上海自动有限公司
  • WTB27-3(标准型)
  • 发布时间:2012/3/16 10:36:37   修改时间:2012/3/16 10:36:37 浏览次数:1619
  •  WTB27-3(标准型)
      公司经营品牌:施克SICK 倍加福P+F, 易福门IFM ,罗斯蒙特 . 图尔克TURCK,美国 埃福创编码器AVTRON. 宜科、ABB瑞士。巴鲁夫 , SMC ,费斯托FESTO
    销售:张龙刚
    手机:13817798194
    邮箱:zlgsh@hotmail.com
     WTB27-3(标准型)
    最近更新:2006.11.21
    特性与规格 资料下载
     Model Name Part Number Dimensions (W x H x D) Connection type Sensing range min ... max
     WTB27-3E2641 1027747 24,6 x 80,6 x 54 mm Connector, Q6, 6-pin, DC 30 ... 1.100 mm
     WTB27-3F2641 1027746 24,6 x 80,6 x 54 mm Connector, Q6, 6-pin, DC 30 ... 1.100 mm
     WTB27-3P2441 1027744 24,6 x 80,6 x 54 mm Connector, M12, 4-pin 30 ... 1.100 mm
     WTB27-3P2443 1027745 24,6 x 80,6 x 54 mm Connector, M12, 4-pin 30 ... 1.100 mm
     WTB27-3P3741 1027748 24,6 x 80,6 x 54 mm Cable with plug, Q7, 7-pin, DC, 150 mm 30 ... 1.100 mm
     WTB27-3R2641 1027750 24,6 x 80,6 x 54 mm Connector, Q6, 6-pin, AC/UC 30 ... 1.100 mm
     WTB27-3S1541 1027749 24,6 x 80,6 x 54 mm Cable, 2 m 30 ... 1.100 mm
     WTB27-3S3741 1027751 24,6 x 80,6 x 54 mm Cable with plug, Q7, 7-pin, AC/UC, 150 mm 30 ... 1.100 mm
     WTB27-3E2411 1027755 24,6 x 80,6 x 54 mm Connector, M12, 4-pin 30 ... 1.600 mm
     WTB27-3E2611 1027757 24,6 x 80,6 x 54 mm Connector, Q6, 6-pin, DC 30 ... 1.600 mm
     WTB27-3F2411 1027753 24,6 x 80,6 x 54 mm Connector, M12, 4-pin 30 ... 1.600 mm
     WTB27-3F2611 1027756 24,6 x 80,6 x 54 mm Connector, Q6, 6-pin, DC 30 ... 1.600 mm
     WTB27-3P1111 1027752 24,6 x 80,6 x 54 mm Cable, 2 m 30 ... 1.600 mm
     WTB27-3P2411 1025994 24,6 x 80,6 x 54 mm Connector, M12, 4-pin 30 ... 1.600 mm
     WTB27-3P2421 1027754 24,6 x 80,6 x 54 mm Connector, M12, 4-pin 30 ... 1.600 mm
     WTB27-3P3711 1027758 24,6 x 80,6 x 54 mm Cable with plug, Q7, 7-pin, DC, 150 mm 30 ... 1.600 mm
     WTB27-3N2413 1027761 24,6 x 80,6 x 54 mm Connector, M12, 4-pin 30 ... 1.600 mm
     WTB27-3P1113 1027759 24,6 x 80,6 x 54 mm Cable, 2 m 30 ... 1.600 mm
     WTB27-3P2413 1027760 24,6 x 80,6 x 54 mm Connector, M12, 4-pin 30 ... 1.600 mm
     WTB27-3R2611 1027763 24,6 x 80,6 x 54 mm Connector, Q6, 6-pin, AC/UC 30 ... 1.600 mm
     WTB27-3S1511 1027762 24,6 x 80,6 x 54 mm Cable, 2 m 30 ... 1.600 mm
