R&S?FSW26 频谱与信号分析仪
![](http://img52.chem17.com/9/20160618/636018628399376598114.jpg)
Specifications
Frequency
Frequency range R&S?FSW8 2 Hz to 8 GHz
R&S?FSW13 2 Hz to 13.6 GHz
R&S?FSW26 2 Hz to 26.5 GHz
R&S?FSW43 2 Hz to 43.5 GHz
R&S?FSW50 2 Hz to 50 GHz
R&S?FSW67 2 Hz to 67 GHz
Aging of frequency reference 1 × 10–7/year
with R&S?FSW-B4 option 3 × 10–8/year
Bandwidths
Resolution bandwidths standard filter 1 Hz to 10 MHz, 80 MHz (with R&S?FSW-B8 option)
RRC filter 18 kHz (NADC),
24.3 kHz (TETRA),
3.84 MHz (3GPP)
channel filter 100 Hz to 5 MHz
video filter 1 Hz to 10 MHz
I/Q demodulation bandwidth 10 MHz
with R&S?FSW-B28 option 28 MHz
with R&S?FSW-B40 option 40 MHz
with R&S?FSW-B80 option 80 MHz
with R&S?FSW-B160 option 160 MHz
with R&S?FSW-B320 option 320 MHz
Displayed average noise level (DANL)
2 GHz –156 dBm (1 Hz) (typ.)
with R&S?FSW-B13 option –159 dBm (1 Hz) (typ.)
8 GHz –156 dBm (1 Hz) (typ.)
20 GHz –150 dBm (1 Hz) (typ.)
40 GHz –144 dBm (1 Hz) (typ.)
DANL with preamplifier
(R&S?FSW-B24 option) 8 GHz –169 dBm (1 Hz) (typ.)
20 GHz –166 dBm (1 Hz) (typ.)
40 GHz –165 dBm (1 Hz) (typ.)
DANL with noise cancellation, preamplifier off, 2 GHz –169 dBm (1 Hz) (typ.)
Intermodulation
Third-order intercept (TOI) f < 1 GHz (typ.) +30 dBm (typ.)
f < 3 GHz +25 dBm (typ.)
8 GHz to 26 GHz +17 dBm (typ.)
13.6 GHz to 40 GHz +15 dBm (typ.)
WCDMA ACLR dynamic range with noise cancellation 88 dB
Phase noise
10 kHz offset from carrier 500 MHz carrier –140 dBc (1 Hz) (typ.)
1 GHz carrier –137 dBc (1 Hz) (typ.)
10 GHz carrier –128 dBc (1 Hz) (typ.)
Total measurement uncertainty 8 GHz < 0.4 dB
Models
R&S?FSW8
Order No. 1312.8000K08
Signal and Spectrum Analyzer, 2 Hz to 8 GHz
R&S?FSW13
Order No. 1312.8000K13
Signal and Spectrum Analyzer, 2 Hz to 13.6 GHz
R&S?FSW26
Order No. 1312.8000K26
Signal and Spectrum Analyzer, 2 Hz to 26.5 GHz
R&S?FSW43
Order No. 1312.8000K43
Signal and Spectrum Analyzer, 2 Hz to 43.5 GHz
R&S?FSW50
Order No. 1312.8000K50
Signal and Spectrum Analyzer, 2 Hz to 50 GHz
R&S?FSW67
Order No. 1312.8000K67
Signal and Spectrum Analyzer, 2 Hz to 67 GHz
全新高性能R&S?FSW信号与频谱分析仪满足客户高性能需求,提供低相位噪声,宽分析带宽和直观性操作,使得测试工作快速简单。
主要特点
? 频率范围覆盖从2 Hz 至 8/13.6/26.5/43.5 GHz (加外部谐波混频器可扩展至110GHz)
? 相位噪声低至-137dBc/Hz@1GHz,10kHz频偏
? WCDMA 邻信道功率比测试88dB动态范围(噪声消除功能打开)
? 最高160MHz分析带宽
? 8 GHz范围内低至0.4dB总测量不确定度
? 高分辨率的12.1寸触摸屏方便操作
? 支持多任务并行测量及显示
型号
型号 订货号
R&S?FSW 频谱与信号分析仪,2Hz到8GHz 1312.8000K08
R&S?FSW 频谱与信号分析仪,2Hz到13.6GHz 1312.8000K13
