Transducer Techniques传感器、Techniques称重传感器、
Transducer Techniques扭矩传感器、Transducer Techniques专用传感器
上海秋腾贸易有限公司优势供应美国Transducer Techniques传感器
、Techniques称重传感器、Transducer Techniques扭矩传感器、
Transducer Techniques专用传感器。美国Transducer Techniques公司成
立于1979年,专门从事设计和制造全系列的称重传感器,扭矩传感器,专
用传感器和相关仪器仪表。Transducer Techniques公司的传感器具有独
特的设计重量和力量等多元化的过程控制,可在工厂自动化以及其他数百
个应用服务等工业领域测量。所有的传感器传感元件都配有保税箔应变计
和连接电缆。
SLB-25 Capacity: 25 lbs Mini Compression Button
SLB-50 Capacity: 50 lbs Mini Compression Button
SLB-100 Capacity: 100 lbs Mini Compression Button
SLB-250 Capacity: 250 lbs Mini Compression Button
SLB-500 Capacity: 500 lbs Mini Compression Button
SLB-750 Capacity: 750 lbs Mini Compression Button
SLB-1K Capacity: 1,000 lbs Mini Compression Button
LB0-100 Capacity: 100 lbs Compression Load Button
LB0-100A Capacity: 100 lbs Compression Load Button
LB0-250 Capacity: 250 lbs Compression Load Button
LB0-500 Capacity: 500 lbs Compression Load Button
LB0-750 Capacity: 750 lbs Compression Load Button
LB0-1K Capacity: 1,000 lbs Compression Load Button
LB0-2K Capacity: 2,000 lbs Compression Load Button
LB0-3K Capacity: 3,000 lbs Compression Load Button
LB0-5K Capacity: 5,000 lbs Compression Load Button
LB0-10K Capacity: 10,000 lbs Compression Load Button
LB0-15K Capacity: 15,000 lbs Compression Load Button
LB0-20K Capacity: 20,000 lbs Compression Load Button
LB0-30K Capacity: 30,000 lbs Compression Load Button
LB0-50K Capacity: 50,000 lbs Compression Load Button
LBC-100 Capacity: 100 lbs Compression Load Button
LBC-100A Capacity: 100 lbs Compression Load Button
LBC-250 Capacity: 250 lbs Compression Load Button
LBC-500 Capacity: 500 lbs Compression Load Button
LBC-750 Capacity: 750 lbs Compression Load Button
LBC-1K Capacity: 1,000 lbs Compression Load Button
LBC-2K Capacity: 2,000 lbs Compression Load Button
LBC-3K Capacity: 3,000 lbs Compression Load Button
LBC-5K Capacity: 5,000 lbs Compression Load Button
LBC-10K Capacity: 10,000 lbs Compression Load Button
LBC-15K Capacity: 15,000 lbs Compression Load Button
LBC-20K Capacity: 20,000 lbs Compression Load Button
LBC-30K Capacity: 30,000 lbs Compression Load Button
LBC-50K Capacity: 50,000 lbs Compression Load Button
LBM-50 Capacity: 50 lbs Calibrated in Compression
LBM-100 Capacity: 100 lbs Calibrated in Compression
LBM-200 Capacity: 200 lbs Calibrated in Compression
LBM-500 Capacity: 500 lbs Calibrated in Compression
LBM-1K Capacity: 1,000 lbs Calibrated in Compression
LBM-2K Capacity: 2,000 lbs Calibrated in Compression
LBM-2.5K Capacity: 2,500 lbs Calibrated in Compression
LBM-5K Capacity: 1,000 lbs Calibrated in Compression
LBM-8K Capacity: 8,000 lbs Calibrated in Compression
LBM-10K Capacity: 10,000 lbs Calibrated in Compression
