上海自动有限公司
  • 易福门流体传感器和诊断系统PH9958
  • 发布时间:2011/10/19 13:29:59   修改时间:2011/10/19 13:29:59 浏览次数:1909
  • 流体传感器和诊断系统 监控流体和振荡 从监控液体、气体、颗粒及软膏状的介子到分析机器和设备的振荡,易福门提供一系列丰富多彩的电子传感器产品。 阀门传感器 液位传感器 流量传感器 压力传感器 真空传感器 温度传感器 诊断系统
    易福门全国经销     IFM   全国 销售
    华东区: 张龙刚13817798194
     PH99 M12 DC -25...80 °C -25...125 (145 max. 1h) °C — EHEDG PH9956 PH99 M12 DC -25...80 °C -25...125 (145 max. 1h) °C — cULus EHEDG PH9957 PH99 M12 DC -25...80 °C -25...125 (145 max. 1h) °C — EHEDG PH9958
     PI00 G1 M12 DC PNP/NPN (250mA) -20...60 *** °C -20...60 *** °C — FDA ATEX 3G ATEX 3D PI003A PI00 G1 M12 DC PNP/NPN (250mA) -20...60 *** °C -20...60 *** °C — FDA ATEX 3G ATEX 3D PI008A PI00 G1 M12 DC PNP/NPN (250mA) -20...60 *** °C -20...60 *** °C — FDA ATEX 3G ATEX 3D PI009A PI10 用于Aseptoflex适配器 M12 DC -25...80 °C -25...125 (145 max. 1h) °C — 3A cULus EHEDG FDA PI1096 PI10 用于Aseptoflex适配器 M12 DC -25...80 °C -25...125 (145 max. 1h) °C — 3A cULus EHEDG FDA PI1097 PI10 用于Aseptoflex适配器 M12 DC -25...80 °C -25...125 (145 max. 1h) °C — 3A cULus EHEDG FDA PI1098 PI10 用于Aseptoflex适配器 M12 DC -25...80 °C -25...125 (145 max. 1h) °C — 3A cULus EHEDG FDA PI1099 PI16 G1 A M12 DC -25...80 °C -25...125 (145 max. 1h) °C — 3A EHEDG FDA PI1689 PI16 G1 A M12 DC -25...80 °C -25...125 (145 max. 1h) °C — 3A cULus EHEDG FDA PI1696 PI16 G1 A M12 DC -25...80 °C -25...125 (145 max. 1h) °C — 3A cULus EHEDG FDA PI1697 PI16 G1 A M12 DC -25...80 °C -25...125 (145 max. 1h) °C — 3A cULus EHEDG FDA PI1698 PI16 G1 A M12 DC -25...80 °C -25...125 (145 max. 1h) °C — 3A cULus EHEDG FDA PI1699 PI20 用于Aseptoflex适配器 M12 DC PNP/NPN (250mA) -25...80 °C -25...125 (145 max. 1h) °C — 3A cULus EHEDG FDA PI2096 PI20 用于Aseptoflex适配器 M12 DC PNP/NPN (250mA) -25...80 °C -25...125 (145 max. 1h) °C — 3A cULus EHEDG FDA PI2097 PI20 用于Aseptoflex适配器 M12 DC PNP/NPN (250mA) -25...80 °C -25...125 (145 max. 1h) °C — 3A cULus EHEDG FDA PI2098 PI20 用于Aseptoflex适配器 M12 DC PNP/NPN (250mA) -25...80 °C -25...125 (145 max. 1h) °C — 3A cULus EHEDG FDA PI2099 PI26 G1 A M12 DC PNP/NPN (250mA) -25...80 °C -25...125 (145 max. 1h) °C — 3A cULus EHEDG FDA PI2696 PI26 G1 A M12 DC PNP/NPN (250mA) -25...80 °C -25...125 (145 max. 1h) °C — 3A cULus EHEDG FDA PI2697 PI26 G1 A M12 DC PNP/NPN (250mA) -25...80 °C -25...125 (145 max. 1h) °C — 3A cULus EHEDG FDA PI2698 PI26 G1 A M12 DC PNP/NPN (250mA) -25...80 °C -25...125 (145 max. 1h) °C — 3A cULus