上海自动有限公司
  • IGR204
  • 发布时间:2011/10/6 23:48:44   修改时间:2011/10/6 23:48:44 浏览次数:1208
  • 3 m PVC cable · output function · 2-wire DC PNP / NPN
    M8 2 f 150 0.75 * high-grade stainless steel – IER204
    M12
    L = 45
    华东区:销售张龙刚 13817798194
    L = 40 4 f 75 0.5 * high-grade stainless steel – IFR204
    M18 L = 40 6 f 50 0.5 * high-grade stainless steel – IGR204
    M30 L = 40 12 f 25 0.5 * high-grade stainless steel – IIR204
    5 m PVC cable · output function · 2-wire DC PNP / NPN
    M8 2 f 150 0.75 * high-grade stainless steel – IER205
    M12
    L = 45
    L = 40 4 f 75 0.5 * high-grade stainless steel – IFR205
    M18 L = 40 6 f 50 0.5 * high-grade stainless steel – IGR205
    M30 L = 40 12 f 25 0.5 * high-grade stainless steel – IIR205[m/s]
    < 35
    < 35
    15.1 static 2 < 35 10...150 0.5 / 10 I7R205
    15.1 dynamic 0.8 < 35 0.1...150 0.2 / 0.2 I7R207
    20.1 static 2.5 < 35 10...150 0.5 / 10 I7R209
    20.1 dynamic 1 < 35 0.1...150 0.2 / 0.2 I7R211
    25.1 static 3 < 35 10...150 0.5 / 10 I7R213
    25.1 dynamic 1.2 < 35 0.1...150 0.2 / 0.2 I7R215
    < 35
    10.1 dynamic 0.6 < 35 0.1...150 0.2 / 0.2 I7R204
    15.1 static 2 < 35 10...150 0.5 / 10 I7R206
    15.1 dynamic 0.8 < 35 0.1...150 0.2 / 0.2 I7R208
    20.1 static 2.5 < 35 10...150 0.5 / 10 I7R210
    20.1 dynamic 1 < 35 0.1...150 0.2 / 0.2 I7R212
    25.1 static 3 < 35 10...150 0.5 / 10 I7R214
    25.1 dynamic 1.2 < 35 0.1...150 0.2 / 0.2 I7R216
    Sensing range
    [mm]
    Order
    no.
    M8 connector · Output function · 3-wire DC PNP
    14 I85000
    Operating
    principle
    static
    Resolution
    Steel ball
    [? mm]
    3
    Pulse
    stretching
    [ms]
    100
    Response time /
    fall time
    [ms]
    0.5 / 100
    20 dynamic 1 100 0.2 / 100 I85004
    Part
    speed
    [m/s]
    < 35
    < 35
    M8 connector · Output function · 3-wire DC NPN
    14 static 3 100 0.5 / 100 I85001
    20 dynamic 1 100 0.2 / 100 I85005
    < 35
    < 35
    M12 cable plug 0.09 m · Output function · 3-wire DC PNP
    14 static 3 100 0.5 / 100 I85002
    20 dynamic 1 100 0.2 / 100 I85006
    < 35
    < 35
    M12 cable plug 0.09 m · Output function · 3-wire DC NPN
    14 static 3 100 0.5 / 100 I85003
    20 dynamic 1 100 0.2 / 100 I85007
    10 I7R202
    Part
    speed
    [m/s]
    < 35
    < 35
    < 35
    Sensing range
    [mm]
    Order
    no.
    14 I85000
    Operating
    principle
    static
    Resolution
    Steel ball
    [? mm]
    3
    Pulse
    stretching
    [ms]
    100
    Response time /
    fall time
    [ms]
    0.5 / 100
    Part
    speed
    [m/s]
    < 35
    < 35
    < 35
    < 35
    < 35
    < 35
    IER203
    M8
    Dimensions
    Length
    [mm]
    L = 45
    L = 45 2 f 150 0.75 * high-grade stainless steel 3+4 IER206
    M12 L = 40 4 f 75 0.5 * high-grade stainless steel 1+4 IFR203
    M12 L = 40 4 f 75 0.5 * high-grade stainless steel 3+4 IFR206
    M18 L = 40 6 f 50 0.5 * high-grade stainless steel 1+4 IGR203
    M18 L = 40 6 f 50 0.5 * high-grade stainless steel 3+4 IGR206
    M30 L = 40 12 f 25 0.5 * high-grade stainless steel 1+4 IIR203
    M30 L = 40 12 f 25 0.5 * high-grade stainless steel 3+4 IIR206
    Applications:
    Metalworking and welding applications
    Common technical data
    M12x1
    14
    49
    M12x1
    4
    LED
    11 17