     WTB27-3S3711 1027764 24,6 x 80,6 x 54 mm Cable with plug, Q7, 7-pin, AC/UC, 150 mm 30 ... 1.600 mm
    WT36(标准型)
    最近更新:2006.11.21
    特性与规格 资料下载
     WT36-N210 1010109 36 x 85 x 100 mm Cable gland, Terminal, PG11 200 ... 800 mm
     WT36-N410 1011109 36 x 85 x 77 mm Connector, M12, 4-pin 200 ... 800 mm
     WT36-N710 1006370 36 x 85 x 77 mm Connector, Q7, 7-pin, DC 200 ... 800 mm
     WT36-P210 1010108 36 x 85 x 100 mm Cable gland, Terminal, PG11 200 ... 800 mm
     WT36-P410 1011108 36 x 85 x 77 mm Connector, M12, 4-pin 200 ... 800 mm
     WT36-P710 1006047 36 x 85 x 77 mm Connector, Q7, 7-pin, DC 200 ... 800 mm
     WT36-R210 1010110 36 x 85 x 77 mm Cable gland, Terminal, PG11 200 ... 800 mm
     WT36-R710 1005927 36 x 85 x 77 mm Connector, Q7, 7-pin, AC/UC 200 ... 800 mm
    W15
    最近更新:2010.04.09
    特性与规格 资料下载 创新的设计,提供更强的灵活性, W15迷你型光电开关的优势:
    高性能的背景遮蔽功能,可靠地检测不同颜色、不同质地的物体
    特殊的外壳设计,适合方形传感器安装方式(侧边安装孔)和圆柱形传感器安装方式(M18螺纹)
    带卡环,可以齐平安装
    透明背部外壳,保证LED显示灯可以很清晰的看见,哪怕是从背部
    外部干扰光线遮蔽
    能有效屏蔽其它传感器的干扰
    有效抑制电磁干扰
    多种输出配置(如PNP/NPN,亮通/暗通)
    W15迷你型光电开关系列包括:
    WTB15漫反射式光电开关,带Pin-point LED
    WTE15增强型漫反射式光电开关
    WL15镜反射式光电开关
    WSE1对射式光电开关
    应用领域
    检测不同颜色、不同质地的物体,如包装行业
    从侧边检测,如输送系统
    MHTB15/MHTB15V
    最近更新:2010.04.09
    特性与规格 资料下载 MHTB15漫反射开关系列,检测距离长拥有卓越的背景遮蔽性能。
    保证检测可靠性:对于6%反射率的物体检测距离最长至150mm,对于90%反射率的物体检测距离最长至300mm
    通过电位计设定
    PInPoint技术和同轴外壳
    两种类型:塑料外壳的MHTB15和用于食品饮料的MHTB15V
    小范围内对背景干扰的良好抑制
    在有限的安装空间内仍有很好的性能
    小光点,安装和调校简便,对细小物体检测更可靠
    盲区小
    OES3芯片和散射LED技术提高抗干扰性能
    包装行业应用
    检测所有包装材料
    不受背景范围外物体的影响
    处理线和机器人设备
    检测移动背景之前的小部件
    夹具定位
    可靠检测小部件
    电子行业应用
    原材料检测,到位检测,定位
    PC板检测和定位
    物流自动化
    原材料检测,到位检测,定位
    即便是黑色和闪亮物体都能可靠检测
    在有限的安装空间内没有盲区,极小的外形尺寸
    食品饮料行业
    W11-2
    最近更新:2010.04.09
    特性与规格 资料下载 值得信赖的W11-2光电开关家族:
    小巧,高强度塑料外壳
    2米电缆或可旋转的M12接线插头
    燕尾槽式安装
    卓越的环境光线屏蔽
    具“Pinpoint”技术的类激光红光光源
    工作温度范围从-30°C到+ 60°C
    UL / ECOLAB / IP 69K认证
    针对玻璃/透明物体检测的“同轴光镜头”光电开关
    最远可达1100mm的“背景遮蔽”功能
    “前景遮蔽”功能
    带“自学习(Teach-in)”功能的高效能检测
    W11-2光电开关的应用范围:
    检测、计数和定位各种透明物体、薄膜和瓶
    食品饮料行业
    乳品行业
    包装行业
    仓储物流行业
    检测、计数和定位各种纸箱、盒、包裹和货盘
    包装行业
    食品饮料行业
    处理线和仓储系统
    分拣物流行业
    定位、检测、筛选和计数各种盖、框、盆,以及各种类型、颜色和尺寸的食品
