易福门全国经销 IFM 全国 销售 选型及技术参数
华东区: 张龙刚13817798194
邮箱:zlgsh@hotmail.com-5,0...100,4 inH2O M12 DC PNP/NPN cULus PG2458
G12 V4A -5...100 mbar /
-2,00...40,16 inH2O M12 DC PNP/NPN cULus PG2489
G 1 A / Aseptoflex vario V4A -1,00...10,00 bar /
-14,5...145,0 PSI M12 DC PNP/NPN 3A cULus EHEDG FDA PG2794
G 1 A / Aseptoflex vario V4A -1,000...4,000 bar /
-14,50...58,00 PSI M12 DC PNP/NPN 3A cULus EHEDG FDA PG2795
G 1 A / Aseptoflex vario V4A -0,124...2,5 bar /
-1,8...36,27 PSI M12 DC PNP/NPN 3A cULus EHEDG FDA PG2796
G 1 A / Aseptoflex vario V4A -0,05...1 bar /
-0,73...14,5 PSI M12 DC PNP/NPN 3A cULus EHEDG FDA PG2797
G 1 A / Aseptoflex vario V4A -12,4...250,0 mbar /
-5,0...100,4 inH2O M12 DC PNP/NPN 3A cULus EHEDG FDA PG2798
G 1 A / Aseptoflex vario V4A -1...1 bar /
-14,5...14,5 PSI M12 DC PNP/NPN 3A cULus EHEDG FDA PG2799
G 1 A V4A -1,00...10,00 bar /
-14,5...145,0 PSI M12 DC PNP/NPN cULus EHEDG PG2894
G 1 A V4A -1,000...4,000 bar /
-14,50...58,00 PSI M12 DC PNP/NPN cULus EHEDG PG2895
G 1 A V4A -0,05...1 bar /
-0,73...14,5 PSI M12 DC PNP/NPN cULus EHEDG PG2897
G 1 A V4A -12,4...250,0 mbar /
-5,0...100,4 inH2O M12 DC PNP/NPN cULus EHEDG PG2898
G 1 A V4A -1...1 bar /
-14,5...14,5 PSI M12 DC PNP/NPN cULus EHEDG PG2899
SPA-Varivent 型号N V4A -1,00...10,00 bar /
-14,5...145,0 PSI M12 DC PNP/NPN PH4004
G ? I V2A -1000...0 mbar M12 DC PNP
ATEX 3D PN009A
G ? I V2A -1000...1000 mbar /
cULus PN2009
?" NPT V2A -14,5...14,5 PSI M12 DC PNP/NPN
cULus PN2209
cULus PN3029
?" NPT V2A -1...1 bar /
-30...30 inHg /
-100...100 kPa 1/2" AC / 三端双向可控硅开关元件triac cULus PN4229
G ? I V2A -1000...1000 mbar M12 DC PNP/NPN cULus PN7009
?" NPT V2A -14,5...14,5 PSI /
-1000...1000 mbar M12 DC PNP/NPN cULus PN7209
G 1/8 I V2A -1000...1000 mbar /
-14,5...14,5 PSI /
-100...100 kPa M12 DC PNP/NPN cULus PN7809
G 1/8 I V2A -1...10 bar /
-14,5...145 PSI /
-0,1...1,0 MPa M12 DC PNP/NPN cULus PN7834
G 1/8 I V2A -1...1 bar M8 DC NPN cULus PQ0809
G 1/8 I V2A -1...10 bar M8 DC NPN cULus PQ0834
G 1/8 I V2A -1...1 bar M8 DC PNP cULus PQ7809
G 1/8 I V2A -1...10 bar M8 DC PNP cULus PQ7834
?" NPT A/M5I V4A -14,5...0 PSI M12 DC cULus PX3229
G ? A / M5 I V4A -1...10 bar M12 DC cULus PX3524
?" NPT A/M5I V4A -14,5...0 PSI M12 DC cULus PX9119
实际感应距离 (Sr) [mm] 10 ± 10 %
工作距离 [mm] 0...8.1
开关点偏移 [Sr的百分比] -10...10
迟滞 [Sr的百分比] 1...15
开关频率 [Hz] 400
修正系数 钢(St37) = 1 / 不锈钢约0.7 / 黄铜约0.4 / Al约0.4 / Cu约0.3
环境温度 [°C] -25...100
防护等级 IP 67, II
EMC电磁兼容
EN 60947-5-2
MTTF [年] 1365
外壳材料 黄铜 白青铜-镀层; PBT
功能显示
开关状态 LED 黄色
接口 PUR电缆 / 6 m; 4 x 0.34 mm2; 无卤素
