东莞市富爱其自动化科技有限公司
  • MIDOPT滤光镜
  • 发布时间:2017/5/5 12:06:22   修改时间:2017/10/27 12:37:49 浏览次数:3194
  • MIDOPT滤光镜询价电话:0769-23133982  13544870909 QQ:2582393957
    美国Midopt成立于1988年,是世界领先的机器视觉滤光镜生产厂商,致力于为客 户提供精密可靠的光学器件加工及定制,其产品广泛应用于工业成像、图像检测、安防监控等领域.
    Part # Description Useful Range
    BP250 Deep-to-Near-UV Bandpass Filter 230-275nm
    BP324 Near-UV Bandpass Filter 290-365nm
    BP365 Near-UV Bandpass Filter 335-400nm
    BP470 Blue Bandpass Filter 425-495nm
    BP500 Green-Blue Bandpass Filter 440-555nm
    BP505 Cyan Bandpass Filter 485-550nm
    BP525 Light Green Bandpass Filter 500-555nm
    PE530 Photopic Response Filter 495-565nm
    BP550 Near-IR/UV Block-Visible Bandpass Filter 410-690nm
    BP590 Orange Bandpass Filter 560-600nm
    BP635 Light Red Bandpass Filter 615-645nm
    BP660 Dark Red Bandpass Filter 640-680nm
    BP695 Near-IR Bandpass Filter 680-720nm
    BP735 Near-IR Bandpass Filter 715-780nm
    BP800 Near-IR Bandpass Filter 745-950nm
    BP810 (Discontinued) Limited Stock Available 790-830nm
    BP850 Near-IR Bandpass Filter 820-910nm
    BP880 Near-IR Bandpass Filter 845-930nm
    BN Series - Narrow Bandwidth(Midopt 窄带滤光镜)
    BN470 Narrow Blue Bandpass Filter 460-490nm
    BN532 Narrow Green Bandpass Filter 525-550nm
    BN595 Narrow Orange Bandpass Filter 580-610nm
    BN630 Narrow Light Red Bandpass Filter 625-645nm
    BN650 Narrow Red Bandpass Filter 638-672nm
    BN660 Narrow Dark Red Bandpass Filter 645-675nm
    BN740 Narrow Near-IR Bandpass Filter 730-755nm
    BN785 Narrow Near-IR Bandpass Filter 770-790nm
    BN810 Narrow Near-IR Bandpass Filter 798-820nm
    BN850 Narrow Near-IR Bandpass Filter 840-865nm
    BN880 Narrow Near-IR Bandpass Filter 855-890nm
    BN940 Narrow Near-IR Bandpass Filter 928-955nm
    Bi Series - Narrow Interference Bandwidth(Midopt窄带滤光片)
    Bi405 Violet Interference Bandpass Filter 390-410nm
    Bi550 Green Interference Bandpass Filter 535-558nm
    Bi632 Light Red Interference Bandpass Filter 625-640nm
    Bi650 Red Interference Bandpass Filter 643-665nm
    Bi660 Dark Red Interference Bandpass Filter 650-665nm
    Bi808 Near-IR Interference Bandpass Filter 798-820nm
    Bi850 Near-IR Interference Bandpass Filter 845-860nm
    LP Series - Longpass(Midopt 长通滤光镜)
    LP285 High Trans. Heat Resistant VIS-NIR A/R Protective Window 385-1100nm
    LP330 Protective Window 340-1100nm
    LP340 A/R Protective Window 390-800nm
    LP390 UV Absorbing Protective Window 420-1100nm
    LP415 UV Block A/R Protective Window 420-1100nm
    LP470 Light Yellow Longpass Filter 480-1100nm
    LP500 Yellow Longpass Filter 510-1100nm
    LP515 Yellow-Orange Longpass Filter 520-1100nm
    LP530 Orange Longpass Filter 545-1100nm
    LP550 Orange Longpass Filter 560-1100nm
    LP580 Red-Orange Longpass Filter 585-1100nm
    LP590 Red Longpass Filter 605-1100nm
    LP610 Red Longpass Filter 620-1100nm
    LP630 Red Longpass Filter 645-1100nm
    LP645 Dark Red Longpass Filter 650-1100nm
    LP665 Dark Red Longpass Filter 680-1100nm
    LP695 Near-IR Longpass Filter 715-1100nm
    LP715 Near-IR Longpass Filter 730-1100nm
    LP780 Near-IR Longpass Filter 800-1100nm
    LP800 Near-IR Longpass Filter 820-1100nm
    LP815 Near-IR Longpass Filter 825-1100nm
    LP830 Near-IR Longpass Filter 845-1100nm
    LP850 Near-IR Longpass Filter 870-1100nm
    LP920 Near-IR Longpass Filter 930-1100nm
    LP1000 Near-IR Longpass Filter 1010-1500nm
    Shortpass/NIR cut
    SP Series - VIS Pass(Midopt 短波通滤光镜-紫外高通)
    SP510 Blue Shortpass Filter 340-500nm