    包装行业
    木材加工行业
    装配系统
    烘焙工艺
    VTB18
    最近更新:2006.11.21
    特性与规格 资料下载
     VTB18-4N1212 6030190  Cable, 2 m 25 ... 140 mm
     VTB18-4N1240 6030191  Connector, M12, 4-pin 25 ... 140 mm
     VTB18-4P1212 6030188  Cable, 2 m 25 ... 140 mm
     VTB18-4P1240 6030189  Connector, M12, 4-pin 25 ... 140 mm
    VTB18
    最近更新:2006.11.21
    特性与规格 资料下载
    WT45(标准型)
    最近更新:2006.11.21
    特性与规格 资料下载 坚固金属外壳
    红外光源
    可调校的背景遮蔽功能
    加热防雾镜片(可选)
    无技术参数! WT34(标准型)
    最近更新:2006.11.21
    特性与规格 资料下载 坚固塑料外壳
    可见红色光源
    可进行精确调整的背景屏蔽
    可旋转900的M16固定螺孔
    选择式时间延迟(可选)
    无技术参数! WT36(标准型)
    最近更新:2006.11.21
    特性与规格 资料下载
      WTB27-3(标准型)
    最近更新:2006.11.21
    特性与规格 资料下载
    WT260(标准型)
    最近更新:2006.11.21
    特性与规格 资料下载 可靠检测黑色物体
    检测距离可无级调校
    端子排或4针/5针M12插头
    测试输入端
    VMA污染信号输出
     WT260-P260 6009471 25 x 77,5 x 63 mm Cable gland 0 ... 380 mm
     WT260-P460 1011540 25 x 77,5 x 63 mm Connector, M12, 4-pin 0 ... 380 mm
     WT260-P560 1011541 25 x 77,5 x 63 mm Connector, M12, 5-pin 0 ... 380 mm
     WT260-R260 6009472 25 x 77,5 x 63 mm Cable gland 0 ... 380 mm
     WT260-S260 6009473 25 x 77,5 x 63 mm Cable gland 0 ... 380 mm
     WT260T-N290 6021921 25 x 78 x 63 mm Cable gland 70 ... 2.100 mm
     WT260T-N490 6021922 25 x 78 x 63 mm Connector, M12, 4-pin 70 ... 2.100 mm
     WT260T-P290 6021919 25 x 78 x 63 mm Cable gland 70 ... 2.100 mm
     WT260T-P490 6021920 25 x 78 x 63 mm Connector, M12, 4-pin 70 ... 2.100 mm
     WT260T-R290 6021924 25 x 78 x 63 mm Cable gland 70 ... 2.100 mm
     WT260T-S290 6021923 25 x 78 x 63 mm Cable gland 70 ... 2.100 mm
    WT250(标准型)
    最近更新:2006.11.21
    特性与规格 资料下载 背景遮蔽(HGA)
    对物体检测距离实现无级调校,带位置指示器(2700C)的检测距离控制(2U)
    可见红色光源辅助对准
    通用电压
    无技术参数! WT24-2Exi(标准型)
    最近更新:2006.11.21
    特性与规格 资料下载 红外光源
    可调校的背景遮蔽功能
    防爆等级EEX ia IIC T6
    可旋转900的插头
    端子座
     WT24-2X260 1025684 27 x 87,5 x 65 mm Cable gland, Terminal, M16 100 ... 2.000 mm
     WT24-2X460 1025683 27 x 87,5 x 65 mm Connector, M12, 4-pin 100 ... 2.000 mm
     SICK传感器工业用自动化传感器漫反射式光电开关背景遮蔽BGS
    探测指定扫描范围内的物体,扫描范围外的物体则探测不到。
    激光:
    带激光的小型接近开关:WTB 190(T) L, WT 9L, WT 12L-2
    带激光的标准接近开关:WT 27-2
    执行器-传感器接口
    带执行器-传感器接口小型接近开关:WT 12-2