EHEDG FDA PI2699 PI27 G1 / Aseptoflex Vario M12 DC PNP/NPN (250mA) -25...80 °C -25...125 (145 max. 1h) °C — 3A cULus EHEDG FDA PI2789 PI27 G1 / Aseptoflex Vario M12 DC PNP/NPN (250mA) -25...80 °C -25...125 (145 max. 1h) °C — 3A cULus EHEDG FDA PI2796 PI27 G1 / Aseptoflex Vario M12 DC PNP/NPN (250mA) -25...80 °C -25...125 (145 max. 1h) °C — 3A cULus EHEDG FDA PI2797 PI27 G1 / Aseptoflex Vario M12 DC PNP/NPN (250mA) -25...80 °C -25...125 (145 max. 1h) °C — 3A cULus EHEDG FDA PI2798 PI27 G1 / Aseptoflex Vario M12 DC PNP/NPN (250mA) -25...80 °C -25...125 (145 max. 1h) °C — 3A cULus EHEDG FDA PI2799 PI29 G? A M12 DC PNP/NPN (250mA) -25...80 °C -25...125 (145 max. 1h) °C — cULus FDA PI2997 PL20 用于Aseptoflex适配器 M12 3线DC ; 2线DC -25...80 °C -25...80 °C — 3A cULus EHEDG FDA PL2056 PL20 用于Aseptoflex适配器 M12 3线DC ; 2线DC -25...80 °C -25...80 °C — 3A cULus EHEDG FDA PL2057 PL20 用于Aseptoflex适配器 M12 3线DC ; 2线DC -25...80 °C -25...80 °C — 3A cULus EHEDG FDA PL2058 PL26 G1 A M12 3线DC ; 2线DC -25...80 °C -25...80 °C — 3A cULus EHEDG FDA PL2656 PL26 G1 A M12 3线DC ; 2线DC -25...80 °C -25...80 °C — 3A cULus EHEDG FDA PL2657 PL26 G1 A M12 3线DC ; 2线DC -25...80 °C -25...80 °C — 3A cULus EHEDG FDA PL2658 PM20 用于Aseptoflex适配器 M12 DC -25...80 °C -25...125 (145 max. 1h) °C — 3A cULus EHEDG FDA PM2056 PM20 用于Aseptoflex适配器 M12 DC -25...80 °C -25...125 (145 max. 1h) °C — 3A cCSAus cULus EHEDG FDA PM2057 PM20 用于Aseptoflex适配器 M12 DC -25...80 °C -25...125 (145 max. 1h) °C — 3A cULus EHEDG FDA PM2058 PM26 G1 A M12 3线DC ; 2线DC -25...80 °C -25...125 (145 max. 1h) °C — 3A cULus EHEDG FDA PM2656 PM26 G1 A M12 3线DC ; 2线DC -25...80 °C -25...125 (145 max. 1h) °C — 3A cULus EHEDG FDA PM2657 PM26 G1 A M12 3线DC ; 2线DC -25...80 °C -25...125 (145 max. 1h) °C — 3A cULus EHEDG FDA PM2658 连接 工作温度 介质温度 目标介质温度 许可证 订购编号 LMT G? M12 DC PNP (50mA) 0...60 °C 参见技术参数表 — 3A cULus EHEDG FDA LMT100 LMT G? M12 DC PNP (50mA) 0...60 °C 参见技术参数表 — 3A cULus EHEDG FDA LMT110 PF20 用于Aseptoflex适配器 M12 DC PNP/NPN (2mA) -25...80 °C -25...80 °C — 3A cULus EHEDG FDA PF2056 PF20 用于Aseptoflex适配器 M12 DC PNP/NPN (2mA) -25...80 °C -25...80 °C — 3A cULus EHEDG FDA PF2057 ? 10 mm V4A V4A M12   连接控制显示器 ATEX 2G  SF620A
    流量传感器
    SF0516
    SFG 14ZBB
    分体式流量传感器
    电缆
    系统接口: 夹子ISO 2852 DN25
    卫生用装置
    Made in Germany
    应用范围 高温和卫生范围
    连接控制显示器 VS3000
    介质温度梯度最大值 [K/min] 15
    抗压强度 [bar] 30
    液体介质
    介质温度 [°C] 0...120
