Thru-beam sensor
LA31/LK31/31/115 Operating voltage AC / DC, Highly visible LED, Protection class II, Relay output, Compact and stable housing, Construction type(S2): Rectangular type, Housing: Polycarbonate, Effective detection range: 0 ... 30 m, Light type: modulated visible red light , 630 nm, Operating voltage: 24 ... 240 V AC 12 ... 240 V DC, Signal output: Relay, 1 alternator, Connection: Emitter: 2 m fixed cable , 2-wire Receiver: 2 m fixed cable , 5-wire, Protection degree: IP67
公司经营品牌:施克SICK 倍加福P+F, 易福门IFM ,基恩士罗斯蒙特(Rosemount) . 图尔克TURCK,美国 埃福创编码器AVTRON. 宜科、ABB瑞士。巴鲁夫 , SMC ,费斯托FESTO
西门子仪器仪表
销售:张龙刚
手机:13817798194
邮箱:zlgsh@hotmail.com
Thru-beam sensor
LA31/LK31/16/25/31/115 Operating voltage AC / DC, Highly visible LED, Protection class II, Relay output, Compact and stable housing, Construction type(S2): Rectangular type, Housing: Polycarbonate, Effective detection range: 0 ... 30 m, Light type: modulated visible red light , 630 nm, Operating voltage: 24 ... 240 V AC 12 ... 240 V DC, Signal output: Relay, 1 alternator, Connection: Emitter: 2 m fixed cable , 2-wire Receiver: 2 m fixed cable , 5-wire, Protection degree: IP67
Thru-beam sensor
LA31/LK31/25/31/115 Operating voltage AC / DC, Highly visible LED, Protection class II, Relay output, Compact and stable housing, Construction type(S2): Rectangular type, Light type: modulated visible red light , 630 nm, Operating voltage: 24 ... 240 V AC 12 ... 240 V DC, Signal output: Relay, 1 alternator, Connection: Emitter: 2 m fixed cable , 2-wire Receiver: 2 m fixed cable , 5-wire, Protection degree: IP67
Thru-beam sensor
LA31/LK31/25/31/115 SET Photoelectric sensor for detecting people, objects and vehicles, Sturdy, waterproof plastic housing , Version for universal voltages, Good optical performance despite small housing size, Not sensitive to ambient light, Construction type(S2): Rectangular type, Housing: Polycarbonate, Effective detection range: 0 ... 30 m, Light type: modulated visible red light , 630 nm, Operating voltage: 24 ... 240 V AC 12 ... 240 V DC, Signal output: 1 relay output, 1 alternator
Thru-beam sensor