    带执行器-传感器接口的标准接近开关:WT 27-2
    用于依照94/9/EC指令划分的危险区域的传感器(ATEX):
    用于危险区域的标准接近开关: WT 24-2Exi
    用于危险区域的标准接近开关: WTB 27-3 Ex
    选择表
    产品分类 扫描范围(毫米) 光类型 电源电压 连接
    微型接近开关
    WT 2 1 - 30 红光 DC 电缆/电缆宽度插头
    WT 4-3 4 - 150 红光 DC 插头/电缆
    WT 140-2 2 - 500 红光 DC 插头/电缆
    WT 150 2 - 100 红光 DC
    DC 插头/电缆
    小型接近开关
    WTB 160T 15 - 150 红光 DC 插头/电缆
    WTB 190T 50 - 300 红光 DC 插头/电缆
    激光WTB190(T) 10 - 450 激光 DC 插头/电缆
    WT 9-2 30 - 250 红光/红光外线 DC 插头/电缆
    激光WT 9L 30 - 150 激光 DC 插头
    WT 11 20 - 250 红光 DC 插头/电缆
    WT 12-2 20 - 250 红光/红光外线 DC 插头/电缆
    激光WT 12L-2 20 - 200 激光 DC 插头
    WT 18-3 50 - 1000 红光 DC 插头/电缆
    标准接近开关
    WT 24-2 100 - 2500 红光/红光外线 DC / UC 插头/终端
    WT24-2 Exi 100 - 2000 红光外线 NAMUR 插头/终端
    WT 250 5 - 600 红光 DC / UC 插头/电缆
    WT 260 0 - 380 红光外线 DC / UC 插头/终端
    WTB 27-3 30 - 1600 红光/红光外线 DC / UC 插头/电缆
    WTB 27-3 Ex 30 - 1600 红光外线 DC 电缆
    WT 30 100 / 200 / 300 i
    红光外线 DC 终端
    WT 34 100 - 2500 红光/红光外线 DC / UC 插头/终端
    WT 36 200 - 800 红光外线 DC / UC 插头/终端
    WT 45 400 - 2000 红光外线 DC / UC 终端
    圆柱形接近开关
    VTB 18 25 - 140 红光 DC 插头/电缆
    销售:张龙刚
    手机:13817798194
TO:采购 公司经营品牌:施克SICK 倍加福P+F, 易福门IFM ,基恩士 罗斯蒙特(Rosemount) . 图尔克TURCK,美国 埃福创编码器AVTRON. 宜科、ABB瑞士。巴鲁夫 , SMC ,费斯托FESTO 西门子仪器仪表 销售:张龙刚 手机:13817798194 邮箱:zlgsh@hotmail.com 价格优惠!…  更多>>
上海自动有限公司
联系人:张龙刚
地址:上海松江区
邮编:201613
电话:13817798194
公司网址:http://xhzlg.b2b.youboy.com
  • Ferenc Nagy 在2024/11/29 23:20:00留言
  • 详细留言:RFQ 1-2 x Sick SCS70HLA0K01 ID: 1034069
  • 明小姐 在2015/3/26 16:05:00留言
  • 详细留言:还看了HYDAC给水泵:http://www.hydac-zh.com/gsb/ 贺德克给水泵:http://www.hydac-zh.com/gsb/ 给水泵:http://www.hydac-zh.com/gsb/ 贺德克轴向柱塞泵:http://www.hydac-zh.com/zxzsb/ HYDAC轴向柱塞泵:http://www.hydac-zh.com/zxzsb/ 轴向柱塞泵:http://www.hydac-zh.com/zxzsb/ 贺德克内啮合齿轮泵:http://www.hydac-zh.com/nniclb/ HYDAC内啮合齿轮泵:http://www.hydac-zh.com/nniclb/ 内齿轮油泵:http://www.hydac-zh.com/nniclb/ 贺德克外啮合齿轮泵:http://www.hydac-zh.com/wniclb/ HYDAC外啮合齿轮泵:http://www.hydac-zh.com/wniclb/ 外啮合齿轮泵:http://www.hydac-zh.com/wniclb/ HYDAC压力传感器:http://www.hydac-zh.com/ylcgq/ 贺德克压力传感器:http://www.hydac-zh.com/ylcgq/
  • 王力 在2014/12/10 18:16:00留言
  • 梁先生 在2014/7/17 9:23:00留言
  • 详细留言:流量传感器0-15ml/min
  • 荣玉成 在2014/4/15 14:14:00留言
  • 详细留言:压力传感器:范围不+-20Pa 范围0-50Pa 电压24VDC 电流4-20mA