    设定范围 [cm/s] 3...300
    最大灵敏度时的测量范围 [cm/s] 3...60
    气体介质
    介质温度 [°C] 0...100
    设定范围 [cm/s] 200...2000
    最大灵敏度时的测量范围 [cm/s] 200...800
    反应时间 [s] 1...10
    外壳防护等级 IP 67
    抗冲击
    DIN IEC 68-2-27: 40 g (11 ms)
    抗震
    DIN IEC 68-2-6: 10 g (55...2000 Hz)
    MTTF [年] 8648
    外壳材料 不锈钢 (320S31)
    材料(潮湿部件) 不锈钢 (320S31)
    接口 硅镀层电缆 / 6 m; 5 x 0.34 mm2
    最大的导线长度 [m] 100 (5 x 0.5mm2)
    重量 [kg] 0.487
    注释
    如果具有3A证书的适配器用于安装,3A认证才有效。
    接线
    芯线颜色
    BN 棕色
    BU 蓝色
    BK 黑色
    WH 白色
    GY 灰色
    LR70 G3/4 M12   DC PNP (200mA) 0...60 °C 0...80 *** °C cULus  LR7000
    LR80 G3/4 M12   DC PNP (200mA) 0...60 °C 0...80 *** °C cULus  LR8000
    LT ? 16 mm M12   DC PNP (200mA) 0...60 °C 参见技术参数表 cULus  LT8022
    LT ? 16 mm M12   DC PNP (200mA) 0...60 °C 参见技术参数表 cULus  LT8023
    LT ? 16 mm M12   DC PNP (200mA) 0...60 °C 参见技术参数表 cULus  LT8024
    可证 订购编号
    处理显示器 3S3T4A   AC cULus  SN0150
    处理显示器 3S3T4A   AC cULus  SN0151
    处理显示器 3S3T4A   AC cULus  SN0152
    处理显示器 塑料   AC IEC TIIS ATEX 1G  SN2301
    处理显示器 塑料   AC IEC TIIS ATEX 1G  SN2302
    处理显示器 塑料   AC TIIS ATEX 1G  SN2303
    处理显示器 塑料   AC ATEX 1G  SN2304
    处理显示器 塑料   DC PNP  SR0127
    处理显示器 3S3T4A   DC cULus  SR0150
    处理显示器 3S3T4A   DC  SR0151
    处理显示器 3S3T4A   DC cULus  SR0153
    处理显示器 塑料   DC IEC ATEX 1G  SR2301
    处理显示器 V4A M12   DC PNP cULus  SR5900
    处理显示器 V4A 1/2"   AC / 继电器 cULus  SR5906
    许可证 订购编号
    Clamp DN25 V4A 3S3T7R 6 m   连接控制显示器 3A cULus  SF0516
    通用转接头 V4A V4A M12   连接控制显示器 cULus  SF0537
    G ? A 陶瓷 陶瓷 16 m   连接控制显示器  SF0540
    M12 x 1 V4A V4A 6 m   连接控制显示器 TIIS ATEX 1G ATEX 2G  SF111A
    M12 x 1 V4A V4A M12   连接控制显示器 ATEX 2G  SF120A
    M12 x 1 V4A V4A 6 m   连接控制显示器 ATEX 2G  SF121A
    G ? A V4A V4A 6 m   连接控制显示器 TIIS ATEX 1G ATEX 2G  SF211A
    G ? A V4A V4A M12   连接控制显示器 ATEX 2G  SF220A
    G ? A V4A V4A 6 m   连接控制显示器 ATEX 2G  SF221A
    G ? A 陶瓷 陶瓷 6 m   连接控制显示器 ATEX 2G  SF223A
    G ? A 陶瓷 陶瓷 M12   连接控制显示器 cULus  SF2405
    G ? A 陶瓷 陶瓷 6 m   连接控制显示器 cULus  SF2410
    ?" NPT (DN15) V4A 3S3T7R 6 m   连接控制显示器 cULus  SF3020
    G ? A V4A V4A 6 m   连接控制显示器 TIIS ATEX 1G ATEX 2G  SF311A
    G ? A V4A V4A M12   连接控制显示器 IEC ATEX 2G  SF320A
    G ? A V4A V4A 6 m   连接控制显示器 IEC ATEX 2G  SF321A
    G ? A 陶瓷 陶瓷 6 m   连接控制显示器 ATEX 2G  SF323A
    G ? A 陶瓷 陶瓷 M12   连接控制显示器  SF3405
    G ? A 陶瓷 陶瓷 6 m   连接控制显示器  SF3410