LA31/LK31/25/31/115 SET2 Photoelectric sensor for detecting people, objects and vehicles, Sturdy, waterproof plastic housing , Version for universal voltages, Good optical performance despite small housing size, Not sensitive to ambient light, Construction type(S2): Rectangular type, Housing: Polycarbonate, Effective detection range: 0 ... 30 m, Light type: modulated visible red light , 630 nm, Operating voltage: 24 ... 240 V AC 12 ... 240 V DC, Signal output: Relay, 1 alternator
Thru-beam sensor
Accessory of 文件名称
RL31-54/115/136 Retroreflective sensor
LA31/LK31/16/25/31/115 Thru-beam sensor
RL31-54/25/73c/136 Retroreflective sensor
RL31-8-1200-RT/73c/136 Diffuse mode sensor
RL31-8-1200-RT/59/73c/136 Diffuse mode sensor
RL31-8-HGU-300-RT/73c/136 Convergent mode sensor
RL31-8-HGU-300-RT/59/73c/136 Convergent mode sensor
LD31/LV31/73c/76a/136 Thru-beam sensor
LD31/LV31/76a/115/136 Thru-beam sensor
LD31/LV31/25/73c/76a/136 Thru-beam sensor
RLK31-6/31/115 Retroreflective sensor
RLK31-6/25/31/115 Retroreflective sensor
RLK31-54/31/115 Retroreflective sensor
RLK31-54/25/31/115 Retroreflective sensor
RLK31-8-1200-RT/31/115 Diffuse mode sensor
RLK31-8-1200-RT/31/59/115 Diffuse mode sensor
LA31/LK31/31/115 Thru-beam sensor
LA31/LK31/25/31/115 Thru-beam sensor
RLK31-54/31/33/115 Retroreflective sensor
RL31-54/73c/136 Retroreflective sensor
RL31-8-HGU-300-RT/115b/136 Convergent mode sensor
RL31-54/115/136-5M Retroreflective sensor
RLK31-54/25/31/33/115-5M Retroreflective sensor
RLK31-8-2500-IR/31/115 Diffuse mode sensor
RLK31-8-2500-IR/31/59/115 Diffuse mode sensor
RLK31-8-2500-IR/31/33/115-5M Diffuse mode sensor
RL31-8-2500-IR/73c/136 Diffuse mode sensor
RL31-8-2500-IR/115/136 Diffuse mode sensor
LC10 地磁线圈控制器
出入口车辆检测
● 自动补偿温度、湿度变化
● 线圈破损、短路指示
● 易维护,配置方便
LT(K)2-8-HS 系列光电传感器
安装与栅栏下,车辆防夹
● 可靠检测不规则车辆表面
● 长距离检测,无须反射板
● 背景抑制和背景分析功能
RMS-G-RC 雷达传感器
工业门启动触发
● 微波感应原理,感应度可调
● 通过遥控器设定,方便简单
● 可以区别人员和车辆
LA31/LK31 系列对射光电传感器
工业门车辆防夹
● 长距离检测,可达30 m
● 高性价比
● 交直流两用,继电器输出ML100 系列光电
检票通道入口,检测人员
● 紧凑的外型
● 合适的发射角,方便对齐 柜员机系统
● 红外光,检测稳定
Proscan 光电传感器
车门防夹,顾客检测
● 自学习功能 公司经营品牌:施克SICK 倍加福P+F, 易福门IFM ,基恩士罗斯蒙特(Rosemount) . 图尔克TURCK,美国 埃福创编码器AVTRON. 宜科、ABB瑞士。巴鲁夫 , SMC ,费斯托FESTO
西门子仪器仪表
销售:张龙刚
手机:13817798194
● 自动适应新背景
● 铁路和汽车认证
AIR30 系列光电
车门防夹
● 带有背景抑制或背景分析功能
● 机械式调节检测距离
● 包装内带安装支架
巴士、火车自动门ML29 系列对射光电传感器
车门防夹
● 小巧的体积,适合安装于门内
● 合适的发射角,易于安装
● 红外光,检测稳定FLT-D 光电传感器
平移门启动触发
● 启动、防夹一体式
● 多达20种感应模式
● 感应区域设定
ML29/BB10 系列对射型光电传
旋转门、平移门防夹
● 小巧的体积,适合安装于门内
● 合适的发射角,易于安装
● 红外光,检测稳定
RMS-M,D 雷达传感器
