SICK传感器WT9-2N130
- 发布时间:2011/10/24 15:48:37
修改时间:2011/10/24 15:48:37 浏览次数:799
SICK传感器
工业用自动化传感器
漫反射式光电开关
背景遮蔽BGS
WT9-2 (小型)
WT9-2 (小型)
WT9-2 (小型)
LED光源,可见红光或红外光
背景遮蔽功能
可调校检测距离
开关频率为1000/s或1500/s
输出短路保护
施克SICk选型及技术参数
华东区: 张龙刚13817798194
Model Name Part Number Dimensions (W x H x D) Connection type Sensing range min ... max
WT9-2N130 1018294 12 x 40 x 22 mm Cable, 2 m 30 ... 250 mm
WT9-2N430 1018296 12 x 40 x 22 mm Connector, M12, 4-pin 30 ... 250 mm
WT9-2P430 1018295 12 x 40 x 22 mm Connector, M12, 4-pin 30 ... 250 mm
WT9-2P630 1019272 12 x 40 x 22 mm Cable with plug, M12, 4-pin, 120 mm 30 ... 250 mm
WT9-2P110 1018577 12 x 40 x 22 mm Cable, 2 m 30 ... 250 mm
WT9-2P410 1019668 12 x 40 x 22 mm Connector, M12, 4-pin 30 ... 250 mm
WT9-2P130 1018293 12 x 40 x 22 mm Cable, 2 m 30 ... 250 mm
WT9-2P330 1019026 12 x 40 x 22 mm Connector, M8, 4-pin 30 ... 250 mm
WT9-2P310 1028279 12 x 40 x 22 mm Connector, M8, 4-pin 30 ... 250 mm
WT9-2 (小型)
LED光源,可见红光或红外光 背景遮蔽功能 可调校检测距离 开关频率为1000/s或1500/s 输出短路保护 Model Name Part Number Dimensions (W x H x D) Connection type Sensing range min ... max WT9-2N130 1018294 12 x 40 x 22 mm Cable, 2 m 30 ... 250 mm WT9-2N4......
WT9L Laser (小型)
2级红色激光光源可调校的背景遮蔽功能开关频率为1000/s 紧凑的ABS塑料外壳 Model Name Part Number Dimensions (W x H x D) Connection type Sensing range min ... max WT9L-N330 1023991 12 x 40 x 22 mm Connector, M18, 4-pin 30 ... 150 mm WT9L-N430 102......
WT9-2(小型)
LED红色发射光、辅助对位可调校检测距离开关频率为800/s 输出短路保护自学习模式 Model Name Part Number Dimensions (W x H x D) Connection type Sensing range min ... max WT9-2P620 1019711 12 x 40 x 22 mm Cable with plug, M12, 4-pin, 120 mm 30 ... 500 mm ...
WT9-2(小型),增强型
LED红外发射光 可调校检测距离 开关频率为500/s 输出短路保护 自学习模式无技术参数!W9
1018294 WT9-2N130
1019340 WT9-2N130P02
1018296 WT9-2N430
1019688 WT9-2N430P04
1018293 WT9-2P130
1019339 WT9-2P130P01
1041567 WT9-2P320
1019026 WT9-2P330
1018295 WT9-2P430
1019272 WT9-2P630
1027461 WT9-2N150S03
1028279 WT9-2P310
1018577 WT9-2P110
1019668 WT9-2P410
1018298 WT9-2N151
1018300 WT9-2N451
1018297 WT9-2P151
1019027 WT9-2P351
1018299 WT9-2P451
1019273 WT9-2P651
1018302 WT9-2N141
1018304 WT9-2N441
1018301 WT9-2P141
1019274 WT9-2P341
1018303 WT9-2P441
1019275 WT9-2P641
1019656 WT9-2P671
1019342 WT9-2N160
1019097 WT9-2P160
1019098 WT9-2P460
1022579 WT9-2N160P05
1019711 WT9-2P620
1018282 WL9-2N130
1025462 WL9-2N130P09
1019511 WL9-2N330
1018284 WL9-2N430
1026615 WL9-2N630
1018281 WL9-2P130
1025270 WL9-2P130P08
1019024 WL9-2P330
1019381 WL9-2P330P03
1018283 WL9-2P430
1019268 WL9-2P630
1019326 WL9-2P130S01
1025271 WL9-2P130S07
1019007 WL9-2P231
1025464 WL9-2N130S09
1027185 WL9-2P030S17
1018286 WL9-2N131
1019366 WL9-2N131P02
1018288 WL9-2N431
1018285 WL9-2P131
1019365 WL9-2P131P01
1019025 WL9-2P331
1028181 WL9-2P331S20
1018287 WL9-2P431
1019269 WL9-2P631
1022299 WL9-2P481
1018290 WL9-2N121
1018292 WL9-2N421
1018289 WL9-2P121
1019270 WL9-2P321
1018291 WL9-2P421
1019271 WL9-2P621
1025966 WL9-2P031S13
1019341 WT9-2N141P03
1019260 WS/WE9-2N130
1019367 WS/WE9-2NP01
1019262 WS/WE9-2N430
1019259 WS/WE9-2P130
1019383 WS/WE9-2P330
1019261 WS/WE9-2P430
1019382 WS/WE9-2P630
W9L
1023991 WT9L-N330
1023990 WT9L-N430
1023977 WT9L-P330
1023959 WT9L-P430
1026600 WT9L-P330S02
1042470 WT9L-N330S05
1023989 WL9L-N330
1023988 WL9L-N430
1023976 WL9L-P330
1023958 WL9L-P430
1023995 WS/WE9L-N330
1023994 WS/WE9L-N430
1023993 WS/WE9L-P330
1023992 WS/WE9L-P430
2027847 WS9L-D430
施克SICk选型及技术参数
华东区: 张龙刚13817798194