    通用转接头 V4A V4A M12   连接控制显示器 cULus  SF5200
    通用转接头 V4A V4A M12   连接控制显示器 cULus  SF5201
    ANSI B 16.5 V4A V4A 6 m   连接控制显示器 ATEX 2G  SF521A
    通用转接头 3SGLXT V4A 6 m   连接控制显示器 cULus  SF5300
    通用转接头 V4A V4A 6 m   连接控制显示器 cULus  SF5301
    通用转接头 V4A V4A 6 m   连接控制显示器 cULus  SF5350
    通用转接头 V4A M12   连接控制显示器 cULus  SF5700
    通用转接头 6 m   连接控制显示器 cULus  SF5800
    ? 10 mm V4A V4A M12   连接控制显示器 cULus  SF6200
    ? 10 mm V4A V4A M12   连接控制显示器 cULus  SF6201
    对射式传感器
      镜面反射传感器
      漫反射传感器
      光电距离传感器
     高性能工业传感器
    易福门全国经销     IFM   全国 销售
    华东区: 张龙刚13817798194
        颜色传感器连接 工作温度 介质温度 目标介质温度 许可证 订购编号
    LMT G? M12   DC PNP (50mA) 0...60 °C 参见技术参数表 3A cULus EHEDG FDA  LMT110
    KDE 105 x 80 x 40 mm   AC/DC (250mA) -20...60  °C ATEX 3D  KD000A
    KDE 105 x 80 x 40 mm   DC PNP (250mA) -20...60  °C ATEX 3D  KD500A
    KGE M18 / L = 110 mm   AC/DC (350mA) -25...80 °C CCC  KG0008
    KGE M18 / L = 110 mm   DC PNP/NPN (400mA) -25...80 °C CCC  KG5040
    KGE M18 / L = 110 mm   DC PNP (250mA) -25...80 °C  KG5041
    KGE M18 / L = 110 mm   DC PNP (250mA) -25...80 °C  KG5042
    KG M18 / L = 87 mm M12   DC PNP/NPN (200mA) -25...80  °C 110 °C cULus  KG5065
    KG M18 / L = 87 mm M12   DC PNP (200mA) -25...80  °C 110 °C cULus  KG5066
    KIE M30 / L = 151 mm   AC/DC (250mA) -20...60  °C ATEX 3D  KI0042
    KI M30 / L = 90 mm 1/2"   AC/DC (150mA) -25...80  °C 110 °C CCC  KI0054
    KIE M30 / L = 141 mm M12   DC PNP (250mA) -20...60  °C ATEX 3D  KI501A
    KI M30 / L = 81 mm 2 m PVC电缆   NAMUR -20...60 °C cCSAus FM IECEx TIIS ATEX 1G ATEX 1D  KI5030
    KIE M30 / L = 151 mm   DC PNP (250mA) -20...60  °C ATEX 3D  KI5065
    KI M30 / L = 90 mm M12   DC PNP/NPN (200mA) -25...80  °C 110 °C cULus  KI5082
    KI M30 / L = 90 mm M12   DC PNP (200mA) -25...80  °C 110 °C cULus  KI5083
    KI M30 / L = 90 mm M12   DC PNP/NPN (100mA) -25...80 °C cULus  KI5084
    KI M30 / L = 90 mm M12   DC PNP (100mA) -25...80 °C cULus  KI5085
    KI M30 / L = 90 mm M12   DC PNP/NPN (100mA) -25...80 °C cULus  KI5086
    KI M30 / L = 90 mm M12   DC PNP (100mA) -25...80 °C cULus  KI5087
    KNM M30 / L = 92 mm 1/2"   AC (250mA) -25...80 °C -25...110 °C  KN0005
    KNM M30 / L = 92 mm 1/2"   AC (250mA) -25...80 °C -25...110 °C  KN0006
    KNM M30 / L = 116 mm M12   DC PNP (200mA) -15...230  °C 250 °C (CCC)  KN5121
    KQ6 48 x 20 x 14 mm 2 m PVC电缆   带自动负载识别的1x open整流子(DC PNP或DC NPN) (100mA) -25...80 °C cULus  KQ6001