重量 [kg] 0.371
配件(同时供货) 2个固定螺母
接线
芯线颜色
BK 黑色
BN 棕色
BU 蓝色
WH 白色
电感式传感器
II5800
IIA4010ZCPKG/6m/BH
电感式传感器
金属螺纹 M30 x 1.5易福门全国经销 IFM 全国 销售 选型及技术参数
华东区: 张龙刚13817798194
电缆
感应距离 10 mm [f]
齐平安装
Made in Germany
电气设计 DC PNP
输出功能 NO+NC
工作电压 [V] 10...36 DC
电流负载 [mA] 250 (...80 °C) / 100 (...100 °C)
短路保护 脉冲
反相保护 是
过载保护 是
电压降 [V] < 2.5
电流损耗 [mA] < 15
证 订购编号
SPA-多功能管路适配器 V4A -1,000...4,000 bar /
-14,50...58,00 PSI /
-100,0...400,0 kPa M12 DC EHEDG FDA PH7995
G 1 A V4A -1,00...25,00 bar /
-14,4...362,7 PSI /
-0,100...2,500 MPa M12 DC PNP/NPN
FDA ATEX 3G ATEX 3D PI003A
Aseptoflex 过程连接 V4A -1,00...10,00 bar /
-14,5...145,0 PSI /
-0,100...1,000 MPa M12 DC 3A cULus EHEDG FDA PI1094
Aseptoflex 过程连接 V4A -1,000...4,000 bar /
-100,0...400,0 kPa M12 DC 3A cULus EHEDG FDA PI1095
Aseptoflex 过程连接 V4A -50...1000 mbar M12 DC 3A cULus EHEDG FDA PI1097
Aseptoflex 过程连接 V4A -12,4...250,0 mbar M12 DC 3A cULus EHEDG FDA PI1098
Aseptoflex 过程连接 V4A -1000...1000 mbar M12 DC 3A cULus EHEDG FDA PI1099
G 1 A V4A -5,0...100,0 mbar M12 DC 3A EHEDG FDA PI1689
-14,5...145,0 PSI /
-0,100...1,000 MPa M12 DC 3A cULus EHEDG FDA PI1694
-100,0...400,0 kPa M12 DC 3A cULus EHEDG FDA PI1695
G 1 A V4A -0,124...2,500 bar M12 DC 3A cULus EHEDG FDA PI1696
G 1 A V4A -50...1000 mbar M12 DC 3A cULus EHEDG FDA PI1697
G 1 A V4A -12,4...250,0 mbar M12 DC 3A cULus EHEDG FDA PI1698
G 1 A V4A -1000...1000 mbar M12 DC 3A cULus EHEDG FDA PI1699
-14,5...145,0 PSI /
-0,100...1,000 MPa M12 DC PNP/NPN
3A cULus EHEDG FDA PI2094
-100,0...400,0 kPa M12 DC PNP/NPN
3A cULus EHEDG FDA PI2095
Aseptoflex 过程连接 V4A -1000...1000 mbar M12 DC PNP/NPN
3A cULus EHEDG FDA PI2099
G 1 A V4A -1,0...100,0 bar /
-15...1450 PSI /
-0,10...10,00 MPa M12 DC PNP/NPN
3A cULus EHEDG FDA PI2692
-14,4...362,7 PSI /
3A cULus EHEDG FDA PI2693
-14,5...145,0 PSI /
3A cULus EHEDG FDA PI2694
3A cULus EHEDG FDA PI2695
G 1 A V4A -1000...1000 mbar M12 DC PNP/NPN
3A cULus EHEDG FDA PI2699
-14,5...145,0 PSI /
-0,100...1,000 MPa M12 2线DC / 3线DC PNP/NPN 3A cULus EHEDG FDA PI2794
-100,0...400,0 kPa M12 2线DC / 3线DC PNP/NPN 3A cULus EHEDG FDA PI2795
G 1 A / Aseptoflex vario V4A -1000...1000 mbar /
-14,5...14,5 PSI M12 2线DC / 3线DC PNP/NPN 3A cULus EHEDG FDA PI2799
G ? A V4A -1,00...25,00 bar /
-14,4...362,7 PSI /
cULus FDA PI2993
G ? A V4A -1,00...10,00 bar /
-14,5...145,0 PSI /
cULus FDA PI2994
G ? A V4A -1,000...4,000 bar /
cULus FDA PI2995
G ? A V4A -50...1000 mbar M12 DC PNP/NPN
cULus FDA PI2997
-14,5...145,0 PSI /
-0,100...1,000 MPa M12 DC PNP/NPN 3A cULus EHEDG FDA PI7094
