上海自动有限公司
  • 库伯勒KUBLER功能安全控制器14 incl. 8 OSSD
  • 发布时间:2012/8/20 14:15:53   修改时间:2012/8/20 14:15:53 浏览次数:2334
  • 功能安全控制器
    Safety-MS1, Speed for 1 axis
    Safe DI: 14 incl. 8 OSSD
    Safe DO: 2
    安全继电器输出: 1
    编码器接口: 2
     欢迎进入长度和角度测量、数显和计数、信号传输技术的世界
    库伯勒KUBLER
     销售:张龙刚
    手机:13817798194
    邮箱:
    zlgsh@hotmail.com
    Safety-MSP1, Speed a
    nd position for 1 axis
    Safe DO: 2
    安全继电器输出: 1
    编码器接口: 3
    Safety-MS2, Speed for 2 axes
    Safe DO: 2
    安全继电器输出: 1
    编码器接口: 4
    Safety-MSP2, Speed and position for 2 axes
    Safe DO: 2
    安全继电器输出: 1
    编码器接口: 6
    BM Field bus extension module
    通讯接口:
    Profibus, Profinet, CANopen?, EtherCAT
    Safe PLC Software
    The Safe PLC software offers a comfortable graphic programming with function chart and block functions.
    倾角仪
    IS40量程范围: ±10° ±45° ±60°
    接口模式: 模拟量 4...20mA
    模拟量 0,1...4,9V
    比例 2%...98 %
    IS60量程范围: ±10° ±45° ±60°
    接口模式: CANopen?
    直线测量系统
    Limes LI20 / B1
    Magnetic sensor with B1 magnetic band
    up to 25 m/s!
    Limes LI50 / B2
    Magnetic sensor with B2 magnetic band
    Large distance between band and sensor possible!
    Draw wire encoder A50
    Measuring range: up to 1250 mm
    Resolution: 0,05 mm
    Dimensions: 50x50 mm
    Draw wire encoder B80
    Measuring range: up to 3000 mm
    Resolution: 0,05 mm
    Dimensions: 80x80 mm
    Draw wire encoder C120
    Measuring range: up to 6000 mm
    Resolution: 0,08 mm
    Dimensions: 120x120 mm
    Draw wire encoder D135
    Measuring range: up to 42500 mm
    Resolution: 0,08 mm
    Dimensions: 135x135 mm
    Miniature draw wire encoder
    Measuring range: up to 2000 mm
    Resolution: 0,1 mm
    Dimensions: 40x40x55 mm
    Draw wire encoder
    Resolution: 0,1 mm
    Dimensions: 105x115 mm
    Measuring system for lift LM2
    The rugged solution:
    Guided-belt shaft copying
    Up to heights of 120 m
    Up to 6 m/sec lift car speed
    Measuring system for lift LM3
    The compact solution:
    Up to heights of 53 m
    Up to 1.6 m/sec lift car speed
    Measuring system for lift LM5
    The flexible solution:
    Circumferential shaft copying
    Suitable for mounting either at the top or at the bottom
    Mini measuring wheel system
    Compact Measurement System.
    Perfectly harmonized components.
    Protected with IP 64.
    With incremental interface and push-pull.
    Length measuring kit
    The (metric) measuring kit is a complete solution for the quick and simple implementation of length measurements on products in movement.
    Displacement measuring device
    Measuring system with mobile encoder holder, mounted on springs, (with rack and pinion) for an optimum contact pressure and protection of the encoder shaft.
    Components suited optimally to each other. One rotation of the pinion corresponds to a movement of 50 mm.
    Measuring wheels
    Measuring wheels are utilized in combination with encoders to measure material in the wood, paper, metal, textile and plastic industry. When selecting a measuring wheel, the first consideration is the type of material to be measured as this serves as the basis for determining the surface finish or coating of the measuring wheel. Various diameters, designed for use with Kuebler encoders, available for metric and imperial systems.Spring encoder arm
    Robust reliable and versatile. Max. 40 N, adjustable spring pressure available in any position. Pressure for each notch appr. 20 N (first notch between 0 and appr. 20 N). Wide temperature range -40°C ... 120°C. Can be installed in any mounting position 9 setting positions in 40° steps. Base plate - variable in 4 directions.
    库伯勒KUBLER
     销售:张龙刚
    手机:13817798194
    邮箱:
    zlgsh@hotmail.com
TO:采购 公司经营品牌:施克SICK 倍加福P+F, 易福门IFM ,基恩士 罗斯蒙特(Rosemount) . 图尔克TURCK,美国 埃福创编码器AVTRON. 宜科、ABB瑞士。巴鲁夫 , SMC ,费斯托FESTO 西门子仪器仪表 销售:张龙刚 手机:13817798194 邮箱:zlgsh@hotmail.com 价格优惠!…  更多>>
上海自动有限公司
联系人:张龙刚
地址:上海松江区
邮编:201613
电话:13817798194
公司网址:http://xhzlg.b2b.youboy.com
  • Ferenc Nagy 在2024/11/29 23:20:00留言
  • 详细留言:RFQ 1-2 x Sick SCS70HLA0K01 ID: 1034069
  • 明小姐 在2015/3/26 16:05:00留言
  • 详细留言:还看了HYDAC给水泵:http://www.hydac-zh.com/gsb/ 贺德克给水泵:http://www.hydac-zh.com/gsb/ 给水泵:http://www.hydac-zh.com/gsb/ 贺德克轴向柱塞泵:http://www.hydac-zh.com/zxzsb/ HYDAC轴向柱塞泵:http://www.hydac-zh.com/zxzsb/ 轴向柱塞泵:http://www.hydac-zh.com/zxzsb/ 贺德克内啮合齿轮泵:http://www.hydac-zh.com/nniclb/ HYDAC内啮合齿轮泵:http://www.hydac-zh.com/nniclb/ 内齿轮油泵:http://www.hydac-zh.com/nniclb/ 贺德克外啮合齿轮泵:http://www.hydac-zh.com/wniclb/ HYDAC外啮合齿轮泵:http://www.hydac-zh.com/wniclb/ 外啮合齿轮泵:http://www.hydac-zh.com/wniclb/ HYDAC压力传感器:http://www.hydac-zh.com/ylcgq/ 贺德克压力传感器:http://www.hydac-zh.com/ylcgq/
  • 王力 在2014/12/10 18:16:00留言
  • 梁先生 在2014/7/17 9:23:00留言
  • 详细留言:流量传感器0-15ml/min
  • 荣玉成 在2014/4/15 14:14:00留言
  • 详细留言:压力传感器:范围不+-20Pa 范围0-50Pa 电压24VDC 电流4-20mA