    KQ6 48 x 20 x 14 mm 2 m PVC电缆   1x open collector DC PNP (100mA) -25...80 °C cULus  KQ6002
    KQ6 48 x 20 x 14 mm M8 / 0,04 m PVC电缆   带自动负载识别的1x open整流子(DC PNP或DC NPN) (100mA) -25...80 °C cULus  KQ6003
    KQ6 48 x 20 x 14 mm M8 / 0,04 m PVC电缆   1x open collector DC PNP (100mA) -25...80 °C cULus  KQ6004
    KQ6 48 x 20 x 14 mm M12 / 0,1 m PVC电缆   1x open collector DC PNP (100mA) -25...80 °C cULus  KQ6005
    KX M34 / L = 92 mm 2 m PVC电缆   NAMUR -20...60 °C cCSAus FM ATEX 1G ATEX 1D  KX5001
    KX M34 / L = 92 mm 6 m PVC电缆   NAMUR -20...60 °C cCSAus FM ATEX 1G ATEX 1D  KX5002
    KX M34 / L = 92 mm 20 m PVC电缆   NAMUR -20...60 °C cCSAus FM ATEX 1G ATEX 1D  KX5004
    LI ? 16 mm M12   DC PNP (200mA) 0...65 °C 参见技术参数表 cULus WHG  LI2141
    LI ? 16 mm M12   DC PNP (200mA) 0...65 °C 参见技术参数表 cULus WHG  LI2142
    LI ? 16 mm M12   DC PNP (200mA) 0...65 °C 参见技术参数表 cULus WHG  LI2143
    LI ? 16 mm M12   DC PNP (200mA) -25...80 °C 参见技术参数表 cULus  LI5141
    LI ? 16 mm M12   DC PNP (200mA) -25...80 °C 参见技术参数表 cULus  LI5142
    LI ? 16 mm M12   DC PNP (200mA) -25...80 °C 参见技术参数表 cULus  LI5143
    LI ? 16 mm M12   DC PNP (200mA) -25...80 °C 参见技术参数表 cULus  LI5144
    LMT G? M12   DC PNP (50mA) 0...60 °C 参见技术参数表 3A cULus EHEDG FDA  LMT100
    PF20 用于Aseptoflex适配器 M12   DC PNP/NPN (2mA) -25...80 °C -25...80 °C 3A cULus EHEDG FDA  PF2056
    PF20 用于Aseptoflex适配器 M12   DC PNP/NPN (2mA) -25...80 °C -25...80 °C 3A cULus EHEDG FDA  PF2057
    PF20 用于Aseptoflex适配器 M12   DC PNP/NPN (2mA) -25...80 °C -25...80 °C 3A cULus EHEDG FDA  PF2058
    PF26 G1 A M12   DC PNP/NPN (2mA) -25...80 °C -25...80 °C 3A cULus EHEDG FDA  PF2609
    PF26 G1 A M12   DC PNP/NPN (2mA) -25...80 °C -25...80 °C 3A cULus EHEDG FDA  PF2656
    PF26 G1 A M12   DC PNP/NPN (2mA) -25...80 °C -25...80 °C 3A cULus EHEDG FDA  PF2657
    PF26 G1 A M12   DC PNP/NPN (2mA) -25...80 °C -25...80 °C 3A cULus EHEDG FDA  PF2658
    PF29 G? A M12   DC PNP/NPN (2mA) -25...80 °C -25...80 °C cULus FDA  PF2956
    PF29 G? A M12   DC PNP/NPN (2mA) -25...80 °C -25...80 °C cULus FDA  PF2957
    PG27 G1 A M12   DC PNP/NPN (250mA) -25...80 °C -25...125 (145 max. 1h) °C 3A EHEDG FDA  PG2789
    PG27 G1 A M12   DC PNP/NPN (250mA) -25...80 °C -25...125 (145 max. 1h) °C 3A cULus EHEDG FDA  PG2796
    PG27 G1 A M12   DC PNP/NPN (250mA) -25...80 °C -25...125 (145 max. 1h) °C 3A cULus EHEDG FDA  PG2797