G 1 A V4A -1,0...150,0 bar M12 DC PNP/NPN
EHEDG FDA PY2692
订购编号
-14,4...362,7 PSI /
-14,5...145,0 PSI /
-14,5...145,0 PSI /
-14,5...145,0 PSI /
-15...1450 PSI /
-14,4...362,7 PSI /
-14,5...145,0 PSI /
-14,5...145,0 PSI /
-14,4...362,7 PSI /
cULus FDA PI2993
-14,5...145,0 PSI /
cULus FDA PI2994
cULus FDA PI2995
cULus FDA PI2997
-14,5...145,0 PSI /
EHEDG FDA PY2692
购编号
Aseptoflex 过程连接 V4A -1,00...25,00 bar /
-14,4...362,7 PSI /
-0,100...2,500 MPa M12 DC PNP 3A cULus EHEDG FDA PIM093
-14,5...145,0 PSI /
-0,100...1,000 MPa M12 DC PNP 3A cULus EHEDG FDA PIM094
-14,4...362,7 PSI /
-0,100...2,500 MPa M12 DC PNP 3A cULus EHEDG FDA PIM693
-14,5...145,0 PSI /
-14,4...362,7 PSI /
-14,4...362,7 PSI /
-0,100...2,500 MPa M12 DC 3A cULus EHEDG FDA PI1093
-14,5...145,0 PSI /
-14,4...362,7 PSI /
-0,100...2,500 MPa M12 DC 3A cULus EHEDG FDA PI1693
-14,5...145,0 PSI /
-14,4...362,7 PSI /
3A cULus EHEDG FDA PI2093
-14,5...145,0 PSI /
-15...1450 PSI /
-14,4...362,7 PSI /
-14,5...145,0 PSI /
G 1 A / Aseptoflex vario V4A -1,00...25,00 bar /
-14,4...362,7 PSI /
-0,100...2,500 MPa M12 2线DC / 3线DC PNP/NPN 3A cULus EHEDG FDA PI2793
-14,5...145,0 PSI /
-14,4...362,7 PSI /
cULus FDA PI2993
-14,5...145,0 PSI /
cULus FDA PI2994
cULus FDA PI2995
cULus FDA PI2997
-14,4...362,7 PSI /
-0,100...2,500 MPa M12 DC PNP/NPN 3A cULus EHEDG FDA PI7093
-14,5...145,0 PSI /
-14,4...362,7 PSI /
-0,100...2,500 MPa M12 DC PNP/NPN cULus FDA PI7993
Aseptoflex 过程连接 V4A -1,0...25 bar /
-15...363 PSI /
-0,1...2,5 MPa M12 3线DC ; 2线DC 3A cULus EHEDG FDA PL2053
G 1 A V4A -1...100 bar /
-10...1450 PSI /
-0,1...10 MPa M12 3线DC ; 2线DC 3A cULus EHEDG FDA PL2652
G 1 A V4A -1,0...25 bar /
-15...363 PSI /
-0,1...2,5 MPa M12 3线DC ; 2线DC 3A cULus EHEDG FDA PL2653
Aseptoflex 过程连接 V4A -1...25 bar /
-15...363 PSI /
-0,1...2,5 MPa M12 DC 3A cULus EHEDG FDA PM2053
Aseptoflex 过程连接 V4A -0,99...4,00 bar /
-14,4...58,0 PSI /
-99...400 kPa M12 DC 3A cULus EHEDG FDA PM2055
G 1 A V4A -1...25 bar /
-15...363 PSI /
-0,1...2,5 MPa M12 3线DC ; 2线DC 3A cULus EHEDG FDA PM2653
EHEDG FDA PY2692
编号
-14,4...362,7 PSI /
-14,5...145,0 PSI /
-14,4...362,7 PSI /
-14,5...145,0 PSI /
-0,100...1,000 MPa M12 DC PNP 3A cULus EHEDG FDA PIM694
-15...363 PSI /
-0,1...2,5 MPa M12 DC PNP/NPN
3A cULus EHEDG FDA PF2053
G 1 A V4A -0,99...1,00 bar /
-30...30 inHg /
-99...100 kPa M12 DC PNP/NPN
3A cULus EHEDG FDA PF2609
G 1 A V4A -1,0...100 bar /
-10...1450 PSI /
-0,10...10,0 MPa M12 DC PNP/NPN
3A cULus EHEDG FDA PF2652
-15...363 PSI /