平移门,旋转门开门启动
● 微波雷达传感器,感应度可调
● 交通抑制功能
● 可选配遥控器设定TOPSCAN系列光电传感器
旋转门、平移门防夹
● 模块化设计,适应不同规格的门
● 测试输入功能
● 背景抑制和背景分析
AIR30 系列光电传感器
旋转门防夹
● 带有背景抑制或背景分析功能
● 机械式调节检测距离
● 包装内带安装支架RHI90 旋转编码器
电梯速度、方向控制 WCS3R 编码系统/VDM70 激光测距
● 高分辨率 电梯速度、方向、高度控制
● 安装简单 ● 绝对位置检测
● 外形坚固 ● 无接触、无磨损,运行可靠
● 高精度、高响应时间
OBE24 槽型光电开关
电梯平层控制
AL2109 电梯光幕
● 坚固的外壳
电梯门防夹
● 高亮度指示灯
● 可变交叉光束,最多可达135束
● 高防护等级
● 高抗外界光能力
● 无附加控制器
NBN5-F7 接近开关
电梯门机开关到位确认
LA31/LK31 系列对射光电传感器NCB2-12GM35 系列接近开关
电机测速
● 齐平安装,体积小巧
● 耐高温,可达100℃
● SIL2的安全完整性等级
NBN40-L2 系列接近开关
扶梯梯级丢失检测
● 长距离检测
● 超亮指示灯,各个角度都可看到
● 感应面可五个方向选择,安装灵活
RLK31-8-2500 系列漫反射光电传
NBB4-12GM40 系列接近开关
扶梯启动触发
扶手带测速
● 长距离漫反射光电,可调感应距离
● 体积小巧,坚固
● 坚固的外壳,良好的性价比
● 齐平安装,适合狭小空间
● 可选背景抑制功能型号(RLK28-8-H
● 安装简便GD18/GV18 & ML29 系列对射型光电传感器
扶梯启动触发
● 合适的扩散角,易于对齐
● 小巧的外形,便于安装
● IP67,可用于户外场合
Pro_Model多圈绝对值编码器AVM58-0工业标准的住房58毫米,30位多圈,数据传输高达2 MBaud的,光隔离RS 422接口,伺服或夹紧法兰多圈绝对值编码器AVM58-H工业标准住房58毫米,30位多圈,硬件编码器,数据传输高达2 MBaud的,光隔离RS 422接口多圈绝对值编码器AVM58 - K工业标准住房58毫米,30位多圈,数据传输高达2 MBaud的,光隔离RS 422接口,伺服或夹紧法兰多圈绝对值/增量编码器AVM58I YY1AAA0GY-1213部分。编号:221679,工业标准的住房58毫米,25位多圈,1024 PPR,增量,数据传输高达2 MBaud的,光隔离双极型接口,输出类型:A和B:推拉式,增量
AVM58N-011AAAHGN-1212
AVM58N-032K1RPGN-1212
AVM58N-011ABR0GN-1212
AVM58N-011AAR0GN-1212
AVM58N-011K1R0GN-1213
AVM58N-032AAR0GN-1212
AVM58N-032K1R0GN-1212
AVM58N-023AARPGN-1212
AVM58N-032AAR0BN-1213
AVM58N-011ABR0BN-1213 BVM58多圈绝对值编码器CVS58S单圈绝对值编码器RVI58N-*******6通用的增量型编码器RVI58N******* 1特殊应用的增量型编码器RVI58N-******* X增量编码器的特殊应用RVI58N-******* X通用增量型编码器RVI84增量式旋转编码器14-14361增量式旋转编码器14-14366增量式旋转编码器FVS58单圈绝对值编码器FVM58多圈绝对值编码器EVS58-TZ单圈绝对值编码器EVM58-TZ多圈绝对值编码器RVI58X******* 1增量式旋转编码器RVI58X-*******6增量式旋转编码器RVI58X-******* X增量式旋转编码器EVM58-PZ多圈绝对值编码器EVS58-PZ单圈绝对编码器EVM58-PN多圈绝对值编码器“EVS58-PN单圈绝对编码器BVM58多圈绝对值编码器BVS58单圈绝对值编码器RVI58N-*******6特殊应用的增量型编码器CVM58S多圈绝对值编码器EVM58工业区多圈绝对编码器RVS58N-*******?增量式旋转编码器EVS58工业区单圈绝对编码器PVS58单圈绝对值编码器PVM58多圈绝对值编码器DVS58单圈绝对值编码器DVM58多圈绝对值编码器CVS58单圈绝对值编码器CVM58多圈绝对值编码器AVS58-0单圈绝对值编码器AVM58-0多圈绝对值编码器AVS58 - K单圈绝对编码器AVM58 - K多圈绝对值编码器AVS58-H的单圈绝对值编码器RVI58N******* 1通用增量型编码器RVI78增量式旋转编码器TVI58N增量式旋转编码器AVM58-H的多圈绝对值编码器RVI58L增量式旋转编码器14-1436X的增量式旋转编码器
AVM58N-011K1R0BN-1213
AVM58N-032K1R0BN-1212
AVM58N-011K1R0BN-1212
AVM58N-011K1R0GN-1212
AVM58N-032K1R0GN-1213 公司经营品牌:施克SICK 倍加福P+F, 易福门IFM ,基恩士罗斯蒙特(Rosemount) . 图尔克TURCK,美国 埃福创编码器AVTRON. 宜科、ABB瑞士。巴鲁夫 , SMC ,费斯托FESTO
西门子仪器仪表
销售:张龙刚
手机:13817798194