    PG27 G1 A M12   DC PNP/NPN (250mA) -25...80 °C -25...125 (145 max. 1h) °C 3A cULus EHEDG FDA  PG2798
    PG27 G1 A M12   DC PNP/NPN (250mA) -25...80 °C -25...125 (145 max. 1h) °C 3A cULus EHEDG FDA  PG2799
    PG28 G1 A M12   DC PNP/NPN (250mA) -25...80 °C -25...125 (145 max. 1h) °C cULus EHEDG  PG2889
    PG28 G1 A M12   DC PNP/NPN (250mA) -25...80 °C -25...125 (145 max. 1h) °C cULus EHEDG  PG2896
    PG28 G1 A M12   DC PNP/NPN (250mA) -25...80 °C -25...125 (145 max. 1h) °C cULus EHEDG  PG2897
    PG28 G1 A M12   DC PNP/NPN (250mA) -25...80 °C -25...125 (145 max. 1h) °C cULus EHEDG  PG2898
    PG28 G1 A M12   DC PNP/NPN (250mA) -25...80 °C -25...125 (145 max. 1h) °C cULus EHEDG  PG2899
    PH M12   DC PNP/NPN (250mA) -25...80 °C -25...125 (145 max. 1h) °C  PH5007
    PH99 M12   DC -25...80 °C -25...125 (145 max. 1h) °C EHEDG  PH9956
    PH99 M12   DC -25...80 °C -25...125 (145 max. 1h) °C cULus EHEDG  PH9957
    PH99 M12   DC -25...80 °C -25...125 (145 max. 1h) °C EHEDG  PH9958
    PI00 G1 M12   DC PNP/NPN (250mA) -20...60 *** °C -20...60 *** °C FDA ATEX 3G ATEX 3D  PI003A
    PI00 G1 M12   DC PNP/NPN (250mA) -20...60 *** °C -20...60 *** °C FDA ATEX 3G ATEX 3D  PI008A
    PI00 G1 M12   DC PNP/NPN (250mA) -20...60 *** °C -20...60 *** °C FDA ATEX 3G ATEX 3D  PI009A
    PI10 用于Aseptoflex适配器 M12   DC -25...80 °C -25...125 (145 max. 1h) °C 3A cULus EHEDG FDA  PI1096
    PI10 用于Aseptoflex适配器 M12   DC -25...80 °C -25...125 (145 max. 1h) °C 3A cULus EHEDG FDA  PI1097
    PI10 用于Aseptoflex适配器 M12   DC -25...80 °C -25...125 (145 max. 1h) °C 3A cULus EHEDG FDA  PI1098
    PI10 用于Aseptoflex适配器 M12   DC -25...80 °C -25...125 (145 max. 1h) °C 3A cULus EHEDG FDA  PI1099
    PI16 G1 A M12   DC -25...80 °C -25...125 (145 max. 1h) °C 3A EHEDG FDA  PI1689
    PI16 G1 A M12   DC -25...80 °C -25...125 (145 max. 1h) °C 3A cULus EHEDG FDA  PI1696
    PI16 G1 A M12   DC -25...80 °C -25...125 (145 max. 1h) °C 3A cULus EHEDG FDA  PI1697
    PI16 G1 A M12   DC -25...80 °C -25...125 (145 max. 1h) °C 3A cULus EHEDG FDA  PI1698
    PI16 G1 A M12   DC -25...80 °C -25...125 (145 max. 1h) °C 3A cULus EHEDG FDA  PI1699
    PI20 用于Aseptoflex适配器 M12   DC PNP/NPN (250mA) -25...80 °C -25...125 (145 max. 1h) °C 3A cULus EHEDG FDA  PI2096
    PI20 用于Aseptoflex适配器 M12   DC PNP/NPN (250mA) -25...80 °C -25...125 (145 max. 1h) °C 3A cULus EHEDG FDA  PI2097