3A cULus EHEDG FDA PF2653
G ? A V4A -1,0...25 bar /
-15...363 PSI /
cULus FDA PF2953
G 1 A / Aseptoflex vario V4A -5,0...100,0 mbar /
-2,0...40,15 inH2O M12 DC PNP/NPN 3A EHEDG FDA PG2789
-14,4...362,7 PSI M12 DC PNP/NPN 3A cULus EHEDG FDA PG2793
G 1 A V4A -5,0...100,0 mbar /
-2,0...40,15 inH2O M12 DC PNP/NPN cULus EHEDG PG2889
-14,4...362,7 PSI M12 DC PNP/NPN cULus EHEDG PG2893
-14,4...362,7 PSI /
-14,4...362,7 PSI /
-14,5...145,0 PSI /
-14,4...362,7 PSI /
-14,5...145,0 PSI /
-14,4...362,7 PSI /
-14,4...362,7 PSI /
-14,5...145,0 PSI /
-14,4...362,7 PSI /
cULus FDA PI2993
-14,5...145,0 PSI /
cULus FDA PI2994
cULus FDA PI2995
cULus FDA PI2997
-14,4...362,7 PSI /
-14,5...145,0 PSI /
-14,4...362,7 PSI /
-15...363 PSI /
-10...1450 PSI /
-15...363 PSI /
-15...363 PSI /
-14,4...58,0 PSI /
-15...363 PSI /
EHEDG FDA PY2692
订购编号
-14,4...362,7 PSI /
-14,5...145,0 PSI /
-14,4...362,7 PSI /
-14,5...145,0 PSI /
G ? I V4A -1000...0 mbar M12 DC PNP
cULus PE3029
G ? I V2A -1000...1000 mbar M12 DC PNP/NPN cULus PE7009
-15...363 PSI /
-30...30 inHg /
-10...1450 PSI /
-15...363 PSI /
-15...363 PSI /
cULus FDA PF2953
-14,4...362,7 PSI /
-14,4...362,7 PSI /
-14,5...145,0 PSI /
-14,4...362,7 PSI /
-14,5...145,0 PSI /
-14,4...362,7 PSI /
-14,5...145,0 PSI /
-15...1450 PSI /
-14,4...362,7 PSI /
-14,5...145,0 PSI /
-14,4...362,7 PSI /
-14,5...145,0 PSI /
-14,4...362,7 PSI /
-14,5...145,0 PSI /
-14,4...362,7 PSI /
-15...363 PSI /
-10...1450 PSI /
-15...363 PSI /
-15...363 PSI /
-14,4...58,0 PSI /
-15...363 PSI /
EHEDG FDA PY2692
编号
G ? I V2A -1...0 bar M12 DC cULus PA3029
?" NPT V2A -1...0 bar M12 DC cULus PA6229
G ? I V2A -1...0 bar M12 DC cULus PA9029
cULus PE3029
G12 V4A -1...25 bar /
-14,5...362,5 PSI M12 DC PNP/NPN cULus PG2453
G12 V4A -1...10 bar /
-14,4...145 PSI M12 DC PNP/NPN cULus PG2454
G12 V4A -1...4 bar /
-14,5...58 PSI M12 DC PNP/NPN cULus PG2455
G12 V4A -0,05...1 bar /
-0,72...14,5 PSI M12 DC PNP/NPN cULus PG2457
G12 V4A -12,5...250 mbar /
G 1 A V4A -0,124...2,5 bar /
-1,8...36,27 PSI M12 DC PNP/NPN cULus EHEDG PG2896
cULus PN2009
cULus PN2209
cULus PN3029
-30...30 inHg /
订购编号
G ? A / M5 I V2A -1...1 bar M12 DC cULus PA3509
cULus PE3029
G12 V4A -1...1 bar /
-14,52...14,52 PSI M12 DC PNP/NPN cULus PG2409
G12 V4A -0,125...2,5 bar /
-1,8...36,25 PSI M12 DC PNP/NPN cULus PG2456
-15...363 PSI /
-30...30 inHg /
-10...1450 PSI /
-15...363 PSI /
-15...363 PSI /
cULus FDA PF2953
-14,5...145,0 PSI /
-15...1450 PSI /
-14,4...362,7 PSI /
-14,5...145,0 PSI /
华东区: 张龙刚13817798194