    40
    30
    Example IFR203
    E10736
    E10737
    E10734
    E10735
    -0.012...0.40
    -1.00...39.96
    -1.00...15.98
    -1.000...6.39
    -0.124...3.996
    -0.05...1.598
    -0.0124...0.3996
    -1...1 1.6 PG2899
    -0.005...0.1 0.16
    10
    4
    -1...1.1
    -0.005...0.135
    inputs and outputs CR7506
    usable at the same time CR7201
    40
    24
    80
    Number of inputs / CR7021
    of which safe CR7506
    CR7201
    28 / 16
    20 / 16
    2 x 28 / 2 x 16
    Number of outputs / CR7021
    CR7201
    40
    24
    80
    CR7201
    28 / 16
    20 / 16
    2 x 28 / 2 x 16
    CR72014 digital inputs AC2410
    4 digital inputs,
    metal parts made of stainless steel AC2451
    4 digital inputs, 4 digital outputs AC2465
    4 digital outputs AC2417
    2 digital inputs, 2 digital outputs AC2411
    4 digital inputs, 4 digital outputs AC2412
    4 digital inputs, 4 digital outputs,
    metal parts made of stainless steel AC2452
    4
    4
    4
    4
    EBC014
    EBC016
    5
    10 EBC026
    5
    10 EBC028
    EBC017
    EBC019
    5
    10 EBC029
    5
    10 EBC031
    EBC018
    EBC020
    5
    10 EBC030
    5
    10 EBC032
    EBC021
    EBC023
    5
    10 EBC033
    5
    10 EBC035
    EBC022
    EBC024
    5
    10 EBC034
    5
    10 EBC036
    0.3 m EVC265
    0.6 m EVC266
    1.0 m EVC267
    E11319
    E11320
    E11321
    2.0 m EVC268
    5.0 m EVC269
    E11322
    E11323
    0.3 m EVC275
    0.6 m EVC276
    1.0 m EVC277
    E11324
    E11325
    E11326
    2.0 m EVC278
    5.0 m EVC279
    E11327
    E11328
    0.3 m, 2 LED EVC280
    0.6 m, 2 LED EVC281
    1.0 m, 2 LED EVC282
    E11329
    E11330
    E11331
    2.0 m, 2 LED EVC283
    5.0 m, 2 LED EVC284
    -50...150 / -58...302
    Process connection
    G 1/4
    G 1/4
    Probe length
    [mm]
    46.50
    186.50
    Accuracy
    [K]
    ± 0.4
    ± 0.4
    Pressure
    resistance
    [bar]
    400
    0...140 / 32...284 G 1/4 46.50 ± 0.5 400 TA3130
    400
    TA3231
    TA3233
    -10...150 / 14...302
    -17.8...148.9 / 0...300
    ? 6 mm
    ? 6 mm
    123
    123
    ± 0.3
    ± 0.4
    50*
    50*
    TA3237
    TA3333
    0...100 / 32...212
    ? 6 mm
    1/4" NPT
    123
    46.50
    ± 0.3
    ± 0.4
    50*
    300
    0...100 / 32...212 1/4" NPT 46.50 ± 0.3 300 TA3337
    -1...25 40 PG2893
    -1...10 16 PG2894
    -1...4 6.4
    100
    50
    30
    -1.00...33.76
    -1.0...13.50
    -1.00...5.40
    5.24...40.00
    1.5...16.00
    0.00...6.40 PG2895
    -0.96...40.00
    -0.98...16.00
    -0.990...6.40
    -0.124...2.5 4 PG2896
    -0.05...1 1.6 PG2897
    -0.0124...0.25 0.4
    20
    10
    10
    -0.124...3.370
    -0.05...1.35
    -0.0124...0.3376
    0.500...4.000
    0.2...1.60
    0.05...0.40 PG2898
    -0.120...4.000
    -0.048...1.60
    -0.012...0.40
    -1.00...39.96
    -1.00...15.98
    -1.000...6.39
    -0.124...3.996
    -0.05...1.598
    -0.0124...0.3996
    -1...1 1.6 PG2899
    -0.005...0.1 0.16
    10
    4
    -1...1.1
    -0.005...0.135
    -0.5...1.6
    0.02...0.16 PG2889
    -1...25 40 PG2893
    -1...10 16 PG2894
    -1...4 6.4
    100
    50
    30
    -1.00...33.76
    -1.0...13.50
    -1.00...5.40
    5.24...40.00
    1.5...16.00
    0.00...6.40 PG2895
    -0.96...40.00
    -0.98...16.00
    -0.990...6.40