    PI20 用于Aseptoflex适配器 M12   DC PNP/NPN (250mA) -25...80 °C -25...125 (145 max. 1h) °C 3A cULus EHEDG FDA  PI2098
    PI20 用于Aseptoflex适配器 M12   DC PNP/NPN (250mA) -25...80 °C -25...125 (145 max. 1h) °C 3A cULus EHEDG FDA  PI2099
    PI26 G1 A M12   DC PNP/NPN (250mA) -25...80 °C -25...125 (145 max. 1h) °C 3A cULus EHEDG FDA  PI2696
    PI26 G1 A M12   DC PNP/NPN (250mA) -25...80 °C -25...125 (145 max. 1h) °C 3A cULus EHEDG FDA  PI2697
    PI26 G1 A M12   DC PNP/NPN (250mA) -25...80 °C -25...125 (145 max. 1h) °C 3A cULus EHEDG FDA  PI2698
    PI26 G1 A M12   DC PNP/NPN (250mA) -25...80 °C -25...125 (145 max. 1h) °C 3A cULus EHEDG FDA  PI2699
    PI27 G1 / Aseptoflex Vario M12   DC PNP/NPN (250mA) -25...80 °C -25...125 (145 max. 1h) °C 3A cULus EHEDG FDA  PI2789
    PI27 G1 / Aseptoflex Vario M12   DC PNP/NPN (250mA) -25...80 °C -25...125 (145 max. 1h) °C 3A cULus EHEDG FDA  PI2796
    PI27 G1 / Aseptoflex Vario M12   DC PNP/NPN (250mA) -25...80 °C -25...125 (145 max. 1h) °C 3A cULus EHEDG FDA  PI2797
    PI27 G1 / Aseptoflex Vario M12   DC PNP/NPN (250mA) -25...80 °C -25...125 (145 max. 1h) °C 3A cULus EHEDG FDA  PI2798
    PI27 G1 / Aseptoflex Vario M12   DC PNP/NPN (250mA) -25...80 °C -25...125 (145 max. 1h) °C 3A cULus EHEDG FDA  PI2799
    PI29 G? A M12   DC PNP/NPN (250mA) -25...80 °C -25...125 (145 max. 1h) °C cULus FDA  PI2997
    PL20 用于Aseptoflex适配器 M12   3线DC ; 2线DC -25...80 °C -25...80 °C 3A cULus EHEDG FDA  PL2056
    PL20 用于Aseptoflex适配器 M12   3线DC ; 2线DC -25...80 °C -25...80 °C 3A cULus EHEDG FDA  PL2057
    PL20 用于Aseptoflex适配器 M12   3线DC ; 2线DC -25...80 °C -25...80 °C 3A cULus EHEDG FDA  PL2058
    PL26 G1 A M12   3线DC ; 2线DC -25...80 °C -25...80 °C 3A cULus EHEDG FDA  PL2656
    PL26 G1 A M12   3线DC ; 2线DC -25...80 °C -25...80 °C 3A cULus EHEDG FDA  PL2657
    PL26 G1 A M12   3线DC ; 2线DC -25...80 °C -25...80 °C 3A cULus EHEDG FDA  PL2658
    PM20 用于Aseptoflex适配器 M12   DC -25...80 °C -25...125 (145 max. 1h) °C 3A cULus EHEDG FDA  PM2056
    PM20 用于Aseptoflex适配器 M12   DC -25...80 °C -25...125 (145 max. 1h) °C 3A cCSAus cULus EHEDG FDA  PM2057
    PM20 用于Aseptoflex适配器 M12   DC -25...80 °C -25...125 (145 max. 1h) °C 3A cULus EHEDG FDA  PM2058
    PM26 G1 A M12   3线DC ; 2线DC -25...80 °C -25...125 (145 max. 1h) °C 3A cULus EHEDG FDA  PM2656
    PM26 G1 A M12   3线DC ; 2线DC -25...80 °C -25...125 (145 max. 1h) °C 3A cULus EHEDG FDA  PM2657