R&S?FSW 频谱与信号分析仪,2Hz到26.5GHz 1312.8000K26
R&S?FSW 频谱与信号分析仪,2Hz到43.5GHz 1312.8000K43
Hardware Options
R&S?FSW-B4
Order No. 1313.0703.02
OCXO Precision Reference Frequency
R&S?FSW-B8
Order No. 1313.2464.26
Resolution Bandwidths > 10 MHz
(for R&S?FSW8, R&S?FSW13 and R&S?FSW26)
R&S?FSW-B8
Order No. 1313.2464.02
(for R&S?FSW43 and R&S?FSW50)
R&S?FSW-B10
Order No. 1313.1622.02
External Generator Control
R&S?FSW-B13
Order No. 1313.0761.02
Highpass Filters for Harmonic Measurements
R&S?FSW-B17
Order No. 1313.0784.02
Digital Baseband Interface
R&S?FSW-B71
Order No. 1313.1651.13
Analog Baseband Inputs
for R&S?FSW8 and R&S?FSW13
R&S?FSW-B71
Order No. 1313.1651.26
(for R&S?FSW26, R&S?FSW43 and R&S?FSW50)
R&S?FSW-B71
Order No. 1313.1651.67
(for R&S?FSW67)
R&S?FSW-B71E
Order No. 1313.6547.02
80 MHz Bandwidth for Analog Baseband Inputs
R&S?FSW-B18
Order No. 1313.0790.02
Spare Solid State Disk (removable hard drive)
R&S?FSW-B21
Order No. 1313.1100.26
LO/IF Ports for External Mixers
(for the R&S?FSW26)
R&S?FSW-B21
Order No. 1313.1100.43
(for the R&S?FSW43, R&S?FSW50 and R&S?FSW67)
R&S?FSW-B24
Order No. 1313.0832.13
Preamplifier, 100 kHz to 8 GHz/13 GHz
(for the R&S?FSW8 and R&S?FSW13)
R&S?FSW-B24
Order No. 1313.0832.26
Preamplifier, 100 kHz to 26.5 GHz
(for the R&S?FSW26)
R&S?FSW-B24
Order No. 1313.0832.43
Preamplifier, 100 kHz to 43 GHz
(for the R&S?FSW43)
R&S?FSW-B24
Order No. 1313.0832.50
Preamplifier, 100 kHz to 50 GHz
(for R&S?FSW50)
R&S?FSW-B24
Order No. 1313.0832.67
Preamplifier, 100 kHz to 67 GHz
(for R&S?FSW67)
R&S?FSW-B25
Order No. 1313.0990.02
Electronic Attenuator, 1 dB steps
R&S?FSW-B33
Order No. 1313.3602.02
USB Mass Memory Write Protection
R&S?FSW-B28
Order No. 1313.1645.02
28 MHz Analysis Bandwidth
R&S?FSW-B40
Order No. 1313.0861.02
40 MHz Analysis Bandwidth
R&S?FSW-B80
Order No. 1313.0878.02
80 MHz Analysis Bandwidth
R&S?FSW-B160
Order No. 1313.1668.02
160 MHz Analysis Bandwidth
R&S?FSW-B320
Order No. 1313.7172.02
320 MHz Analysis Bandwidth
R&S?FSW-U40
Order No. 1313.5205.02
Analysis Bandwidth Upgrade from 28 MHz to 40 MHz
R&S?FSW-U80
Order No. 1313.5211.02
Analysis Bandwidth Upgrade from 40 MHz to 80 MHz
R&S?FSW-U160
Order No. 1313.3754.02
Analysis Bandwidth Upgrade from 80 MHz to160 MHz
R&S?FSW-U320
Order No. 1313.7189.02
Analysis Bandwidth Upgrade from 160 MHz to 320 MHz
R&S?FS-Z60/-Z75/-Z90/-Z110 R&S?FS-Z60/-Z75/-Z90/-Z110 Harmonic Mixers
Harmonic Mixers