    -0.0124...0.25 0.4
    20
    10
    10
    -0.124...3.370
    -0.05...1.35
    -0.0124...0.3376
    0.500...4.000
    0.2...1.60
    0.05...0.40 PG2898
    -0.120...4.000
    -0.048...1.60-1...25 40 PG2893
    -1...10 16 PG2894
    -1...4 6.4
    100
    50
    30
    -1.00...33.76
    -1.0...13.50
    -1.00...5.40
    5.24...40.00
    1.5...16.00
    0.00...6.40 PG2895
    -0.96...40.00
    -0.98...16.00
    -0.990...6.40
    -0.0124...0.25 0.4
    20
    10
    10
    -0.124...3.370
    -0.05...1.35
    -0.0124...0.3376
    0.500...4.000
    0.2...1.60
    0.05...0.40 PG2898
    -0.120...4.000
    -0.048...1.60
    -0.012...0.40
    -1.00...39.96
    -1.00...15.98
    -1.000...6.39
    -0.124...3.996
    -0.05...1.598
    -0.0124...0.3996
    -1...1 1.6 PG2899
    -0.005...0.1 0.16
    10
    4
    -1...1.1
    -0.005...0.135
    -0.5...1.6
    0.02...0.16 PG2889O7E201F711S
    0.5...4 mm, nf
    GF711S
    Enable zone: GM701S
    10...15 mm, f / nf
    Enable zone: GM705S
    4...20 mm, nf
    Enable zone: GM504S
    10...15 mm, f / nf
    Enable zone: GM505S
    50 AC, 500 DC MR0119
    30.5 x 5 x 6.5 AC/DC, PNP ≤ 1 typ. 2.1 350 AC, 500 DC MR0120
    Connection cable 6 m PUR · output function · 3-wire
    30.5 x 5 x 6.5 AC/DC, PNP ≤ 1 typ. 2.1 350 AC, 500 DC MR0123
    30.5 x 5 x 6.5 AC/DC, PNP ≤ 1 typ. 2.1 350 AC, 500 DC MR0122
    Connection cable 0.3 m PUR with M12 connector · output function · 3-wire
    5...50 AC/DC
    5...50 AC/DC
    5...50 AC/DC
    5...50 AC/DC
    5...50 AC/DC ≤ 1
    -25...70
    -25...70
    -25...70
    -25...70
    -25...70 typ. 2.1 350 AC, 500 DC MR0121
    20 110 ? 10 IP 65, IP 67,II programmable PNP / NPN* KI5082
    20 110 ? 10 IP 65, IP 67,II programmable PNP KI5083
    Type M30 · non-flush mountable · 1/2" UNF connector · 2-wire
    20 110 ? 10 IP 65, IP 67,II programmable AC / DC KI0054
    Type M30 · non-flush mountable · M12 connector · 4-wire
    20 250 ? 10 IP 67,III programmable PNP KN5121
    Type M18 · non-flush mountable · M12 connector · 3-wire
    12 110 ? 10 IP 65, IP 67,II programmable PNP / NPN* KG5065
    12 110 ? 10 IP 65, IP 67,II programmable PNP KG5066
    10 I7R202
    Part
    -0.5...1.6
    0.02...0.16 PG2889
TO:采购 公司经营品牌:施克SICK 倍加福P+F, 易福门IFM ,基恩士 罗斯蒙特(Rosemount) . 图尔克TURCK,美国 埃福创编码器AVTRON. 宜科、ABB瑞士。巴鲁夫 , SMC ,费斯托FESTO 西门子仪器仪表 销售:张龙刚 手机:13817798194 邮箱:zlgsh@hotmail.com 价格优惠!…  更多>>
上海自动有限公司
联系人:张龙刚
地址:上海松江区
邮编:201613
电话:13817798194
公司网址:http://xhzlg.b2b.youboy.com
  • Ferenc Nagy 在2024/11/29 23:20:00留言
  • 详细留言:RFQ 1-2 x Sick SCS70HLA0K01 ID: 1034069
  • 明小姐 在2015/3/26 16:05:00留言
  • 详细留言:还看了HYDAC给水泵:http://www.hydac-zh.com/gsb/ 贺德克给水泵:http://www.hydac-zh.com/gsb/ 给水泵:http://www.hydac-zh.com/gsb/ 贺德克轴向柱塞泵:http://www.hydac-zh.com/zxzsb/ HYDAC轴向柱塞泵:http://www.hydac-zh.com/zxzsb/ 轴向柱塞泵:http://www.hydac-zh.com/zxzsb/ 贺德克内啮合齿轮泵:http://www.hydac-zh.com/nniclb/ HYDAC内啮合齿轮泵:http://www.hydac-zh.com/nniclb/ 内齿轮油泵:http://www.hydac-zh.com/nniclb/ 贺德克外啮合齿轮泵:http://www.hydac-zh.com/wniclb/ HYDAC外啮合齿轮泵:http://www.hydac-zh.com/wniclb/ 外啮合齿轮泵:http://www.hydac-zh.com/wniclb/ HYDAC压力传感器:http://www.hydac-zh.com/ylcgq/ 贺德克压力传感器:http://www.hydac-zh.com/ylcgq/
  • 王力 在2014/12/10 18:16:00留言
  • 梁先生 在2014/7/17 9:23:00留言
  • 详细留言:流量传感器0-15ml/min
  • 荣玉成 在2014/4/15 14:14:00留言
  • 详细留言:压力传感器:范围不+-20Pa 范围0-50Pa 电压24VDC 电流4-20mA