    PM26 G1 A M12   3线DC ; 2线DC -25...80 °C -25...125 (145 max. 1h) °C 3A cULus EHEDG FDA  PM2658
    订购编号
    LK ? 16 mm M12   DC PNP (200mA) 0...60 °C 参见技术参数表 cULus  LK1022
    LK ? 16 mm M12   DC PNP (200mA) 0...60 °C 参见技术参数表 cULus  LK1023
    LK ? 16 mm M12   DC PNP (200mA) 0...60 °C 参见技术参数表 cULus  LK1024
    LK ? 16 mm M12   DC PNP (200mA) 0...60 °C 参见技术参数表 WHG  LK1222
    LK ? 16 mm M12   DC PNP (200mA) 0...60 °C 参见技术参数表 WHG  LK1223
    LK ? 16 mm M12   DC PNP (200mA) 0...60 °C 参见技术参数表 WHG  LK1224
    LK ? 16 mm M12   DC PNP (200mA) 0...60 °C 参见技术参数表 cULus  LK3122
    LK ? 16 mm M12   DC PNP (200mA) 0...60 °C 参见技术参数表 cULus  LK3123
    LK ? 16 mm M12   DC PNP (200mA) 0...60 °C 参见技术参数表 cULus  LK3124
    LK ? 16 mm M12   DC PNP (200mA) 0...60 °C 参见技术参数表 cULus  LK8122
    LK ? 16 mm M12   DC PNP (200mA) 0...60 °C 参见技术参数表 cULus  LK8123
    LK ? 16 mm M12   DC PNP (200mA) 0...60 °C 参见技术参数表 cULus  LK8124
    LL ? 16 mm M12   DC PNP (200mA) 0...60 °C 参见技术参数表 cULus  LL8022
    LL ? 16 mm M12   DC PNP (200mA) 0...60 °C 参见技术参数表 cULus  LL8023
    LL ? 16 mm M12   DC PNP (200mA) 0...60 °C 参见技术参数表 cULus  LL8024
    LR30 G3/4 M12   DC PNP (200mA) 0...60 °C 0...80 *** °C cULus  LR3000
    易福门全国经销     IFM   全国 销售
    华东区: 张龙刚13817798194
TO:采购 公司经营品牌:施克SICK 倍加福P+F, 易福门IFM ,基恩士 罗斯蒙特(Rosemount) . 图尔克TURCK,美国 埃福创编码器AVTRON. 宜科、ABB瑞士。巴鲁夫 , SMC ,费斯托FESTO 西门子仪器仪表 销售:张龙刚 手机:13817798194 邮箱:zlgsh@hotmail.com 价格优惠!…  更多>>
上海自动有限公司
联系人:张龙刚
地址:上海松江区
邮编:201613
电话:13817798194
公司网址:http://xhzlg.b2b.youboy.com
  • Ferenc Nagy 在2024/11/29 23:20:00留言
  • 详细留言:RFQ 1-2 x Sick SCS70HLA0K01 ID: 1034069
  • 明小姐 在2015/3/26 16:05:00留言
  • 详细留言:还看了HYDAC给水泵:http://www.hydac-zh.com/gsb/ 贺德克给水泵:http://www.hydac-zh.com/gsb/ 给水泵:http://www.hydac-zh.com/gsb/ 贺德克轴向柱塞泵:http://www.hydac-zh.com/zxzsb/ HYDAC轴向柱塞泵:http://www.hydac-zh.com/zxzsb/ 轴向柱塞泵:http://www.hydac-zh.com/zxzsb/ 贺德克内啮合齿轮泵:http://www.hydac-zh.com/nniclb/ HYDAC内啮合齿轮泵:http://www.hydac-zh.com/nniclb/ 内齿轮油泵:http://www.hydac-zh.com/nniclb/ 贺德克外啮合齿轮泵:http://www.hydac-zh.com/wniclb/ HYDAC外啮合齿轮泵:http://www.hydac-zh.com/wniclb/ 外啮合齿轮泵:http://www.hydac-zh.com/wniclb/ HYDAC压力传感器:http://www.hydac-zh.com/ylcgq/ 贺德克压力传感器:http://www.hydac-zh.com/ylcgq/
  • 王力 在2014/12/10 18:16:00留言
  • 梁先生 在2014/7/17 9:23:00留言
  • 详细留言:流量传感器0-15ml/min
  • 荣玉成 在2014/4/15 14:14:00留言
  • 详细留言:压力传感器:范围不+-20Pa 范围0-50Pa 电压24VDC 电流4-20mA
