x 11 mm 8 m M8 DC PNP cULus (CCC) OJ5114
OJPL 35 x 11 x 24 mm 8 m M8 DC PNP cULus (CCC) OJ5136
光电传感器
OGP701
OGPLFPKG/US
镜面反射传感器
螺纹结构 M18 x 1
接插件
偏振滤光镜
可见激光,激光等级1
检测距离 0.2...2m
(棱镜反射镜? 80 (E20005))
可设定
Made in Germany
电气设计 DC PNP
输出功能 通过按钮可选明电路/暗电路
出厂设定 dark-on模式
最小的可识别的物体 [? in mm] 1.5 (1 m) / 2 (2 m)
光斑直径 [mm] 5 ( 在最大的检测距离 )
工作电压 [V] 10...36 DC
电流负载 [mA] 200
短路保护 脉冲
反相保护 是
过载保护 是
电压降 [V] < 2.5
电流损耗 [mA] 15
开关频率 [Hz] 2000
光线种类 红光 655 nm
寿命 [h] 50000
环境温度 [°C] -10...60
防护等级 IP 65 / IP 67, II
EMC电磁兼容
EN 60947-5-2
MTTF [年] 600
外壳材料 外壳: 不锈钢 (316S12); 操作接口: PA; 密封圈: EPDM; 按钮: TPU
透镜材料 PMMA
功能显示
开关状态 LED 黄色
接口 M12接插件
重量 [kg] 0.065
注释
激光
激光等级1
IEC 60825-1 : 2007
除了偏差外,符合21 CFR 1040.10标准
根据激光规定Nr. 50, 2007年6月
按照cULus工作电压"电源级2"
配件(同时供货) 2个固定螺母
接线
过量增益
x: 距离[mm]
y: 超额增益系数
光电传感器
OJ5114
OJPLFPKG/FO/AS
镜面反射传感器
矩形塑料
接插件
电子锁
激光镜面反射传感器
偏振滤光镜
可见激光,激光等级1
外部Teach示教功能
前面的镜组
检测距离 8m
(棱镜反射镜50 x 50 mm (E20722))
可设定
Made in Germany
电气设计 DC PNP
输出功能 明电路 / 暗电路可选
最小的可识别的物体 [? in mm] ? 2.5mm (0.1m) ? 4mm (2.5m) ? 8mm (5m)
光斑直径 [mm] < 12 ( 在最大的检测距离 )
工作电压 [V] 10...30 DC
电流负载 [mA] 200
短路保护 脉冲
反相保护 是
过载保护 是
电压降 [V] < 2.5
电流损耗 [mA] < 15
开关频率 [Hz] 2000
光线种类 红光 650 nm
寿命 [h] 50000
环境温度 [°C] -10...60
防护等级 IP 67, III
EMC电磁兼容
EN 60947-5-2
MTTF [年] 706
外壳材料 外壳: ABS; LED窗口: SEPS; 按钮: SEPS
透镜材料 玻璃
功能显示
开关状态 LED 黄色
运行 LED 绿色
功能 LED 红色
接口 M8接插件
重量 [kg] 0.041
注释
激光
激光等级1
IEC 60825-1 : 2007
按照cULus工作电压"电源级2"
配件(同时供货) 2个固定螺栓, 2个弹簧垫圈, 2个螺母
接线
过量增益