    SP570 Blue-Green Shortpass Filter 410-560nm
    SP585 Cyan Shortpass Filter 395-575nm
    NF550 Magenta Dichroic Shortpass Filter (Green Block) 395-475nm, 605-700nm
    SP Series - NIR Block(Midopt 短通滤光镜-红外截止)
    SP625 Blue-Orange Shortpass Filter 425-620nm
    SP645 Near-IR/Mid-Red Dichroic Block Shortpass Filter 400-640nm
    SP650 Near-IR/Mid-Red Dichroic Block Shortpass Filter 400-640nm
    SP675 Near-IR/Deep Red Dichroic Block Shortpass Filter 420-660nm
    SP700 Near-IR/UV Block-Visible Shortpass Filter 410-690nm
    SP701 Extended Hot Mirror/Reflects up to 1550nm 410-690nm
    SP705 Near-IR/Deep Red Absorp. Block Shortpass Filter 370-630nm
    SP730 Near-IR/Colorless Dichroic Block Shortpass Filter 400-710nm
    SP785 Modified Near-IR Dichroic Block Shortpass Filter 425-770nm
    Polarizing
    Polarizing Filters(Midopt 偏振镜)
    PR032 Linear Polarizer 400-700nm
    PR120 Ultra High Contrast Linear Polarizer 400-700nm
    PC052 Circular Polarizer 400-700nm
    Pi031 Near-Infrared Linear Polarizer, High Extinction 400-2000nm
    Pi035 Near-Infrared Linear Polarizer, High Transmission 400-2000nm
    Polarizing Sheets(Midopt 偏振镜)
    PS007 High Contrast Linear Polarizer Film .007" thk 400-700nm
    PS010 High Contrast Linear Polarizer Film .010" thk 400-700nm
    PS030 Ultra High Contrast Linear Polarizer Film .030" thk 400-700nm
    HT025 High Temperature Linear Polarizing Film .025" 400-700nm
    PG120 Ultra High Contrast Glass Linear Polarizer Sheet 400-700nm
    Pi005 NIR High Contrast Linear Polarizer Film .007" thk 700-1100nm
    ND Series - VIS(Midopt 衰减片)
    ND030 Neutral Density Filter - Absorptive 50% Transmission 425-675nm
    ND060 Neutral Density Filter - Absorptive 25% Transmission 425-675nm
    ND090 Neutral Density Filter - Absorptive 12.5% Transmission 425-675nm
    ND120 Neutral Density Filter - Absorptive 6.25% Transmission 425-675nm
    ND200 Neutral Density Filter - Absorptive 1.0% Transmission 425-675nm
    ND300 Neutral Density Filter - Absorptive 0.1% Transmission 425-675nm
    ND400 Neutral Density Filter - Absorptive 0.01% Transmission 425-675nm
    Ni Series - VIS/NIR
    Ni030 Neutral Density Filter - Low Reflectivity 50% Transmission 400-1100nm
    Ni060 Neutral Density Filter - Low Reflectivity 25% Transmission 400-1100nm
    Ni090 Neutral Density Filter - Low Reflectivity 12.5% Transmission 400-1100nm
    Ni120 Neutral Density Filter - Low Reflectivity 6.25% Transmission 400-1100nm
    AC Series - Acrylic Longpass
    AC380 A/R Acrylic Protective Window 450-850nm
    AC685 Acrylic NIR Longpass Filter 710-1100nm
    AC760 Acrylic NIR Longpass Filter 780-1100nm
    LA Series | LB Series | FL Series
    LA080 Light Balancing Filter (Minus Blue) 400-700nm
    LA120 Light Balancing Filter (Minus Blue) 400-700nm
    LB080 Light Balancing Filter (Minus Red) 400-700nm
    LB120 Light Balancing Filter (Minus Red) 400-700nm
    FL550 Light Balancing Filter (Minus Green) 400-700nm
东莞市富爱其自动化有限公司自成立以来汇集了一批图形图像处理、光电设计的专业化高科技人才, 致力于为用户提供高性价比机器视觉软硬件及光学器件,具备了完善的开发、设计和生产光学器件的高科技力量。凭借公司雄厚的技术力量和多年的机器视觉…  更多>>
东莞市富爱其自动化科技有限公司
联系人:李华
地址:东莞市南城区高盛科技园
邮编:523000
电话:0769-23133982
传真:0769-23135582
公司网址:http://www.vision-fa.com/
  • 欧欧 在2022/4/8 15:18:00留言
  • 详细留言:MidOpt 产品询价
  • 董冬连 在2021/6/30 10:38:00留言
  • 详细留言:midopt 的镜片 mw_lp330_46數量3
  • 钟工 在2018/5/15 0:53:00留言
  • 详细留言:M25.5*P0.5: 400-760nm通过,760nm(或800nm)之后不通过 M28.5*P0.5: 400-760nm通过,760nm(或800nm)之后不通过 M30.5*P0.5: 400-760nm通过,760nm(或800nm)之后不通过
  • 高杰 在2017/6/22 16:52:00留言
  • 详细留言:M27 P=0.9
